I have been unsuccessfully switching off the autosaving from Maple 2021. There is no "Options Dialog - General Tab". Please help me. Thank you!
int( exp(-2*r)*cos(theta)^3*r^2*sin(theta), phi=0..2*Pi, theta=0..Pi, r=0..infinity);
                      undefined
This integral with cos(theta) to an odd power should evaluate to zero, as found in Maple 17 [moderator: and up to Maple 2015.2] but not the most recent versions.
Hi there!
Do you know when the new version of Maple will be released?
Do you think it might come with a "Dark Theme"?
Kevin
How we can find the degree of the equation in which its powers are parametric?
For example, let
H := x^k+x^(2*k);
where k is a positive number.
Now, the degree must be 2*k, but when I use "frontend" I receive "one" !!!!
See:
assume(k>0);
frontend(degree,[H,x^k],[{`+`, `*`,`^`}]);
Opgave 1)
with(LinearAlgebra);
a = radius 1
b = radius 2
h = højde
Error, unexpected number
a := 213/2;
b := 144/2;
h := 46;
Vi definerer A_g(a,b)= areal af grundfladne, hvor a og b er de to radiusser.
r(u,v) = parametrisering af fladen i rummet
jf = Jacobi for fladen
r(u,v,w) = parametrisering af voluminet i rummet
jv = jacobi for voluminet
v(u0,u1,v0,v1,w0,w1) = voluminet af figuren
A_f(u0,u1,v0,v1) = voluminet af fladen
A_g := (a, b) -> b*a*Pi;
V := (a, b, h) -> 2/3*b*a*Pi*h;
x := (u, v) -> a^cos(u)*sin(v);
y := (u, v) -> b*sin(u)*sin(v);
z := (u, v) -> h*cos(v);
r := (u, v) -> <x(u, v), y(u, v), z(u, v)>;
ru := (u, v) -> diff(r(u, v), u);
rv := (u, v) -> diff(r(u, v), v);
jac := CrossProduct(ru(u, v), rv(u, v));
jf := sqrt(jac[1]^2 + jac[2]^2 + jac[3]^2);
           |               2       4
     jf := |10969344 cos(u)  sin(v)
               /     cos(u)\                 2           /
               |/213\      |        2   /213\        4   |
        + 2116 ||---|      |  sin(u)  ln|---|  sin(v)  + |
               \\ 2 /      /            \ 2 /            \
              cos(u)
         /213\             2   /213\
     -72 |---|       sin(u)  ln|---| sin(v) cos(v)
         \ 2 /                 \ 2 /
                                cos(u)       \  |
                           /213\             |  |
        - 72 cos(u) sin(v) |---|       cos(v)|^2|^(1/2)
                           \ 2 /             /  /
      |               2       4                  2       4
jf := \10969344 cos(u)  sin(v)  + 24000201 sin(u)  sin(v)
                                                               2\
     /            2                            2              \ |
   + \-7668 sin(u)  sin(v) cos(v) - 7668 cos(u)  sin(v) cos(v)/ /^
  (1/2)
Opgave b)
A_g(a, b);
                            7668 Pi
evalf(7668*Pi);
                          24089.73247
V(a, b, h);
                           235152 Pi
evalf(235152*Pi);
                                      5
                        7.387517958 10
Opgave b)
Vi skal blot løse integralet for
u \in [0,2*Pi] og v \in [0,Pi/2].
V bestemmer hvor langt z skal gå. Da dette er vores højde, lader vi denne gå til 0. Men ikke længere.
NULL;
int(jf, [u = -Pi .. Pi, v = 0 .. Pi/2]);
                             34384.
Opgave c)
Humlen er her, blot at definere en f(x,y,z)=z0-hældning*z, hvor:
hældning = df/dz
z0 = f(z=0)
I opgaven får vi
z=0 -> f = 20
z=46 -> f=10
Det er en fastprocentdel, så vi skal bruge eksponentialfunktion:
Hældning := (10/20)^(1/46)
Vi går så m(u,v) = f(x(u,v),y(u,v),z(u,v))
Bagefter, skal vi gange med jacobi og tage integralet.
z0 := 20;
`hældning` := (10/20)^(1/46);
f := (x, y, z) -> 20*`hældning`^z;
m := (u, v) -> 20*(1/2*2^(45/46))^(46*cos(v));
NULL;
int(m(u, v)*jf, [u = 0 .. 2*Pi, v = 0 .. Pi/2]);
                           129.98 jf
NULL;
Question:
Whenever I run any of the double integrals in this script, Maple freezes out and doesn't come back. What am I doing wrong? Why does it lag so much?
I'd like to pass a matrix/row as an argument to a function (as in the example below) but I cannot find any documentation on it. Is it possible? If so, how could it be done?
a:=Array(1,5,frandom(0..20))
b:=sin(a)
thanks very much in advance.
best regards.
I need 4400 N of friction and not 2200N, so in wich direction operate it?Whit 2200N i I have mauch oscillation.fall_elevator_on_spring.msimfall_elevator_on_spring.msimthanks
Hi professors,
Please can someone help me
i want code of  function in maple to calculate values  of B(t),
i have this matlab code
randn('state',100)
T = 1; N = 5; dt = T/N;
dW = sqrt(dt)*randn(1,N);
W = cumsum(dW)
but does not calculate B(0.25) and B(0.5)
I want to generate several graphs  at the same time that can be dynamically adjusted.I tried to write the following code. But it seemed to keep overwriting the previous drawing of graphs in the list g. I only got the last graph K6.
with(GraphTheory):
g:=[seq(CompleteGraph(i),i=2..6)]:
DrawGraph~(g, layout = interactive, layoutoptions = [neutral_color = "pink", initial = spring])
I don't know how to generate  some graphs with dynamically modified layouts at once
Maple uses \begin{array}...\end{array} for the latex of a Matrix, which is all good. But for an empty matrix, it does not generate the column specification c or and so the latex when compiled gives an error. Here is an example
W:=Matrix([[]]);
latex(W)
#which gives
\left[\begin{array}{}
\end{array}\right]
Compare to
W:=Matrix([[1]]);
latex(W)
#gives
\left[\begin{array}{c}
\end{array}\right]
Because the c is missing in the first example, this generates an error
\documentclass[12pt]{book}
\usepackage{amsmath}
\begin{document}
\end{array}\right]
\end{document}
>lualatex foo.tex
This is LuaHBTeX, Version 1.13.2 (TeX Live 2021)
 restricted system commands enabled.
(./foo.tex
LaTeX2e <2021-11-15>
 L3 programming layer <2021-11-12>
(/usr/local/texlive/2021/texmf-dist/tex/latex/base/book.cls
Document Class: book 2021/10/04 v1.4n Standard LaTeX document class
(/usr/local/texlive/2021/texmf-dist/tex/latex/base/bk12.clo))
(/usr/local/texlive/2021/texmf-dist/tex/latex/amsmath/amsmath.sty
For additional information on amsmath, use the `?' option.
(/usr/local/texlive/2021/texmf-dist/tex/latex/amsmath/amstext.sty
(/usr/local/texlive/2021/texmf-dist/tex/latex/amsmath/amsgen.sty))
(/usr/local/texlive/2021/texmf-dist/tex/latex/amsmath/amsbsy.sty)
(/usr/local/texlive/2021/texmf-dist/tex/latex/amsmath/amsopn.sty))
(/usr/local/texlive/2021/texmf-dist/tex/latex/l3backend/l3backend-luatex.def)
(./foo.aux) (/usr/local/texlive/2021/texmf-dist/tex/latex/base/ts1cmr.fd)
! Missing # inserted in alignment preamble.
<to be read again>
\cr
l.6 \left[\begin{array}{}
Adding the `c` fixes the Latex.
This came up with my code generated an empty  matrix from some computation.
May be this could be corrected for future version of Maple?
Maple 2021.2 on windows 10.
I have a continuous piecewise function, but I can't evaluate its integral
Integral.mw
thank you for your help
Say I have 3 players on 2 teams. The teams play each other and there are 9 single [[A[s], B[s]], [A[s], B[m]], [A[s], B[w]], [A[m], B[s]], [A[m], B[m]], [A[m], B[w]], [A[w], B[s]], [A[w], B[m]], [A[w], B[w]]]matchups.
A, B, C & X, Y, Z. are the players. A and X are the strongest players, C and Z are the weakest.
Here's one: [[A,X],[B,Y],[C,Z],[A,Y],[B,Z],[C,X],[A,Z],[B,X],[C,Y]]
So i'm looking for some code to display all such permutations.
Carl came up with some code a while back which 'kind of' does it
P:= [A,B]:  S:= [s,m,w]:
[seq(rtable((1..nops(S)) $ nops(P), ()-> index~(P, S[[args]]), order= C_order))];
This is perhaps a stupid question, when I use the ScientificConstant package and call a constant e.g. R this works smoothly. But when I assign the value to a variable to use it in a calculation Maple complains about the units. However, if I assign the constant manually (without using GetConstant) Maple has no issues in solving. Is there a trick to use such a constant in a calculation? I have attached a worksheet to illustrate my question better. Thank you in advance for helping me out.GetConstantQuestion.mw
Hi guys,
I've got problem with integrating terms consisting complex values, I would like to use principle value (1/x+ie = P(1/x) -i pi \delta(x)) to make integration process easier but dont know how to do it with maple . without using that maple gives very long answer.
Thanks for your help
ex.mw
Best
Hello Maple gurus!
I have two questions related to working with operands:
Question 1
I often find myself in a situation where I have a non-trivial expression for instance containing double integrals with complex exponentials, and want to perform some operation on a heavily nested operand like the exponent to a specific exponential inside the double integral. Usually what I do is use a list argument with the op() or subsop() to operate on the nested operator by finding specific operand numbers.
However, the problem with this is that I am hard-coding the operand number(s) for the operator, and this expression can be located in the middle of a large worksheet. If something above these op() or subop() calls changes and the changes trickle down, the operands might change number and the commands are no longer valid.
Does Maple have any commands that will let me 'find' an operand like one does in by-hand calculations? For example, there might be an exponent nested in a double integral that has 'a*b' in it. What I want is to operate on the operand containing 'a*b' rather than specifying the actual operand number. Is there anything like this?
Question 2
Somewhat related to the above, I sometimes want to do a single function on multiple operands. I tried applyop but that seems to apply a function to each operand individually. What if, for example, I want to run combine() on 2 specific operands, assuming these operands are heavily nested, to combine just those two operands.
First 331 332 333 334 335 336 337 Last Page 333 of 2428
