> c:=-4:
> FM1:=DEplot(diff(y(x),x)=-c/x^2,y(x),x=-10..10,y=-10..10,color=red):
> FM2:=DEplot(diff(y(x),x)=x^2/c,y(x),x=-10..10,y=-10..10,color=green):
> display(FM1,FM2);
how can I join the direction fileds together?
i mean just like plooting the solutions of the ODEs..
I want to do with "linestyle"..tried, but dosent seem to work...
Just wondering what the easiest way is to extract data from an excel spread sheet so that it can be used as data in a maple worksheet.  For that matter, what other database programs can I use with maple?
Is Maple (student version) appropriate for typing non-professional documents containing trigonometric graphs and 2D shapes?
I would like to plot functions like sin(x)  with the horizontal axis labeled in multiples of pi, and draw polygons with angles labeled.
I'd like to copy and paste the following from Maple 9.5 into a Windows 2000 text:
lim x-->0  .
The trouble is,in Maple you can't write x-->0 as a subscript to the word "lim". That is how you HAVE to write if you're writing a maths thesis. Can someone please tell me how I can overcome this problem? Thanks
Ian
We are looking to use TA.  Our Uni common authentication system uses Apache/Kerberos.  Is there a way of getting TA to use the Apache-supplied authenticated username?
The documentation seems to suggest the only options are TA's internal user/pw system (where I saw something that suggests the p/words are held in plain text(!)) or an LDAP server.
Grateful, as always,  for any insight.
Toby
   The equation like that:
  a*(x/sqrt(x^2-1)+2*x/(Pi*sqrt(x^2-1))-1-2/(Pi*x))=1
when i used solve command in Maple, the result is :
   RootOf((-Pi^2-2*Pi^2*a)*_Z^6+(2*Pi^2+4*Pi^2*a+a^2*Pi^2)*_Z^4+(4*a*Pi+4*a^2*Pi)*_Z^3+(-a^2*Pi^2-2*Pi^2*a-Pi^2)*_Z^2+(-4*a*Pi-4*a^2*Pi)*_Z-4*a^2)
  this result is not what i want, i need exactly solution.
 Can anyone help me?
 Thanks very much for your help!!
Hi, I am trying to generate 20*10000 random numbers with Logistic distributions and a 20*20 correlation matrix, but I don't know how to do so. Could someone help me on this topic?
Hi All,
Could someone please tell me how to create a simple input/output table from an equation such as y=x^2 + 2 or lead me to a task from which I can cut and paste and change parameters.
Bob
Hi, using a solution of u that I have already calculated from an ode (by the method of multiple scales), how would I plot a phase portrait of u' against u??  All help is greatly appreciated.  Many thanks in advance.
Hi, I'm new to maple and to the site.
How do I find and / or graph a double or triple intral over a implicit function?
for example I want to find the volume         / /  x^2  dA                over the ellipse x^2 + y^2 - xy < 2.
Hello, again,
basically, I have an implicit relation for lambda:
> eq1 := (sqrt(lambda*alpha)+alpha)*BesselJ(alpha, 2*sqrt(lambda*alpha))/(2*sqrt(lambda*alpha)) = BesselJ(1+alpha, 2*sqrt(lambda*alpha))/alpha;
So solutions of lambda, for a particular alpha are given at the intersections of the two functions:
> plot({subs(alpha = 2, (sqrt(lambda*alpha)+alpha)*BesselJ(alpha, 2*sqrt(lambda*alpha))/(2*sqrt(lambda*alpha))), subs(alpha = 2, BesselJ(1+alpha, 2*sqrt(lambda*alpha))/alpha)}, lambda = 0 .. 50, -1 .. 1, color = [red, blue])
Anyone out there know where the FEM library is that is mentioned in the Finite Elememt Method worksheet from the Applications Center, author Fedderik van der Bos, 2000?  The introduction lists several procedures that are stored in the FEM library which are loaded via the with(FEM) command.
Thank you for your assistance.
The amount 180.00 is what percent greater than 135.00?
Obtain Hamilton's equations of motion for a plane pendulum of length l with mass poin m whose radius of suspension rotates uniformly on the circumference of a vertical circle of radius a.  Describe physically the nature of the canonical momentum and the Hamiltonian.
v/r,
I know this is a mathematics forum, but I think that there are many faculty members and others here directly or indirectly affiliated with physics.
Again from Goldstein's, "Classical Mechanics" Chapter 8, The Hamilton Equations Of Motion.
The question is:
Write the problem of central force motion of two mass points in Hamiltonian formulation, eliminating the cyclic variables, and reducing the problem to quadratures.
dc
First 2284 2285 2286 2287 2288 2289 2290 Last Page 2286 of 2457
