Hey,
I am trying to plot 3d graphs but I get the following error message written in blue:
Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct.
The function im trying to plot is:
f(x,y)=[ xy (x²-y² ] / (x² + y²)=expr
This is what I write in Maple:
plot3d( expr,x=-1..1, y=-1..1)
In advance, thanks.
Emile
I have a number of expressions.  An example is:
-1/3*(xjm1^2-2*xj*xjm1+xj^2+3)/(xjm1-xj)
I would like to substitue the expression h=xj-xjm1, which in this case would result in
1/h+2*h/6.
Does anyone know how I can make this sort of substitution in Maple automatically?
Hopefully, anyone can help me with the following problem:
I have two functions:  Inta=f(Pa) and ETa=f(Pna). Both can not be solved analytically, but I can plot them separately when I use >plot (evalf(Inta), Pa=0..100) and >plot(evalf(ETa), Pna=0..100). So far no problem.
Furthermore, Pna can be described as >Pna:=Pa-Inta, so in fact ETa=f(Pa). But I fail to plot ETa against Pa (or at least it takes ages..since it keeps 'evaluating'..... for days) . I tried several things like:
When I export maple files into html files (with gif images), I often get jibberish text after "a>b". Maybe it's rendered as a html tag or something, I don't know.
Hiya,
I have an implicit equation;
> tan(beta)=-2/alpha*(beta);
where,
> beta:= sqrt(lambda*alpha-(alpha/2)^2);
for some dimensionless variable alpha.
I want to solve the equation for lamba and plot it as a function of beta.... but I don't know how to go about it.
Thanks for your help
k
So I have read (correctly?) that I can create an object with maple?
How do I go about that?  Just a push in the right direction, im not looking to do anything crazy at this moment, just an object with an array of numbers, some variables also with meaningful information.
Am I headed in the right direction investigating modules?
How do I set the worksheet font in initialization file? Thank you all!
hi,
i've a mathe exercise with the taylor series that i did on paper. i use maple to solve my tasks but now i have a situation where i am sure that i am not wrong but maple tells me something other
my function
f(x) = sqrt(x-1)
x_o = 5
i derivated the function tree times
f'(x) = (1/2)(x-1)^(-1/2)
f''(x) = -(1/4)(x-1)^(-3/2)
f'''(x) = (3/8)(x-1)^(-5/2)
for my x_o
f(5) = 2
f'(5) = 0.25
f''(5)=-0.03125
f'''(5) = 0.011171875
Hello everyone
I have a small, yet tricky question and hope someone knows a quick answer.
A calculation gives me a vector of say 10 complex numbers (floats). I want to store the amplitudes ( abs() ) and the phases ( argument() ) of these complex values in two seperate lists. Next, I want to sort the complex numbers by ascending amplitude, but I do not want to lose the phase belonging to each amplitude, for example:
Is it possiable to create a matrix be setting the eigenvalues you wish to end up with?
I am trying to create a 3X3 random matrix with a set of repeated eigenvalues and was wondering is it's possible to set the eigenvalues and then generate  matrices for them.
I am writing a small procedure to help out some friends in a Diff EQ class and I want to print out little notes (their prof is letting them use maple on the test).  In other languages if I wanted to print something plaintext I could usually enclose them in quotation or tickmarks, or I would precede them by a backslash.
I am trying to say "implies F is equal to [crazy long function]" and I would like to use that cool little implies sign that maple has but whenever I do that I get a weird error message
The attached worksheet uses several procedures to develop a solution which is presented as a parametric plot of two procedures ("alpha" and "strain").  The current solution uses some constants declared at the beginning of the file which I would like to vary and then generate multiple plots associated with the different constants.
I obtained the following result
> dsolve({diff(y(x), x, x)+e^x*(diff(y(x), x))+(1+x^2)*y(x) = 0, y(0) = 1, (D(y))(0) = 0}, y(x), series);
y(x) = 1-(1/2)*x^2+(1/6)*x^3+((1/12)*ln(e)-1/12)*x^4+O(x^5));
A procedure named curve(x) in the attached worksheet solves several equations, each dependent on the solution to the previous equation.  The problem is that when I issue the plot command for a range of the dependent variable x, the equation result that gets plotted is not for the result of the solution to the last equation for P.  Specifically, I would like to issue the "plot(curve,0.0..0.5, <other format commands>);" and get a plot of k vs. P.  Currently the plot is of k vs. P_bar.  Your comments are appreciated.
(1) Maybe the following problem is closely related to "An easily corrected limitation to symbolic derivatives in fsolve() when solving a system of equations" in TomM's blog.
(2) The problem: I would like to solve a set of equations with
     fsolve({f(x,y)=0,g(x,y)=0},{x,y},{x=-10..10,y=-10..10};
      with the procedures
First 2297 2298 2299 2300 2301 2302 2303 Last Page 2299 of 2457
