Would you let me know how to run a matrix differentiation?
with(VectorCalculus):
x:=<<x1>,<x2>>
W:=<<w11, w12>|<w21, w22>>
Cal:=Transpose(W.x).(W.x)
## Up to this point, there was no problem
map(diff,Cal,x) ## Then, this operation caused an error
What I wanted to do is
diff(VectorCalculus:-Norm(W.x)^2, x)
Thank you,
In Kwon Park
L := proc(N) N; end:
plot([seq(L(min(5, max(-5, 5^(x*10) + 5^(x*k))),k=0..10))], x = 0..3);
Warning, expecting only range variable x in expression max(-5,5^(10*x)+5^(x*k)) to be plotted but found name k
Removing L and everythign works. I want maple to first compute the inner expression before calling L. But even thenn it shouldn't matter in this case, it is just an identity function.
There should be no reason why this can't be done. I experience this *type* of problem with maple a lot. Where it seems to try to compute everything symbolically and breaks in some cases for unknown reasons.
I want to find the numbers a, b, c, d, t, m, n of this equation. I tried
 k := 0:
 for a to 10 do
for b to 10 do
for c to 10 do
for d to 10 do
for t to 2 do
for m to 10 do
for n to 10 do
if a > c and igcd(a, b, c, d, t, m, n) = 1 and abs(b)+abs(d)-n <> 0 then X := [solve(abs(a*x+b)+abs(c*x+d)-t*x^2+m*x-n = 0)]; if nops(X) = 6 and type(X[1], integer) and type(X[2], integer) and type(X[3], integer) and type(X[4], integer) and type(X[5], integer) and type(X[6], integer) then k := k+1; L[k] := [a, b, c, d, t, m, n, X[]]
end if end if
end do end do end do end do end do end do end do;
L := convert(L, list);
k;
L;
I can not get the result for along time. How can I get the result and reduce the time?
Is it possible to create the operator command : |x| so that it passes x to the VectorCalculus Norm function so that if I write:
>  | < 3, 0, 4> |
the result is 5?
I have a Maple program and i need to call a python script with a specified input (10 integers). The script returns a number that I would like to use in my Maple program afterwards. This is what I would do in shell:
result=`python model.py 1 2 3 4 5 6 7 8 9 10`
echo $result
Is there a way to get the `result` using Maple? I checked the documentation for Maple and it is not very clear so I appreciate any help on this. Thanks!
Hi everyone:
I have a matrix with 2(n+1) row and (n+1)^2 column, for example, the matrix A at the below with n=1:
A:=Matrix(4, 8, [[-1, 1-t, 0, 0, 0, 0, 0, 0], [0, 0, 1, 1+t, 0, 0, 0, 0], [0, 0, 0, 0, -1, 1-t, 0, 0], [0, 0, 0, 0, 0, 0, 1, 1+t]]);
I want to obtain the B matrix that created by the matrix A with a general code in Maple:
B:=Matrix(4, 8, [[-1, 1-t1, 0, 0, 0, 0, 0, 0], [0, 0, 1, 1+t1, 0, 0, 0, 0], [0, 0, 0, 0, -1, 1-t2, 0, 0], [0, 0, 0, 0, 0, 0, 1, 1+t2]]);
I can the create the A matrix with any value of n and my goal is create the B matrix?
tnx...
This question is used for general demonstration purposes only. I wish to animate a periodic function whose amplitude is growing and I'd like to trace the growth over time.
Can anyone suggest a simple function that can provide this requirement? The example given here is the basic sine curve of fixed amplitude and wavelength.
Thanks for reading.
MaplePrimes_Question.mw
From a previous calculation, I got the following nested sum:
Sum(Sum(f[n]*g[q-n]*exp(2*i*Pi*q*x),q = -infinity .. infinity),n = -infinity ..
infinity)
However, to keep on the calculus, It is more convenient to have:
Sum(Sum(f[n]*g[q - n]*exp(2*i*Pi*q*x), n = -infinity .. infinity), q = -infinity .. infinity)
That is, permute the summation precedence.
Is there a way to automatically transform the first expression into the second one?
Can Minimize function in maple locate all the local optima of a function. Thank you.
ODE := 2.56*(diff(x(t), t, t))+.32*(diff(x(t), t))+x(t)+0.5e-1*x(t)^3 = 2.5*sin(t)
a1 := 2.56; a2 := .32; a3 := 0.5e-1; B := sin(t)
dfieldplot([diff(x(t), t) = y(t), diff(y(t), t) = (B-a2*y(t)-x(t)-a3*x(t)^3)/a1], [x(t), y(t)], t = -2 .. 2, x = -1 .. 2, y = -1 .. 2, arrows = SLIM, color = black, dirfield = [10, 10])
Error, (in DEtools/dfieldplot) cannot produce plot, non-autonomous DE(s) require initial conditions.
I frequently title my plots to identify what is being plotted. Very often that means specifying a parameter. For example, I might want the title to read;  Exponential when the power is c.
In the above I want to replace c with a real number. For example, my command might read
> for c from 1 to 10 do
p||c := plot( x^c, x= -1..1, title= the power is c )
I can then display the sequence of plots nicely labelled.
That does not work.
I cannot find adequate  info about what follows title =  in the help pages or the manual so I end up creating a worksheet and experimenting for quite a while until I find something that works.
(The Help page says: “The value t can be an arbitrary expression.” That’s it. One can go to the typesetting page to get more info about captions which is probably relevant but it begins to feel like learning about sex by looking up words in the dictionary.
BTW, I have been using Maple for 18+ years so I should have a cheat sheet somewhere to remind me of the correct syntax but I am suggesting that Maple would be much more user friendly if this info was in the help pages.
It would be very nice to have a fuller explanation with more examples.
Here is what works:
c:=3;  # special case
plot(x^c, x=-1..1,title=`power is `|| c);  Why back quotes?
or
cc:=convert(c,string);
plot(x^c,x=-1..1,title=[`power is `||cc]);   why barckets?
or not as nice
plot(x^c,x=-1..1,title=power.is.cc);  why dots?
or if you get rid of the is
plot(x^c,x=-1..1,title=[power = c]);  why noy use is?
not as nice
plot(x^c,x=-1..1,title=[power = cc]);  ugly quote marks
Here is a list of failures in this very simple case:
c:=3;
plot(x^c,x=-1..1,title="power is c");
plot(x^c,x=-1..1,title=power is c);
cc:="c";plot(x^c,x=-1..1,title="power is cc");
or
plot(x^c,x=-1..1,title=power is cc);
cc:=convert(c,string);plot(x^c,x=-1..1,title="power is cc");
plot(x^c,x=-1..1,title='power is cc');
plot(x^c,x=-1..1,title=[power, is, cc]);
plot(x^c,x=-1..1,title='power = cc');
plot(x^c,x=-1..1,title=power = cc); but plot(x^2,x=-1..1,title=[power = cc]);is acceptable
another couple of failures:
plot(x^c,x=-1..1,title=[`power is c`]);
plot(x^c,x=-1..1,title=[`power is cc`]);
I want to define the co-ordianates (phi, PI, ....)  as functions of some variable eg:- x,y.
Hi everyone,
When my cursor is on an output, the paragraph style changes to 2D Output, as it most likely should. When I then go to a new executable line, it takes forever for all of my expressions to "light up" (meaning that it takes a while for me to be able to use them), and it takes forever for the paragraph to go from 2D Output to 2D Math.
I sadly don't remember when this happened, or what might have caused it, but if any of have any suggestions or answers, I'd greatly appreciate it.
Thanks for listening,
A confused highschool student.
,Hello dears
I have the following function
where L=10 and I want to plot this function, so I use
But it does not work.
Is there any help.
Amr
Im beginner in Maple so i need a help with the following differential equation:
y'' - y = 0 where y(0) = 0 and y(1) = 1
I solved this but im confused how can i solve it in Maple.
Thank you in advance.
First 629 630 631 632 633 634 635 Last Page 631 of 2458
