I think the Maple Physics package has the promise to revolutionize the teaching of physics. Two recent tutorials have been very helpful (“Vectors in Spherical coordinates using tensor notation” and “A Complete Guide for performing Tensors computations using Physics”).   Unfortunately, despite these, I still have problems even when trying to use it for simple things. No doubt this is primarily a sign of my limitations. However, in the hope that others might share this, I have the following question.
As an exercise, I would like to use the Maple Physics Tensor notation to derive the expression for acceleration in spherical coordinates – identifying Coriolis force, etc.  I can’t get past the first step – how to define the tensor dx/dt.   That is, how do I write the time derivative of the Maple space coordinates [X].  I assume that this can be done in about 3 steps, if someone would be kind enough to humor my ignorance. Thanks in advance.
Why on earth is Maple giving me all these solutions compared to last year??
Last year:
Now:
I am trying to  find the funtion of this graph
I tried
f := x -> a12*x^12 + a1*x^11 + a2*x^10 + a3*x^9 + a4*x^8 + a5*x^7 + a6*x^6 + a7*x^5 + a8*x^4 + a9*x^3 + a10*x^2 + a11*x + a13;
solve([f(-4) = 3, f(-3) = 1, f(-2) = 1, f(-1) = 1, f(0) = 0, f(1) = -1, f(3) = -5, f(4) = -5, f(5) = 1, eval(diff(f(x), x), x = -2.5) = 0, eval(diff(f(x), x), x = -1.5) = 0, eval(diff(f(x), x), x = 3.5) = 0, f(6) = 3], [a12, a1, a2, a3, a4, a5, a6, a7, a8, a9, a10, a11, a13]);
I got
[[a12 = 4.697405911*10^(-6), a1 = -0.00006250181861, a2 = -1.444112429*10^(-6), a3 = 0.002660698702, a4 = -0.004689494622, a5 = -0.04291772722, a6 = 0.08407481146, a7 = 0.3251529098, a8 = -0.4752692626, a9 = -1.066462933, a10 = 0.3958806924, a11 = -0.2183704462, a13 = 0.]]
plot(4.697405911*10^(-6)*x^12 - 0.00006250181861*x^11 - 1.444112429*10^(-6)*x^10 + 0.002660698702*x^9 - 0.004689494622*x^8 - 0.04291772722*x^7 + 0.08407481146*x^6 + 0.3251529098*x^5 - 0.4752692626*x^4 - 1.066462933*x^3 + 0.3958806924*x^2 - 0.2183704462*x, x = -4 .. 5)
It doesn't like the graph of the first picture.
Since Maple comes with source code that one can display. Even though it is stripped of all comments, which makes it hard to follow sometimes, I was wondering if there are any tools to help one get the large picture of what is there without having to step and go through all the thousands and thousands of the help pages jumping from one to another and losing the path.
I am looking for something similar to the tree program one finds on Unix, but applied to Maple's logical package hierarchy.
Since Maple has thousands of packages and subpackages and some has sub subpackages and then thousands of commands below all these, such an automated tool will be useful.
For example, I could ask it to show me top level packages and subpackages only (and not show the names of all the functions below that). This will help one see what is out there at a glance. i.e. see the big picture.
Here is an example of tree command I found on the net. But instead of looking at directories, the maple one will look at logical package tree.
For example, I just made short example for the Student package now
But doing the above by hand for everything is not practical. The above is just partial view of one package, and there are hundreds others.
It will be nice if there is a tool, where one can tell to show the Maple package tree and the level of details to show. This will help one learn Maple better also.
The output of such tool does not even have to graphical. It could plain text, something like this
Student
      LinearAlgebra
               Basis
               IntersectionBasis
               etc.....
      Calculus1
Physics
DataSets
Alignment is done using tabs for example to help show the structure.
Any suggestions?
Taking the example below from the help page, showstat displays the content of a procedure. This is convenient when writing code. However, to perform copy & paste, I would like to get rid of the displayed line number. Is that possible?
f := proc(x) if x <= 2 then print(x); print(x^2) end if; print(-x); x^3 end proc:
showstat(f);
f := proc(x)
   1   if x <= 2 then
   2       print(x);
   3       print(x^2)
   4   print(-x);
   5   x^3
end proc
Hi everyone, I hope you are staying safe from coronavirus.
I have a table of data points in excel (attached file) and want to plot a smooth surface plot in Maple, the plot will look like in the image below. How can I do it in Maple (2017)? I tried matrixplot(matrix) and the surface is good. However, I couldn't change the X, Y axes value since it should be the default value.
Thank you very much.PlotTest.xlsx
The uploaded worksheet contains an apparently unsolvable ode.
Please see the text in the worksheet for a description of the problem.
Roller_coaster_loop.mw
I've define a list V of 2 random variables and saved the result in an .m file.
When I read this same file and try to sample V I get a message error which, after quick search, comes from the fact that the V I read is no longer a random variable.
How can I fix this?
TIA
interface(version)
with(Statistics):
V := [ RandomVariable(Normal(0, 1)), RandomVariable(Uniform(0, 1)) ]
[_R, _R0]
map(v -> [attributes(v)][3], V);
print~(map(Sample, V, 5)):
"[[Typesetting:-mi("_ProbabilityDistribution",italic = "true",mathvariant = "italic"), Typesetting:-mi("_ProbabilityDistribution0",italic = "true",mathvariant = "italic")]]"
Vector[row](5, {(1) = -1.07242412799827, (2) = -.329077870547065, (3) = -.617091936909790, (4) = .214466745245291, (5) = -0.254281280423846e-1})
Vector[row](%id = 18446744078251172318)
dir := currentdir():
f   := cat(dir, "/Desktop/rvs.m"):
save V, f
with(Statistics):
read f:
anames(user);
V;
dir, f, V
[_R, _R0]
Error, (in Statistics:-Sample) invalid input: expected distribution or algebraic expression with random variables, but received _R
attributes(V[1]); # The Vs are no longer random variables
Download Why.mw
I work for the University of Dundee as a packager for the staff and student desktops.
We have a licence for 2020 applied to our licance server, I only require the software.
Is your free version the full package that once it sees the licence server will unlock all the features do I need to download a specific version from yourselves,
Best regards
Colin
plot([sin(x), sin(x), x=0..420]);
The matrix A := op([1,1], %)  has equal columns, so the bug is in the PLOT engine.
plot(A) generates the same plot.
See also the "circle":
plot([cos(x), sin(x), x=0..5000*Pi]);
help me for solve the error of plot
p1.mw
Hello everyone! I'm pretty new to Maple and struggling with some basics.
I want to use a for-loop to print out the square numbers from 11 to 20. And the outputs should be presented within a list.
This is what I have so far:
|> for i from 11 to 20 do print(i^2) od;
                              121
                              144
                              169
                              196
                              225
                              256
                              289
                              324
                              361
                              400
But I don't know how I can put all these results in a list, so that in the end it looks like this:
L: = [121,144,169,196,225,256,289,324,361,400]
I'm grateful for every answer :)
With Maple 2020, I have been experiencing some odd behavior of simple 2D plots. For example, I plotted two functions on the same graph, and the default view did not contain the full upper or lower limits of both functions. (Sorry, I chose to move on and so I am unable to reproduce this outcome – but it has happened more than once.)
Now I am experiencing another limited view of a plot, this time a single function. In creating a simple example of the SIR model, I have dsolve output a list of procedures so that I can plot them as functions. But when I plot one of the functions, it does not plot the entire function from the lower to the upper limit. Am I alone in experiencing this outcome? Is there something I am doing wrong that is causing this behavior?
restart; plots:-setoptions(size = [300, 300])
s_eq := diff(s(t), t) = -ir*i(t)*s(t); i_eq := diff(i(t), t) = ir*i(t)*s(t)-rr*i(t); d_eq := diff(d(t), t) = dr*i(t); ics := s(0) = s0, i(0) = i0, d(0) = 0
"i0:=1.E3:    P0:=3.E8:    drate:=0.02:     s0:=0.6*P0:    ir:=(0.1)/(s0):   rr:=1/(30.):  dr:=rr*drate:   "
sol := dsolve({d_eq, i_eq, ics, s_eq}, numeric); tf := 120; plots:-odeplot(sol, [t, d(t)], 0 .. tf)
sol := dsolve({d_eq, i_eq, ics, s_eq}, numeric, output = listprocedure); i := eval(i(t), sol); s := eval(s(t), sol); d := eval(d(t), sol)
tf; plot(d(t), t = 0 .. tf)
120
plot(d(t), t = 0 .. tf, view = [0 .. 150, 0 .. 40000])
Download plot_view_problem.mw
Following situation: I have a bunch of matrices A,B,Dm, Dinv (which is the inverse of Dm). They happen to be 2x2 matrices, but I want/need to keep these in a symbolic or abstract form, i.e. I am not saying what these are.
They are then used as submatrices of other (2x2) matrices like so:
R:=<<A|0>,<0|B>>;
I then have various dot products between these & others.
My issue/question is: How can I make sure, Maple obeys the non-commutativeness of the products that occur in doing these matrix products? I tried declaring A and B etc. as Matrix(), but that fails, saying the matrices are either too short or too long.
At any rate, I do not want Maple to expand these into their elements. A particular concern is that Dm*B*Dinv bcomes B*Dm*Dinv = B; obviously not correct for matrices B,Dm,Dinv.
So, can Maple handle abstract matrices?
M.D.
First 589 590 591 592 593 594 595 Last Page 591 of 2458
