Has anybody tried Maple 2020.2 on a new Macbook with Apple silicon? I believe native support is in development, i was curious if anyone had experience running Maple via Rosetta 2?
The function is y^2 = x^3 - 3x - 1
How to calculate the defined integral when x < 0 in maple?
Always get a very long output rather than a numerical value.
I have to create a simulation of the orbit of Hyperion around Saturn, which should be reliable for up to thousands of orbits. In practice I don't seem to be able to make the model stay consistent above a few hundred orbits using dsolve for the ODEs, but is there any way to do this so that the orbit stays on the same path?
I have uploaded my code here for your perusal.
with(plots)
G := 0.667408e-10
MH := 0.55855e19
MSat := 0.56832e27
M := MSat+MH
a := 0.1501e10
ecc := .232
beta := .89
Digits := 10
TH := sqrt(4*3.141592653589793^2*a^3/(G*M))
omegaH := (2*3.141592653589793)/TH
Eqns := diff(xH(t), t) = vxH(t), diff(yH(t), t) = vyH(t), diff(vxH(t), t) = -G*M*xH(t)/(xH(t)^2+yH(t)^2)^(3/2), diff(vyH(t), t) = -G*M*yH(t)/(xH(t)^2+yH(t)^2)^(3/2), diff(theta(t), t) = omega(t), diff(omega(t), t) = -G*MSat*beta^2*(xH(t)*sin(theta(t))-yH(t)*cos(theta(t)))*(xH(t)*cos(theta(t))+yH(t)*sin(theta(t)))/(xH(t)^2+yH(t)^2)^2.5
ICs := xH(0) = a*(1-ecc), yH(0) = 0., vxH(0) = 0., vyH(0) = sqrt(G*M*(1+ecc)/(a*(1-ecc))), theta(0) = 0., omega(0) = omegaH
soln := dsolve({Eqns, ICs}, numeric, method = rkf45, abserr = 0.1e-9, relerr = 0.1e-9, maxfun = 0)
T := 100*TH
odeplot(soln, [xH(t)/a, yH(t)/a], 0 .. T, scaling = constrained, labels = ["x/a", "y/a"], numpoints = 2000)``
odeplot(soln, [theta(t), omega(t)], 0 .. T, labels = ["theta", "omega"], numpoints = 2000)
Download Project.mw
Maple how to prove Sin2x=2sinxcosx for every real number
  interface(rtablesize=10):
  local gamma:local pi:
if false then
 theta := 0.987: betae := 0.231: betay := 0.112: rho := 0.17: muh := 0.05 : sigma2 := 0.0411: sigma1 := 0.212: alpha1 := 0.111: alpha2 := 0.131 : eta := 0.134: thetaa := 0.7271: betaf := 0.00954: betah := 0.008220: gamma := 0.0012: mua := 0.0023: sigma3 := 0.203: d := 0.451: z := 0.072:
end if:
# D() is Maple's differential operator replated D(T)
# with DD(T) in the following to avoid confusion
  ODE1 := diff(B(T), T) = theta-(betae*C(T)+betay*rho*G(T))*B(T)-muh*B(T)+sigma2*E(T):
  ODE2 := diff(C(T), T) = (betae*C(T)+betay*rho*G(T))*B(T)-(muh+sigma1+alpha1)*C(T):
  ODE3 := diff(E(T), T) = sigma1*C(T)-(muh+sigma2)*E(T):
  ODE4 := diff(G(T), T) = alpha1*C(T)+alpha2*K(T)-eta*G(T):
  ODE5 :=  diff(H(T), T) = thetaa-(betaf*H(T)+betah*gamma*G(T))*H(T)-mua*H(T)+sigma3*K(T):
  ODE6 :=  diff(J(T), T) = (betaf*H(T)+betah*gamma*G(T))*H(T)-(mua+d+z+alpha2)*J(T):
  ODE7 :=  diff(K(T), T) = z*J(T)-(mua+sigma3)*K(T):
if false then
  B0 := 100: C0 := 60: E0 := 50: G0 := 55: H0 := 80: J0 := 80: K0 := 80:
end if:
# system + ic
sys := { ODE1, ODE2, ODE3, ODE4, ODE5, ODE6, ODE7,
                   B(0) = B0, C(0) = C0, E(0) = E0, G(0) = G0, H(0) = H0, J(0) = J0, K(0) = K0
params := convert(indets(sys, name) minus {T}, list);
[B0, C0, E0, G0, H0, J0, K0, alpha1, alpha2, betae, betaf, betah, betay, d, eta, gamma, mua, muh, rho, sigma1, sigma2, sigma3, theta, thetaa, z]
# Solve system
  ans := dsolve( { ODE1, ODE2, ODE3, ODE4, ODE5, ODE6, ODE7,
                 parameters = params,
                 numeric
Error, (in dsolve/numeric) 'parameters' must be specified as a list of unique unassigned names
Download sim.mw
I have a problem when searching in a document. Namelly is there a way to search in the whole worksheet including all code editing regions?
In order to show a point, there is a worksheet. I determine a variable
x11:= 12;
This variable is used in the document and code edit regions. Then I want to change a variable name from x11 to x11data. In order to do that, I use Ctrl+F to find all the times when the variable is used. I have a problem while  searching 'x11'. Namelly, the cases outside a code edit region are displayed, and the ones that are situated in the code edit regions are not seen.
Best regards
The dsolve function is not working to solve a set of differential equations I have written. No error message is showing, but the code does not work.
with*plots
G := 0.667408e-10
0.667408e-10
M := 0.56832e27+0.55855e19
0.5683200056e27
a := 0.1501e10
0.1501e10
ecc := .232
.232
orbit := proc (T) local Eqns, ICs, soln; Eqns := diff(xH(t), t) = vxH(t), diff(yH(t), t) = vyH(t), diff(vxH(t), t) = G*M*xH(t)/(xH(t)^2+yH(t)^2)^(3/2), diff(vyH(t), t) = G*M*yH(t)/(xH(t)^2+yH(t)^2)^(3/2); ICs := xH(0) = a*(1-ecc), yH(0) = 0., vxH(0) = 0., vyH(0) = sqrt(G*M*(1+ecc)/(a*(1-ecc))); soln := dsolve({Eqns, ICs}, numeric, method = classical[rk4]); odeplot(soln, [xH(t)/a, yH(t)/a], 0 .. T, scaling = constrained, labels = ["x/a", "y/a"], numpoints = 2000) end proc
orbit(20)
odeplot(soln, [0.6662225183e-9*xH(t), 0.6662225183e-9*yH(t)], 0 .. 20, scaling = constrained, labels = ["x/a", "y/a"], numpoints = 2000)
Download Project.mw
I need a procedure that given two lists of sets A and returns a list of lists such that L[i] is the list of j such that A[i] subset B[j]. Here is an example:
ans6 := [{alpha[1, 8], alpha[2, 2], alpha[2, 5], alpha[2, 8], alpha[3, 6], alpha[3, 9]}, {alpha[1, 8], alpha[2, 2], alpha[2, 5], alpha[2, 8], alpha[3, 3], alpha[3, 6]}, {alpha[1, 8], alpha[2, 2], alpha[2, 5], alpha[2, 7], alpha[3, 6], alpha[3, 8]}, {alpha[1, 8], alpha[2, 2], alpha[2, 5], alpha[2, 7], alpha[3, 3], alpha[3, 8]}, {alpha[1, 8], alpha[2, 2], alpha[2, 5], alpha[2, 7], alpha[3, 3], alpha[3, 6]}, {alpha[1, 8], alpha[2, 2], alpha[2, 4], alpha[2, 5], alpha[3, 3], alpha[3, 6]}, {alpha[1, 8], alpha[2, 1], alpha[2, 2], alpha[2, 5], alpha[3, 3], alpha[3, 6]}, {alpha[1, 8], alpha[2, 0], alpha[2, 2], alpha[2, 5], alpha[3, 3], alpha[3, 6]}, {alpha[1, 5], alpha[2, 8], alpha[3, 6], alpha[3, 7], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 5], alpha[3, 7], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 5], alpha[3, 6], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 5], alpha[3, 6], alpha[3, 7], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 5], alpha[3, 6], alpha[3, 7], alpha[3, 8]}, {alpha[1, 5], alpha[2, 8], alpha[3, 4], alpha[3, 7], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 4], alpha[3, 6], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 4], alpha[3, 6], alpha[3, 7], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 4], alpha[3, 6], alpha[3, 7], alpha[3, 8]}, {alpha[1, 5], alpha[2, 8], alpha[3, 4], alpha[3, 5], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 4], alpha[3, 5], alpha[3, 7], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 4], alpha[3, 5], alpha[3, 7], alpha[3, 8]}]:
ans7 := [{alpha[1, 8], alpha[2, 2], alpha[2, 5], alpha[2, 7], alpha[3, 3], alpha[3, 6], alpha[3, 8]}, {alpha[1, 5], alpha[2, 8], alpha[3, 5], alpha[3, 6], alpha[3, 7], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 4], alpha[3, 6], alpha[3, 7], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 4], alpha[3, 5], alpha[3, 7], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 4], alpha[3, 5], alpha[3, 6], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 4], alpha[3, 5], alpha[3, 6], alpha[3, 7], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 4], alpha[3, 5], alpha[3, 6], alpha[3, 7], alpha[3, 8]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 6], alpha[3, 7], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 5], alpha[3, 7], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 5], alpha[3, 6], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 5], alpha[3, 6], alpha[3, 7], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 5], alpha[3, 6], alpha[3, 7], alpha[3, 8]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 4], alpha[3, 7], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 4], alpha[3, 6], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 4], alpha[3, 6], alpha[3, 7], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 4], alpha[3, 6], alpha[3, 7], alpha[3, 8]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 4], alpha[3, 5], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 4], alpha[3, 5], alpha[3, 7], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 4], alpha[3, 5], alpha[3, 7], alpha[3, 8]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 4], alpha[3, 5], alpha[3, 6], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 4], alpha[3, 5], alpha[3, 6], alpha[3, 8]}, {alpha[1, 5], alpha[2, 8], alpha[3, 3], alpha[3, 4], alpha[3, 5], alpha[3, 6], alpha[3, 7]}, {alpha[1, 5], alpha[2, 8], alpha[3, 2], alpha[3, 6], alpha[3, 7], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 2], alpha[3, 5], alpha[3, 7], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 2], alpha[3, 5], alpha[3, 6], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 2], alpha[3, 5], alpha[3, 6], alpha[3, 7], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 2], alpha[3, 5], alpha[3, 6], alpha[3, 7], alpha[3, 8]}, {alpha[1, 5], alpha[2, 8], alpha[3, 2], alpha[3, 4], alpha[3, 7], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 2], alpha[3, 4], alpha[3, 6], alpha[3, 8], alpha[3, 9]}, {alpha[1, 5], alpha[2, 8], alpha[3, 2], alpha[3, 4], alpha[3, 6], alpha[3, 7], alpha[3, 9]}]:
and my procedure
SubsetPairs:= (A::list(set), B::list(set))->
    map(z-> [ListTools:-SearchAll](true, map(w-> z subset w, B)), A)
SubsetPairs(ans6, ans7);
The result of applying SubsetPairs is:
[[], [], [1], [1], [1], [], [], [], [2, 3, 8, 23], [2, 4, 9, 24], [2, 5, 10, 25], [2, 6, 11, 26], [2, 7, 12, 27], [3, 4, 13, 28], [3, 5, 14, 29], [3, 6, 15, 30], [3, 7, 16], [4, 5, 17], [4, 6, 18], [4, 7, 19]]
When it is used for long lists, it takes a long time to return the results.  I wonder if a more time- and memory-efficient code can be implemented (perhaps Threads or Grid can be used).
In addition to that, how can a diagram (figure, plot, ...) be drawn to show which subset of the first list is linked to which subsets of the second list (including no link as well).  The length of the first list is always smaller than the length of the second list.
Many thanks
I noticed that something changed with the output of translating abs() to latex. I am not sure when this happened.
Current version use \mid ...\mid  instead of the original \left| .... \right|
The problem with \mid is that the spacing no longer symmetric. It generate too much space on one side of | compared to the other side, and makes the output not pretty any more.
Is it possible to revert this back to the original way it was done? Please see example
Latex(ln(abs(1+x))=x)
                     \ln \! \left({\mid 1+x \mid}\right) = x
latex(ln(abs(1+x))=x)
                   \ln  \left(  \left| 1+x \right|  \right) =x
The second example gives better looking Latex where the space is symmetric. Here is the output
\documentclass{book}
\usepackage{amsmath}
\begin{document}
\ln \! \left(  \left| 1+x \right|  \right) =x
\end{document}
The second output is much better since \left|...\right| automatically sets the spacing the same between them and the math on each side.  (same if \lvert and \rvert were used)
I just noticed this first time looking at current output. I do not think this is how it used to be, else I would probably seen it before.
I am using Maple 2020.2 and Physics 890 (latest).
If not possible to change back to \left| ... right| . may be a new configuration parameter could be added to alow a user to choose which one?
Window 10.
Working with Legendre Polynomials (LegendreP) I observed that solve doesn't find the correct number of zeros.
More precisely, for N > 17, solve(LegendreP(N, x)) finds less zeros than N.
I wrote a procedure based on a theorem about the intertwined location of the zeros of orthogonal polynomial of successive degrees. So this problem is not blocking, but I would like to understand while solve(LegendreP(N, x)) doesn't always do the job.
Z := n -> op~(2, { allvalues(solve(LegendreP(n,x))) } );
proc (n) options operator, arrow; `~`[op](2, {allvalues(solve(LegendreP(n, x)))}) end proc
Digits:=10:
Z(17):
numelems(%);
17
Z(18):
numelems(%);
16
Digits:=15:
Z(18):
numelems(%);
16
Digits:=20:
Z(18):
numelems(%);
15
Zf := n -> op~(2, { allvalues(solve(evalf(LegendreP(n,x)))) } );
Z(18):
numelems(%);
proc (n) options operator, arrow; `~`[op](2, {allvalues(solve(evalf(LegendreP(n, x))))}) end proc
15
# Let z[N][i] the ith zero of any orthogonal polynomial P(N,x) of degree N.
# It is known that each open interval(z[N][i], z[N][i+1]) contains
# exactly a unique zero of the of P(N+1,x).
Z17 := [ -1, Z(17)[], 1]:
Z18 := NULL:
for n from 1 to 18 do
  Z18 := Z18, fsolve(LegendreP(18,x),  x=Z17[n]..Z17[n+1]);
numelems({Z18})
18
# A procedure to compute zeros of LegendreP up to degree N
zeros := proc(N)
  local zeros_table, Z, n, p, z:
  zeros_table := table([0=[]]):
  Z := [-1, 1]:
  for n from 1 to N do
    z := NULL:
    for p from 1 to n do
      z := z, fsolve(LegendreP(n,x),  x=Z[p]..Z[p+1]);
    zeros_table[n] := [z]:
    Z := [-1, z, 1]
  return zeros_table
Download LegendreP_zeros.mw
This ode
ode:=diff(y(x),x)=sqrt(1-y(x)^2)
has general solution y(x) = sin(x + _C1) but it also has solution y=-1 and y=+1. Since these extra solutions can't be obtained from the general solution by specific value of the constant of integration, they are singular solution.
But I am not able to get Maple to show these:
ode:=diff(y(x),x)=sqrt(1-y(x)^2);
dsolve(ode);
dsolve(ode,'singsol'='all',[separable]);
dsolve(ode,[separable]);
We can check that y=1.,y=-1 are solutions
odetest(y(x)=1,ode);
odetest(y(x)=-1,ode);
Only after I used this, was Maple able to gives these solutions
dsolve(ode,'Lie');
dsolve(ode,'Lie',singsol=all);
So only when using `Lie` symmetry methods and also using singsol=all it worked.
Most people will not think of using this specialized option.
Why Maple did not give these singular solutions using the standard dsolve(ode,singsol=all) command?
Should it not have done so? Now it makes it more confusing as to which option to use to obtain the singular solution, as one might have to keep trying different options.
What do others think?
Maple 2020.2
I used dsolve to solve the Initial value problems numericaly.
When I set the parameter range=1..5*10^4 , it works and cost only about 200s cpu time.
But if I set range=1..2*10^5, it stop running ( cpu time stop) when the mserver memory reach about 1.5 G. (the memory record in the bottom-right of maple interface is about 700M .)
What is the reason please?
Hello. I want to use the command verify but with two variables. For example:
verify(x^2 + y^2, 0, {'greater_equal'});
but I get FAIL as an answer. I tried adding before the verify command assume(x, 'real'); assume(y, 'real');
but notihng changed.
Thanks for any help.
I need help for designing a procedure for Schubert Kronecker polynomial program in maple.
I am trying to solve this type of problem:
I thought I could double check my answers by creating a RandomVariable and calculating the probablity using the Probability function.
But from the RandomVariables documentation,  it seems only univariate random variables are supported.
Is there really no way to define a RandomVariable given a joint distribution?
First 495 496 497 498 499 500 501 Last Page 497 of 2458
