I am being given the following question:
Let f(x) = tan(sin x2)−sin(tan x2). Let n be the smallest positive integer
such that f(^(n))(0) 6= 0. Then n = __.
I am suppose to differentiate f(x) using maple to solve for n, that is to differentiate the function over and over again till I am able to get say f(^(16))=0.
However, maple gets very laggy after i tried n=10.
Is there any shortcut that could help solve this problem?
Best regards,
zn.
Hi, I have the following memory problem with maple 12 on mac (intel) which (I guess) should be known already, so hopefully someone can give me a quick solution to it: I can not rise via kernelopts(datalimit=blabla...) the soft datalimit above 500 mb. ("Error, cannot raise the datalimit above the hard limit". ) This is quite weird, since I have for sure more physical memory available than that... The suggested solution for this problem according to the maplesoft FAQ (only for PPC !?!) is to edit a file named mserver_ulimit ... unfortunately this does not seem to help !
My data file is a list, where each line is
[elm1,elm2,elm3,elm4].
I would like to read through and calculate the mean of all of the elm1's.
I would like to get a distribution of the elm1 data.  For example, in 800 lines of data, if elm1 takes on values 5,6 and 7, I want to know that there are 300 5's 400 6's and 100 7's.
stats[mean](data) needs the numbers inputted.  I even thought I could pull off the elm1's into a separate list, but stats[mean] won't take a list.
Any help is appreciated.
Hi Everyone!
I want to export several Figures with Maple at the same time. I tried
for i from 1 to 5 do
interface(plotdevice=ps, plotoutput=`c:/test||i.eps`, plotoptions=`color,portrait,
noborder,width=16cm,height=12cm`);
 plot(cos(i*x), x = -5..5);
 interface(plotdevice=inline);
but it did not work. How can I create one file per Figure?
Thanks a lot,
Bernardo
If I try to solve the following differential equation with simbolic parameters:
IC := p(0) = condizIni
ode := diff(p(t), t) = (QIn-QOut-derV)/((1/Boil+1/Bwall+percair/(m*p(t)))*V)
func := rhs(dsolve({IC, ode}))
the result I get from Maple12 have the following member inside it:
LambertW(_Z7, _Z)
but I do not know what are _Z7 and _Z.
Where I can find the expression of these parameters?
Why Maple added these parameters?
I like the feature that permits the use of the dotted derivative, as it has the look and feel of the work that I am doing. However, when I enter, say, (x_dot + 1)^2 and invoke the expansion, I get x_dot(t)^2 +...
It's nice that Maple knows that x is a function of t, but I would like to avoid the clutter. How do I suppress the (t) so that all I see is x_dot^2?
I use Maple 11. Sometimes, the result become more then one when it run. Then the results are same. How to make it to give difference result?
 i have a project from my univercity an d i want to ask you how can i put maple into flash document so can you help cause i must give my project one month again thanx before
How can i avoid this error?
that happens 'cause I have 3 different solution for Vv:
> Vv3:=Re(solve(eq1,Vv)[3]);
The following program was created to determine a Hermite polynomial. Can anyone see where the error lies? Thanks!
restart; f:=x-> (x*(cos(x)))- ((x*x(sin(x/2))));
                 f := x -> x cos(x) - x x(sin(1/2 x))
                              fp := D(f)
I am trying to modify a solution to a non-homogeneous boundary value problem presented in Dr.
Hi everybody, one thing is not still clear to me about assume: for example  I have to find the solution of this simple equation:
e1 := q=ks*h^(5/3)*sqrt(If);
If i write solve(e1,h);   I get also all the complex solutions. I want just the real solution so i wrote:
assume(h::real);
solve(e1,h);
but I still have all the complex solutions. Why? I tried also  with assume(h::real,h>=0); but it's the same.
alberto
I need to input f(N,x)=summation{(-1)^(n+1)/n}sin(nx) N=1,3,5....infinity
Why gives Maple T.A. for the function
decimal(2,-0.625)
as an answer -0.62 instead of -0.63?
I could not find documentation on the decimal function. Where can I find it?
kind regards,
Harry Garst
First 2245 2246 2247 2248 2249 2250 2251 Last Page 2247 of 2471
