Show that if lambda[i] are the eigenvalues of a square matrix, then if the reciprocal matrix exists it has the eigenvalues (lambda[i])^(-1).
By "reciprocal matrix" I assume he means inverse.
dc
I found a used copy of Probability and Statistics Explorations with Maple by Karian and Tanis. I'd like to work through it, but the supplements come in Maple 6,7 and 8 versions and I use Maple 11. Can I load the supplement?
The version 8 one comes as a "package", stat.all, but I don't know what to do with it. The version 6 one comes as two files, a help file, *.hdb, which seems to load, and a stat.src file. I put the  src file in a directory which I added to libname, but I can't use "with" to call it.
Hi guys
Is it relatively simple to create a maplet which allows a user to fill in the entries of a matrix, and then to take the elements of that matrix and put it through a procedure. So to clariffy say i make a window appear with 4 empty boxes, this would correspond to the entries of a matrix.
I need to do the integral of a certain function by using
a) Rectangles method
- Would it be sum(f,x=a..b,n) ?
b)Trapezoid method ( I can not use trapezoid() )
c)Simpson's method ( I can not use simpson() )
I know how to do them without Maple, but with Maple I have no idea.
Hi everyone,
i plotted a graph last time, and Maple showed a very clear graph. But when i Opened my file on the next day agian and re-enter t to my input. Maple gave me a string of number instead of graph. Even to teacher's guide as well, sometime Maple gives nicely graph, but mostly a string of number. Can anyone give me solution ? Thx a lot
My graph:
I'm looking for your help on
How to solve my problem in withhere file
How to plot the solution
How to convert the solution in matlab or in C code
View 4968_My problem.mw on MapleNet or Download 4968_My problem.mw
View file details
Thank you for your great support !
I am trying to solve this ode numerically in Maple 11.
c:=3;
ode1 := (diff(y(x), x))^2+4*c*(diff(y(x), x))+4*c^2*y(x)/(1-x^2);
dsn3 := dsolve({ics, ode1}, numeric);
But I get the following error:
Error, (in DEtools/convertsys) unable to convert to an explicit first-order system
What does this error mean?  The function y(x) is valid on {0,1}
HI to everybody, I have to manipulate a system of partial differential equation,one by one.how can I do? I have in particolat to derive a lot of time my differential equations(shallow water equations),and then to group, to substitute and at the and I need time derivative in function of spatial derivative. How is the best choice for working? I think to define for example:
pde := diff(q(x, y, t), t) +(g*D-u^2)*(diff(h(x, y, t), x))-2*u*(diff(q(x, y, t), x))=0
How can I get the powers of "y" for all terms in eq1:
eq1:=A*(k+1)*y^n+(k+2)*y^(n+1)+12*y^n+k*y^6 +... other terms
where A,k, = consts, n::posint
,for example, as a list  [n,n+1,n,6,....]
Thanks in advance - jerzy
hi everone,
i m new user . My dad just got for me MAPLE 11 last week. So interested! But when i do sloving equtaion 2*cos(x) - exp(x)= 0 interval -3..3. Maple only give me 1 solution instead of 2 solutions . I wonder if i my imput date is wrong. Can anyone help me, thx!
probably I should not have written my question as a comment here
http://www.mapleprimes.com/forum/how-to-evaluate-faster, si I now put it as a new topic. Thanks for your time and help.
The problem is to evaluate as effectively as possible an n-fold sum of N additions, e.g., for n=3
FF := proc (N) options operator, arrow; evalhf(add(add(add((1/2*1/3*1/4)*(1/2)^j*(3/4)^g*(2/3)^i/(.4*i+.4+.1*j+.1+.3*g+.3), i = 0 .. N), j = 0 .. N), g = 0 .. N)) end proc
In one of the good books on Maple, an advice was to use external text editor of your choice if yoru code is likely to be more than 10 lines. I know there are WinEdt for laTex, RWinEdt , TinnR or Emacs for R, but what  is best for Maple? What will highlight Maple syntacis, commands, etc? What's available and what's good?  Thanks.
In menu Options/Interface I chose to open worksheets as a new tab. That's convenient. However, I cannot figure out how to make Maple 11 start up with the same set of tabs/worksheets automatically loaded when I turn on my PC to use Maple next time. Thanks.
hi i need to plot xlogx^k for x small and positive and k=1,2,3... could anyone help me pls
 Hi All,
I'm trying to copy from my Maple 11 document into this box but I am not able to so I am going to have to explain what is happening.
I am trying to intergrate the indefinite integral of exp(x)dx and Maple 11 comes back with exp(x) divided by lnexp(x)squared.  This amounts to exp(x) over two which is clearly wrong.
Please tell me what is going on???
Bob
First 2285 2286 2287 2288 2289 2290 2291 Last Page 2287 of 2457
