I've been trying to vreate a script which will provide the roots of the Bessel function of the first kind, and it's derivative.
The root of the Bessel itself is fairly straight forward, simply BesselJZero(m,n); however, I can't do the same for the derivative diff(BesselJ(m,n),n).
Any help would be appreicated.
A population has a mean of 75 and a standard deviation equal to 21. Find the mean and standard deviation of a sampling distribution of a sample means with a sample size of 49.
I am using dsolve to integrate a system of equations, and I am using stop_cond to stop the integration when certain conditions are met.
The problem is, I want the integration to stop when condition 1 AND condition 2 are met, but when I use, for example
stop_cond=[y(t)-2,t-4]
it stops as soon as ONE of these conditions are met, not both. I want it to stop when y(t) is equal to 2 AFTER t=4, not before.
Any suggestions would be greatly appreciated!
Hi, i just want to write this equation im Maple,  how do i do it ?
I'm trying to find all solutions to a system of polynomial equations. I've tried using Isolate from the RootFinding package and for some choice of parameters this works well. However changing the parameters (i.e changing some of the coeffients of the polynomials), I get the error message.
Error, (in RootFinding:-Isolate) decreasing address previous=1e0f0020 new=10010020!
Any ideas on what this means?  possible ways around it? or other functions in maple that would give me all solutions?
Thanks, Steve.
View 127_phase coloring.mw on MapleNet or Download 127_phase coloring.mw
View file details
I am trying to color  3D plots according to phase using color=argument(x)/Pi/2
I get different results depending on the form I enter the expression x, as shown on the worksheet. Any suggestions to make this consistent?
I was testing if Maple can prove/show limit(a*(1-F(a)), a=infinity,left)=0, where F(.) is a general cumulative distribution function. Though, I doubt Maple has the ability.  However, I come across with some other questions during the exploration:
1. how is maple exactly doing to find limit:
Let's first try a normal distribution case:
with(Statistics):
U := RandomVariable(Normal(s,t))  :
limit(CDF(U,x),x=infinity,left)  assuming t>0,t<infinity ;
Is there an explanation on how each of the different paragraph styles work?
I was experimenting the other day and some selected paragraph styles don't allow you to type any text at all.  Couldn't find anything in the help pages, or I might have just been looking in the wrong area.
Hi to everybody.  I have to manipulate a system of partial differential equation,one by one.I have in particolar to derive a lot of time my differential equations(shallow water equations),and then to group, to substitute and at the and I need time derivative in function of spatial derivative.
I'm almost done. The problem is that now every time that  I execute a command it takes  a lot of time. The entire file takes some minuts to compile. It's so slow.
Suppose that you want to solve x'(t)=f(x,t)   x(t0)=x0
The theory show that:
x(t+h)=x(t)+1/2*h*(F1+F2) where F1=f(x,t) and F2=f(x+F1,t+h)
SO I made procedure:
Is there a switch/case statement in Maple?  So that instead of:
if (a = a1) then
   b1
elif (a = a2) then
   b2
elif (a = a3) then
  b3
end if
Something like:
switch (a) {
case: a1 {b1}
case: a2 {b2}
case: a3 {b3}
I'm potentially going to have a long list of elif's and might need  more efficient way of doing it.
How do I plot a 3d helicoid?  I can easily plot a helix, but cannot figure out how to fill the plane to the axis, to generate the helicoid?
Leslie
while studying this ODE
I now have 77 points and I am getting worried as it may suggest I know 77 points worth of maple.
However, all my points come from asking questions.
I wonder whether two types of pointing should be created: one for very grateful receivers such as I and one for all you wonderful givers - thank you - who are prepared to shed light on so many questions.
Just a thought.
First 2247 2248 2249 2250 2251 2252 2253 Last Page 2249 of 2457
