> with(LinearAlgebra) :
> a:=<<.1,.2>|<.3,.4>>:
> ScalarMultiply(a,.1);
INTEL MKL ERROR: /home/jet08013/maple2022/bin.X86_64_LINUX/libmkl_gf_lp64.so: undefined symbol: mkl_blas_cdgmm_batch_strided.
Intel MKL FATAL ERROR: Cannot load libmkl_gf_lp64.so.
maple: fatal error, lost connection to kernel
This is EXTREMELY inconvenient.
I try to design a half rectifier circuit in MapleSim, but the simulation is so slow and the console output says "Warning: many small integration steps are being taken at a very small proportion of integration range at t=2.9653230e-006, absolute/relative tolerance may be too tight for problem, or problem may require a stiff solver". So how should i improve the circuit to make the simulation faster?
By the way, i don't want to change the basic design of the circuit, so the circuit should consist of both diode and op amp. I know the diode only circuit can achieve the same goal.
half_rectifier.msim
Programm zur Brechnung der Kreisteilungspolynome_2022-04-05 Ki
restart; with(Algebraic); with(NumberTheory)
n := 6
6
cyclo_poly := Vector[row](1 .. n, 0)
Vector[row](%id = 36893489967244295332)
i := 1; cyclo_poly[1] := X-1
X-1
c_poly := proc (i, kt_poly) local j, hz1, hz2, X; j := i+1; hz1 := X^j-1; hz2 := kt_poly; kt_poly := Quotient(hz1, hz2, X) end proc
cyclo_poly[2] := c_poly(i, cyclo_poly[i])
Error, (in c_poly) illegal use of a formal parameter
i := 1; kt_poly := X-1
X-1
X^2-1
X-1
X+1
Download Programm_zur_Brechnung_der_Kreisteilungspolynome_2022-04-05_Ki.mw
Good morning
Why doesn't Quotient(x,y,z) not work within a procedure whereas it works well standing alone? See example.
Greetings  Heinz
I'm using Maple to calculate the geodesics of the Poincare' Half Plane:
with(LinearAlgebra): with(DifferentialGeometry): with(Tensor): with(Tools): with(plots):
DGsetup([x,y],M1)
g1 := evalDG(1/y^2*(dx &t dx+dy &t dy))
R1 := CurvatureTensor(g1)
K := SectionalCurvature(g1,R1,D_x,D_y)
Gamma := Christoffel(g1)
C := [x(t), y(t)]
V := GeodesicEquations(C, Gamma, t)
DE := Tools:-DGinfo(V, "CoefficientSet")
simplify(dsolve(DE, explicit))
I receive this error message
Error, (in simplify/siderels:-simplify/siderels) specified variables must be names or functions
How can I fix this error?
Thanks, Nicola
Please, how do I find the minimum of the real part of a complex function? I tried min ( ) function it didn't work.
Find attached the fileFinding_min_zero.mw
Import packages
restart: with(ArrayTools): with(Student:-Calculus1): with(LinearAlgebra): with(ListTools):with(RootFinding):with(ListTools):
Parameters
gamma1 := .1093:
alpha3 := -0.1104e-2:
k[1] := 6*10^(-12):
d:= 0.2e-3:
xi:= -0.01:
theta0:= 0.1e-3:
eta[1]:= 0.240e-1:
alpha:= 1-alpha3^2/(gamma1*eta[1]):
c:= alpha3*xi*alpha/(eta[1]*(4*k[1]*q^2/d^2-alpha3*xi/eta[1])):
theta_init:= theta0*sin(Pi*z/d):
n:= 10:
Assign g for q and plot g
g := q-(1-alpha)*tan(q)-c*tan(q):
plot(g, q = 0 .. 3*Pi, view = [DEFAULT, -30.. 10]);
Set q as a complex
Assume q = x+I*y and subsitute the result into g and equate the real and complex part to zero, and solve for x and y.
f := subs(q = x+I*y, g):
b1 := evalc(Re(f)) = 0:
b2 := evalc(Im(f)) = 0:
Compute the Special Asymptotes
This asymptote is coming from the c from the definition of "q."
qstar := (fsolve(1/c = 0, q = 0 .. infinity)):NULLNULL``
Compute Odd asymptote
First, Since tan*q = sin*q*(1/(cos*q)), then an asymptote occurs at cos*q = 0. In general, we have
"q= ((2 k+1)Pi)/(2). "
Next, we compute the entry of the Oddasymptotes that is close to qstar (special asymptote) as assign it to
ModifiedOaddAsym, and then find the minimum of the ModifiedOaddAsym. Searchall Function returns
the index of an entry in a list.
OddAsymptotes := Vector[row]([seq(evalf((1/2*(2*j+1))*Pi), j = 0 .. n)]);
ModifiedOddAsym := abs(`~`[`-`](OddAsymptotes, qstar));
qstarTemporary := min(ModifiedOddAsym);
indexOfqstar2 := SearchAll(qstarTemporary, ModifiedOddAsym);
qstar2 := OddAsymptotes(indexOfqstar2);
OddAsymptotes := Vector(4, {(1) = ` 1 .. 11 `*Vector[row], (2) = `Data Type: `*anything, (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
ModifiedOddAsym := Vector(4, {(1) = ` 1 .. 11 `*Vector[row], (2) = `Data Type: `*anything, (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
.6952012913
(4.2.1)
Compute x and y
Here, we solve for xand y within the min. and max. of qstar2 and qstar, and substitute the results into q.
AreThereComplexRoots := type(true, 'truefalse');
try
   soln1:= fsolve({b1, b2}, {x = min(qstar2, qstar) .. max(qstar2, qstar), y = 0 .. infinity});
   soln2:= fsolve({b1, b2}, {x = min(qstar2, qstar) .. max(qstar2, qstar), y = -infinity .. 0});
   qcomplex1 := subs(soln1, x+I*y);
   qcomplex2 := subs(soln2, x+I*y);
catch:
   AreThereComplexRoots := type(FAIL, 'truefalse');
end try;
{x = 1.348928550, y = .3589396337}
{x = 1.348928550, y = -.3589396337}
1.348928550+.3589396337*I
1.348928550-.3589396337*I
(4.3.1)
Compute the rest of the Roots
In this section we compute the roots between each asymptotes.
OddAsymptotes := Vector[row]([seq(evalf((1/2)*(2*j+1)*Pi), j = 0 .. n)]);
AllAsymptotes := sort(Vector[row]([OddAsymptotes, qstar]));
if AreThereComplexRoots then
gg := [qcomplex1, qcomplex2, op(Roots(g, q = 0.1e-3 .. AllAsymptotes[1])), seq(op(Roots(g, q = AllAsymptotes[i] .. AllAsymptotes[i+1])), i = 1 .. n)];
elif not AreThereComplexRoots then
gg := [op(Roots(g, q = 0.1e-3 .. AllAsymptotes[1])), seq(op(Roots(g, q = AllAsymptotes[i] .. AllAsymptotes[i+1])), i = 1 .. n)];
end if:
AllAsymptotes := Vector(4, {(1) = ` 1 .. 12 `*Vector[row], (2) = `Data Type: `*anything, (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
(4.4.1)
Remove the repeated roots if any
qq := MakeUnique(gg):
Redefine n
m := numelems(qq):
Compute the `&tau;_n`time constants
for i to m do
p[i] := gamma1*alpha/(4*k[1]*qq[i]^2/d^2-alpha3*xi/eta[1]);
93.91209918-98.41042341*I
93.91209918+98.41042341*I
8.521555786
2.990232721
1.515805379
.9145981009
.6114591994
.4374663448
.3284338129
.2556221851
.2045951722
(4.7.1)
Minimum of the Re(`&tau;_n`)
for i to m do
p[i] := min(Re(gamma1*alpha/(4*k[1]*qq[i]^2/d^2-alpha3*xi/eta[1])));
93.91209918
93.91209918
8.521555786
2.990232721
1.515805379
.9145981009
.6114591994
.4374663448
.3284338129
.2556221851
.2045951722
(4.7.1.1)
## I expected 0.20459 but return all the entries in the list.
Download Finding_min_zero.mw
I always found it odd that the end of a series was truncated with O(x^9) or whatever.
convert ( a, polynom) gets rid of it, but it just stops.  Could the O(x^9) be replaced with a +... or even a -... ?
series(tan^(-1)(x),x,9)
convert(%,polynom)
What's the best way to add a + ... to the end of that.
The random connected graphs used to be connected in Maple 2020. But then ...
with(GraphTheory):
with(RandomGraphs):
N:=100: n:=20: m:=30:
add(`if`(IsConnected(RandomGraph(n,m,connected)), 1, 0), 1..N) <> N;
        54 <> 100
I would like to print the current values of both displayed functions for x=1 in each frame of the animation. My example code is below:
plot1 := animate(plot, [a*x^2, x = -1 .. 1, color = "Green", thickness = 3], a = 0.2 .. 1.2);
plot2 := animate(plot, [a*x^2 + 0.3, x = -1 .. 1, color = "Red", thickness = 3], a = 0.2 .. 1.2);
display([plot1, plot2]);
I would be grateful for any tips.
Thank you,
Iza
Hello all,
Would you allow me to ask this one question?
[moderator: See also this previous question]
Is there any possible way to treat the differentiation operator (e.g., 'D') as an ordinary coefficient of a polynomial?
For example, as described in the attached worksheet, I was wondering if there is a way to re-write the LHS of the expression 'eq_e5_9b' as the expression 'desired'.
In Kwon Park
with(DEtools):
eq_e5_9b := psi__d0*Delta__delta(t) + psi__q0 * D(Delta__delta(t))/omega__0 = p_(Delta__psi__d(t))/omega__0 - Delta__psi__q(t);
psi__d0*Delta__delta(t)+psi__q0*D(Delta__delta(t))/omega__0 = p_(Delta__psi__d(t))/omega__0-Delta__psi__q(t)
collect(lhs(eq_e5_9b), Delta__delta(t));
desired := Delta__delta(t) * (psi__d0 + psi__q0 * D/omega__0);
Delta__delta(t)*(psi__d0+psi__q0*D/omega__0)
Download Q20220404.mw
How do I create a pointplot with different values of a parameter?
I tried
pointplot([seq([k, a(k, a0)], k = 0 .. 10, a0 = [0, 50, 100, 150, 200])]);
Error, invalid input: seq expects its 3rd argument, step, to be of type numeric, but received a0 = [0, 50, 100, 150, 200]
NULL;
ImportGraph reads one or more graphs from a file. For a file containing multiple graphs, the supported formats are digraph6, graph6, and sparse6. I notice that one option is "output = graph or list, or iterator". However, in my programming with Maple, I was reminded several times that list is only good for a small amount of data.
Although I can convert the list to an array using the convert function, the time spent in the conversion process needs to be considered.
with(GraphTheory):
L:=ImportGraph("C:/Users/eul10c.g6", graph6, output=list):#31026 connected eulerian graphs on 10 vertices graphs and Change to your path here.
convert(L,Array)
So does it make more sense to provide an "output=Array" as an output option?
eul10c.txt
I am trying to decide O of times fo a computer process. I thought it was n^2*log(N) or something like that.
With 12  points, it may be hard to determine if O(N^4), etc.
See big-o.mw
When resizing a textplot the text is not scaled.
I am trying to use "solve" to solve a set of 2 equations defined by using summation function "sum". But I got an error saying "Error, (in sum) summation variable previously assigned, second argument evaluates to 3 = 1 .. 2".
The Maple code is listed here
N := 2:
var:= seq(alpha[n], n = 1 .. N):
v(x):=sum(alpha[n]*phi[n](x), n = 1 .. N):
R(x):=diff(v(x), x $ 4) - p/EI:
eqs := seq('int'('R(x)'*phi[n](x), x = 0 .. L) = 0, n = 1 .. N):
for n to N do
    phi[n](x):= sin((2*n - 1)*Pi*x/L):
solve({eqs}, {var});
current_mirror.msim
I try to simulate a current mirror model, but it doesn't work and say "cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up". Maybe some incorrect parameters are set there, could you fix it?
First 324 325 326 327 328 329 330 Last Page 326 of 2428
