Gurus...
Any idea why I get the "Parts of the expression are ambiguous. Please select one of the suggested meanings." alert on some of this code, but not other parts? I want them all to be "table assignments" not "function definitions" (per my options in the window). I would really like to not have it keep asking me the question on each run, so is there a way for me to be more specific? Thanks in advance!
Fred
deq(i,XMethanol):=M*diff(X[i](t),t)=(L*(X[i-1](t)-X[i](t))+V*(Y[i+1](t)-Y[i](t)));
deq(i,XWater):=XW[i](t)=1-X[i](t);
I have these 3 equations i am trying to rearrange into real and imaginarry parts. This is pretty easy execpt I am unable to rearrange C(k) into real and imaginary parts.
C(k)= H1(k)/ (H1(k) + iH0(k))
Is it possible to solve piecewise equations in maple? All I get is 'warning, solutions may have been lost'.
solve((piecewise(x<0,x,x>=0,x^2)=0));
I am trying to evaluate the hypergeometric function : hypergeom([1],[1.5],-z) where z is in the order of 1e-6. Its taking very long time where as if I use maple through matlab, then its quite fast !!. Evaluation of Gauss-hypergeometric functions for the similar arguments in maple is quite fast.  Is there any trick I can use for the fast computation of the confluent hypergeom in the case above?.
Thanks for any help
Good evening everyone
I am trying to solve this new problem the whole day up till now and as it is getting very late, I thought asking someone smarter than me might help in the end.
What I experience at the moment is that a written program of mine, as given below, works pretty well, when I set Digits to 10 or less. 100000 loops are not a problem. Yet, as soon as I start increasing Digits to values greater that about 15, my program crashes after about 100 loops. I can see what is happening: The RAM (2GB), is full.
I was wondering how you would convert a number to a Mayan number using Maple11.
I have the expression
(r(r+(1/2)*s))(sin(t)/(r+(1/2)*s)+(diff(y(x), x))/(r^2+(1/2)*rs))
and I want to obtain
r*sin(t)+diff(y(x),x)
I tried expand,collect,combine without success.
Hopefully I missed something and there is a simple solution.
                                       Sandor
I have been reaading previous posts on plotting Dirac functions; in particular: Plotting the Dirac Function and How do I plot Cos(w*t) in frequency domain?
I'm doing a series expansion of complicated expressions using Maple. How can I limit the number of terms, and not the order of the series? To be more precise, I need the series up to x^2, but when I ask for series(expr,x,3) I get terms of x^(2.5) which I don't need. How can I get rid of them without dropping the x^2 terms? series(expr,x,2) truncates them.
Thanks a lot to whomever can help!
Hello Maple experts,
Plotting a procedure is this possible?
Greetings All
I’ve worked out a Fourier Series Expansion using excel and verified it by graphing it in excel to check my results.  See example
http://demos.onewithall.net/discrete_fourier_expansion_coefficients.jpg
Hello all!
I'm am trying to replicate a Berkeley MADONNA problem in MAPLE, and I'm having problems. For those with the great book "Chemical Engineering Dynamics" by Ingham, Dunn, Heinzle, Prevosil, Snape, it's the BUBBLE program.
Hello.
I am haveing one or two issues with vectors.
I am trying to calculate the Angle.
The angle is between
a = s -d -f
b = 3s + d
and then the unit vector which lies perpendicular to a and b
To figure to angle out would you use
cos(theta) = a.b / ( |a| * |b| )
Am i way off or am i close?
I have been playing around with vectors, and have managed to do all the usual mathmatical things with them, except for this.
How do i figure the value for |a|
I have vectors a, b, c.
I have tried help, and google, but cant seem to find out how to find |a|
Any help appreciated, thanks.
I'd welcome some advice please on how to control the points Maple uses when plotting in 2D. I have a function f(i) and I'd like it only to plot the points where i is an integer. I have tried including assuming (i::integer) but this seems to make no difference - maybe I have the syntax wrong. I have found the POINTS option but haven't worked how to use this for, eg, 100 points f(1), f(2), f(3) ....... without inputting each point separately (very tedious!) [in fact, even doing this for a few points I still cannot get it to work].
Any help very gratefully received.
First 2295 2296 2297 2298 2299 2300 2301 Last Page 2297 of 2457
