I have a question about a calculation of a differential of a functional.
I think dW(Y(t), t)/dt equals W  +W'Y .
There is some problem when I try to calculate it in Maple as below:
diff(w(y(t), t), t);
                          / d      \
         D[1](w)(y(t), t) |--- y(t)| + D[2](w)(y(t), t)
                          \ dt     /
I don't know it right or wrong; and  what does the D[1],D[1] mean?
I hope i can get your help!
please help me export data of for(do) to excel
Digits := 8
with(plots)
with(CurveFitting)
with(plottools)
with(ExcelTools)
v := .7
Disp := 20
esp := 1000000
k := 0
E := proc (x, t) options operator, arrow; Int(exp((-esp*w^4+Disp*w^2+k)*t)*cos(w*(x+v*t))/Pi, w = 0 .. infinity, epsilon = 0.1e-6) end proc
"f(x):=15.5*(e)^((-(x-12590)^(2))/(3710000))+14.55*(e)^((-(x-16100)^(2))/(3000000)):"
u := proc (x, t) options operator, arrow; Int(E(x-xi, t)*f(xi), xi = 0 .. 0.2e5, epsilon = 0.1e-4) end proc
uu := evalf(Int(E(0-xi, i)*f(xi), xi = 0 .. 20000, method = _NCrule, epsilon = 10^(-6)))
Int((Int(.31830988*exp((-1000000.*w^4+20.*w^2)*i)*cos(w*(-1.*xi+.7*i)), w = 0. .. Float(infinity)))*(15.5*exp(-0.26954178e-6*(xi-12590.)^2)+14.55*exp(-0.33333333e-6*(xi-16100.)^2)), xi = 0. .. 20000.)
for i from 0 by 300 to 39000 do evalf(Int(E(0-xi, 39000-i)*f(xi), xi = 0 .. 20000, method = _NCrule, epsilon = 10^(-6))) end do
-0.40453181e-3
0.34992127e-3
0.12637278e-2
0.16816398e-2
0.98280208e-3
-0.90049939e-3
-0.31323275e-2
-0.41557391e-2
-0.25326936e-2
0.18889271e-2
0.72213081e-2
0.99627384e-2
0.68245493e-2
-0.27701468e-2
-0.15052225e-1
-0.22679194e-1
-0.18343538e-1
0.20091767e-3
0.26631663e-1
0.47005735e-1
0.46070677e-1
0.16544944e-1
-0.33724783e-1
-0.81923601e-1
-0.99668403e-1
-0.68223938e-1
0.83269218e-2
.10029034
.16367514
.16160510
0.85214080e-1
-0.37861317e-1
-.15374440
-.20787576
-.17365568
-0.69367811e-1
0.46138347e-1
0.98175763e-1
0.30797102e-1
-.16333068
-.42882780
-.65291065
-.68519320
-.36491699
.45065352
1.8601309
3.8933757
6.4921833
9.4993084
12.664412
15.671497
18.185563
19.912262
20.654429
20.352632
19.099001
17.122716
14.750504
12.351527
10.277969
8.8110726
8.1121013
8.2595148
9.1484300
10.625106
12.470000
14.442900
16.334977
17.814817
18.760786
19.181587
18.732976
17.780388
16.318411
14.486252
12.440398
10.334385
8.3022216
6.4471886
4.8365207
3.5019327
2.4446257
1.6429774
1.0611606
.65712596
.38895586
.21914009
.11682497
0.58405315e-1
0.26982858e-1
0.11209327e-1
0.39351902e-2
0.94525962e-3
-0.74540895e-4
-0.29495088e-3
-0.25204186e-3
-0.16004845e-3
-0.86532870e-4
-0.41463181e-4
-0.17899580e-4
-0.69278927e-5
-0.23491366e-5
-0.66829402e-6
-0.13686514e-6
-0.76837315e-8
0.49022551e-8
-0.69948640e-9
0.21531116e-8
0.94383197e-8
0.13935450e-7
0.74857886e-8
-0.17655857e-7
-0.20268315e-7
0.19079956e-6
0.10964273e-6
-0.46401214e-7
0.65111854e-8
0.19030541e-9
-0.32052754e-6
-0.33434254e-7
0.21130779e-7
-0.60700260e-9
-0.15371908e-9
0.56652633e-10
-0.29781841e-10
-0.17334684e-11
0.20761743e-11
0.98264048e-9
0.43165138e-11
-0.28235638e-7
Download getD1.mw
Second Try:
f:= c/(c - 1) - c*(Pi^2 - 12*ln(c))*(1 + c)/(12*(c - 1)^3*n) + (((144*c^3 + 1584*c^2 + 1584*c + 144)*ln(c)^2 - 24*Pi^2*(1 + c)*(c^2 + 10*c + 1)*ln(c) + (-96*c^3 - 288*c^2 + 288*c + 96)*Zeta(3) + Pi^2*((Pi^2 + 24)*c^3 + (11*Pi^2 + 72)*c^2 + (11*Pi^2 - 72)*c + Pi^2 - 24))*c)/(288*(c - 1)^5*n^2)
This expression is already arranged with respect to n. However, the nominator of each term is not collected with respect to c. So naturally I thought
collect(f,[n,c]) or collect(f,[n,c],simplify)
would work. But now he messes up the nominator i.e. he can not factor and simplify. Note that the single variable case collect(f,n,simplify) works in not messing up, but this is not what I want, since the nominator of each n-term is not in c-collected form.
collect(f,[n],u->collect(u,[c],...))
also does not work, since he messes up again.
By c-collected form I mean the following:
The n^0 and n^{-1} term are actually fine. The factorization in the second term is ok. But for the third term
f2:=(144*c^3 + 1584*c^2 + 1584*c + 144)*ln(c)^2 - 24*Pi^2*(1 + c)*(c^2 + 10*c + 1)*ln(c) + (-96*c^3 - 288*c^2 + 288*c + 96)*Zeta(3) + Pi^2*((Pi^2 + 24)*c^3 + (11*Pi^2 + 72)*c^2 + (11*Pi^2 - 72)*c + Pi^2 - 24)
what I mean by c-collected is
collect(f2,c,simplify)
This is the nominator of the n^{-2} term.
I sort of managed by the following to procedings:
of:=[op(f)];
add(`~`[`/`](collect~(numer~(of), c, factor), ` $`, denom(of)));
add(collect~(of, c, simplify));
but the first one seems cumbersome for such a trivial thing that should be handled by collect. It also does not factor out the e.g. 12*ln(c)-Pi^2. This seems to be a general behaviour
g:=a*x*(x+1);
collect(g,x) does not factor out the a as in a*(x^2+x).
With the second method I'm more or less happy, but I didn't manage to completely collect the c terms i.e. the n^{-1} term is still c*(c+1) and not c^2+c.
Instead of getting a pop message telling me I have been cut off from the maple kernel can I please know how to recieve that error in the output of my worksheet instead?
Why does it insist I have to close and reopen the worksheet?
I was just thinking that if it were in my worksheets output I could have the current procedure in a try catch statement and write the occurance of the loss of server connection to a text file that is being checked by a script that will then send the necessary keystrokes to maple to save the worksheet close it then reopen it
Maple2020 was installed in windows 10 home. When installing maplesim 2019, it was looking for maple2019. Do I have to install maple 2019 before maplesim 2019?
P1 := plot([-sin(t), t, t = 0 .. 2*Pi], coords = polar, color = red);
P2 := plot([cos(t), t, t = 0 .. 2*Pi], coords = polar, color = blue);
display(P1, P2, scaling = constrained);
I have two polar equation in the same graph but how do i shade the region between those two polar curve?
s1 := RootOf(D1*D2*D6*_Z^2+(-D1*D4*D6-D2*D6*S-D4)*_Z+D4*D6*S)
s2 := -(D1*RootOf(D1*D2*D6*_Z^2+(-D1*D4*D6-D2*D6*S-D4)*_Z+D4*D6*S)*D6-S*D6+RootOf(D1*D2*D6*_Z^2+(-D1*D4*D6-D2*D6*S-D4)*_Z+D4*D6*S))/(D2*D6*RootOf(D1*D2*D6*_Z^2+(-D1*D4*D6-D2*D6*S-D4)*_Z+D4*D6*S))
algsubs(s = RootOf(D1*D2*D6*_Z^2+(-D1*D4*D6-D2*D6*S-D4)*_Z+D4*D6*S), s2)
I try to use s1 to represent s2, and I get the following result:
-(D1*__SELECTION(RootOf(D1*D2*D6*_Z^2+(-D1*D4*D6-D2*D6*S-D4)*_Z+D4*D6*S))*D6-S*D6+RootOf(D1*D2*D6*_Z^2+(-D1*D4*D6-D2*D6*S-D4)*_Z+D4*D6*S))/(D2*D6*RootOf(D1*D2*D6*_Z^2+(-D1*D4*D6-D2*D6*S-D4)*_Z+D4*D6*S))
what is mean of __SELECTION, If algsubs cannot work well, what should I do?
How can I load a .m file with the big green arrow ?
TIA
If I execute a program like:
pathname := "C:\\Users\\Gregory McColm\\Desktop\\Scratch2";
filename := "WhatGives6.txt";
stream := cat(pathname, "\\", filename);
Y := seq(rand(1..10)(), j = 1..10);
writeto(stream);
for i from 1 to 10 do
 printf("X[ %d ]:= %d;\n", i, Y[i]);
writeto(terminal);
printf("DONE\n");
Maple will print exactly what I told it to print.  But when I enter
filename := "WhatGives44.txt";
writeto(stream);
 Y := rand(1..10)();
 printf("X[ %d ]:= %d;\n", i, Y);
writeto(terminal);
printf("DONE\n");
Maple prints:
             YAssign7, [Typesetting:-mprintslash([Y := 7], [7])]
X[ 1 ]:= 7;
           YAssign10, [Typesetting:-mprintslash([Y := 10], [10])]
X[ 2 ]:= 10;
             YAssign6, [Typesetting:-mprintslash([Y := 6], [6])]
X[ 3 ]:= 6;
             YAssign2, [Typesetting:-mprintslash([Y := 2], [2])]
X[ 4 ]:= 2;
             YAssign4, [Typesetting:-mprintslash([Y := 4], [4])]
X[ 5 ]:= 4;
X[ 6 ]:= 6;
             YAssign5, [Typesetting:-mprintslash([Y := 5], [5])]
X[ 7 ]:= 5;
             YAssign1, [Typesetting:-mprintslash([Y := 1], [1])]
X[ 8 ]:= 1;
             YAssign8, [Typesetting:-mprintslash([Y := 8], [8])]
X[ 9 ]:= 8;
X[ 10 ]:= 5;
This must be more than a matter of calling rand when I am writing to terminal, for if I enter:
filename := "WhatGives8.txt";
writeto(stream);
X := rand(0..1)():
printf("Mary had a little lamb\n");
writeto(terminal);
printf("DONE\n");
then all Maple prints is "Mary is a little lamb".  I have tried this on Maple 2018 and Maple 2019, with the same results.
Any ideas or suggestions?
I'm having trouble converting a static plot to animated plot:
Also I've been considering using functional operators instead of expressions so that there's no reuse of variable s when drawing different curves, though I'm not sure if this will be harder to differentiate since diff(expr, s) does not work on a functional operator meaning I'd have to do unapply(diff(f(s),s),s) which seems a long route and I'm not sure if it's what I'm looking for (in terms of simplification).
Thanks guys
agentpath.mw
 Hello everyone!
 I want to find all solutions of  following equations :
I used Maple 2019:
solutions:=solve([abs(1+1/3*lambda+1/18*lambda^2-1/324*lambda^3+1/1944*lambda^4)-1=0],[lambda]);
evalf(solutions)
The output is:
So we have two solutions. But when I use Matlab 2018,
four solutions are returned.
syms lambda
eqn =abs(1+1/3*lambda+1/18*lambda^2-1/324*lambda^3+1/1944*lambda^4)-1==0;
solx1=solve(eqn, lambda)
solx1 =
 root (z1 ^ 4-6 * z1 ^ 3 + 108 * z1 ^ 2 + 648 * z1, z1, 1)
 root (z1 ^ 4-6 * z1 ^ 3 + 108 * z1 ^ 2 + 648 * z1, z1, 2)
 roots (z1 ^ 4-6 * z1 ^ 3 + 108 * z1 ^ 2 + 648 * z1, z1, 3)
 roots (z1 ^ 4-6 * z1 ^ 3 + 108 * z1 ^ 2 + 648 * z1, z1, 4)
solx3=solve(eqn, lambda,   'MaxDegree', 4)
double(solx3)
%%The solution is:
 -4.2681 + 0.0000i
 0.0000 + 0.0000i
 5.1340 -11.2012i
5.1340
+ 11.2012i
It is easy to check that  first two in Maple and Matlab are  same.
Who is right? Does Maple miss complex solutions?
Dear,
I need to attach CPU time to my iterations/Computations, please how do I obtain that in Maple. I tried
a:=time ()
Iterations code
cputime:=time() -a;
But the issue is that once I rerun the code, It produces different cpu time, kindly help me out here.
First make sure that  and  are unassigned variables and then enter the Maple command
This tells Maple that  is a postive real number.  (You will see more on using "assume" later.)
Next, calculate the improper definite integral of
(8sin(x)+11cos(x))e^(−52cx)
for  from 0 to ∞ and assign this to the variable .  (Notice that Maple displays  as  to indicate it that an assumption has been made about .)
Finally calculate the limit of  times  as  tends to infinity and enter the limit in the box below.  (Enter your answer exactly using Maple syntax, not as a decimal.)
Can someone please help me in this? I cant really understand this.
1 discuss and show graphically the effects of decrease in wage on labor supply. if A, leisure is normal good. B, if leisure is inferior good.
How do I animate the cylinder width, or some variation of it as we trace it's path in the z-axes
with(plottools);
display([seq(cylinder([2, 2, 2], 3, i/10, capped = false), i = 1 .. 60)], insequence);
First 624 625 626 627 628 629 630 Last Page 626 of 2472
