How to attach an m-file to a question?
Does it exist a rspecific repository where I can put an m-file?
Suppose we have a function that we want to plot in different styles and to finally put all these different plots in one single plot.
When we use the plot command, it is easy to gather several plots in one single plot but when it commes to another special kind of plots (namely, DiscretePlot from DynamicSystems), there I am stuck.
Would you like help me to solve this problem? Thank you.
Here attached the corresponding worksheet.
altogether.mw
When I was drawing a plane graph, I found that the labels  of vertices were not displayed  and some edges even overlap when drawing because they were too close due to embedding.
with(GraphTheory):
g:=ConvertGraph("GsaCB{");
DrawPlanar(g,stylesheet=[vertexborder=false,vertexpadding=5,edgecolor = maroon,vertexcolor=gray,edgethickness=3])
So I thought that  option  Interactive  can adjust the position manually, but  at the same time I found that the style of  edges, such as the color and thickness, etc., is lost.  How to handle it? Is this a bug?
with(GraphTheory):
DrawPlanar(g,stylesheet=[vertexborder=false,vertexpadding=5,edgecolor = maroon,vertexcolor=gray,edgethickness=3],layout=interactive)
Hello, ive got some trouble calculating this problem. Ive been looking at it for quite some time. I suspect you first need to differentiate to get the minimum value and then make it back to p. Time is ticking away, and i can just cant get it right. Its 2 questions out of some Dutch mathbook from 2007. It has a lot of Maple in it too. Just so to get a broad a view on maple as possible. I must say these maplebooks have quite the repertoirs. The other book "Advanced Problem Solving Using Maple" book turns you into some British chap. And this book:"toegepaste Wiskunde voor het hoger beroepsonderwijs deel 1"(translated applied math for higher job education part 1), turns you into the odd obnoxious Dutch mathematician... Well what can i say??
Here are the questions:
1st Question:
For which values of p does the graph of the function: y=f(x)=(p*x^2)+3*p*x+1 have one intersection with the x-axis? When does it have two intersections with the x-axis? When does it have no intersections with the x-axis.
2nd Question:
Given functions are: y=f(x)=(x^2)-6x+p+3, and y=g(x)=(4x^2)-(p-8)x+7. When do these functions have the same minimum value. Calculate p and the minimum value.
Greetings,
1st Question:
f(x) = p*x^2+3*p*x+1
2nd Question:
f(x) = x^2+p-6*x+3
f(x) = x^2+p-6*x+3
g(x) = 4*x^2-(p-8)*x+7
Download Applied_Math_Part_1_questions.mw
the function
I am looking for an output without denominator. I.e.:  2^(-1/3) instead of 2^(2/3)/2
Given some intert expression like 4%*5 %+ 3 is there a way to progressively convert it to a non-inert expression(and evaluated expression)?
I'd like to see the stages without having to hard code it all. Value simply converts the expression all the way down. I'd like to see intermediate stages. Ideally it should followthe order of operations and hault when it reaches a fixed point(when the output equals the input).
e.g., value(exp, 3) will value the expression 3 times carrying out one one reduction of inert operations.
I have seen some examples of linear programming or integer programming in Maple. But, I am wondering how to solve a mixed-integer program when just some of the decision variables are integer and the rest are continuous? I would be thankful if you can share an example.
Hello all,
The following minimal worksheet leads to a "Kernel Connection Lost" message. At seemingly random times, I get a `System error, `, "bad id" message in the worksheet output instead.
Temporarily disabling ESET Internet Security did not help. Before I contact technical support, I would like to ask if there is anything obvious that I am overlooking that could cause this problem.
Thank you very much.
kernelopts(version);
`Maple 2021.1, X86 64 WINDOWS, May 19 2021, Build ID 1539851`
with(Iterator):
P := CartesianProduct([1,2,3,4],[1,2,3,4]):
add(p,p in P);
Download Minimal.mw
I don't know how overcoming this error . Thank you. MyPackage := module() export f1, f2; local loc1; option package; f1 := proc() loc1 end proc; f2 := proc( v ) loc1 := v end proc; loc1 := 2; end module: savelib('MyPackage'); Error, cannot open archive, C:\Program Files\Maple 2018\lib, for writing. restart; with(MyPackage); Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received MyPackage
x1^4 + x2^4 + 0.4*sin(7*x1) + 0.3*sin(4*Pi*x2) -1 = 0;
The task itself is not needed by anyone, it's just for rest and distraction from work.
(For example, this is not difficult to do with Draghilev's method.)
I have a system of equations that returns a RealRange :
xLp_tmp := RealRange(85.32914119, infinity)
it actually looks like this:
anyway, I want to "pick" the lowerbound of that range and assign it to a variable but I can't figure  out how to do it.
I've tried:
xLp_tmp[1]
lowerbound(xLp_tmp)
but neither worked.  I don't know what else to try.
Thank you in advance for the help.
Dear Forum,
I want to make a Document where some values are initialised and left alone afterwards.
The startup-code seems to be the solution. The manual says, it is executed, when the document is reloaded.
But if i execute the document with "!!!" the startup-code is executed too.
How can I avoid this ?
Is there a good way to write "run once" code ?
Thank you very much
Klaus
startup code is  :
init:=false;
After reloading, this should be false  init = trueNULL
the startup code should be executed after reloading but is executed when the code is executed with !!! . init is set to false again
If the code is executed stepwise , ! by ! , it behaves as expected.
if not init then x := 3; y := 4; init := true end if
2*x = 8NULL
x := 4
4
2*x = 8NULL
Download doesnotrunonce.mw
Dear esteem colleagues,
Please I am trying to plot a function using both implicitplot and contourplot. However, I found out that I have two different plots. What are the differences between them and perhaps which is better?
Thank you all for your time and best regards.
with(GroupTheory):
MinimumPermutationRepresentationDegree(PermutationGroup({[[2, 3], [4, 5]], [[2, 5], [3, 4]]}, degree = 5, supergroup = PermutationGroup({[[2, 3, 4]], [[1, 2], [4, 5]]}, degree = 5)));
#an error appears in Maple 2017
As a newbie I tried to do some simple calculations. Unfortunately one of my calculations does not solve. I assume I do not see the obvious. Would someone be so kind to help me out? Thank you
with(LinearAlgebra)
pH := Vector(2, {(1) = 7.17, (2) = 7.25})
Vector[column](%id = 4598165698)
pCO2 := Vector(2, {(1) = 74, (2) = 56})
Vector[column](%id = 4696862338)
pK := 6.1
6.1
CO2 := `~`[`*`](pCO2, 0.3e-1)
Vector[column](%id = 4696842050)
HCO3 := `~`[`*`](`~`[`*`](0.3e-1, pCO2), 10^`~`[`-`](pH, pK))
Error, (in rtable/Power) exponentiation operation not defined for non-algebraic exponents
TCO2 := CO2+HCO3
28.30272572
VCO2 := 22.4*(28.3-25.41)*5.9
381.9424
Download test.mw
with(LinearAlgebra)
pK := 6.1
6.1
TCO2 := CO2+HCO3
28.30272572
381.9424
Download test.mw
First 409 410 411 412 413 414 415 Last Page 411 of 2458
