what is problem in here
with(DEtools):
diff(u(x), x) = f(u(x), v(x)), diff(v(x), x) = g(u(x), v(x)) for the two differential equations.
f := (u,v) -> u+cos(v);
g := (u,v) -> u*v-v+sin(v);
proc (u, v) options operator, arrow; u+cos(v) end proc
proc (u, v) options operator, arrow; v*u-v+sin(v) end proc
The equilibria:
equilibria := solve({f(u,v)=0, g(u,v)=0}, {u,v},explicit);
{u = 1, v = Pi}, {u = -cos(RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z)), v = RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z)}
allvalues(RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z))
RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z, 1.306542374), RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z, -1.306542374), RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z, -2.331122370), RootOf(sin(_Z)*_Z^2+sin(_Z)-2*_Z, 2.331122370), 0
Download remove.mw
when we do the linearization we do transfer the critical point to the orgin, i want see the plot of nonlinear system before the linearization and after linearization which is critical point is tranfered to orgin, also i try to find `conserved quantity` and make a good plot with the critical point shown in graph how i can do the linearization by maple, also  we  by hand when we solved we show that in new system when we give him variable we have to write for each new system  u=x-x[0] when is u is new system for linearization we need that or not? becuase result is not change when we take jacobian result is same !
Linearization.mw
i want plot a system of differential equation and do phaseportrait i did but when i want make it a little bit more clear and colorfull like rainbow when i find the C.Q i don't know how set the option for ploting?
e1.mw
i have a system but i don't know how i can plot chaotic or is need time for ploting or not ?
Has anyone else run into the following bug in the PolynomialTools package?
> PolynomialTools[PolynomialToPDE]([z*f], [z], [f]);
                            d
                           [-- f(z)]
                            dz
> PolynomialTools[PolynomialToPDE]([z[1]*f], [z[1]], [f]);
                           [f(z[1])]
I believe the first behavior is correct, but when I use subscripted variables, I get the second behavior for linear terms.  (Nonlinear terms appear to work correctly:
>  PolynomialTools[PolynomialToPDE]([z[1]^2*f], [z[1]], [f]);
                               d
                             [------ f(z[1])]
                              dz[1]
I have observed this in Maple 2024.2 and previous versions.  Does anyone know if it's fixed in Maple 2025?  (I don't have access yet.)  Does anyone know a good workaround for polynomials with both linear and nonlinear terms?
----Josh
On my journey of discovery through the world of Maple, I would like to ask for help again:
How are the properties of variables and the indexing of sequences handled/determined? For this purpose, I chose an old problem from a challenging MO as an exercise and tried it in the attached file, which, of course, failed.
a[i] := 2*cos(t/2^i)-1
2*cos(t/2^i)-1
b[n] := product(a[i], i = 1 .. n)
product(2*cos(t/2^i)-1, i = 1 .. n)
limit(b[n], n = infinity)
limit(product(2*cos(t/2^i)-1, i = 1 .. n), n = infinity)
simplify(limit(b[n], n = infinity))
limit(product(2*cos(t*2^(-i))-1, i = 1 .. n), n = infinity)
Download test.mw
Regarding to this equation i want to do the same as paper did, but i am not sure how i can determine the both  point in plot and how thus point show effect of system of equation and  how find jacobian in the two different point  i think he find it in general but i think we have to find it for each one  of equalibriom point  or we just find in general .
thus plot also are emazing did he use special code in matlab or mathematica? there is some app for plot thus kind of phase portrait but they not like this this is must have a special code for plotting in matlab or mathematica
with(PDEtools)
undeclare(prime, quiet)
with(LinearAlgebra)
declare(u(x, t), quiet); declare(U(xi), quiet); declare(V(xi), quiet)
DU := V
V
DV := U^2*beta/(delta*k^2)+(alpha*w/(delta*k^3)+1/(delta*k^2)-w^2/(delta*k^4))*U
var := U, V
U, V
J := Student:-MultivariateCalculus:-Jacobian([DU, DV], [var], 'output' = 'matrix')
Matrix(%id = 36893490902008029780)
Eigenvalues(J, implicit, output = 'list')
[RootOf(_Z^2*delta*k^4-2*U*beta*k^2-alpha*k*w-k^2+w^2, index = 1), RootOf(_Z^2*delta*k^4-2*U*beta*k^2-alpha*k*w-k^2+w^2, index = 2)]
Eigenvalues(J)
Vector[column](%id = 36893490902007993756)
DU1 := V
V
V = solve(DU1, V)
V = 0
DV1 := U^2*F[2]+U*F[1]
U^2*F[2]+U*F[1]
U = solve(DV1, U)
U = (0, -F[1]/F[2])
so*we*have*three*equalibriom*point*(0, 0)
J1 := Student:-MultivariateCalculus:-Jacobian([DU1, DV1], [var], 'output' = 'matrix')
Matrix(%id = 36893490902007256836)
Eigenvalues(J1, implicit, output = 'list')
[RootOf(-2*U*F[2]+_Z^2-F[1], index = 1), RootOf(-2*U*F[2]+_Z^2-F[1], index = 2)]
Eigenvalues(J1)
Vector[column](%id = 36893490901938203092)
(14)
Download bi-1.mw
The attached problem is from a 1988 MO. It can be solved using complete induction, paper, and pencil, and with some effort, yields a simple answer. It's quite challenging to do by hand, but with "derive", it only takes three lines and a fraction of a second. Mow test.mw
"puzzle(n):=(∑)(cos(k*Pi/(2*n+1))^())^(4);"
Download test.mw
I can't do it with Maple because I'm doing something wrong again. Therefore, I'm asking for help.
Recently, I was surprised by the fact that it is not possible to create a table, where the values of entries are tables.
Toy example:
T1:=table(["1"=table(["first"=12, "second"=15]), "2"= table(["first"=9, "second"=7])]);
The code
T1["1"];
doesn't return table(["first"=12, "second"=15])
If table has lists in right-hand side
T1:=table(["1"=[12, 15], "2"= [9, 7]]);
all works properly.
 Based on the type of coefficients in the linear equations, SolveTools[Linear] provide several method including method = Rational, Polynomial etc.
The Polynomial method of SolveTools[Linear] however, cannot be directly called by SolveTools[Linear]. The interpreter complains that no such methd called "Polynomial".
This could only be solved if I import the SolveTools package in advance and call Linear.
I hope Maple could solve this issue.
I'm trying to reproduce a manual asymptotic analysis (see the attached pdf file) in Maple for a two-soliton solution. Specifically, I want to evaluate the limit of a function (e.g., r[2]r[2]r[2] or ∂xq[2]\partial_x q[2]∂x​q[2]). How can I properly perform the limit a2→+−∞ as t​→+−∞ in Maple, either by substitution or by reparametrization, in order to study the asymptotic behavior of a multi-variable expression symbolically?
with(Student[Calculus1])
lambda1 := I*mu1; lambda2 := I*mu2; a1 := -2*x/mu1+mu1*t; a2 := -2*x/mu2+mu2*t
numer_r := lambda2*cosh(a1)-lambda1*cosh(a2)
denom_r := (lambda1^2+lambda2^2)*cosh(a1)*cosh(a2)-2*lambda1*lambda2*(1+sinh(a1)*sinh(a2))
r2 := I*(-lambda1^2+lambda2^2)*numer_r/denom_r
numer_dq := (sinh(a1)-sinh(a2))^2; denom_dq := ((lambda1^2+lambda2^2)*cosh(a1)*cosh(a2)-2*lambda1*lambda2*(1+sinh(a1)*sinh(a2)))^2
dq2 := 1-2*(lambda1^2-lambda2^2)^2*numer_dq/denom_dq
limit_r2 := limit(r2, a2 = -infinity); simplify(limit_r2)
Error, invalid input: limit expects its 2nd argument, p, to be of type Or(name = algebraic,set(name = algebraic),list(name = algebraic)), but received -2*x/mu2+mu2*t = -infinity
limit_r2
limit_r2_pos := limit(r2, a2 = infinity); simplify(limit_r2_pos)
Error, invalid input: limit expects its 2nd argument, p, to be of type Or(name = algebraic,set(name = algebraic),list(name = algebraic)), but received -2*x/mu2+mu2*t = infinity
limit_r2_pos
Download asymptotic.mw cooocp_(2).pdf
Any suggestions for reformulating the limit or change of variables would be appreciated.
I have solution of this problem but how I can plot simulation on Maple?Thanks, In attach my problem
Good day, everyone
I am trying to code HPM but it's giving me the error code "Error, invalid subscript selector
" once I increase the number of iterations above 2.
Attached below is the code.
HPM.mw
In a recent MaplePrimes question: https://mapleprimes.com/questions/240543-Maple-20251-On-Windows-11-How-To-Resize
a discussion of interrupting a computation also came up.
I gave some comments. In one of these I wanted to include a link to a screenshot.
I tried several times. It seemed that I only had the choice between the full image or a thumb nail.
So I chose the latter. That appeared to me as worthless. I tried a couple of times more, but decided to delete all 3.
Then I wrote a comment without a screenshot.
It looks silly to have these empty (and anonymous) "comments" still around.
Is there any way to remove these?
Hello, when I have a complex conjugate in the denominator of a fraction, the conjugate bar symbol and the division line of the fraction overlap. When this happens, it is not apparent that the variable is a conjugate, so I have had to just type the command conjugate() in order to make this clear.
Reference the linked sample document that illustrates this: Conjugate.flow
I would appreciate any suggestion on how to use the conjugate symbol in this case. I would prefer the symbol wherever possible rather than the text command for clarity in the flow document.
1 2 3 4 5 6 7 Last Page 3 of 2424
