I get an error message when I evaluate this line:
piecewise(And(And(abs(a)<infinity,a<>0),And(abs(b)<infinity,b<>0)),1,0);
Error, (in PDEtools/sort_as_in) sort: 2nd argument must be a function that always returns true or false
I don't know what the problem is with this line. I have Maple 12.
Have you got any idea?
How do I convert a 2D expression constructed with MathMLEditor to a normal 1 D string? I know that example 6 from the maplet builder tutorial does this, but the result is often in a prefix notation. For example, if I enter "x-square + 1" as a 2D expression in the MathMLEditor, the result is `&plus;`(x^2,1). I would like to get more normal x^2+1. I have examined the code generated by the maplet builder and experimented with options in the MathMLEditor and MathML[Import], but to no avail. Is there a way to convert the prefix notation to the more normal infix?
I'd like to have a question which gives information about a circle, and asks students to enter the correct equation. I don't mind whether the equation is in the form (x-a)^2+(y-b)^2=r^2, or the expanded-out version. Here are some ways I've tried to do this, and why I'm not happy with them!
How do I simplify an expression imported from the MathMlEditor? For example, the following code is taken  from Maple help. I have saved the result in the variable abc.
with(Maplets[Elements]): maplet := Maplet([
    [BoxCell("Enter and expression")] , [MathMLEditor('reference'='ME1')],[Button("Done",Shutdown([ME1]))]  ]):
result := Maplets[Display](maplet): abc "= MathML[Import](result[1]);
I am trying to assign a value to a variable depending on whether fsolve does or does not give a solution.
However, I cannot do it when there is no solution - fsolve returns unevaluated, and I cannot do almost anything with the unevaluated expression.
The only way I can do it is the following:
a:=fsolve(x+ln(x)=0,x=1..2);
if (a='fsolve(x+ln(x) = 0,x,1 .. 2)') then solution:='no' else solution:='yes' end if;
this equation does not have solutions, and returns the string to which I compare a.
Hi all
I have this integration , HOW can I solve
the problem is in recent  file named  argent pdf
please help me to solve it
and give results please.......
I have the following ODE
sorry , i forget the term so the question is :
int ( q  * exp((1-b)^2* qz^2 / lambda[1] ) * exp((1-b)^2* q^2 / lambda[2])   /  ((1+b^2*q^2+b^2*qz^2)*(q^2+qz^2)) , qz= -infinity..infinity)  then w.r.t     q  from (0......infinity)
after integration we want to minimize the results , the range is as (b=0..1), ( lambda[1])  =1....100000) ,   (lambda[2])  =1....100000)
I need some help to figure out how to get maple to use distributive property and rules of exponents.
>A:=R/(1+exp(-2(h-s))
>a:=A/(exp(h-s))
I would like to get the answer back in the form
R/(exp(h-s)+exp(-(h-s))
suggestions?
Is it possible to add block comments in maple. Like, for example, /* ...*/ in java. Thank you.
I have this line in maple 11:
polygonplot([[0,0],[1,1],[1,0],[0,0]],legend="stuff");
and the legend doesn't appear, is there a way to force maple to produce the legend (other than horribly right clicking and manually writing the legend in every time - I'm trying to make lots of polygon plots...)
Steve
I'm trying to solve a largeish matrix equation of the form A*X + Transpose(A*X) = B for X, where A and B are known matrices.  I know there must be some clever way to get Maple to automatically unpack this equation into the equations for the components and then solve them symbolically, but I haven't had much success.  Could someone more skilled point the way?
Using Maple, I integrated and expression and got ln(e) in the answer.  How can I eliminate this?
i have this integration:
int(q*exp((1-b)^2* qz^2/lambda )/((1+b^2*q^2+b^2*qz^2)*(q^2+qz^2)),qz=-infinity..infinity) then w.r.t      q  from (0......infinity)
I want to take two numbers, for example 37665432 and 59374696 (later extrapolate to 3 or 4 etc... sets of numbers) and take each individual number alternately and put them into a list.
Here's what I have
a:=37665432;
b:=59374696;
c:=convert(a,base,10);
d:=convert(b,base,10);
e:=ListTools:-Reverse(c);
f:=ListTools:-Reverse(d);
So now I have the numbers all in a list and I want to select each one alternately into another list.
g:=seq(e[i],f[i],i=1..8);
First 2242 2243 2244 2245 2246 2247 2248 Last Page 2244 of 2457
