Good day all.
My particular question concerns a Traveling Salesman-type problem.
Suppose I wish to move along the x-y plane and visit specific nodes (see the attached worksheet).
Starting at the origin, A, I intend to visit four locations, B to E, and finally return to the origin point. These nodes may be visited in any order - but, my total distance travelled must be a minimum.
However, my direction of travel is restricted; namely:
1. Movement is limited to the x and y-directions only (up and down as well as left and right)
2. Horizontal (left or right) movement is permitten only at y=1 and y=10
This second rule restricts me from turning left or right in between y= 1 and 10.
The Traveling Salesman routine (attached) is constructed to select a tour that is confined to orthogonal movement but it does not observe the second restriction (i.e. move left or right when you reach y=1 or y=10).
Is there any way in which I can build this condition into the routine so that the movement along the circuit observes the restrictions?
If so - is it possible to graphically illustrate the order of travel (using arrows from point-to-point) on a point plot?
I appreciate you taking the time to read this.
MaplePrimes_May_6.mw
I tried to graph the function f(x)=x^(1/3) but it only gives me a graph for non-negative x's, when the function f has all real numbers as its domain.
Maybe I'm doing it wrong.
ac-dc-dc1.msim
When i click off the "Plot events", the figure of Probe2 is pretty different comparing with "Plot events" is turned on. Here is my assumption: the simulation duration is 500 seconds and the plot points are 2000. Considering the frequency of sine current is 40HZ, many points cannot be ploted in the figure. So it is not a big deal for curve like Probe1 and Probe5 because  they tend to be a constant and Probe2 just reflect the tendency.
Hey I’m trying to shift a function horizontally to the right.
I have the following 3 functions:
V1 := -x
V2:= -2*x + 4.95
V3:= -x + 1.665
Function V2 I want to shift l_1 to the right, and V3 I want to shift l_1 + l_2 to the right.
I know I can do this manually by define the functions:
V2:= -2*(x-l_1) + 4.95
V3:= -(x-l_1-l_2) + 1.665
Where l_1:=1.665 and l_2:=4.95
Is there a way to do this without typing it manually?
By the way it’s only for plotting, so it’s not necessary for me to actually define them, if there is a way to do it within a plot some how.
Thank you in advance.
I am trying to solve these equation using fsolve, but it returns the same valve. Please provide a solution.\
Please see the attachment.
Hi, with Units[Simple] package loaded, I tried to differentiate a few functions using D[n] but it does not work. problem.mw
a := proc (x, y) options operator, arrow; exp(x*y) end proc
proc (x, y) options operator, arrow; exp(y*x) end proc
D[1](a)
proc (x, y) options operator, arrow; y*exp(y*x) end proc
D[2](a)
proc (x, y) options operator, arrow; x*exp(y*x) end proc
retart
retart
"with(Units[Simple]):"
proc (x, y) options operator, arrow; Units:-Simple:-exp(Units:-Simple:-`*`(x, y)) end proc
D[1](a)
Error, (in tools/gensym) too many levels of recursion
D[2](a)
Download problem.mw
Hi! I've got a set of subsets S with Abeing the i-subset. I need to sum up all the x's in all the Ai's. How can this be achieved?
(ex):
sum( { {a, b, c}, {a, b, d} } )= 2a+2b+c+d
Hey I’m trying to define the antiderivative for a function:
g(x) = 1
G(x) = int(g(x),x)
When I then type:
G(x) and press enter Maple gives me G(x) = x which of course is correct
But I can’t type:
G(5)
Then it gives me the error message:
Error, (in int) integration range or variable must be specified in the second argument, got 5
How to fix this?
I know I can type G(x) = x manually but I’m not interested in doing so, because in my document I’m going to have a lot of antiderivatives.
I have a student who then she uses tools/assistent/import data and then the file then Maple claims the Excel file is empty? She uses Maple 2021.2. File works on other my and other student computers.
I would like to perform the following expansion up to an arbitrary order. The dots refer to higher-order terms. All the coefficients are symmetric except for the first one.
Thank you very much!
To Maple support:
I was investigating this pde from a different forum.
I noticed that when using an expanded version of the pde, Maple hangs. Without expanding the PDE, Maple gives an answer in 2 seconds.
Why does expanding the PDE makes a difference? I do not have an earlier version of Maple on my new PC to check if this is a new issue or not.
`Standard Worksheet Interface, Maple 2022.0, Windows 10, March 8 2022 Build ID 1599809`
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1230 and is the same as the version installed in this computer, created 2022, April 21, 9:8 hours Pacific Time.`
pde1:=VectorCalculus:-Laplacian(u(r,theta),'polar'[r,theta]);
pde1_expanded:=expand(pde1);
bc  := u(1,theta)=sin(theta)^4,u(3,theta)=1;
pdsolve([pde1=0,bc],u(r,theta))
(diff(u(r, theta), r)+r*(diff(diff(u(r, theta), r), r))+(diff(diff(u(r, theta), theta), theta))/r)/r
(diff(u(r, theta), r))/r+diff(diff(u(r, theta), r), r)+(diff(diff(u(r, theta), theta), theta))/r^2
u(1, theta) = sin(theta)^4, u(3, theta) = 1
u(r, theta) = (1/52480)*((328*r^6-26568*r^2)*ln(3)*cos(2*theta)+(-r^8+6561)*ln(3)*cos(4*theta)+19680*(ln(3)+(5/3)*ln(r))*r^4)/(ln(3)*r^4)
pdsolve([pde1_expanded=0,bc],u(r,theta)); #HANGS, Waited more than 40 minutes.
Download hangs_pde.mw
DirectSearch finds nonexisting roots....     DirectSearch_finds_nonexisting_roots.mw
plot([cos(x), 0.001*x*x],x=-40..40,y=0..2)     ### test function plot
eq:= cos(x)= 0.001*x*x;     ###   float
cos(x) = 0.1e-2*x^2
use RealDomain in solve(eq,x,explicit) end use   ## lacking some of the roots
-7.793210110, 7.793210110, -11.11953559, 11.11953559, -4.734809278, 4.734809278, -1.568336644, 1.568336644
use RealDomain in solve(eq,x) end use
fsolve(eq,x=-30)
-31.17938383
plot([cos(x), 0.001*x*x],x=-32..-31,y=0.9..1)
fsolve(eq,x=-32..-30);  fsolve(eq,x=-31.7..-31.4)
-31.17938383
-31.52634294
with(DirectSearch)
[BoundedObjective, CompromiseProgramming, DataFit, ExponentialWeightedSum, GlobalOptima, GlobalSearch, Minimax, ModifiedTchebycheff, Search, SolveEquations, WeightedProduct, WeightedSum]
eq;
SolveEquations(eq,AllSolutions):
cos(x) = 0.1e-2*x^2
interface(rtablesize=90);
SolveEquations(eq, AllSolutions)
90
Matrix(%id = 4800942722)
DirectSearch finds nonexisting roots!!!
Dr. Ali GÜZEL
Download DirectSearch_finds_nonexisting_roots.mw
How do I get the plot of P(t) and C(t) and also a table with the values of P(t) for each t? Itried but I couldn't...
restart; beta := 0.7e-2; Lambda := 0.2e-4; `ρ__o` := 0.3e-2; lambda := 0.8e-1; h := 0.1e-1; n := 100
Error,
for i from 0 to n-1 do P[i+1] := (1+h*(`ρ__o`-beta)/Lambda)*P(i)+h*lambda*C(i); C[i+1] := h*beta*P(i)/Lambda+(-h*lambda+1)*C(i) end do:
seq(i, i = 0 .. 30); seq(P[i], i = 0 .. 30)
Error,
with(plots); with(DEtools); p1 := plot([P(t)], t = 0 .. 100, [[P(0) = 1]], scene = [t, P(t)], thickness = 2, linecolor = red, stepsize = .1); p2 := plot([C(T)], t = 0 .. 100, [[C(0) = beta/(Lambda*lambda)]], scene = [t, C(t)], thickness = 2, linecolor = red, stepsize = .1); display([p1, p2])
Download System_Recursive_Equations.mw
Thank!!!
How can I add more terms, in taylor approximation of odes.
Attached the code well written for only second order approximatiom, how can i get the fourth order approximation in taylor expansion to approximate an IVP
taylor_fourth_order.mw
thank you
First 345 346 347 348 349 350 351 Last Page 347 of 2458
