j'ai deux spheres concentriques s1 et s2  de centre O(-1,-1,-1) de rayon respectivement 3 et 2. mais maple donne que FindAngle(s1,s2)=arcos(31/12). comment expliquez ceçi et merci beaucoup.
PDETWOSTEPVARIAMETHOD.mwPDETWOSTEPVARIAMETHOD.mw
Pls i need help to correct this iteration code, I wrote but is not given the correct answer. find attached the worksheet
Hi again everybody,
I hope this can help in some classrooms.
This procedure has some warnings.  Someone else can clean it up.
Also, the ithprime() command can make it a bit slicker.
I did work with prime constelations project, and you can see my web page at mattanderson.fun  .
Refference oeis.org/A40 .
Some prime constelations, and k-tuples, are not of 'general intrest' yet, so they are not in the OEIS encyclopedia YET!
But prime numbers are exciting.  I like doing calculations.
Hopefully someone in the next generation will take up an intrest and do what I did.
pairs_procedure.mw
pairs_procedure.pdf
I wish the best on all of you.
Matt C. Anderson
which kind of input is DeepLearning:-Optimizer(GradientDescent()) suppose to take? Nummeric value or function?
I am fairly new to maple and needing to use it for my project this year. I have been advised to use it to help solve the following integral:
int(2/(1-x^p)^(1/p), x=0..1)
It will give me the answer I am looking for, however I cannot get it to explain the steps to get the answer. I have tried Student Calculus1 and ShowSolution but neither of them seem to be working.
Any help would be really appreiacted!
When plotting for exampe 1/x, can I make the x-axis show 1/10, 2/10, 3/10 and so forth instead of 0.1, 0.2, 0.3?
i wanna build an integrated circuit by digital block of electrical in maplesim. i know the input of digital items should be a vector, but i dont know how to build a vector in maplesim. for example, how to build a simple gate circuit in maplesim? Maybe i should use the modelica to do it?
 i use maplesim 2020.
Hello Sir
Hope you are fine. I am facing issues in integration evaluations. I have attched code and pic as well. Kindly guide me. I am waiting for your kind response.
question.mw
restart; printlevel := 4; kernelopts(version)
{--> enter Terminate, args =
<-- exit Terminate (now at top level) = }
{--> enter ModuleUnload, args =
<-- exit ModuleUnload (now at top level) = }
{--> enter OnUnload, args =
<-- exit OnUnload (now at top level) = }
`Maple 2015.0, X86 64 WINDOWS, Feb 17 2015, Build ID 1022128`
L[time] := 1:
ff11 := cos(1.0*k*(p+q+x+t)):
JJx11 := QQ*(int(int(p*ff11/`&gamma;&gamma;Exact`, p), q))/m;
175631174533.479692645444566411*(int(int(0.273299999999999999999999999999e-21*p*cos(.50*p+.50*q+.50*x+.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2), p), q))
evalf(IntegrationTools:-Expand(%));
int(int(p*ff11/`&gamma;&gamma;Exact`, p = 0 .. 1), q = 0 .. 1); evalf(IntegrationTools:-Expand(%))
int(int(0.273299999999999999999999999999e-21*p*cos(.50*p+.50*q+.50*x+.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2), p = 0 .. 1), q = 0 .. 1)
0.273299999999999999999999999999e-21*(Int(Int(p*cos(.50*p)*cos(.50*q)*cos(.50*x)*cos(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)-1.*p*cos(.50*p)*cos(.50*q)*sin(.50*x)*sin(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)-1.*p*cos(.50*p)*sin(.50*q)*sin(.50*x)*cos(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)-1.*p*cos(.50*p)*sin(.50*q)*cos(.50*x)*sin(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)-1.*p*sin(.50*p)*sin(.50*q)*cos(.50*x)*cos(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)+p*sin(.50*p)*sin(.50*q)*sin(.50*x)*sin(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)-1.*p*sin(.50*p)*cos(.50*q)*sin(.50*x)*cos(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2)-1.*p*sin(.50*p)*cos(.50*q)*cos(.50*x)*sin(.50*t)/(p^2+q^2+0.746928900000000000000000000000e-43)^(1/2), p = 0. .. 1.), q = 0. .. 1.))
Download question.mw
i use dslove command to solve system of differential equations but got an error, i checked the error but i don't know where i went wrong, please help me!
error: Error, (in dsolve/numeric/process_input) system must be entered as a set/list of expressions/equations
HOI.mw
In Maple what is the fastest way to convert a directed line segment into a vector? Please help me. Thank you a lot.
I have an assignment for my class but I don't know how to get the answer without getting an error. Maple_2.mw
Vector Valued Functions
Level Sets of Scalar Valued Functions
This worksheet is meant to give you some tools that you can use to
explore vector valued functions and scalar valued functions of several variables.
We will use the Student[VectorCalculus]  and the plots  packages.
First we load the packages with a restart at the beginning.  That is
meant to make it easier to check what happens when you run your
solutions.
with(Student:-VectorCalculus);
BasisFormat(false):
with(plottools):
Deivatives and integrals for vector valued functions
Plotting velocity and acceleration along a curve
Plotting functions of two variables and contours.
Exercises
Download Maple_2.mw
I have a finite set, I would like to compute all possible sigma algebra
Using the following code ( thanks to vv), for helping me to use this code:
sigma_algebra_all.mw
This code give me the sigma algebra if I fix the generator of the sigma algebra, How can I find all possible sigma algebra in the global set {1,2,3}
I have a problem with maple. I used to work with maple until 2019. Now I installed Maple 2021 and I wanted to plot something, but it didn't worked anymore. I have problems to plot anything. When I try to plot something, maple only writes a very long list instead of a graphic. Here you can see, what I wrote in the worksheet:
plot(x^2,x=0..2);
INTERFACE_PLOT(CURVES(Matrix(200,2,{(2, 1) = HFloat(.105152100502512568e-1), (2
, 2) = HFloat(.110569642400905045e-3), (3, 1) = HFloat(.196644380904522631e-1),
(3, 2) = HFloat(.386690125413229849e-3), (4, 1) = HFloat(.299537019095477385e-1
), (4, 2) = HFloat(.897224258086043816e-3), (5, 1) = HFloat(.403111696482412116\
e-1), (5, 2) = HFloat(.162499039840928341e-2), (6, 1) = HFloat(.\
506194101507537672e-1), (6, 2) = HFloat(.256232468401023337e-2), (7, 1) =
HFloat(.601764686432160745e-1), (7, 2) = HFloat(.362120737836796758e-2), (8, 1)
= HFloat(.700722491457286406e-1), (8, 2) = HFloat(.491012010034106838e-2), (9,
1) = HFloat(.803064794974874402e-1), (9, 2) = HFloat(.644913064928037075e-2), (
10, 1) = HFloat(.905078885427135632e-1), (10, 2) = HFloat(.819167788846026160e-\
2), (11, 1) = HFloat(.101001291658291470), (11, 2) = HFloat(.102012609166432580\
e-1), (12, 1) = HFloat(.110243886834170857), (12, 2) = HFloat(.\
121537145843054698e-1), (13, 1) = HFloat(.120648859899497501), (13, 2) = HFloat
(.145561473950485756e-1), (14, 1) = HFloat(.131096556783919599), (14, 2) =
HFloat(.171863072005994551e-1), (15, 1) = HFloat(.141164848643216101), (15, 2)
= HFloat(.199275144924621096e-1), (16, 1) = HFloat(.150307822211055264), (16, 2
) = HFloat(.225924414178301988e-1), (17, 1) = HFloat(.161179702110552769), (17,
2) = HFloat(.259788963724465298e-1), (18, 1) = HFloat(.170389610452261309), (18
, 2) = HFloat(.290326193500733548e-1), (19, 1) = HFloat(.181102923316582926), (
19, 2) = HFloat(.327982688338121151e-1), (20, 1) = HFloat(.190586020502512554),
(20, 2) = HFloat(.363230312109841386e-1), (21, 1) = HFloat(.200990481105527641)
, (21, 2) = HFloat(.403971734950314618e-1), (22, 1) = HFloat(.21089798804020101\
8), (22, 2) = HFloat(.444779613594047732e-1), (23, 1) = HFloat(.221235432160804\
046), (23, 2) = HFloat(.489451164433777272e-1), (24, 1) = HFloat(.2307284328643\
21625), (24, 2) = HFloat(.532356097320257696e-1), (25, 1) = HFloat(.24096791658\
2914582), (25, 2) = HFloat(.580655368223104776e-1), (26, 1) = HFloat(.251603862\
412060286), (26, 2) = HFloat(.633045035806669570e-1), (27, 1) = HFloat(.2608624\
84522613070), (27, 2) = HFloat(.680492358313105478e-1), (28, 1) = HFloat(.27086\
2050050251268), (28, 2) = HFloat(.733662501574248171e-1), (29, 1) = HFloat(.281\
192579698492429), (29, 2) = HFloat(.790692668774930219e-1), (30, 1) = HFloat(.2\
91298987537688459), (30, 2) = HFloat(.848551001404823785e-1), (31, 1) = HFloat(
.301077456783919617), (31, 2) = HFloat(.906476349834729883e-1), (32, 1) =
HFloat(.311934779698492481), (32, 2) = HFloat(.973033067855470363e-1), (33, 1)
= HFloat(.321690567236180891), (33, 2) = HFloat(.103484821048735812), (34, 1) =
HFloat(.332106952763819130), (34, 2) = HFloat(.110295028074069587), (35, 1) =
HFloat(.341545746231155745), (35, 2) = HFloat(.116653496768597043), (36, 1) =
HFloat(.351864840603015094), (36, 2) = HFloat(.123808866052585217), (37, 1) =
HFloat(.361574304221105480), (37, 2) = HFloat(.130735977472976550), (38, 1) =
HFloat(.371723491356783953), (38, 2) = HFloat(.138178354026477046), (39, 1) =
HFloat(.381646176884422095), (39, 2) = HFloat(.145653804330495601), (40, 1) =
HFloat(.392034309045226126), (40, 2) = HFloat(.153690899468567871), (41, 1) =
HFloat(.402039314974874384), (41, 2) = HFloat(.161635610785466260), (42, 1) =
HFloat(.412270878592964851), (42, 2) = HFloat(.169967277335815153), (43, 1) =
HFloat(.422417719698492511), (43, 2) = HFloat(.178436729915274178), (44, 1) =
HFloat(.431741612864321611), (44, 2) = HFloat(.186400820278685764), (45, 1) =
HFloat(.442427846633165867), (45, 2) = HFloat(.195742399476460133), (46, 1) =
HFloat(.451985741507537675), (46, 2) = HFloat(.204291110526118674), (47, 1) =
HFloat(.462176450954773888), (47, 2) = HFloat(.213607071817150523), (48, 1) =
HFloat(.471930260201005036), (48, 2) = HFloat(.222718170493388323), (49, 1) =
HFloat(.482760611859296529), (49, 2) = HFloat(.233057808362762353), (50, 1) =
HFloat(.492138900603015073), (50, 2) = HFloat(.242200697486744360), (51, 1) =
HFloat(.502783342211055251), (51, 2) = HFloat(.252791089204919106), (52, 1) =
HFloat(.512484595175879409), (52, 2) = HFloat(.262640460292584976), (53, 1) =
HFloat(.523096241306532650), (53, 2) = HFloat(.273629677669022242), (54, 1) =
HFloat(.532252297286432086), (54, 2) = HFloat(.283292507966684481), (55, 1) =
HFloat(.542679976281407073), (55, 2) = HFloat(.294501556656788566), (56, 1) =
HFloat(.552752599396984956), (56, 2) = HFloat(.305535436140123740), (57, 1) =
HFloat(.562818642311557871), (57, 2) = HFloat(.316764824133425327), (58, 1) =
HFloat(.572847654070351764), (58, 2) = HFloat(.328154434773905379), (59, 1) =
HFloat(.582482394673366821), (59, 2) = HFloat(.339285740104419864), (60, 1) =
HFloat(.592897804422110597), (60, 2) = HFloat(.351527806488559302), (61, 1) =
HFloat(.602824445125628161), (61, 2) = HFloat(.363397311641021459), (62, 1) =
HFloat(.613271767035175941), (62, 2) = HFloat(.376102260242447139), (63, 1) =
HFloat(.622729109145728654), (63, 2) = HFloat(.387791543377432824), (64, 1) =
HFloat(.633181242613065298), (64, 2) = HFloat(.400918485997025453), (65, 1) =
HFloat(.643192565125628168), (65, 2) = HFloat(.413696675832885441), (66, 1) =
HFloat(.653179519798995023), (66, 2) = HFloat(.426643485084845731), (67, 1) =
HFloat(.663610932663316611), (67, 2) = HFloat(.440379469950276936), (68, 1) =
HFloat(.673218644723618143), (68, 2) = HFloat(.453223343603505191), (69, 1) =
HFloat(.683058256080402049), (69, 2) = HFloat(.466568581199600096), (70, 1) =
HFloat(.693922356180904587), (70, 2) = HFloat(.481528236407658183), (71, 1) =
HFloat(.703758908944723593), (71, 2) = HFloat(.495276601919067749), (72, 1) =
HFloat(.713818626633165865), (72, 2) = HFloat(.509537031728459100), (73, 1) =
HFloat(.724049100402010093), (73, 2) = HFloat(.524247099792960136), (74, 1) =
HFloat(.733452896582914682), (74, 2) = HFloat(.537953151505867755), (75, 1) =
HFloat(.743477038793969869), (75, 2) = HFloat(.552758107213850214), (76, 1) =
HFloat(.753424876582914571), (76, 2) = HFloat(.567649044653980028), (77, 1) =
HFloat(.764065970854271415), (77, 2) = HFloat(.583796807817480334), (78, 1) =
HFloat(.773456275577889429), (78, 2) = HFloat(.598234610230820030), (79, 1) =
HFloat(.784290737889447254), (79, 2) = HFloat(.615111961539173691), (80, 1) =
HFloat(.794068004824120544), (80, 2) = HFloat(.630543996285359509), (81, 1) =
HFloat(.803742099396984933), (81, 2) = HFloat(.646001362343072816), (82, 1) =
HFloat(.814144858894472301), (82, 2) = HFloat(.662831851264300220), (83, 1) =
HFloat(.824589699698492495), (83, 2) = HFloat(.679948172848850008), (84, 1) =
HFloat(.834092958291457243), (84, 2) = HFloat(.695711063071394631), (85, 1) =
HFloat(.844184996783919672), (85, 2) = HFloat(.712648308795066465), (86, 1) =
HFloat(.854033840000000044), (86, 2) = HFloat(.729373799865145722), (87, 1) =
HFloat(.864710089949748739), (87, 2) = HFloat(.747723539660902548), (88, 1) =
HFloat(.873948014472361812), (88, 2) = HFloat(.763785132000183498), (89, 1) =
HFloat(.884558106633165808), (89, 2) = HFloat(.782443044010451172), (90, 1) =
HFloat(.894532151055276392), (90, 2) = HFloat(.800187769271579863), (91, 1) =
HFloat(.904409857085427094), (91, 2) = HFloat(.817957189593282674), (92, 1) =
HFloat(.914295420904522649), (92, 2) = HFloat(.835936116686978203), (93, 1) =
HFloat(.924378070251256290), (93, 2) = HFloat(.854474816761436551), (94, 1) =
HFloat(.935065509648241200), (94, 2) = HFloat(.874347507333725016), (95, 1) =
HFloat(.944864845025125577), (95, 2) = HFloat(.892769575364354528), (96, 1) =
HFloat(.954538047336683348), (96, 2) = HFloat(.911142883813328308), (97, 1) =
HFloat(.964878541407035106), (97, 2) = HFloat(.930990599667767538), (98, 1) =
HFloat(.975196525125628155), (98, 2) = HFloat(.951008262617099920), (99, 1) =
HFloat(.984457528241206137), (99, 2) = HFloat(.969156624910785136), (100, 1) =
HFloat(.995427854271356827), (100, 2) = HFloat(.990876613059277656), (101, 1) =
HFloat(1.00460731437185924), (101, 2) = HFloat(1.00923585608943966), (102, 1) =
HFloat(1.01534372402010042), (102, 2) = HFloat(1.03092287790700587), (103, 1) =
HFloat(1.02559058693467331), (103, 2) = HFloat(1.05183605200900776), (104, 1) =
HFloat(1.03473981497487433), (104, 2) = HFloat(1.07068648469423722), (105, 1) =
HFloat(1.04502907879397000), (105, 2) = HFloat(1.09208577552497355), (106, 1) =
HFloat(1.05538654653266328), (106, 2) = HFloat(1.11384076260214138), (107, 1) =
HFloat(1.06569478703517584), (107, 2) = HFloat(1.13570537911394887), (108, 1) =
HFloat(1.07525184552763808), (108, 2) = HFloat(1.15616653131059177), (109, 1) =
HFloat(1.08514762603015091), (109, 2) = HFloat(1.17754537027887229), (110, 1) =
HFloat(1.09538185638190955), (110, 2) = HFloat(1.19986141129067825), (111, 1) =
HFloat(1.10558326542713559), (111, 2) = HFloat(1.22231435679252809), (112, 1) =
HFloat(1.11607666854271348), (112, 2) = HFloat(1.24562713006540182), (113, 1) =
HFloat(1.12531926371859292), (113, 2) = HFloat(1.26634344529615617), (114, 1) =
HFloat(1.13572423678391954), (114, 2) = HFloat(1.28986954201841653), (115, 1) =
HFloat(1.14617193366834180), (115, 2) = HFloat(1.31371010152902579), (116, 1) =
HFloat(1.15624022552763828), (116, 2) = HFloat(1.33689145912820373), (117, 1) =
HFloat(1.16538319909547727), (117, 2) = HFloat(1.35811800073400879), (118, 1) =
HFloat(1.17625507899497483), (118, 2) = HFloat(1.38357601086147453), (119, 1) =
HFloat(1.18546498733668337), (119, 2) = HFloat(1.40532723620116284), (120, 1) =
HFloat(1.19617830020100513), (120, 2) = HFloat(1.43084252587176586), (121, 1) =
HFloat(1.20566139738693479), (121, 2) = HFloat(1.45361940514901633), (122, 1) =
HFloat(1.21606585798994971), (122, 2) = HFloat(1.47881617096883256), (123, 1) =
HFloat(1.22597336492462317), (123, 2) = HFloat(1.50301069150460331), (124, 1) =
HFloat(1.23631080904522617), (124, 2) = HFloat(1.52846441656206178), (125, 1) =
HFloat(1.24580380974874383), (125, 2) = HFloat(1.55202713238448431), (126, 1) =
HFloat(1.25604329346733667), (126, 2) = HFloat(1.57764475506427404), (127, 1) =
HFloat(1.26667923929648252), (127, 2) = HFloat(1.60447629526471558), (128, 1) =
HFloat(1.27593786140703536), (128, 2) = HFloat(1.62801742617195888), (129, 1) =
HFloat(1.28593742693467328), (129, 2) = HFloat(1.65363506599136811), (130, 1) =
HFloat(1.29626795658291449), (130, 2) = HFloat(1.68031061526364467), (131, 1) =
HFloat(1.30637436442211063), (131, 2) = HFloat(1.70661398001927345), (132, 1) =
HFloat(1.31615283366834168), (132, 2) = HFloat(1.73225828157320549), (133, 1) =
HFloat(1.32701015658291466), (133, 2) = HFloat(1.76095595567421159), (134, 1) =
HFloat(1.33676594412060301), (134, 2) = HFloat(1.78694318936064711), (135, 1) =
HFloat(1.34718232964824125), (135, 2) = HFloat(1.81490022931646267), (136, 1) =
HFloat(1.35662112311557781), (136, 2) = HFloat(1.84042087168337165), (137, 1) =
HFloat(1.36694021748743699), (137, 2) = HFloat(1.86852555818460164), (138, 1) =
HFloat(1.37664968110552777), (138, 2) = HFloat(1.89516434448795135), (139, 1) =
HFloat(1.38679886824120602), (139, 2) = HFloat(1.92321110095508985), (140, 1) =
HFloat(1.39672155376884422), (140, 2) = HFloat(1.95083109876245442), (141, 1) =
HFloat(1.40710968592964836), (141, 2) = HFloat(1.97995766823703367), (142, 1) =
HFloat(1.41711469185929650), (142, 2) = HFloat(2.00821404988346908), (143, 1) =
HFloat(1.42734625547738680), (143, 2) = HFloat(2.03731733302531737), (144, 1) =
HFloat(1.43749309658291469), (144, 2) = HFloat(2.06638640272353680), (145, 1) =
HFloat(1.44681698974874351), (145, 2) = HFloat(2.09327940182561578), (146, 1) =
HFloat(1.45750322351758776), (146, 2) = HFloat(2.12431564656415928), (147, 1) =
HFloat(1.46706111839195996), (147, 2) = HFloat(2.15226832509746835), (148, 1) =
HFloat(1.47725182783919595), (148, 2) = HFloat(2.18227296285424543), (149, 1) =
HFloat(1.48700563708542721), (149, 2) = HFloat(2.21118576472383710), (150, 1) =
HFloat(1.49783598874371848), (150, 2) = HFloat(2.24351264917587256), (151, 1) =
HFloat(1.50721427748743708), (151, 2) = HFloat(2.27169487826197702), (152, 1) =
HFloat(1.51785871909547732), (152, 2) = HFloat(2.30389509113416313), (153, 1) =
HFloat(1.52755997206030147), (153, 2) = HFloat(2.33343946824086901), (154, 1) =
HFloat(1.53817161819095460), (154, 2) = HFloat(2.36597192700818004), (155, 1) =
HFloat(1.54732767417085437), (155, 2) = HFloat(2.39422293125498564), (156, 1) =
HFloat(1.55775535316582903), (156, 2) = HFloat(2.42660174031679654), (157, 1) =
HFloat(1.56782797628140713), (157, 2) = HFloat(2.45808456321065272), (158, 1) =
HFloat(1.57789401919598005), (158, 2) = HFloat(2.48974953581444369), (159, 1) =
HFloat(1.58792303095477383), (159, 2) = HFloat(2.52149955223659550), (160, 1) =
HFloat(1.59755777155778911), (160, 2) = HFloat(2.55219083346468922), (161, 1) =
HFloat(1.60797318130653277), (161, 2) = HFloat(2.58557775180105187), (162, 1) =
HFloat(1.61789982201005023), (162, 2) = HFloat(2.61759983406015229), (163, 1) =
HFloat(1.62834714391959801), (163, 2) = HFloat(2.65151442111111191), (164, 1) =
HFloat(1.63780448603015083), (164, 2) = HFloat(2.68240353446048641), (165, 1) =
HFloat(1.64825661949748747), (165, 2) = HFloat(2.71674988371728521), (166, 1) =
HFloat(1.65826794201005034), (166, 2) = HFloat(2.74985256749824769), (167, 1) =
HFloat(1.66825489668341720), (167, 2) = HFloat(2.78307440030819908), (168, 1) =
HFloat(1.67868630954773868), (168, 2) = HFloat(2.81798772586300617), (169, 1) =
HFloat(1.68829402160804021), (169, 2) = HFloat(2.85033670339744960), (170, 1) =
HFloat(1.69813363296482422), (170, 2) = HFloat(2.88365783540631249), (171, 1) =
HFloat(1.70899773306532654), (171, 2) = HFloat(2.92067325162242497), (172, 1) =
HFloat(1.71883428582914588), (172, 2) = HFloat(2.95439130214179002), (173, 1) =
HFloat(1.72889400351758793), (173, 2) = HFloat(2.98907447539907345), (174, 1) =
HFloat(1.73912447728643227), (174, 2) = HFloat(3.02455394749680639), (175, 1) =
HFloat(1.74852827346733686), (175, 2) = HFloat(3.05735112311466573), (176, 1) =
HFloat(1.75855241567839204), (176, 2) = HFloat(3.09250659868830802), (177, 1) =
HFloat(1.76850025346733686), (177, 2) = HFloat(3.12759314651403475), (178, 1) =
HFloat(1.77914134773869348), (178, 2) = HFloat(3.16534393523345470), (179, 1) =
HFloat(1.78853165246231161), (179, 2) = HFloat(3.19884547185956691), (180, 1) =
HFloat(1.79936611477386954), (180, 2) = HFloat(3.23771841499641022), (181, 1) =
HFloat(1.80914338170854272), (181, 2) = HFloat(3.27299977557982169), (182, 1) =
HFloat(1.81881747628140711), (182, 2) = HFloat(3.30809701202666684), (183, 1) =
HFloat(1.82922023577889470), (183, 2) = HFloat(3.34604667098299524), (184, 1) =
HFloat(1.83966507658291456), (184, 2) = HFloat(3.38436759399882092), (185, 1) =
HFloat(1.84916833517587942), (185, 2) = HFloat(3.41942353181713354), (186, 1) =
HFloat(1.85926037366834174), (186, 2) = HFloat(3.45684913709334163), (187, 1) =
HFloat(1.86910921688442211), (187, 2) = HFloat(3.49356926464229778), (188, 1) =
HFloat(1.87978546683417092), (188, 2) = HFloat(3.53359340132096200), (189, 1) =
HFloat(1.88902339135678377), (189, 2) = HFloat(3.56840937309308481), (190, 1) =
HFloat(1.89963348351758787), (190, 2) = HFloat(3.60860737170116597), (191, 1) =
HFloat(1.90960752793969868), (191, 2) = HFloat(3.64660091076396720), (192, 1) =
HFloat(1.91948523396984938), (192, 2) = HFloat(3.68442356342828736), (193, 1) =
HFloat(1.92937079778894471), (193, 2) = HFloat(3.72247167536074919), (194, 1) =
HFloat(1.93945344713567835), (194, 2) = HFloat(3.76147967360646573), (195, 1) =
HFloat(1.95014088653266326), (195, 2) = HFloat(3.80304947732640164), (196, 1) =
HFloat(1.95994022190954786), (196, 2) = HFloat(3.84136567345884794), (197, 1) =
HFloat(1.96961342422110564), (197, 2) = HFloat(3.87937704087198920), (198, 1) =
HFloat(1.97995391829145739), (198, 2) = HFloat(3.92021751855769507), (199, 1) =
HFloat(1.99027190201005011), (199, 2) = HFloat(3.96118224393070228), (200, 1) =
HFloat(2.), (200, 2) = HFloat(4.)},datatype = float[8],storage = rectangular,
order = Fortran_order,shape = []),COLOUR(RGB,.47058824,0.,.54901961e-1,
_ATTRIBUTE("source" = "mathdefault"))),AXESLABELS(x,""),VIEW(0. .. 2.,DEFAULT,
I also opened an old worksheet with plots and pressed the "!!!" buttom, but maple didn't plotted anything, but 3 years ago, it worked with the old version of maple.  Does anybody knows what the problem is?
I'm struggling with following simple problem which I however cannot seem to implement easily in Maple:
  • I have 2 different periodic functions: f1 and f2, each time in  variables x and t.
  • On the second function f2 a duty cycle with period T and fraction q should need to be applied so that:
    • during the DUTY (=ON or 1) part of this period, so from 0 -> q*T, f2__DC=f2
    • during the remainder (=OFF or 0) part of this period, so from q*T->T, f2__DC=0
    • each subsequent DUTY part starts at the same point where it ended at the previous cycle, so as if f2 was 'froozen' during the OFF part (see code for more details, but basically this means that the t parameter needs to be constantly translated depending on which duty cycle we are in).
  • In the end I want to calculate f1*f2 in a simple way using ranges for both variables x and t so that e.g. plotting can easily be done.
I've tried implicit functions and procedures but keep getting stuck whenever I introduce a second variable.  Somehow, Maple does not seem to work straightforward with non-univariate stuff.  Such an examples can also not be found in the programming guide so I'm hoping that one of you knows how to tackle this.
Any help will be much appreciated!
f1 := (x, t) -> A * (1 + B * sin(a*x-b*t));
proc (x, t) options operator, arrow; A*(1+B*sin(a*x-b*t)) end proc
f2 := (x, t) -> C * (1 + E * sin(c*x-d*t));
proc (x, t) options operator, arrow; C*(1+E*sin(c*x-d*t)) end proc
A:=1: B:=0.5: a:=100: b:=1:
C:=1: E:=0.5: c:=10: d:=10:
densityplot(f1(x,t) * f2(x,t), x = 0..1, t = 0..10, style=patchnogrid);
#Duty cycle (DC) applied to f2
# ON state:      n*T <= t <(n+q)*T  : f2__DC(x,t)=f2(x,t-n*(1-q)*T)
# OFF state: (n+q)*T <= t < (n+1)*T : f2__DC(x,t)=0 (so all other cases)
# (n is a positive integer, zero included, and n=floor(t/T))
T:=1:
q:=0.3; #fraction of T where DC is 1=ON
#How to apply the above DC to f2(x,t) so that f2__DC is obtained and following command works:
densityplot(f1(x,t) * f2__DC(x,t), x = 0..1, t = 0..10, style=patchnogrid);
Download dutycycle_.mw
Could anyone please tell me how to solve the following system of equations and inequalities numerically in Maple:
{x + y = 2 and y = 1 and x > 0} or {x^2 = 4 and x < 0 and y = 0}?
By now I have been using solve() function in similar cases, but did not manage to adopt it for the or logical connector.
Solving the two cases separately obviously works here, but does not help in the example, for which I need this,
Thank you in advance!
First 368 369 370 371 372 373 374 Last Page 370 of 2458
