Hello there,
Here is a set
Hello there,
Here is a set of non-linear equations:
TrainLoad := -10*10^6*(cos(convert(40*degrees, radians))+I*sin(convert(40*degrees, radians)));
-10000000*cos((2/9)*Pi)-(10000000*I)*sin((2/9)*Pi)
evalf(TrainLoad, 7);
-7660444.-6427876.*I
f1n2 := (0.03 + I*0.1515)*Ix[c1] - (0.03 + I*0.1515)*Ix[c2] + 2 * V[at1] - 55*10^3 = 0;
(0.3e-1+.1515*I)*Ix[c1]+(-0.3e-1-.1515*I)*Ix[c2]+2*V[at1]-55000 = 0
f3n4 := (1.6 + I*6.24)*Ix[c1] + (1.12 + I*2.64)*Ix[c2] + V[t] - V[at1] = 0;
(1.6+6.24*I)*Ix[c1]+(1.12+2.64*I)*Ix[c2]+V[t]-V[at1] = 0
f5n6 := (1.36 + I*4.44)*Ix[c2] + V[at2] - V[t] = 0;
(1.36+4.44*I)*Ix[c2]+V[at2]-V[t] = 0
f7n8 := (-1.12 - I*2.64)*Ix[c1] + (-3.92 - I*12.00)*Ix[c2] + V[at2] - V[at1] = 0;
(-1.12-2.64*I)*Ix[c1]+(-3.92-12.00*I)*Ix[c2]+V[at2]-V[at1] = 0
f9n10 := V[t] * (Ix[c1] - Ix[c2]) + TrainLoad = 0;
V[t]*(Ix[c1]-Ix[c2])-10000000*cos((2/9)*Pi)-(10000000*I)*sin((2/9)*Pi) = 0
polynomials := {f1n2, f3n4, f5n6, f7n8, f9n10};
{(1.36+4.44*I)*Ix[c2]+V[at2]-V[t] = 0, V[t]*(Ix[c1]-Ix[c2])-10000000*cos((2/9)*Pi)-(10000000*I)*sin((2/9)*Pi) = 0, (-1.12-2.64*I)*Ix[c1]+(-3.92-12.00*I)*Ix[c2]+V[at2]-V[at1] = 0, (0.3e-1+.1515*I)*Ix[c1]+(-0.3e-1-.1515*I)*Ix[c2]+2*V[at1]-55000 = 0, (1.6+6.24*I)*Ix[c1]+(1.12+2.64*I)*Ix[c2]+V[t]-V[at1] = 0}
variables := {Ix[c1], Ix[c2], V[at1], V[at2], V[t]};
fsolve(polynomials, variables, complex);
{Ix[c1] = 955.2297105-5281.491898*I, Ix[c2] = -505.0156845+2424.830843*I, V[at1] = 26894.34238+4.981252431*I, V[at2] = 10829.70666+56.66545127*I, V[t] = -623.3636109+1112.165758*I}
The 'fsolve()' command was able to come up with a solution.
Then, when 'f9n10 := V[t] * (Ix[c1] - Ix[c2]) + TrainLoad = 0;' becomes 'f9n10 := V[t] * conjugate(Ix[c1] - Ix[c2]) + TrainLoad = 0;',
the command ('fsolve()') refused to produce a solution.
Would you tell me how to make the 'fsolve()' command work with the 'conjugate()' operator?
Thank you,
In Kwon Park
Download no_conjugate.mw
I am one of the software coordinators for CUNY and was wondering how would i obtain access to download Maplesoft for the college community?
I have the following program which constructs the multiplication table, CI, for a matrix Lie algebra and evaluates the difference between CI's row dimension and its rank. The code is a little convoluted because "LieTable" formats the entries very strangely and forces incorrect rank values.
The matrix CI is constructed rather quickly (within a few seconds), and everything works well with "small" examples (up to 12 basis elements has evaluated within seconds). However, the example I've included is for a 27-dimensional Lie algebra. As I stated, CI is constructed quickly, even in larger examples, but the rank evaluation (i.e., LinearAlgebra:-Rank(CI)) has never completed for the example I've included. I let it run for about 3 hours before shutting it down.
I have an older Macbook Air which I am using to run these computations. Could this simply be an issue of not enough computing power?
I have attempted to import the matrix CI into Mathematica (to see if it was simply a limitation of Maple), but that's its own headache (reads entries of the matrix incorrectly).
Any recommendations would help. If this is an issue of computing power, I can get access to a more powerful system soon. It doesn't seem that the code itself would cause the issue, since it is not the construction of the matrix which is giving me issues, it is the evaluation of the rank. I am rather naive about Maple (and programming in general) though, so I may be wrong.
Index_and_Contact.mw
I want to do the substitution f(t) - ff(t) = epsilon for any variable t in Maple:
expand(myerror);
    2 f(x - 2 h)   f(x)   3 f(x + 3 h)   2 ff(x - 2 h)   ff(x)
        15 h       6 h        10 h           15 h         6 h
       3 ff(x + 3 h)
           10 h
NULL;
myfunc := t -> f(t) - ff(t) = epsilon;
 myfunc := proc (t) options operator, arrow, function_assign;
    f(t)-ff(t) = epsilon end proc
algsubs(myfunc(t), myerror);
          2               1        3
        - -- f(x - 2 h) - - f(x) + -- f(x + 3 h)
          15              6        10
                           h
               2                1         3
             - -- ff(x - 2 h) - - ff(x) + -- ff(x + 3 h)
               15               6         10
                                  h
NULL;
subs(f(-h*n + x) = 1, ff(-h*n + x) = 0, f(x) = 1, ff(x) = 0, f(h*m + x) = 1, ff(h*m + x) = 0, myerror)*epsilon;
                           4 epsilon
                             15 h
How do I change equations from the 2D-output into definitions?
#! Change the order (this case second):
solve({-alpha[-1] + 2*alpha[2] = 1, 1/2*alpha[-1]*h + 2*alpha[2]*h = 0, alpha[-1]/h + alpha[0]/h + alpha[2]/h = 0}, {alpha[a], alpha[b], alpha[c]});
          /            -2             1             1\
         { alpha[-1] = --, alpha[0] = -, alpha[2] = - }
          \            3              2             6/
NULL;
lhs({alpha[-1] = -2/3, alpha[0] = 1/2, alpha[2] = 1/6}[1]) := rhs({alpha[-1] = -2/3, alpha[0] = 1/2, alpha[2] = 1/6}[1]);
     /            -2\       / /            -2             1
  lhs|alpha[-1] = --| := rhs|{ alpha[-1] = --, alpha[0] = -,
     \            3 /       \ \            3              2
               1\    \
    alpha[2] = - }[1]|
               6/    /
Why am I not able to replace O(h^3), and in what other way can I achieve the result (I want to get the coefficients of the f(x), D(f)(x), and D^(2)(f)(x) variables).
Q(h);
1 /          /                                       2    / 3\\
- |alpha[-2] \f(x) - 2 D(f)(x) h + 2 @@(D, 2)(f)(x) h  + O\h //
h \
   + alpha[0] f(x)
              /                     9                 2    / 3\\\
   + alpha[3] |f(x) + 3 D(f)(x) h + - @@(D, 2)(f)(x) h  + O\h /||
              \                     2                          //
NULL;
subs(f(x) = 1, D(f)(x) = 0, (D@@2)(f)(x) = 0, O(h^3) = 0, collect(Q(h), f(x)));
                         /     / 3\\            /     / 3\\
    alpha[0]   alpha[-2] \1 + O\h // + alpha[3] \1 + O\h //
       h                            h
How do I combine greek letters and latin letters in variable names? e.g. here I want to combine the greek letter Delta and the latin letter x to be used as one variable name:
Delta*x;
                            Delta x
Deltax;
                             Deltax
The original question (crossed through below) was too vague, so I tried to clarified it:
I have the following expression
Q(h);
 1 /  2                    1                 2    / 3\   1
 - |- - f(x) - D(f)(x) h + - @@(D, 2)(f)(x) h  + O\h / + - f(x)
 h \  3                    2                             2
      1                                        2    / 3\\
    + - f(x) + 2 D(f)(x) h + 2 @@(D, 2)(f)(x) h  + O\h /|
      6                                                 /
It doesn't expand this following way...
expand(Q(h));
      /                   1                 2    / 3\\
    2 |f(x) - D(f)(x) h + - @@(D, 2)(f)(x) h  + O\h /|
      \                   2                          /   f(x)
                           3 h                           2 h
                                              2    / 3\
                             6 h
But it does expand when I add the multiplication symbols manually:
expand(2*(f(x) - D(f)(x)*h + 1/2*(D@@2)(f)(x)*h^2 + O(h^3))/(3*h) + f(x)/(2*h) + (f(x) + 2*D(f)(x)*h + 2*(D@@2)(f)(x)*h^2 + O(h^3))/(6*h));
                                                    / 3\
       4 f(x)   1           2                    5 O\h /
       ------ - - D(f)(x) + - h @@(D, 2)(f)(x) + -------
        3 h     3           3                      6 h
How can I expand my output without having to add the multiplication symbols?
------------------------------------old question below, please disregard----------------------
I found there is assume=[...] syntax. So I changed my code to use it, instead of .... assuming
Now I find that some tests fail.  Should assuming and assume not give same result?
sol :=y(x)^(1/2) = -1+2*exp(x):
ode:=diff(y(x),x)-2*y(x) = 2*y(x)^(1/2):
odetest(sol,ode) assuming x::real, x>0
gives 0
but
odetest(sol,ode,assume=[x::real, x >0])
does not give zero. Please see screen shot below.
Reason I changed, since I started saving assumptions to use in a list. So it was easier to use assume=[....] than assuming ...., since assuming wants expression sequence in front of it and I did not know how to convert the list of assumptions I have collected to an expression sequence on the fly to use assuming, otherwise I would not have changed the code.
But my question is: Should both give same result? Why is the result different?
Help says
The assume routine sets variable properties and relationships between variables. Similar functionality is provided by the assuming command.
I am probably not using assume= correctly.   I thought I could use the same thing I had on assuming, just put it in a list.
This happens each time I run a long loop.  (2,500 iterations, which takes about 3 hrs to complete)
Maple always hangs (it does not time out on odetest() ). But my question is not about this (as this is something I have to deal with for long time now and mentioned it before many times. May be one day Maplesoft will fix this).
But I noticed this also.  When Maple hangs, (and it always hangs at least once during this loop), I then click on the button "interrupt the current operation". This does stop the hangs.
Next I do a restart and starts the loop from the loop counter where it hanged in order to continue.
But It still hangs at that same iteration. I repeate this again, and it still hangs.
Now I close Maple altogether, start Maple again, open same worksheet, and repeat from the same iteration again from where it was at before, now it does not hang.
This tells me that restart and "interrupt the current operation" do not clean everything as expected. Else why only restarting Maple makes it work?
It means mserver.exe (separate process from the frontend) still is caching something related, and that is why it hangs at that iteration.
I can reproduce this each time I run the whole loop from the start.
I can't make a minimal example, since I have no idea where it hangs and why. And it is related to running a long loop.
I just know it hangs when doing odetest() with timeout which never timeout, and it seems random at what iteration it decides to hang.
But my question is really basic here: Does mserver.exe keep any information about the earlier user session/worksheet even after restart ? help says that restarts clear internal memory of the kernel.
Isn't mserver.exe  the Maple kernel? If so, then what could explain that only restarting Maple clears the hang? I am just looking for ideas that could explain this.
This type of problem is the most annoying thing about Maple for me.
Maple 2020.1 on windows 10.
Whoever designed Maple's user-interface thinks very differently from me. How can I insert a 2nd section into Chapter 1? There's no space between the end of Section 1 and the end of Chapter 1 for me to put the cursor, so where should I put the cursor, and what should I do?
Eigenvector result is changing every time it run.
How to make eigenvectors result the same every time it run?
Study a example
Procedures. Declare local variables within procedures.
> # Program 1: Procedures.
> # The norm of a 3-dimensional vector.
> norm3d:=proc() local a,b,c;sqrt(aˆ2+bˆ2+cˆ2) end;
> norm3d(3,4,5);
5√(2)
Must say it was never clear for me the procedure ()
Never have read in the tutorials or study material the use of proc ( )  ( i did not read them all, so probably i missed it somewhere )
The procedure norm3d()  i get not working , because i don't not know how to use it
First 545 546 547 548 549 550 551 Last Page 547 of 2458
