Backspacing at the end of a few math containers on one row will shift them upwards beyond the top screen out of view and out of existence.  Your last chance of retrieval is when you can still see the bottom half portions of the letters/equations before you need to go to the first point and press enter to bring them down.  Once they're out of view, there's no chance to bring back what you wrote - the assignments are still valid.  Also note CRTL-Z will not bring them back.
This worksheet displays an intersection between two spheres based on a test which seems unrelated to the display.
How can this be explained?
Intersecting_spheres.mw
Using the hide command after displaying a plot in MapleFlow2022 prevents that plot from being moved.
If you create another plot, then both plots are movable until you use the hide command again, at which point you need to create another plot to allow plots to be positioned.
I am writing an arrow procedure and will like to know if there is a way to implement the following
bj := (G, y) ->  (`@`(seq((t -> u -> v -> G(u, t) - v)(args[1 + nargs - i]), i = 1 .. nargs - 2)))(y)
bj(F, y, a, b, c, d);
v:=[p, q, r, s]
the output
My question is, how can I replace the v with each element of the list to get the following as output
F(F(F(F(y,a)-p),b)-q,c)-r,d)-s
Aany suggestion will be highly appreciated
Here is a Maple 2020 worksheet that ran fine on Maple 2020, but runs slower on Maple 2022, especially when plots[display] is used it seems to take much longer?
with(NumberTheory);
NULL;
NULL;
theta := [14.134725, 21.022039, 25.010858, 30.424876, 32.935062, 37.586178, 40.918719, 43.327073, 48.00515, 49.773832, 52.970321, 56.446248, 59.347044, 60.831779, 65.112544, 67.079811, 69.546402, 72.067158, 75.704691, 77.144840, 79.337375, 82.91038, 84.735493, 87.425273, 88.809111, 92.491899, 94.651344, 95.870634, 98.831194];
y[1] := x -> -2*sqrt(x)*cos(theta[1]*ln(x) - argument(0.5 + theta[1]*I))/(abs(0.5 + theta[1]*I)*ln(x));
y[1] := proc (x) options operator, arrow; -2*sqrt(x)*cos(theta[1\
  ]*ln(x)-argument(.5+I*theta[1]))/(abs(.5+I*theta[1])*ln(x))
   end proc
plot(y[1](x), x = 20 .. 100, title = 'Fig1*(S &G theta) = 1/2 + 14.134725*i');
y[2] := x -> -2*sqrt(x)*cos(theta[2]*ln(x) - argument(0.5 + theta[2]*I))/(abs(0.5 + theta[2]*I)*ln(x));
y[2] := proc (x) options operator, arrow; -2*sqrt(x)*cos(theta[2\
  ]*ln(x)-argument(.5+I*theta[2]))/(abs(.5+I*theta[2])*ln(x))
   end proc
plot(y[2](x), x = 20 .. 100, title = 'Fig1*(S &G theta) = 1/2 + 21.022040*i');
y[3] := x -> -2*sqrt(x)*cos(theta[3]*ln(x) - argument(0.5 + theta[3]*I))/(abs(0.5 + theta[3]*I)*ln(x));
y[3] := proc (x) options operator, arrow; -2*sqrt(x)*cos(theta[3\
  ]*ln(x)-argument(.5+I*theta[3]))/(abs(.5+I*theta[3])*ln(x))
   end proc
plot(y[3](x), x = 20 .. 100, title = 'Fig1*(S &G theta) = 1/2 + 25.00858*i');
y[4] := x -> -2*sqrt(x)*cos(theta[4]*ln(x) - argument(0.5 + theta[4]*I))/(abs(0.5 + theta[4]*I)*ln(x));
y[4] := proc (x) options operator, arrow; -2*sqrt(x)*cos(theta[4\
  ]*ln(x)-argument(.5+I*theta[4]))/(abs(.5+I*theta[4])*ln(x))
   end proc
plot(y[4](x), x = 20 .. 100, title = 'Fig1*(S &G theta) = 1/2 + 30.424876*i');
y[5] := x -> -2*sqrt(x)*cos(theta[5]*ln(x) - argument(0.5 + theta[5]*I))/(abs(0.5 + theta[5]*I)*ln(x));
y[5] := proc (x) options operator, arrow; -2*sqrt(x)*cos(theta[5\
  ]*ln(x)-argument(.5+I*theta[5]))/(abs(.5+I*theta[5])*ln(x))
   end proc
plot(y[5](x), x = 20 .. 100, title = 'Fig1*(S &G theta) = 1/2 + 32.93502*i');
T[1] := x -> -2*sum(Moebius(n)*Re(Ei((0.5 + theta[1]*I)*ln(x)))/n, n = 1 .. trunc(ln(100)/ln(2)) + 1);
T[1] := proc (x) options operator, arrow; -2*(sum(NumberTheory:-\
  Moebius(n)*Re(Ei((.5+I*theta[1])*ln(x)))/n, n = 1 ..
   trunc(ln(100)/ln(2))+1)) end proc
plot(T[1](x), x = 20 .. 100, title = 'T[1]');
T[2] := x -> -2*sum(Moebius(n)*Re(Ei((0.5 + theta[2]*I)*ln(x)))/n, n = 1 .. trunc(ln(100)/ln(2)) + 1);
T[2] := proc (x) options operator, arrow; -2*(sum(NumberTheory:-\
  Moebius(n)*Re(Ei((.5+I*theta[2])*ln(x)))/n, n = 1 ..
plot(T[2](x), x = 20 .. 100, title = 'T[2]');
T[3] := x -> -2*sum(Moebius(n)*Re(Ei((0.5 + theta[3]*I)*ln(x)))/n, n = 1 .. trunc(ln(100)/ln(2)) + 1);
T[3] := proc (x) options operator, arrow; -2*(sum(NumberTheory:-\
  Moebius(n)*Re(Ei((.5+I*theta[3])*ln(x)))/n, n = 1 ..
plot(T[3](x), x = 20 .. 100, title = 'T[3]');
T[4] := x -> -2*sum(Moebius(n)*Re(Ei((0.5 + theta[3]*I)*ln(x)))/n, n = 1 .. trunc(ln(100)/ln(2)) + 1);
T[4] := proc (x) options operator, arrow; -2*(sum(NumberTheory:-\
plot(T[4](x), x = 20 .. 100, title = 'T[4]');
T[5] := x -> -2*sum(Moebius(n)*Re(Ei((0.5 + theta[5]*I)*ln(x)))/n, n = 1 .. trunc(ln(100)/ln(2)) + 1);
T[5] := proc (x) options operator, arrow; -2*(sum(NumberTheory:-\
  Moebius(n)*Re(Ei((.5+I*theta[5])*ln(x)))/n, n = 1 ..
plot(T[5](x), x = 20 .. 100, title = 'T[5]');
f10 := x -> Li(x) - 2*sum(Re(Ei((1/2 + theta[n]*I)*ln(x))), n = 1 .. 10) - ln(2) + int(1/(t*(t^2 - 1)*ln(t)), t = x .. infinity);
f10 := proc (x) options operator, arrow; Li(x)-2*(sum(Re(Ei((1/2\
  +I*theta[n])*ln(x))), n = 1 .. 10))-ln(2)+int(1/(t*(t^2-1)*ln(\
  t)), t = x .. infinity) end proc
R10 := x -> sum(Moebius(l)*f10(x^(1/l))/l, l = 1 .. 8);
R10 := proc (x) options operator, arrow; sum(NumberTheory:-Moebi\
  us(l)*f10(x^(1/l))/l, l = 1 .. 8) end proc
plot1 := plot(R10(x), x = 2 .. 100);
plot2 := plot(pi(x), x = 2 .. 100);
display([plot1, plot2]);
f29 := x -> Li(x) - 2*sum(Re(Ei((1/2 + theta[n]*I)*ln(x))), n = 1 .. 29) - ln(2) + int(1/(t*(t^2 - 1)*ln(t)), t = x .. infinity);
f29 := proc (x) options operator, arrow; Li(x)-2*(sum(Re(Ei((1/2\
  +I*theta[n])*ln(x))), n = 1 .. 29))-ln(2)+int(1/(t*(t^2-1)*ln(\
R29 := x -> sum(Moebius(l)*f29(x^(1/l))/l, l = 1 .. 8);
R29 := proc (x) options operator, arrow; sum(NumberTheory:-Moebi\
  us(l)*f29(x^(1/l))/l, l = 1 .. 8) end proc
plot3 := plot(R29(x), x = 2 .. 100);
NULL;
display([plot1, plot2, plot3]);
R29(100);
R10(100);
pi(100);
                          25.25165721
                          25.28503922
                               25
RR10 := x -> sum(Moebius(l)*f10(x^(1/l))/l, l = 1 .. trunc(ln(1000)/ln(2)) + 1);
RR10 := proc (x) options operator, arrow; sum(NumberTheory:-Moeb\
  ius(l)*f10(x^(1/l))/l, l = 1 .. trunc(ln(1000)/ln(2))+1) end
   proc
RR10(1000);
pi(1000);
                          168.1328341
                              168
RR29 := x -> sum(Moebius(l)*f29(x^(1/l))/l, l = 1 .. trunc(ln(1000)/ln(2)) + 1);
RR29 := proc (x) options operator, arrow; sum(NumberTheory:-Moeb\
  ius(l)*f29(x^(1/l))/l, l = 1 .. trunc(ln(1000)/ln(2))+1) end
   proc
RR29(1000);
                          167.6113955
P1 := plot(RR29(x), x = 880 .. 930);
P2 := plot(pi(x), x = 880 .. 930);
display([P1, P2]);
f0 := x -> Li(x) - ln(2) + int(1/(t*(t^2 + 1)*ln(t)), t = x .. infinity);
f0 := proc (x) options operator, arrow; Li(x)-ln(2)+int(1/(t*(t^\
  2+1)*ln(t)), t = x .. infinity) end proc
RR0 := x -> sum(Moebius(l)*f0(x^(1/l))/l, l = 1 .. trunc(ln(1000)/ln(2)) + 1);
RR0 := proc (x) options operator, arrow; sum(NumberTheory:-Moebi\
  us(l)*f0(x^(1/l))/l, l = 1 .. trunc(ln(1000)/ln(2))+1) end proc
P3 := plot(RR0(x), x = 880 .. 930);
NULL;
display([P1, P2, P3]);
P4 := plot(RR10(x), x = 880 .. 930);
display([P1, P2, P3, P4], color = [green, blue, purple, yellow]);
evalf(Li(2)), evalf(ln(2));
                   1.045163780, 0.6931471806
evalf(li(2));
                             li(2)
evalf(Ei(2));
                          4.954234356
evalf(Int(1/ln(t), t = 0 .. 2));
                        Float(undefined)
evalf(Ei(ln(2)));
                          1.045163780
Li(1000.);
                          177.6096580
isprime, [$ (1 .. 100)];
isprime, [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16,
  17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32,
  33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48,
  49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64,
  65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80,
  81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96,
  97, 98, 99, 100]
nops(select(isprime, [$ (1 .. 100)]));
                               25
theta[1];
                           14.134725
evalf(Ei((1/2 + theta[1]*I)*ln(x)));
             Ei((0.5000000000 + 14.134725 I) ln(x))
evalf(Ei(ln(1/2 + theta[1]*I)));
                  4.386989035 + 6.632175089 I
plot(Li(x), x = 0 .. 5);
Let
                              "a"
                              "b"
 be real numbers and
"A = Matrix(3, 3, [[a, a - 1, -b], [a - 1, a, -b], [b, b, 2*a -
   1]])"
                              "B="
 "Matrix(5, 5, [[0, a, 3, 0, a], [3, 0, 0, b, 0], [0, 1, b, 0,
    1], [b, 0, 0, 1, 0], [0, a, 1, 0, b]])"
(a) Show that if
                            "0 <= a"
                            "a <= 1"
                      "b^2 = 2*a*(1 - a)"
, then A is an orthogonal matrix with determinant equal to one.
(b) For what values of a and b is the matrix B singular? Determine the inverse of B (for those values of a and b for which B is invertible).
Find all rational function solutions to the Kadomtsev-Petviashvili equation
(&PartialD;)/(&PartialD;x);
diff(u, t) + 6*u*diff(u, x) + diff(u, x, x, x) - diff(u, y, y) = 0;
by u = 2
diff(ln, x, x)*f;
=(2 (((&PartialD;)^2)/(&PartialD;x^2) f) f-2 ((&PartialD;)/(&PartialD;x) f)^2)/(f^2);
 with
f;
(a[1 ]x+a[2] y+a[3] t+a[4])^2+(a[5] x+ a[6] y+a[7] t+a[8])^2+a[9], ;
where
a[i], i=1..9, ;
are real constants.
How to find the values of X(1),X(2),..&Y(1),Y(2)...Plese help .
for k from 0 to 5 do
X(k+1):=solve(2*(k+1)*X(k+1)+(k+1)*Y(k+1)-X(k)-Y(k)+(1)/k!,X(k+1));
Y(k+1):=solve((k+1)*X(k+1)+(k+1)*Y(k+1)+2*X(k)+Y(k)+(1)/k!,Y(k+1)); od;
Error, (in solve) a constant is invalid as a variable, -(1/2)*Y(1)+1
Download DE_Using_DTM-Ex-3(1).mw
The serie is :Sum(-5*3^(-k - 1)*(x - 2)^k, k = 0 .. infinity)
How to simplify (with collect ? with convert ?...) this expression to get this more "traditionnal" writing :
-5/3*sum(((x - 2)/3^k)^k, k = 0 .. infinity)
Thank you for your help.
To Maple support:
I see 2 problems here. Maple solves the ode using series method.
First problem: Using odetest shows the syntax according to help does not work. Which is
           odetest(sol, ODE, series, point = 0);
The above gives internal error.
When changing to the following syntax
         odetest(sol,ODE,type='series',point=0);
No internal error.
So help page should be corrected.
The second problem is that Maple odetest does not return 0 on its own solution. I verified manually that the solution is correct actually. So I do not know why maple does not return zero here. Simplfication does not help.
`Standard Worksheet Interface, Maple 2022.0, Windows 10, March 8 2022 Build ID 1599809`
Order:=6;
ode:=x^2*diff(diff(y(x),x),x)+x^2*diff(y(x),x)+y(x) = 0;
maple_sol:=dsolve(ode,y(x),type='series',x=0):
odetest(maple_sol,ode,series,point=0);
odetest(maple_sol,ode,'series',point=0);
6
x^2*(diff(diff(y(x), x), x))+x^2*(diff(y(x), x))+y(x) = 0
Error, (in odetest/series) complex argument to max/min: 13/2-1/2*I*3^(1/2)
odetest(maple_sol,ode,type='series',point=0); #This should return zero, but it does not.
-I*3^(1/2)*x^(3/2-((1/2)*I)*3^(1/2))*(series(-1/2-(I*3^(1/2)/((I*3^(1/2)-1)*(I*3^(1/2)-2)))*x-((1/4)*((5*I)*3^(1/2)+3)/((I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^2-((1/6)*((8*I)*3^(1/2)+9)/((I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^3-((7/16)*((3*I)*3^(1/2)+5)/((I*3^(1/2)-5)*(I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^4+O(x^5),x,5))*_C1+((1/2)*I)*3^(1/2)*x^(3/2+((1/2)*I)*3^(1/2))*(series(1-(1/2)*x+(((1/2)*I)*3^(1/2)/((1+I*3^(1/2))*(I*3^(1/2)+2)))*x^2-((1/12)*((5*I)*3^(1/2)-3)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)))*x^3+((1/24)*(-9+(8*I)*3^(1/2))/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)))*x^4-((7/80)*((3*I)*3^(1/2)-5)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)*(I*3^(1/2)+5)))*x^5+O(x^6),x,6))*_C2+_C1*x^(5/2-((1/2)*I)*3^(1/2))*(series(-I*3^(1/2)/((I*3^(1/2)-1)*(I*3^(1/2)-2))-((1/2)*((5*I)*3^(1/2)+3)/((I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x-((1/2)*((8*I)*3^(1/2)+9)/((I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^2-((7/4)*((3*I)*3^(1/2)+5)/((I*3^(1/2)-5)*(I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^3+O(x^4),x,4))+_C2*x^(5/2+((1/2)*I)*3^(1/2))*(series(I*3^(1/2)/((1+I*3^(1/2))*(I*3^(1/2)+2))-((1/2)*((5*I)*3^(1/2)-3)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)))*x+((1/2)*(-9+(8*I)*3^(1/2))/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)))*x^2-((7/4)*((3*I)*3^(1/2)-5)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)*(I*3^(1/2)+5)))*x^3+O(x^4),x,4))+_C1*x^(3/2-((1/2)*I)*3^(1/2))*(series(-1/2-(I*3^(1/2)/((I*3^(1/2)-1)*(I*3^(1/2)-2)))*x-((1/4)*((5*I)*3^(1/2)+3)/((I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^2-((1/6)*((8*I)*3^(1/2)+9)/((I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^3-((7/16)*((3*I)*3^(1/2)+5)/((I*3^(1/2)-5)*(I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^4+O(x^5),x,5))+_C2*x^(3/2+((1/2)*I)*3^(1/2))*(series(-1/2+(I*3^(1/2)/((1+I*3^(1/2))*(I*3^(1/2)+2)))*x-((1/4)*((5*I)*3^(1/2)-3)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)))*x^2+((1/6)*(-9+(8*I)*3^(1/2))/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)))*x^3-((7/16)*((3*I)*3^(1/2)-5)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)*(I*3^(1/2)+5)))*x^4+O(x^5),x,5))-((1/2)*I)*3^(1/2)*x^(3/2-((1/2)*I)*3^(1/2))*(series(1-(1/2)*x-(((1/2)*I)*3^(1/2)/((I*3^(1/2)-1)*(I*3^(1/2)-2)))*x^2-((1/12)*((5*I)*3^(1/2)+3)/((I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^3-((1/24)*((8*I)*3^(1/2)+9)/((I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^4-((7/80)*((3*I)*3^(1/2)+5)/((I*3^(1/2)-5)*(I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^5+O(x^6),x,6))*_C1+I*3^(1/2)*x^(3/2+((1/2)*I)*3^(1/2))*(series(-1/2+(I*3^(1/2)/((1+I*3^(1/2))*(I*3^(1/2)+2)))*x-((1/4)*((5*I)*3^(1/2)-3)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)))*x^2+((1/6)*(-9+(8*I)*3^(1/2))/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)))*x^3-((7/16)*((3*I)*3^(1/2)-5)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)*(I*3^(1/2)+5)))*x^4+O(x^5),x,5))*_C2+x^(5/2-((1/2)*I)*3^(1/2))*(series(-1/2-(I*3^(1/2)/((I*3^(1/2)-1)*(I*3^(1/2)-2)))*x-((1/4)*((5*I)*3^(1/2)+3)/((I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^2-((1/6)*((8*I)*3^(1/2)+9)/((I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^3-((7/16)*((3*I)*3^(1/2)+5)/((I*3^(1/2)-5)*(I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^4+O(x^5),x,5))*_C1+x^(5/2+((1/2)*I)*3^(1/2))*(series(-1/2+(I*3^(1/2)/((1+I*3^(1/2))*(I*3^(1/2)+2)))*x-((1/4)*((5*I)*3^(1/2)-3)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)))*x^2+((1/6)*(-9+(8*I)*3^(1/2))/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)))*x^3-((7/16)*((3*I)*3^(1/2)-5)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)*(I*3^(1/2)+5)))*x^4+O(x^5),x,5))*_C2+(1/2)*x^(3/2-((1/2)*I)*3^(1/2))*(series(1-(1/2)*x-(((1/2)*I)*3^(1/2)/((I*3^(1/2)-1)*(I*3^(1/2)-2)))*x^2-((1/12)*((5*I)*3^(1/2)+3)/((I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^3-((1/24)*((8*I)*3^(1/2)+9)/((I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^4-((7/80)*((3*I)*3^(1/2)+5)/((I*3^(1/2)-5)*(I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^5+O(x^6),x,6))*_C1+(1/2)*x^(3/2+((1/2)*I)*3^(1/2))*(series(1-(1/2)*x+(((1/2)*I)*3^(1/2)/((1+I*3^(1/2))*(I*3^(1/2)+2)))*x^2-((1/12)*((5*I)*3^(1/2)-3)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)))*x^3+((1/24)*(-9+(8*I)*3^(1/2))/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)))*x^4-((7/80)*((3*I)*3^(1/2)-5)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)*(I*3^(1/2)+5)))*x^5+O(x^6),x,6))*_C2
Download problems_with_series_solution.mw
I want to use this L3 list as the index of another list. I am trying to create a model for short time electricity load forecasting in Maple. I am fairly new to maple coding structures. Can anybody suggest an easier way for doing this kind of thing in Maple? Can I use matrix generation? Please give me suggestions.
Note: Currently working in a Doc File.
The code is pasted below:
L1 := [seq([seq(seq1[i], i = 1 .. 7)], i = 1 .. 24)];
L2 := [seq(i, i = 1 .. 24)];
local(i, j, L3);
L3 = [];
for i to 24 do
    for j to 7 do if i = 1 then L3[i][j] := L1[i][j]; else L3[i][j] := L1[i][j] + L2[i] - 1; end if; end do;
print(L3);
How can I found the area of the region bounded by
y=e^xcos(x), y=o, x=−π/2, x= π/2 ?
I have an example where I try to calculate an infinite sum (G&R1.641.1)  in Maple 2022 (or 2021).  I get a different numerical result when I evaluate the sum if I express the coefficients c(m) in the sum using Maple's doublefactorial function for m!! (c1(m)) or the equivalent expression involving the factorial function (c2(m)).  Only the latter gives the correct value for the sum.  This happens even though Maple gives the same numerical value for the coefficients c1(m) and c2(m).  What's going on?? Please see the attached spreadsheet.
Download doublefactorial_test.mw
I solved a linear system using Jacobi method , then I plot the solution, someting is wrong, I can't plot the solution
jacobi.mw
I have the following expression (result of a calculation):
(1/1296)*cBooP0-(1/1296)*cSRP0-(1/1296)*tStartRamp*f__SR/N
Rather obviously the common factor 1/1296 can be factored out, except I cannot get Maple to factor the 1/1296 without also factoring out N, which I do not want. My desired end result is this:
(1/1296)*(cBooP0-cSRP0-tStartRamp*f__SR/N)
I don't seem to be able to coerce Maple to do this. I can freeze the tStartRamp*f__SR/N term (leaving the 1/1296 unfrozen), but in that case I don't get Maple to pull the 1/1296 factor out at all.
Any hint would be appreciated. I am doing this on Maple 2015. It is really a bit cosmetic, but sometimes I use Maple to write "smart" documentation & then I'd like to end up with a somewhat polished result.
Mac Dude
First 346 347 348 349 350 351 352 Last Page 348 of 2458
