I am just confused to be getting this error seeings FileTools does not encounter this error when I use it's ListDirectory command:
error_for_primes.mw
with(ImageTools):
FileTools:-ListDirectory(currentdir())
["IMG_20200116_015953.jpg", "magetools commands.mw"]
Read("H:\\MAPLE\\Image_Project", format = JPEG)
Error, (in readbytes) permission denied
Download error_for_primes.mw
sigma(integral(F(w,cn1,ct1))+integral(F(w,cn2,ct2))+...+integral(F(w,cn80,ct80)))
integral.mw
In a do loop with a try... catch statement I had placed an assignment to a vector element after catch: but before the line printing the lastexception. That the loop didn't perform as expected, but resulted in an error about ListTools:-FormatMessage wanting its first argument to be a string surprised me. Putting the assigment to the vector after the exception printing worked fine.
It seems that rtables are the exception (no pun intended) to the order being irrelevant.
V:=Vector():
for j from 1 to 5 do
  try
   V(j):=j/(j-1)
  catch:
   V(j):=17; # clears lastexception apparently
   printf(cat(StringTools:-FormatMessage(lastexception[ 2 .. -1 ] ),"\n"));
  end try
V:=Vector():
  try
   V(j):=j/(j-1)
  catch:
   V(j):=17;
  end try
These simple lines confirm my observation:
lastexception;
5/0;
lastexception;
5/5;
lastexception;
x:=47;
lastexception;
table();
lastexception;
[1,2,3];
lastexception;
rtable();
lastexception; # Now cleared!
Hello Dear Brothers and Sistors,
Can you help me giving a maple program to plot cost function  of a an optimal control modeling ?
Looking forward.
hi everyone:
How can I define this matrix in Maple? N is a Natural number. Thank you.
In my maple ini I redefine I.
local a,b,c,I:
Every worksheet I create I always end up with an executed line with just "I". It's just annoying to see it as it service no purpose and takes up space at the start of the worksheet.
Of course I is a predefined symbol which is why I want to redefine it, redefine it to be _i, say. I've tried unprotect and unassign and all that and it still prints out.
Now I always put a restart at the start of a worksheet so I end up getting two lines of the I, which is a total of 4 because it prints a blank line.
Bonjour,
Un connaisseur pourrait-il m'aider s'il vous plaît afin de résoudre un petit problème sur Maple.
J'ai un algorithme qui me renvoie les résultats successifs des nombres utilisés pour faire une multiplication égyptienne.
Sauf que les résultats sont renvoyés sur des lignes différentes avec plusieurs références d'une liste que j'ai nommé "L".
Les résultats sont renvoyés donc ainsi :
L:= [21 , 54 , 47]
L:= [20, 41 , 87]
L:= [2, 8, 12]
L:= [3, 7 , 5]
Comment faire pour que les résultats soient regroupés dans une même liste, c'est à dire :
L:= [21 , 54 , 47, 20, 41 , 87, 2, 8, 12, 3, 7 , 5 ]
Voici l'algorithme :
x := 12:
y := 46:
s := 0;
'x' = x:
'y' = y:
'`résultat`' = s:
while 0 < y do
if type(y, odd) then s := s + x:
y := y - 1:
else x := 2*x:
y := y/2:
L := [x, y, s];
I have this results in Maple :
L:= [21 , 54 , 47]
L:= [20, 41 , 87]
L:= [2, 8, 12]
L:= [3, 7 , 5]
How do for have just one list that :
I got, a bit by mistake, a weird result that seems to come from the way "Maple" manipulates infinity (please have a look at the results below)
I couldn't find a correct explanation to these results in the help pages dedicated to infinity or evaluation.
Could anyone explain me why, in some circumstances, 'infinity' seems to be a name (for instance infinity*Pi; does not return  infinity but infiniy/Pi).
with(Statistics):
f := PDF(Cauchy(0, 1), x)
1/(Pi*(x^2+1))
m := int(x*f, x=-infinity..+infinity);
undefined
p := int(x*f, x);
(1/2)*ln(x^2+1)/Pi
# Naive "proof" : eval(..., infinity) seems to consider infinity as a name (consistent with
# the first line in help(infinity) without any particular property.
# This seems to be confirmed by the value of p1 and p2 : I expected to get infinity instead
# of infinity/Pi.
p1 := eval(p, x=-infinity);
p2 := eval(p, x=+infinity);
p2 - p1;
infinity/Pi
infinity/Pi
# Correct "proof" :
a := limit(p, x=-infinity);
b := limit(p, x=+infinity);
b-a
infinity
infinity
undefined
# Does Maple treat 'infinity' as a number ?
infinity         - infinity;
infinity*2       - infinity*2;
infinity*(1/3)   - infinity*(1/3);
infinity*0.333   - infinity*0.333;
infinity*sqrt(2) - infinity*sqrt(2);
infinity/Pi      - infinity/Pi;
undefined
undefined
undefined
Float(undefined)
limit(sqrt(2)/x, x=0) - limit(sqrt(2)/y, y=0);
limit(Pi/x, x=0)      - limit(Pi/y, y=0);
undefined
undefined
Download Infinity.mw
Dear Guys
How can I plot a fieldplot with a boundary. For example I can plot
> fieldplot([y, -sin(x)-(1/10)*y], x = -1 .. 1, y = 0 .. 1);
but I want to see the field plot only in the region x^2+y^2<=1.
Thanks a lot
timestamp is the number of seconds from the epoch, which I thought was Jan 1, 1970.  Maple uses Dec 31, 1969.  It appears there is a maximum number of seconds you can use with timestamp.
FormatTime("%Y-%m-%d", timestamp = 0)
        "1969-12-31"
FormatTime("%Y-%m-%d", timestamp = 2147483647)
        "2038-01-18"
Who knows if Maple will be around then, however if we add one second more to timestamp we run into the 32 bit integer problem.
FormatTime("%Y-%m-%d", timestamp = 2147483648)
Error, (in StringTools:-FormatTime) timestamp value must be a 32-bit signed integer.
Can Maple get passed 2038 using timestamp?  Is there always that 32 bit limit?
I couldnt find this command in the number theory package, as far as what i am thinking of doing it should be straight forward but very long winded, so if I have missed this command throughout the packages up to Maple 2016 I would appreciate someone telling me otherwise I suppose it's what i am doing for the next few hours
https://en.wikipedia.org/wiki/Partition_(number_theory)
I discovered that the option legend, when used in plots:-inequal, returns an empty graphic.
Is it a bug or a deliberate choice?
Anyways, is it possible to insert a legend in a simple way (that is without using textplot for instance)?
TIA
I am trying to find six integer numbers a, b, c, d, n, p so that this equation
abs(a*x+b)+abs(c*x+d)+x^2+n*x+p = 0
has 6 integer solutions are 1, 2, 3, 4, 5, 6. I tried
f:=x-> abs(a*x+b)+abs(c*x+d)+x^2+n*x+p;
solve([f(1) = 0, f(2) = 0, f(3) = 0, f(4) = 0, f(5) = 0, f(6) = 0], [a, b, c, d, n, p])
This equation has no solution. Is there six integer numbers a, b, c, d, n, p so that this equation has 6 integer solutions?
I have just found one solution is
solve(abs(-2*x+5)+abs(-2*x+9)-x^2+7*x-16 = 0, x);
With Mathematica, I see at here
https://mathematica.stackexchange.com/questions/212808/find-integers-a-b-c-d-m-n-p-so-equation-has-six-distinct-solutions
Dear Users!
Hope you would be fine with everything. I have following code to generate marix A of order M by M
restart; with(LinearAlgebra); with(linalg); Digits := 30; M := 10; nu := 1;
for k1 while k1 <= M do
C[k1] := simplify(sum((-1)^(k1-1-i1)*GAMMA(k1-1+i1+2*nu)*GAMMA(nu+1/2)*x^i1/(GAMMA(i1+nu+1/2)*factorial(k1-1-i1)*factorial(i1)*GAMMA(2*nu)), i1 = 0 .. k1-1))
A := evalm(Matrix(M, M, proc (i, j) options operator, arrow; eval(C[j], x = (i-1)/(M-1)) end proc))
I want to split (or decompose) A into two parts Ad and Ab
A = Ab + Ad
where Ad is M by M matrix of all entries of A but first and last rows of Ad shoud be zero
and Ab is M by M matrix with zero entries expect first and last rows.
For exmaple for M = 5, A, Ab and Ad are given as,
Ab := Matrix(5, 5, {(1, 1) = 1, (1, 2) = -2, (1, 3) = 3, (1, 4) = -4, (1, 5) = 5, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (2, 4) = 0, (2, 5) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0, (3, 4) = 0, (3, 5) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 0, (4, 5) = 0, (5, 1) = 1, (5, 2) = 2, (5, 3) = 3, (5, 4) = 4, (5, 5) = 5});
Ad := Matrix(5, 5, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (1, 5) = 0, (2, 1) = 1, (2, 2) = -1, (2, 3) = 0, (2, 4) = 1, (2, 5) = -1, (3, 1) = 1, (3, 2) = 0, (3, 3) = -1, (3, 4) = 0, (3, 5) = 1, (4, 1) = 1, (4, 2) = 1, (4, 3) = 0, (4, 4) = -1, (4, 5) = -1, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = 0, (5, 5) = 0});
Please help me to fix this problem.
Special request @acer @Carl Love @Kitonum @Preben Alsholm
I have hacked together some things so I can use previously computed values without too much hassle
_Last := 0:
# Stores N in a global to be used
Last := proc(N)
    global _Last;
    _Last := N;
    N;
end:
_Last := 1:
seq(Last(_Last*4 + k),k=1..10);
This is quite hacky but does work. It is not very robust. Is there any better way? [The above is just a trivial example, I know it can be solved as a problem easily, that is not the point. The method can also be used in much more non-trivial scenarios to simplify coding them].
First 596 597 598 599 600 601 602 Last Page 598 of 2425
