I would like to change the color and font type on the Maple-2019 inputs and outputs, so that these formatting would be applied every time I started a new document. I tried doing this through the Styles option on the Format menu, but I could not. Can anyone help? Thank you.
Which sorting related with famous sequence
for example
sorting differential equation in a list
then access the list with famous sequence as index such as using https://oeis.org/
after access with sequence as index, use choose function to get combinations then most result are isomorphism differential ideals?
is there methods about this sorting in Richard Stanley Combinatiric book? which page of it?
Are there commands in Maple to find the order and degree of an ODE?  Searching help I could not find anything so far.
For an example, given
ode:=(1+diff(y(x),x)^2)^(3/2)=diff(y(x),x$2)
I want the command to return 2 for the order of the ODE and degree is also 2 in this case.
I looked at DEtools package and googled. I am sure Maple have build in commands to do this without me having to parse the ODE myself to find out.
Folks,
I am new to maple and looking to solve for all value of a list and return alist as the result
fI := [12.5, 16, 20, 25, 31.5, 40, 50, 63, 80, 100, 125, 160, 200, 250, 315, 400, 500, 630, 800, 1000, 1250, 1600, 2000, 2500, 3150, 4000, 5000, 6300, 8000, 10000, 12500, 16000, 20000];
x:= 23
y:= 36
Lp:= 8-10*log[10]((1+(f1/(2*x))^2.5)*(1+(y/(2.*f1))^1.7))
I am looking to solve Lp to give a result in the form: [a,b,c,d....] i.e solve for  all values of f1 and return a list.
Many Thanks
Last month I still can read file
by
read “c://Users//hello//Documents//h.m”
but
now it return error
no read access c://Users//hello//Documents/
in security I add the m file into readable
I saw open file at c drive has many shell folders
i just add m file
but still the same error
i unencrypted m file by window properties
i save file into maple roaming directory under 12 folder , still the same error
i save into maple installation directory maple 12 , still the same error
I have a system of ODEs with parameters, p[i], and variables, x[i].
f := [
-p[1]*x[1]^2+x[2],
-2*p[1]^2*x[1]^3+2*p[1]*x[1]*x[2]+x[1]+1
associated with the innitial conditions:
[x[1](0) = p[2], x[2](0) = p[3]].
I am interested in sets of parameters where the solution x[1](t) is the same; if [p[1],p[2],p[3]] is associated with a solution x(p,t), and [ph[1],ph[2],ph[3]] is asociated with the solution x(ph,t); then x[1](p,t)=x[1](ph,t) for all t if and only if
[ph[1] = ph[1],
ph[2] = p[2],
ph[3] = -p[1]*p[2]^2+p[2]^2*ph[1]+p[3]]
i.e. ph[1] takes any real value, ph[2] takes the same values as p[2] and ph[3] takes a value determined by the original parameter vector and ph[1].
In a previous question it was demonstrated that x[2](ph,t)/x[2](p,t) rapidly converge on p[1] as t increases for a specific parameter vector that was given in the question (see graph below)
This raises the question does this limit generally hold?
I have struggled to do this in maple and I am suspicious of the answer i have got
i.e.
limit (x[2](ph,t)/x[2](p,t),t=infinity)=+/- infinity
My question is
+ when does a finite limit exist?
+ what is the finite limit?
I would like to see if MAPLE fits our needs. In order to see that I would like to consider the example which is posted in H. Iwaniec :"Introduction to the spectral theory (...)" p. 36, that is as follows:
Suppose that you have a PDE as follows:
This PDE has the following point symmetries:
These differential operators are the representations of the following matrix algebra:
1. I would like to see the MAPLE commands, which give the algebra $v_1, v_2, v_3$
2. I would like to see those commands, which give you the algebra $v_1, v_2, v_3$ as a representation of $X_1, X_2, X_3$.
3. Given the algebra $v$ I would like to see the commands which give you the Laplace-Beltrami operator $\Delta_{LB}=y\partial_{xx} + y\partial_{yy}$
( P.s. sorry for the intransparent form, I do not know how to insert formulae in the comment.)
G45073
possible to solve following equation with unknown parameter omega.
parameter constant.
I see before for one dimension ode this type equation was solved.
Now for 2d equation is possible?
can consider or I can send again.
Best
2d-2
Dear Maple users
I have a question about performing operations on a matrix and another one about retrieving information from a matrix. I am looking for the easiest (hopefully also the shortest) way to do it:
1. Given a matrix with several rows and columns. I want to permute the rows in such a way that the entries in a specific column are ordered (either ascending or decending as wished).
2. Given a matrix with several rows and columns. I want to count how many entries in a specific column are above a certain given fixed value.
I am pretty sure some of you guys out there can do it in an elegant way. Examples will be appreciated.
Erik
pde1 := k*(diff(u(x, t), x, x)) = diff(u(x, t), t)
k*(diff(diff(u(x, t), x), x)) = diff(u(x, t), t)
iv1 := u(0, t) = 0, u(L, t) = 0, u(x, 0) = 2;
pdsolve([pde1, iv1], u(x, t))
u(x, t) = Sum(-4*(-1+(-1)^(_Z4*csgn(1/L)))*sin(Pi*_Z4*x/L)*exp(-Pi^2*_Z4^2*k*t/L^2)/(Pi*_Z4), _Z4 = 1 .. infinity)
subs(`~`[_Z4] = n, %)
"I would like to replace the symbol _Z4~ with the letter n. I tried with the subs command, but I could not. Can anyone help"?"" ""
Download evaluate_a_sum.mw
Why am I not able to use my MaplePrimes login credentials to login into MapleCloud?
I am facing a problem to calculate the variable "al" in a equation like shown below.
fe := int(sqrt(1+(-5.557990765*sin(5.557990765*x)-7.3*cos(5.557990765*x)-5.6*sinh(5.557990765*x)+7.3*cosh(5.557990765*x))^2), x = 0 .. al) = .5
Is there any method in maple to solve it even through using numeric methods.
I'm forward to your response.
Thank you very much!
so i just went from a really old version of maple to a the newest one maple 2019 and at first glance it doesn't seem to work correctly please take a look at the picture maybe there is a toggle i missed or something of the sorts thanks you for your time
Dear Users!
Hoped everything going fine with you. I constrcut the following code to construct the polynomials for any M1 and M2
printlevel := 2; M1 := 3; M2 := 3; nu := 1;
for k1 from 0 while k1 <= M1-1 do
for k2 from 0 while k2 <= M2-1 do
GP[k1+1, k2+1] := simplify(sum((-1)^(k1-i1)*GAMMA(k1+i1+2*nu)*GAMMA(nu+1/2)*x^i1*(sum((-1)^(k2-i2)*GAMMA(k2+i2+2*nu)*GAMMA(nu+1/2)*y^i2/(GAMMA(i2+nu+1/2)*factorial(k2-i2)*factorial(i2)*GAMMA(2*nu)), i2 = 0 .. k2))/(GAMMA(i1+nu+1/2)*factorial(k1-i1)*factorial(i1)*GAMMA(2*nu)), i1 = 0 .. k1))
end do end do;
I want to put this polynomials in a vector like
[GP[1,1]   GP[1,2]   GP[1,3]   GP[2,1]   GP[2,2]   GP[2,3]   GP[3,1]   GP[3,2]   GP[3,3]]
Similarlty I want to construct a vector having constants for any values of M1 and M2 like this
[a[1,1]   a[1,2]   a[1,3]   a[2,1]   a[2,2]   a[2,3]   a[3,1]   a[3,2]   a[3,3]]
In worksheet mode when me is writing my code, running code, evaluating is and can not work well with maple?
How can inactive  action? Because have to wait many times and is very boring for me.
First 663 664 665 666 667 668 669 Last Page 665 of 2425
