Dear community,
this is a related questio to "Determine zeros, indifference curve of two levels, numerical approximation".
I am  trying to model the advantage of corporate taxation (final asset value: V_TEV) over partnership taxation (final asset value: V_P).
I would like to plot the absolute advantage of corporate taxation (VT=V_TEV-V_P) as a function of income (E) and retention period (T). Here x=E, Y=T. I alread plotted the VT. However, Id like to have the graph differently:
I would like to construct the graph in such a way that the absolute wealth advantage VT can be read from the ordinate. Can someone please help me with that?
Here are the formulars, the study is based on:
E := 'E'
h := 4
m := 0.035
g:= h*m
k := 0.15
a := 0.25;
F_ANR := 4*m;
r:= 0.1;
T := 'T';
ESt := piecewise
(E < 9984, 0,
E < 14926, (1008.7*(E - 9984)/10000 + 1400)*(E - 9984)/10000,
E < 58596, (206.43*(E - 14926)/10000 + 2397)*(E - 14926)/10000 + 938.24,
E < 277826, 0.42*E - 9267.53,
0.45*E - 17602.28);
GewSt := piecewise(E < 24500, 0, (E - 24500)*g)
stev := EStk/K
K := 0.6*E*(1 - k - g)*(1 + r*(1 - k - g))^T
EStk := piecewise(K < 9984, 0,
K < 14926, (1008.7*(K - 9984)/10000 + 1400)*(K - 9984)/10000,
K < 58596, (206.43*(K - 14926)/10000 + 2397)*(K - 14926)/10000 + 938.24,
K < 277826, 0.42*K - 9267.53,
0.45*K - 17602.28)
V_TEV := E*(1 + (-k - g))*(1 + r*(1 - k - g))^T*(1 - 0.6*stev)
Er := E + (E - ESt)*r
EStr := piecewise(Er < 9984, 0,
Er < 14926, (1008.7*(Er - 9984)/10000 + 1400)*(Er - 9984)/10000,
Er < 58596, (206.43*(Er - 14926)/10000 + 2397)*(Er - 14926)/10000 + 938.24,
Er < 277826, 0.42*Er - 9267.53,
0.45*Er - 17602.28);
srp := EStr/E
r_p := r*(1 - srp)
V_P := (E - ESt + GewSt - min(ESt, GewSt, E*F_ANR))*(1 + r_p)^T
VT := V_TEV - V_P
plot3d(VT, E = 0 .. 500000, T = 1 .. 15, axes = boxed)
Thank you so much in advance!! Rebekka
When I convert Maple expression to Latex, before calling Latex, I replace some math names by strings in order to keep them as is in the generated Latex instead of using Maple own shortened name when conversion to latex().
Later on, in the Latex file, I add \DeclareMathOperator on each long name. This way the long math names remain and it is more clear.
This has been working well for years. Same code. No problems. All my Latex was generated this way.
Except just now, I hit a case where Maple's latex() gives an error when the math has WeierstrassP in it. latex() generates exception.
I will email this also to Maplesoft. But thought to also post it here in case someone can see what the problem is.
`The "Physics Updates" version in the MapleCloud is 1165 and is the same as the version installed in this computer, created 2022, March 7, 23:42 hours Pacific Time.`
#interface(warnlevel=4);
#kernelopts('assertlevel'=2):
interface(typesetting=standard); #to prevent bug. see https://www.mapleprimes.com/questions/232450-Why-Maple-Writes-The-Equation-Like-This
extended
r:=11/("\\WeierstrassPPrime"(x,a,b)+"\\WeierstrassP"(x,a,b)^2)*"\\WeierstrassP"(x,a,b)*"\\WeierstrassPPrime"(x,a,b)-6/("\\WeierstrassPPrime"(x,a,b)+"\\WeierstrassP"(x,a,b)^2)*"\\WeierstrassP"(x,a,b)^2+1/2*a/("\\WeierstrassPPrime"(x,a,b)+"\\WeierstrassP"(x,a,b)^2)
11*("\WeierstrassP")(x, a, b)*("\WeierstrassPPrime")(x, a, b)/(("\WeierstrassPPrime")(x, a, b)+("\WeierstrassP")(x, a, b)^2)-6*("\WeierstrassP")(x, a, b)^2/(("\WeierstrassPPrime")(x, a, b)+("\WeierstrassP")(x, a, b)^2)+(1/2)*a/(("\WeierstrassPPrime")(x, a, b)+("\WeierstrassP")(x, a, b)^2)
latex(r)
Error, (in latex) unable to proceed; could you please report this problem at physics@maplesoft.com
interface(typesetting=extended);
standard
latex(r)
Error, (in TypeTools/nc_var_local) invalid input: member received MathematicalFunctionsNames, which is not valid for its 2nd argument, s
Download march_8_2021_latex.mw
Hi, this is a small problem in af greater one for me. I'm trying to test to bigger equations if they are the same, which i suspect, the thing is, that maple wont evalb it. When i try with this simple problem, it gives me false. Can someone explaine this to me? Thank you for you help.
I am getting an exception divide by zero using solve. The problem is that when using kernelopts('assertlevel'=2):  I am no longer able to catch the exception in a catch try.
Removing kernelopts('assertlevel'=2):  I can catch the exception.
But I need to use kernelopts('assertlevel'=2): in my program.
Is there a way to keep kernelopts('assertlevel'=2): and still catch exception thrown by solve?
Is this a bug in solve? And why using kernelopts('assertlevel'=2): prevents catching the exception?
Using Maple 2021.2 on windows 10. Worksheet attached.
 exception generated
trial_solution_constants:=[A[1]];
eq:=-A[1]-exp(x^2)*exp(-x^2) = 0;
solve(identity(eq,x),trial_solution_constants)
[A[1]]
Error, (in unknown) numeric exception: division by zero
Using assertlevel, now unable to catch exception
try
catch:
   print("error happend ",lastexception);
end try;
print(" I am here");
[A[1]]
Error, (in unknown) assertion failed
" I am here"
Not Using assertlevel now can catch exception
try
catch:
end try;
[A[1]]
"error happend ", unknown, "numeric exception: division by zero"
" I am here"
Download march_8_2021_solve.mw
Update Sept 7,2022
FYI, here is another internal exception generated by solve which shows only when kernelopts('assertlevel'=2): is set, and which can not be trapped using try/catch. May be this could be fixed in future version of Maple.
Worksheet attached.
`The "Physics Updates" version in the MapleCloud is 1314 and is the same as the version installed in this computer, created 2022, September 2, 15:54 hours Pacific Time.`
eq:=1 = -X*(-(Y^2*exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)+2*exp(X*Y)*y0*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*Y+exp(X*Y)*y0^2*exp(X*y0)*exp(x0*Y)*exp(x0*y0))/(exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0+2*Y+2*y0)+(exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*Y+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*y0+1)/(exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0+2*Y+2*y0)^2*(Y*exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*y0*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)+Y*exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0+exp(X*Y)*y0*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0))/Y/(-(Y*exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*y0*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)+Y*exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0+exp(X*Y)*y0*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0)/(exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0+2*Y+2*y0)+(exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*Y+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*y0+1)/(exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)*x0+2*Y+2*y0)^2*(X^2*exp(X*Y)*exp(X*y0)*exp(x0*Y)*exp(x0*y0)+2*exp(X*Y)*exp(X*y0)*x0*exp(x0*Y)*exp(x0*y0)*X+exp(X*Y)*exp(X*y0)*x0^2*exp(x0*Y)*exp(x0*y0)+2)):
try
     sol:=solve(identity(eq,X),[x0, y0]);
catch:
     print("exception");
end try;
Download solve_exception.mw
I have a function defined over the closed interval [ x[k], x[k+2] ] and zero elsewhere
I would like to plot this sequence of function and compute an integral.
I need your help to finish the attahced code, something is wrong. I can't  use piecewise funciton in loop and plot all functions in the same graph
piecewise_funciton_and_integral.mw
thanks for your remaks and help
Hello, can someone explain why something like this fails? The help page for 'isolate' says the second argument can be 'any algebraic expression'. Thanks.
I have the following systems of ODE in hand and would like to solve them. It would be great if somebody could help me with it.
dudx := -415; dudy := 3901; dudz := -3365; dvdx := 23; dvdy := -1270; dvdz := 994; dwdx := 57; dwdy := -1665; dwdz := 1683; taup := 0.5390603100674905e-5
-415
3901
-3365
23
-1270
994
57
-1665
1683
u := .387; v := -.205; w := -.286; x0 := -0.979849e-2; y0 := -0.14583e-2; z0 := 0.623749e-1
.387
-.205
-.286
-0.979849e-2
-0.14583e-2
0.623749e-1
a__1 := dudx/taup; a__2 := dudy/taup; a__3 := dudz/taup; a__4 := 1/taup; a__5 := u/taup; b__1 := dvdx/taup; b__2 := dvdy/taup; b__3 := dvdz/taup; b__4 := 1/taup; b__5 := v/taup; c__1 := dwdx/taup; c__2 := dwdy/taup; c__3 := dwdz/taup; c__4 := 1/taup; c__5 := w/taup
-76985820.00
723666708.0
-624234420.0
185508.0000
71791.59600
4266684.000
-235595160.0
184394952.0
185508.0000
-38029.14000
10573956.00
-308870820.0
312209964.0
185508.0000
-53055.28800
sys := diff(x(t), t, t) = a__1*x(t)+a__2*y(t)+a__3*z(t)-a__4*(diff(x(t), t))+a__5, diff(y(t), t, t) = b__1*x(t)+b__2*y(t)+b__3*z(t)-b__4*(diff(y(t), t))+b__5, diff(z(t), t, t) = c__1*x(t)+c__2*y(t)+c__3*z(t)-c__4*(diff(z(t), t))+c__5
diff(diff(x(t), t), t) = -76985820.00*x(t)+723666708.0*y(t)-624234420.0*z(t)-185508.0000*(diff(x(t), t))+71791.59600, diff(diff(y(t), t), t) = 4266684.000*x(t)-235595160.0*y(t)+184394952.0*z(t)-185508.0000*(diff(y(t), t))-38029.14000, diff(diff(z(t), t), t) = 10573956.00*x(t)-308870820.0*y(t)+312209964.0*z(t)-185508.0000*(diff(z(t), t))-53055.28800
ics := x(0) = x0, y(0) = y0, z(0) = z0, (D(x))(0) = 0, (D(y))(0) = 0, (D(z))(0) = 0
x(0) = -0.979849e-2, y(0) = -0.14583e-2, z(0) = 0.623749e-1, (D(x))(0) = 0, (D(y))(0) = 0, (D(z))(0) = 0
Thank you very much!
Download m_solution.mw
Warm greetings.
Is it possible to solve the numerical scheme present in the below paper.
Anita Chaturvedi, Kokila Ramesh, and Vatsala G A. (2017). “A MATHEMATICAL APPROACH TO STUDY THE EFFECT OF POLLUTANTS/TOXICANTS IN AQUATIC ENVIRONMENT.” International Journal of Research - Granthaalayah, 5(4) RAST, 33-38.
https://doi.org/10.5281/zenodo.803418
Could please help me solving the following problem?
Thank you a lot.
The question https://www.mapleprimes.com/questions/233780-Plot-Absolute-Advantage-Of-Option-A disappeared (I know since I answered today).
Why?
I simplified a vector column using side relations. Then I wanted to evaluate using
eval( equation,  [x1=3,  x2=5......})
But side relations uses the reverse order i.e. after evaluation
[3=x1, 5=x2......]
So then the internals of the list need to be swaped tto work with eval.That is easy. I am just wondering is there a neater way to achieve this?
P1 := Vector(3, {(1) = -(y[1]-y[3])*(y[2]-y[3])*((x[2]^2-x[2]*x[3]+x[3]^2)*x[1]^2-x[2]*x[3]*(x[2]+x[3])*x[1]+x[2]^2*x[3]^2)*(y[1]-y[2]), (2) = -(x[1]-x[3])*(x[2]-x[3])*(x[1]-x[2])*((y[2]^2-y[2]*y[3]+y[3]^2)*y[1]^2-y[2]*y[3]*(y[2]+y[3])*y[1]+y[2]^2*y[3]^2), (3) = ((-y[1]^2*y[2]+(3*y[2]*y[3]-y[3]^2)*y[1]-y[2]^2*y[3])*x[2]+x[3]*(y[1]^2*y[3]+y[2]*(y[2]-3*y[3])*y[1]+y[2]*y[3]^2))*x[1]^2+((y[1]^2*y[3]+y[2]*(y[2]-3*y[3])*y[1]+y[2]*y[3]^2)*x[2]^2+3*x[3]*(y[2]-y[3])*(y[1]-y[3])*(y[1]-y[2])*x[2]-x[3]^2*(y[1]^2*y[2]+(-3*y[2]*y[3]+y[3]^2)*y[1]+y[2]^2*y[3]))*x[1]-x[3]*((y[1]^2*y[2]+(-3*y[2]*y[3]+y[3]^2)*y[1]+y[2]^2*y[3])*x[2]-x[3]*(y[1]^2*y[3]+y[2]*(y[2]-3*y[3])*y[1]+y[2]*y[3]^2))*x[2]})
eqns := {(x[1]-x[2])*(x[2]-x[3])*(x[3]-x[1]) = R, (y[1]-y[2])*(y[2]-y[3])*(y[3]-y[1]) = S, x[1]^2*x[2]^2-x[1]^2*x[2]*x[3]+x[1]^2*x[3]^2-x[1]*x[2]^2*x[3]-x[1]*x[2]*x[3]^2+x[2]^2*x[3]^2 = Y, y[1]^2*y[2]^2-y[1]^2*y[2]*y[3]+y[1]^2*y[3]^2-y[1]*y[2]^2*y[3]-y[1]*y[2]*y[3]^2+y[2]^2*y[3]^2 = X, x[1]^2*x[2]+x[1]^2*x[3]+x[1]*x[2]^2-6*x[1]*x[2]*x[3]+x[1]*x[3]^2+x[2]^2*x[3]+x[2]*x[3]^2 = Z, y[1]^2*y[2]+y[1]^2*y[3]+y[1]*y[2]^2-6*y[1]*y[2]*y[3]+y[1]*y[3]^2+y[2]^2*y[3]+y[2]*y[3]^2 = W}
P1new := simplify(P1, eqns)
Vector[column](%id = 36893490132854572084)
values := {x[1] = 3, x[2] = 5, x[3] = 7, y[1] = 2, y[2] = -11, y[3] = 13}
vals1 := eval(eqns, values)
{-3432 = S, 16 = R, 120 = Z, 316 = Y, 2018 = W, 22753 = X}
eval(P1new, vals1)
vals1swap := [seq(rhs(vals1[i]) = lhs(vals1[i]), i = 1 .. nops(vals1))]
[S = -3432, R = 16, Z = 120, Y = 316, W = 2018, X = 22753]
eval(P1new, vals1swap)
Vector[column](%id = 36893490132849052116)
eval(P1, values)
Vector[column](%id = 36893490132871267020)
Download Q_6-03-2022_side_rels_and_eval.mw
Need help to plot a graph along x-axis  in attached worksheet.
help_graph.mw
with(plots):with(plottools):
Solve diagonal resistance of nodes (0,0,0)-(3,4,5), (Edge length = ohm).(156/47 ohm)
plots[display]([nodes, node2, plotlinesx], scaling = constrained, style = wireframe, axes = boxed, orientation = [-50, 70, 0])
Solve minimum diagonal surface distance of nodes (0,0,0)-(3,4,5).(sqrt(74))
Download Resistance-345.mw
Edge length = ohm, therefore, each edge has 3, 4 and 5 ohm, respectivery. (156/47 ohm)
Solve minimum diagonal surface distance of nodes (0,0,0)-(3,4,5). (sqrt(74))
Electric circuit study.
Tokoro.
A have som problems when i Will save a project. It Will take 2-5 Minutes where my other freinds never Experince this? Also i have some problems when i pauses writing, when i take notes in class, it Will give me the loading circle on mac( iam using a MacBook Air 2018)
i hope you Can help:)
thx
Hi, im trying to optimize a function with a constraint.
I've tried the Optimize package but I can't seem to make it work.
I've attached  an image to my question, witht the function and the constraint. I want to find the optimal "t_x"
Function: rho*ln((-beta*tau + rho)/(1 + t__x)) + sigma*ln(sigma/(1 + t__y)) + beta*tau + B - rho - sigma - beta*tau*ln((-beta*tau + rho)/(1 + t__x))
Constaint: -t__x*(-beta*tau + rho)/(1 + t__x) + t__y*sigma/(1 + t__y) = R
Hope you can help
First 332 333 334 335 336 337 338 Last Page 334 of 2428
