Hollo evreyone,
Can you help me to plot the functions given by the pdf attached file.
N.B : One can take theta=pi.
Best regardsplot.pdf
I have a list and I would like to generate all the permutations of that list deterministically and sequential. All I have found is shuffle which may duplicate results(of course I could track this to avoid dups but it should be overkill and slow and consume lots of memory).
I’m starting a large project in education for which I can see great potential in the use of the “MapleCloud”.  For many of the students, the ability to see information on their phone is a game-changer. Hence while my students do have access to Maple on their computers, they are more willing to check out a worksheet if they can view it in a browser.
Unfortunately, in the little time that I have started using MapleCloud, and sharing my work with others, numerous issues have arisen. Some examples:
  * the file system is too simplistic and can be overwhelmed easily as I add content;
  * the group sharing system is too limited – one must log on, which is not true for worksheets;
  * the display of the mathematics is sufficiently quirky that it is not easy to read;
  * the hiding of input mathematics appears not to work;
  * plots, animations and the output of the Explore function fails too frequently.
So, my questions:
  1) are you using MapleCloud, and
  2) if so, for what?
  3) And if you are using MapleCloud, do you have similar problems?
  4) Have you developed solutions that you would be willing to share.
If there is no interest, I’ll look in another direction. But if there is sufficient interest, I would hope Maplesoft notices and works to correct and improve. Some of it may be my own failing to understand Maple, but instead of overwhelming MaplePrimes with questions, I would rather converse with similar interested folks.
Dear Users! I solved a PDE by using the following code.
restart;a := 1:b:= 2:l:= 1:alpha[1]:= 1:alpha[2]:= 3:
  syspde:= [diff(u(x, t), t)-a+u(x, t)-u(x, t)^2*v(x, t)-alpha[1]*(diff(u(x, t), x$2)) = 0, diff(v(x, t), t)-b+u(x, t)^2*v(x, t)-alpha[2]*(diff(v(x, t), x$2)) = 0];
Bcs:= [u(x,0)=1,v(x,0)=1,D[1](u)(-l, t) = 0,D[1](u)(l, t) = 0,D[1](v)(-l, t) = 0,D[1](v)(l, t) = 0];
  sol:=pdsolve(syspde, Bcs, numeric);
  p1:=sol:-plot3d( u(x,t), t=0..1, x=-1..1, color=red);
  p2:=sol:-plot3d( v(x,t), t=0..1, x=-1..1, color=blue);
Now I want to see the value of u(x, t)+diff(u(x, t), x)+diff(u(x, t), t) when x=0 and t=1. Please help me to fix the problem. Thanks in advance.
with(RegularChains):
with(ChainTools):
with(MatrixTools):
with(ConstructibleSetTools):
with(ParametricSystemTools):
with(SemiAlgebraicSetTools):
with(FastArithmeticTools):
R := PolynomialRing([x,y,z,a,b]):
sys := [x^2 + y^2 - x*y - 1 = 0, y^2 + z^2 - y*z - a^2 = 0, z^2 + x^2 - x*z - b^2 = 0,x > 0, y > 0, z > 0, a - 1 >= 0, b-a >= 0, a+1-b > 0]:
dec := RealTriangularize(sys,R): # very slow
Display(dec, R);
dec := LazyRealTriangularize(sys,R): # it is faster
dec2 := value(dec): # very slow
value(dec2);
find a , b to satisfy sys have real solution
expect  one of solution is below, but above function are very slow, load a very time still no result, where is wrong?
R1 = a^2+a+1-b^2;
R1 = a^2-1+b-b^2;
[R1 > 0, R2 > 0]
When the Explore command results in a slider, for example like this:
Explore(plot(x^2 + a, x = 0 .. 10), a = 10.5000000000 .. 11.5000000000)
The value shown next to the slider has only one decimal place, despite the fact that the slider can be easly placed at values in between.  Is there a way to change the number of decimal places shown on the slider label for the Explore command?
    In this example, we have the KdV equation
         t] - 6 uux] + xxx] = 0
    I would like to find the Lax pair for the KdV equation, which are
               Lψ=λψ
               ψ[t] = Mψ
              Lt+ML-LM = 0  called a compatibility condition
    So, I will start from this purpose
    Then we will assume M in the form
              M := a3*Dx^3+a^2+a1*Dx+a0
    thenb using M and L in the for L[tL-LM = 0can find
      Dx^5+( ) Dx^4+( ) Dx^3+( ) Dx^2+( ) Dx+( )=0
    then wean find a_i =0,1,2,3
  In the following maple code to do that
  my question is
   .How I canoue the soluo get a_i2,3 usinmaple code
    any maple packge to find Lax pair for PDE -
restart; with(DEtools); with(PDEtools)
     in this exampile we have KdV equation
      u[t]-6*uu[x]+u[xxx] = 0
    I would likeind the Lax pair for the KdV equation, which are
       Lψ=λψ
    psi[t] = M*psi
   where``
    L[t]+ML-LM = 0    called  apatibility  condition
    So, I  will start this purpose
     L:=-Dx^2+u;
    then we will assume M the m
    Ma3*Dx^3+a2*Dx^2+Dx+a0
    then busing in the form L[t]+ML-LM = 0 can find
  ( ) Dx^5+( ) Dx^4+( ) Dx^3+( ) Dx^2+( ) Dx+( )=0
 then we can find a_i ;i=,2,3
the fllowile code to
 my queion is ;
  1) How I can continue the solution  to get a_i ;i=0,1,2,3 using maple code  ?
  2) isir any maple packge to find  Lax pair for PDE ?
alias(u = u(x, t)); declare(u(x, t)); alias(a3 = a3(x, t)); declare(a3(x, t)); alias(a2 = a2(x, t)); declare(a2(x, t)); alias(a1 = a1(x, t)); declare(a1(x, t)); alias(a0 = a0(x, t)); declare(a0(x, t))
u
` u`(x, t)*`will now be displayed as`*u
u, a3
` a3`(x, t)*`will now be displayed as`*a3
u, a3, a2
` a2`(x, t)*`will now be displayed as`*a2
u, a3, a2, a1
` a1`(x, t)*`will now be displayed as`*a1
u, a3, a2, a1, a0
` a0`(x, t)*`will now be displayed as`*a0
_Envdiffopdomain := [Dx, x]
[Dx, x]
L := -Dx^2+u
-Dx^2+u
M := Dx^3*a3+Dx^2*a2+Dx*a1+a0
a3*Dx^3+a2*Dx^2+a1*Dx+a0
LM := expand(mult(L, M))
-a3*Dx^5-2*Dx^4*(diff(a3, x))-a2*Dx^4+Dx^3*u*a3-Dx^3*(diff(diff(a3, x), x))-2*Dx^3*(diff(a2, x))-Dx^3*a1+Dx^2*u*a2-Dx^2*(diff(diff(a2, x), x))-2*Dx^2*(diff(a1, x))-Dx^2*a0+Dx*u*a1-Dx*(diff(diff(a1, x), x))-2*Dx*(diff(a0, x))+u*a0-(diff(diff(a0, x), x))
ML := expand(mult(M, L))
-a3*Dx^5-a2*Dx^4+Dx^3*u*a3-Dx^3*a1+3*Dx^2*a3*(diff(u, x))+Dx^2*u*a2-Dx^2*a0+3*Dx*a3*(diff(diff(u, x), x))+2*Dx*a2*(diff(u, x))+Dx*u*a1+a3*(diff(diff(diff(u, x), x), x))+a2*(diff(diff(u, x), x))+a1*(diff(u, x))+u*a0
Commutator := simplify(ML-LM)
a3*(diff(diff(diff(u, x), x), x))+(3*Dx*a3+a2)*(diff(diff(u, x), x))+diff(diff(a0, x), x)+Dx*(diff(diff(a1, x), x))+Dx^2*(diff(diff(a2, x), x))+Dx^3*(diff(diff(a3, x), x))+(3*Dx^2*a3+2*Dx*a2+a1)*(diff(u, x))+2*Dx^4*(diff(a3, x))+2*Dx^3*(diff(a2, x))+2*Dx^2*(diff(a1, x))+2*Dx*(diff(a0, x))
sol := diff(L, t)-Commutator = 0
diff(u, t)-a3*(diff(diff(diff(u, x), x), x))-(3*Dx*a3+a2)*(diff(diff(u, x), x))-(diff(diff(a0, x), x))-Dx*(diff(diff(a1, x), x))-Dx^2*(diff(diff(a2, x), x))-Dx^3*(diff(diff(a3, x), x))-(3*Dx^2*a3+2*Dx*a2+a1)*(diff(u, x))-2*Dx^4*(diff(a3, x))-2*Dx^3*(diff(a2, x))-2*Dx^2*(diff(a1, x))-2*Dx*(diff(a0, x)) = 0
collect(sol, [Dx, x])
-2*Dx^4*(diff(a3, x))+(-(diff(diff(a3, x), x))-2*(diff(a2, x)))*Dx^3+(-3*a3*(diff(u, x))-(diff(diff(a2, x), x))-2*(diff(a1, x)))*Dx^2+(-2*a2*(diff(u, x))-3*a3*(diff(diff(u, x), x))-(diff(diff(a1, x), x))-2*(diff(a0, x)))*Dx-a1*(diff(u, x))-a2*(diff(diff(u, x), x))-a3*(diff(diff(diff(u, x), x), x))-(diff(diff(a0, x), x))+diff(u, t) = 0
Download find_lax_pair.mw
Is it possible to force Maple to simplify these Sum(s) ?
SimplifySum.mw
s := Sum(a*X[n]+b, n=1..N);
simplify(s);
value(s);  # part of the job done  but...
IWouldLikeToHave = a*Sum(X[n], n=1..N) + b*N; # or +N*b, it doesn't matter
Sum(a*X[n]+b, n = 1 .. N)
N*b+sum(a*X[n], n = 1 .. N)
IWouldLikeToHave = a*(Sum(X[n], n = 1 .. N))+N*b
s := Sum(X[n]+Y[n], n=1..N);
(expand@value)(s);
IWouldLikeToHave = Sum(X[n], n=1..N) + Sum(Y[n], n=1..N);
Sum(X[n]+Y[n], n = 1 .. N)
sum(X[n]+Y[n], n = 1 .. N)
IWouldLikeToHave = Sum(X[n], n = 1 .. N)+Sum(Y[n], n = 1 .. N)
I performed an iteration of over 300 using for loop, how can I label each of the output? Please help...
Hi ,
How to animate implicitplot?
plots:-animatecurve(1/x, x = 0 .. 5, thickness = 5, size = [150, 150], axes = none, color = red)
with(plots, implicitplot)
P1 := implicitplot(x^2+y^2 = 9, x = -3 .. 3, y = -9 .. 9, thickness = 5, size = [150, 150], axes = none, color = red)
plots:-animatecurve(2*abs(x), x = -.5 .. .5, thickness = 5, size = [150, 150], axes = none, color = red)
implicitplot(x = -3*abs(sin(y)), x = -3 .. 3, y = 0 .. 6, thickness = 5, size = [150, 150], axes = none, color = red)
with(plots)
P1 := plots:-animatecurve(sqrt(1-(abs(x)-1)^2), x = -2 .. 2, thickness = 5, axes = none)
P2 := plots:-animatecurve(arccos(1-abs(x))-Pi, x = -2 .. 2, thickness = 5, axes = none)
P := display(P1, P2, view = [-2 .. 2, -3 .. 1], size = [350, 350], axes = none)
Download LoveMaple1Anim.mws.mw
with(plots)
Hello everyone.
I have a very simple question.  When I use maple to solve the following equations,  everything works as expected
solve({
a + b + c + d = 0,
d * (480-471.1) + b * (484.3-471.1) + c * (547.2-471.1) + m4 = 0,
a * (471.1-484.3) + d * (480-484.3) + c * (547.2-484.3)  + m4 = 0,
a * (471.1-547.2) + d * (480-547.2) + b * (484.3-547.2) + m4 = 0,
a * (471.1-477) + d * (480-477) + b * (484.3-477) + c * (547.2-477) + m4 = 0,
a * (471.1-494) + d * (480-494) + b * (484.3 - 494) + c * (547.2 - 494) + m4 = 0,
a * (471.1-540) + d * (480-540) + b * (484.3 - 540) + c * (547.2-540) + m4 = 0,
a * (471.1-477) + m1 = 0,
a * (471.1-494) + d * (480-494) + b * (484.3 - 494) + m2 = 0,
a * (471.1-540) + d * (480-540) + b * (484.3 - 540) + m3 = 0},{a,b,c,d,m4})
Now if I add one more equation to it then maple won't solve
solve({
a + b + c + d = 0,
a * (471.1-481) + d * (480-481) + mx = 0},{a,b,c,d,m4,mx})
Obviously,  using the first solve command,  I can solve for a and d.  I can substitude that into the last equation and solve for mx.  But for some reason, maple just won't do that for me directly from the second solve command.
Can someone help?  thanks
When I tried to copy any of the expression among (1) and (4), the only MathML string appearing at the target application is this:
<math xmlns='http://www.w3.org/1998/Math/MathML'></math>
n:= 2:
X:= Vector(n, symbol= x);
Vector(2, {(1) = x[1], (2) = x[2]})
W:= Matrix(3,2, symbol= w);
Matrix(3, 2, {(1, 1) = w[1, 1], (1, 2) = w[1, 2], (2, 1) = w[2, 1], (2, 2) = w[2, 2], (3, 1) = w[3, 1], (3, 2) = w[3, 2]})
V:= W.X;
Vector(3, {(1) = w[1, 1]*x[1]+w[1, 2]*x[2], (2) = w[2, 1]*x[1]+w[2, 2]*x[2], (3) = w[3, 1]*x[1]+w[3, 2]*x[2]})
answer:=seq(diff~(v,W), v= V);
answer := Matrix(3, 2, {(1, 1) = x[1], (1, 2) = x[2], (2, 1) = 0, (2, 2) = 0, (3, 1) = 0, (3, 2) = 0}), Matrix(3, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = x[1], (2, 2) = x[2], (3, 1) = 0, (3, 2) = 0}), Matrix(3, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0, (3, 1) = x[1], (3, 2) = x[2]})
Can you tel me how to fix this error?
Download question1a.mw
Refers to yMaple 2019.1
The command alias(X(s)=laplace(x(t),s,t)) will not be executed in the  code following it. It seems that the 'funny font' L used instead of the word 'laplace' ist not recognized. Maple 2018.2.1 works fine, since it doesn't use the 'L" but works with 'laplace'. Is there a fix ?
Consider the following problem.
I'm looking for an implementation of the following approximation-method. Thanks to @Carl Love I already have a code for the exact solution. (It might be that my example using the given A,b,c does not have a solution but then I would just have to use different A, b, c.)
num211.pdf
I uploaded the question as a pdf so that it is nicer to read.
I know there are probably better ways which are already part of some packages but I want to use this method.
Edit:
A procedure that does the following is all I need:
num211_2.pdf
see below.  I am getting IC and BC errors.  The code is below/attached.  Can anyone help?
Melvin
This is a corrected version of pdeProb2.mw, in which we examine the 1-D classical burgers equation, and find an asymptotic steady state in the solution fields u, v which is not reached by a solution via numerical simulation.
NOTE:  When generating and displaying PLOTS AT HIGH RESOLUTION, do not use p1 := plot(bla, etc);  i.e. do not end with a semicolon.   Instead, end with a colon viz  p1 := plot(bla, etc): which sends the result to p1 instead of  generating an excess memory use message.  Then create the plot by executing p1; i.e. end the assigned p1 with a semicolon to display the graphics result.
We load the MAPLE Physics package from the MapleCloud, in order to support solutions using pdsolve().
PackageTools:-Install*`\`("5137472255164416", version = 329, overwrite):`
restart; Physics:-Version()
"C:\Users\Melvin Brown\maple\toolbox\2018\Physics Updates\lib\Physics Updates.maple", `2019, October 2, 14:20 hours, version in the MapleCloud: 597, version installed in this computer: 329.`
Start of definition of problem:
with(PDETools); with(CodeTools); with(plots)
[CanonicalCoordinates, ChangeSymmetry, CharacteristicQ, CharacteristicQInvariants, ConservedCurrentTest, ConservedCurrents, ConsistencyTest, D_Dx, DeterminingPDE, Eta_k, Euler, FromJet, FunctionFieldSolutions, InfinitesimalGenerator, Infinitesimals, IntegratingFactorTest, IntegratingFactors, InvariantEquation, InvariantSolutions, InvariantTransformation, Invariants, Laplace, Library, PDEplot, PolynomialSolutions, ReducedForm, SimilaritySolutions, SimilarityTransformation, Solve, SymmetryCommutator, SymmetryGauge, SymmetrySolutions, SymmetryTest, SymmetryTransformation, TWSolutions, ToJet, ToMissingDependentVariable, build, casesplit, charstrip, dchange, dcoeffs, declare, diff_table, difforder, dpolyform, dsubs, mapde, separability, splitstrip, splitsys, undeclare]
with(PDETools); with(CodeTools);with(plots);
[CPUTime, DecodeName, EncodeName, GCTime, Profiling, ProgramAnalysis, RealTime, Test, ThreadSafetyCheck, Usage]
Two 1-D coupled Burgers equations - semiclassical case O(1), O( `&hbar;`) : retain O(1) only for u(x,t) and O(1), O( `&hbar;`) for v(x,t):
In the quantum case, there are two coupled quantum Burgers equations, which each include the quantum potential terms.  As in the classical case above, we apply constant external forces Fuand Fv.  Our aim is to display the profiles of u(x, t) and v(x, t) as strings on x, t space.
#hBar := 'hBar': m := 'm':Fu := 'Fu': Fv := 'Fv': # define constants
hBar:= 1:m:= 1:Fu:= 0.2:Fv:= 0.1: # set constant values - same as above ...consider reducing
Notice that we set `&hbar;` = 1
At O( `&hbar;`^2) the real quantum potential term is zero, leaving the classical expression:
pdeu := diff(u(x,t),t)+u(x,t)/m*(diff(u(x,t),x)) = Fu;
diff(u(x, t), t)+u(x, t)*(diff(u(x, t), x)) = .2
As in the classical case above, the temporal and spatial derivative are each of order 1; so only one initial condition and one boundary condition are required for this part of the semiclassical equations.
On the otherhand, the imaginary quantum potential equation for v(x,t) has only O( `&hbar;`)  terms so together the pair of equations for u, v are semiclassical:
pdev := diff(v(x,t),t)+u(x,t)/m*(diff(v(x,t),x))-hBar*(diff(u(x,t),x$2))/(2*m)+v(x,t)*(diff(u(x,t),x))/m = Fv;
diff(v(x, t), t)+u(x, t)*(diff(v(x, t), x))-(1/2)*(diff(diff(u(x, t), x), x))+v(x, t)*(diff(u(x, t), x)) = .1
By inspection of the derivatives in above two equations we now set up the ICs and BCs for u(x, t) and "v(x,t). "Note that the above second order spatial derivative requires a 1st order derivative boundary condition as defined below.
The quantum initial and boundary conditions are similar to the classical case, but also comprise additional boundary condition terms for v and for u, notably a 1st derivative reflective BC term for u.
ICu:={u(x,0) = 0.1*sin(2*Pi*x)};# initial conditions for PDE pdeu
{u(x, 0) = .1*sin(2*Pi*x)}
ICv:={v(x,0) = 0.2*sin(Pi*x)};# initial conditions for PDE pdev
{v(x, 0) = .2*sin(Pi*x)}
IC := ICu union ICv;
{u(x, 0) = .1*sin(2*Pi*x), v(x, 0) = .2*sin(Pi*x)}
BCu := {u(0,t) = 0.5*(1-cos(2*Pi*t)),D[1](u)(1,t) = 0}; # boundary conditions for PDE pdeu: note the reflective derivative term D[1](u)
{u(0, t) = .5-.5*cos(2*Pi*t), (D[1](u))(1, t) = 0}
BCv := {v(0,t) = 0.5*sin(2*Pi*t), v(1,t)=-0.5*sin(2*Pi*t)}; # boundary conditions for PDE pdev
{v(0, t) = .5*sin(2*Pi*t), v(1, t) = -.5*sin(2*Pi*t)}
BC := BCu union BCv;
{u(0, t) = .5-.5*cos(2*Pi*t), v(0, t) = .5*sin(2*Pi*t), v(1, t) = -.5*sin(2*Pi*t), (D[1](u))(1, t) = 0}
This set of equations and conditions can now be solved numerically.
The above IC and BC are both 0 at 0, 0 and thus consistent.
pdu := pdsolve({pdeu,pdev},{IC,BC},numeric, time = t,range = 0..1,spacestep = 1/66,timestep = .1);
Error, (in pdsolve/numeric/process_IBCs) invalid initial/boundary condition: {u(x, 0) = .1*sin(2*Pi*x), v(x, 0) = .2*sin(Pi*x)}
Here is the 3D plot of u(x,t):
T := 3; p1 := pdu:-plot3d(u,t=0..T,numpoints = 2000,x=0.0..2, shading = zhue,orientation=[-146,54,0],scaling = constrained, title = print("Figure 1",u(x, t), numeric));
Error, `pdu` does not evaluate to a module
Download Semiclassical_Burgers_Eqns_-_MRB.mw
First 627 628 629 630 631 632 633 Last Page 629 of 2458
