In trying to evaluate the accuracy of an asymptotic approximation, I asked evalf to return the numerical value of the difference of two expressions.  It evaluated each expression but would not take their difference (see line 6).  Any idea what's going on?
g := exp(-r*cosh(x))*x^(2*n); G := Int(g, x = 0 .. infinity)
Int(exp(-r*cosh(x))*x^(2*n), x = 0 .. infinity)
f0 := arccosh(1+y); df0 := diff(f0, y)
1/(y^(1/2)*(2+y)^(1/2))
f := f0^(2*n)*df0
arccosh(1+y)^(2*n)/(y^(1/2)*(2+y)^(1/2))
n := 2; series(f, y)
2*2^(1/2)*y^(3/2)-(7/6)*2^(1/2)*y^(5/2)+(47/80)*2^(1/2)*y^(7/2)-(17281/60480)*2^(1/2)*y^(9/2)+O(y^(11/2))
r := 6; evalf(G)
0.8560816424e-4
Ghat := exp(-r)*(2*sqrt(2)*GAMMA(5/2)*`-`*(7*sqrt(2)*(1/6))/r^(5/2)*(GAMMA(7/2)/r^(7/2))); Ghat1 := evalf(Ghat)
0.1056905544e-3-0.2568867641e-4*``
evalf(Ghat1)
Download asyapprox.mw
I am working with an expression in Maple that involves complex terms and an integral. After applying the simplify command, some terms remain unsimplified, even though they seem reducible (see (7)). Additionally, an integral in my expression remains unevaluated (see (9)).
kernelopts(version);
`Maple 2022.0, X86 64 WINDOWS, Mar 8 2022, Build ID 1599809`
with(plots)
interface(showassumed=0):
assume(x::real);assume(t::real);assume(lambda1::complex);assume(b::real);
alias(psi1 = psi1(x,t), psi2 = psi2(x,t), phi1 = phi1(x,t), phi2 = phi2(x,t), beta = beta(t), alpha =alpha(t));
psi1, psi2, phi1, phi2, beta, alpha
rel := {psi1 = exp((-I*lambda1)*x - (1/(4*I*lambda1))*int((alpha + b*beta),t)), psi2 = exp((I*lambda1)*x + (1/(4*I*lambda1))*int((alpha + b*beta),t)), phi1= exp((-I*conjugate(lambda1))*x - (1/(4*I*conjugate(lambda1)))*int((alpha + b*beta),t)), phi2 = exp((I*conjugate(lambda1))*x + (1/(4*I*conjugate(lambda1)))*int((alpha + b*beta),t))}
{phi1 = exp(-I*conjugate(lambda1)*x+((1/4)*I)*(int(b*beta+alpha, t))/conjugate(lambda1)), phi2 = exp(I*conjugate(lambda1)*x-((1/4)*I)*(int(b*beta+alpha, t))/conjugate(lambda1)), psi1 = exp(-I*lambda1*x+((1/4)*I)*(int(b*beta+alpha, t))/lambda1), psi2 = exp(I*lambda1*x-((1/4)*I)*(int(b*beta+alpha, t))/lambda1)}
Bnum := psi2*phi1*conjugate(lambda1) + psi1*lambda1*phi2;
psi2*phi1*conjugate(lambda1)+psi1*lambda1*phi2
Bnumexp := subs(rel,Bnum):
Den := -phi1*psi2 - phi2*psi1;
-phi1*psi2-phi2*psi1
expDen := subs(rel, Den)
-exp(-I*conjugate(lambda1)*x+((1/4)*I)*(int(b*beta+alpha, t))/conjugate(lambda1))*exp(I*lambda1*x-((1/4)*I)*(int(b*beta+alpha, t))/lambda1)-exp(I*conjugate(lambda1)*x-((1/4)*I)*(int(b*beta+alpha, t))/conjugate(lambda1))*exp(-I*lambda1*x+((1/4)*I)*(int(b*beta+alpha, t))/lambda1)
sr := Bnumexp/expDen: ratiosr := simplify(diff(sr,t), complex):
B := b - (4*I/beta(t))*ratiosr
b+2*(b*beta+alpha)*exp(((1/4)*I)*(4*conjugate(lambda1)^2*x-(int(b*beta+alpha, t)))/conjugate(lambda1))*exp(-((1/4)*I)*(4*conjugate(lambda1)^2*x-(int(b*beta+alpha, t)))/conjugate(lambda1))*exp(-((1/4)*I)*(4*lambda1^2*x-(int(b*beta+alpha, t)))/lambda1)*(-conjugate(lambda1)+lambda1)^2*exp(((1/4)*I)*(4*lambda1^2*x-(int(b*beta+alpha, t)))/lambda1)/(beta(t)*(exp(((1/4)*I)*(4*conjugate(lambda1)^2*x-(int(b*beta+alpha, t)))/conjugate(lambda1))*exp(-((1/4)*I)*(4*lambda1^2*x-(int(b*beta+alpha, t)))/lambda1)+exp(-((1/4)*I)*(4*conjugate(lambda1)^2*x-(int(b*beta+alpha, t)))/conjugate(lambda1))*exp(((1/4)*I)*(4*lambda1^2*x-(int(b*beta+alpha, t)))/lambda1))^2*lambda1*conjugate(lambda1))
p := {alpha(t) = t^2, beta = exp(-t)}
{beta = exp(-t), alpha(t) = t^2}
B1 := eval(subs(p, B))
b+2*(b*exp(-t)+alpha)*exp(((1/4)*I)*(4*conjugate(lambda1)^2*x-(int(b*exp(-t)+alpha, t)))/conjugate(lambda1))*exp(-((1/4)*I)*(4*conjugate(lambda1)^2*x-(int(b*exp(-t)+alpha, t)))/conjugate(lambda1))*exp(-((1/4)*I)*(4*lambda1^2*x-(int(b*exp(-t)+alpha, t)))/lambda1)*(-conjugate(lambda1)+lambda1)^2*exp(((1/4)*I)*(4*lambda1^2*x-(int(b*exp(-t)+alpha, t)))/lambda1)/((exp(-t))(t)*(exp(((1/4)*I)*(4*conjugate(lambda1)^2*x-(int(b*exp(-t)+alpha, t)))/conjugate(lambda1))*exp(-((1/4)*I)*(4*lambda1^2*x-(int(b*exp(-t)+alpha, t)))/lambda1)+exp(-((1/4)*I)*(4*conjugate(lambda1)^2*x-(int(b*exp(-t)+alpha, t)))/conjugate(lambda1))*exp(((1/4)*I)*(4*lambda1^2*x-(int(b*exp(-t)+alpha, t)))/lambda1))^2*lambda1*conjugate(lambda1))
Download simplify.mw
is(cos(x)=sqrt(1-sin(x)^2) or cos(x)=-sqrt(1-sin(x)^2)) assuming real;
In a simpler situation the result is correct
is(x=0 or x<>0) assuming real;
SymPy can handle the following query to its assumption system:
>>> from sympy import Q, ask
>>> from sympy.abc import x, y, z
>>> ask(Q.zero(x*y*z), Q.zero(x*z) & Q.real(y))
True
>>> ask(Q.zero(x*y*z), (Q.zero(x) | Q.zero(z)) & Q.real(y))
True
>>> ask(Q.zero(x*y) | Q.zero(y*z), Q.zero(x*z) & Q.real(y))
True
Mathematica can handle an equivalent query:
In[21]:= Assuming[{x*z == 0}, Refine[x*y*z == 0]]
Out[21]= True
However, it can't handle a similar type of query:
In[25]:= Assuming[{x == 0 || z == 0}, Simplify[x*y*z == 0]]
Out[25]= x y z == 0
In[28]:= Assuming[{x*y == 0}, Refine[x*z == 0 || z*y == 0]]
Out[28]= x z == 0 || y z == 0
It seems that Maple can't handle this type of query at all:
> with(RealDomain);
> is(x*y*z = 0) assuming (x*z = 0, y::real);
FAIL
However, Maple can handle simpler assumptions like x = 0:
> is(x*y*z = 0) assuming (x = 0, y::real, z::real);
Is there some way to use Maple's assumption system to reason about assumptions like x*y=0? I believe that's not possible. If Maple can infer either x=0 or y=0 from x*z=0, its assumption system doesn't seem to be capable of dealing with this sort of assumption.
Based on a paper by Weibel and Gonnet (1993), it doesn't seem like Maple can reason about assumptions that are disjunctions of properties for more than one variable, such as "property p holds for x OR property p holds for y."
SymPy can handle these sorts of queries because it uses a SAT solver as part of its assumption system. However, there is no mention of a SAT solver—or any method of checking multiple possibilities—in the referenced paper or related papers on Maple's assumption system.
Am I correct that Maple's assumption system is not capable of handling this sort of query?
Weibel, T., Gonnet, G.H. (1993). An assume facility for CAS, with a sample implementation for Maple. In: Fitch, J. (ed) Design and Implementation of Symbolic Computation Systems. DISCO 1992. Lecture Notes in Computer Science, vol 721. Springer, Berlin, Heidelberg. https://doi.org/10.1007/3-540-57272-4_27
By the way, is there some way to use markdown for these questions? I made the above post by asking chatgpt to convert markdown into html.
How do i plot / graph a limt? The plot must have a hole at 2 because it is undefined.
limit((x^2-1)/(x-1), x = 1) = 2NULL
Download graph-a-limit.mw
i want to get zero of this function i did all part true but i don't know why my pde not getting zero after substitute each parameter and part
with(PDEtools)
undeclare(prime)
p := 2*k; n := 1; xi := -p*t+x
2*k
-2*k*t+x
"U(xi):=(B[1] (RootOf(3 _Z^2-3 _Z-1)+coth(xi)))^(-1/n);u(x,t):=(B[1] (RootOf(3 _Z^2-3 _Z-1)+coth(-p t+x)))^(-1/n) (e)^(&ImaginaryI; (k x-t w))"
proc (xi) options operator, arrow, function_assign; (B[1]*(RootOf(3*_Z^2-3*_Z-1)+coth(xi)))^(-1/n) end proc
proc (x, t) options operator, arrow, function_assign; (B[1]*(RootOf(3*_Z^2-3*_Z-1)+coth(-p*t+x)))^(-1/n)*exp(I*(k*x-t*w)) end proc
pde := I*(diff(u(x, t), t))+diff(u(x, t), `$`(x, 2))+eta*u(x, t)+beta*U(xi)^n*u(x, t)+gamma*U(xi)^(2*n)*u(x, t)+delta*U(xi)^(3*n)*u(x, t)+lambda*U(xi)^(4*n)*u(x, t) = 0
I*(2*exp(I*(k*x-t*w))*k*(1-coth(2*k*t-x)^2)/(B[1]*(RootOf(3*_Z^2-3*_Z-1)-coth(2*k*t-x))^2)-I*w*exp(I*(k*x-t*w))/(B[1]*(RootOf(3*_Z^2-3*_Z-1)-coth(2*k*t-x))))+2*exp(I*(k*x-t*w))*(1-coth(2*k*t-x)^2)^2/(B[1]*(RootOf(3*_Z^2-3*_Z-1)-coth(2*k*t-x))^3)-(2*I)*k*exp(I*(k*x-t*w))*(1-coth(2*k*t-x)^2)/(B[1]*(RootOf(3*_Z^2-3*_Z-1)-coth(2*k*t-x))^2)+2*exp(I*(k*x-t*w))*coth(2*k*t-x)*(-1+coth(2*k*t-x)^2)/(B[1]*(RootOf(3*_Z^2-3*_Z-1)-coth(2*k*t-x))^2)-k^2*exp(I*(k*x-t*w))/(B[1]*(RootOf(3*_Z^2-3*_Z-1)-coth(2*k*t-x)))+eta*exp(I*(k*x-t*w))/(B[1]*(RootOf(3*_Z^2-3*_Z-1)-coth(2*k*t-x)))+beta*exp(I*(k*x-t*w))/(B[1]^2*(RootOf(3*_Z^2-3*_Z-1)-coth(2*k*t-x))^2)+gamma*exp(I*(k*x-t*w))/(B[1]^3*(RootOf(3*_Z^2-3*_Z-1)-coth(2*k*t-x))^3)+delta*exp(I*(k*x-t*w))/(B[1]^4*(RootOf(3*_Z^2-3*_Z-1)-coth(2*k*t-x))^4)+lambda*exp(I*(k*x-t*w))/(B[1]^5*(RootOf(3*_Z^2-3*_Z-1)-coth(2*k*t-x))^5) = 0
case1 := [beta = 2*RootOf(3*_Z^2-3*_Z-1)*(n+2)/(B[1]*n^2), delta = 2*B[1]*(RootOf(3*_Z^2-3*_Z-1)+1)*(3*n+2)/(3*n^2), eta = (k^2*n^2*B[1]^2-n^2*w*B[1]^2-1)/(n^2*B[1]^2), gamma = -6*RootOf(3*_Z^2-3*_Z-1)*(n+1)/n^2, lambda = B[1]^2*(3*RootOf(3*_Z^2-3*_Z-1)-7)*(2*n+1)/(9*n^2), A[0] = RootOf(3*_Z^2-3*_Z-1)*B[1], A[1] = 0, B[1] = B[1]]
[beta = 6*RootOf(3*_Z^2-3*_Z-1)/B[1], delta = (10/3)*B[1]*(RootOf(3*_Z^2-3*_Z-1)+1), eta = (k^2*B[1]^2-w*B[1]^2-1)/B[1]^2, gamma = -12*RootOf(3*_Z^2-3*_Z-1), lambda = (1/3)*B[1]^2*(3*RootOf(3*_Z^2-3*_Z-1)-7), A[0] = RootOf(3*_Z^2-3*_Z-1)*B[1], A[1] = 0, B[1] = B[1]]
pde3 := eval(pde, case1)
Download test.mw
Could you explain me why the three forms of patmatch behave identically (which seems natural) but the three forms of type do not.
Is there a way to define the type in type such that this latter returns the same thing for a*f(x)+b, f(x)*a+b, b+a*f(x), b+f(x)*a ?
Z := f(x)*a+b;
t1 = type(Z, `&+`(algebraic, `&*`(algebraic, function)));
t2 = type(Z, `&+`(`&*`(algebraic, function), algebraic));
t3 = type(Z, `&+`(`&*`(function, algebraic), algebraic));
f(x)*a+b
t1 = false
t2 = false
t3 = true
p1 = patmatch(Z, A::algebraic*f(X::algebraic) + B::algebraic, 'pat');
pat;
p2 = patmatch(Z, B::algebraic + A::algebraic*f(X::algebraic), 'pat');
pat;
p2 = patmatch(Z, B::algebraic + f(X::algebraic)*A::algebraic, 'pat');
pat;
p1 = true
[A = a, B = b, X = x]
p2 = true
p2 = true
Download type_vs_patmatch.mw
TIA
Recently, Maple has become almost unuseable. Whatever I do, it suddenly becomes non-reponsive, the cursor stops blipping and nothing happens for about a minute, although I can still move the cursor around and the page slider works, suggesting that the kernel has gone mad.
Then suddenly it comes back to life, executes where it left off, which in most cases happens while I am typing input. A minute later it's back to sleep. When I look at the CPU usage while it is non-responsive, I can see CPU usage is about 30% (there is nothing else significant running), disk usage is about 1% and there is plenty of memory (everything in total wants about 10GB and I have 32GB).
I have the -nocloud parameter set and finally disconnected the network connection, but that didn't help.
It all seems to have started with the most recent upgrade, although I'm not 100% sure of that.
Is anyone else seeing something like this, or better yet, does anyone have a suggestion to make this behaviour stop?
How does one downgrade to 2024.1?
the second ode is giving me zero also when we back to orginal under the condition by using them must the orginal ode be zero but i don't know where is mistake , when Orginal paper use some thing different but i think they must have same results i don't know i use them wrong i am not sure at here just , when U(xi)=y(z) in my mw
with(PDEtools)
undeclare(prime)
G := V(xi) = RootOf(3*_Z^2-3*_Z-1)*B[1]+B[1]*(exp(xi)+exp(-xi))/(exp(xi)-exp(-xi))
p := 2*k
2*k
ode := I*(-(diff(U(xi), xi))*p*exp(I*(k*x-t*w))-I*U(xi)*w*exp(I*(k*x-t*w)))+(diff(diff(U(xi), xi), xi))*exp(I*(k*x-t*w))+(2*I)*(diff(U(xi), xi))*k*exp(I*(k*x-t*w))-U(xi)*k^2*exp(I*(k*x-t*w))+eta*U(xi)*exp(I*(k*x-t*w))+beta*U(xi)^n*U(xi)*exp(I*(k*x-t*w))+gamma*U(xi)^(2*n)*U(xi)*exp(I*(k*x-t*w))+delta*U(xi)^(3*n)*U(xi)*exp(I*(k*x-t*w))+lambda*U(xi)^(4*n)*U(xi)*exp(I*(k*x-t*w)) = 0
I*(-2*(diff(U(xi), xi))*k*exp(I*(k*x-t*w))-I*U(xi)*w*exp(I*(k*x-t*w)))+(diff(diff(U(xi), xi), xi))*exp(I*(k*x-t*w))+(2*I)*(diff(U(xi), xi))*k*exp(I*(k*x-t*w))-U(xi)*k^2*exp(I*(k*x-t*w))+eta*U(xi)*exp(I*(k*x-t*w))+beta*U(xi)^n*U(xi)*exp(I*(k*x-t*w))+gamma*U(xi)^(2*n)*U(xi)*exp(I*(k*x-t*w))+delta*U(xi)^(3*n)*U(xi)*exp(I*(k*x-t*w))+lambda*U(xi)^(4*n)*U(xi)*exp(I*(k*x-t*w)) = 0
[beta = 2*RootOf(3*_Z^2-3*_Z-1)*(n+2)/(B[1]*n^2), delta = (2/3)*B[1]*(RootOf(3*_Z^2-3*_Z-1)+1)*(3*n+2)/n^2, eta = (k^2*n^2*B[1]^2-n^2*w*B[1]^2-1)/(n^2*B[1]^2), gamma = -6*RootOf(3*_Z^2-3*_Z-1)*(n+1)/n^2, lambda = (1/9)*B[1]^2*(3*RootOf(3*_Z^2-3*_Z-1)-7)*(2*n+1)/n^2, A[0] = RootOf(3*_Z^2-3*_Z-1)*B[1], A[1] = 0, B[1] = B[1]]
n := 1
G := U(xi) = (B[1]*(RootOf(3*_Z^2-3*_Z-1)+coth(xi)))^(-1/n)
U(xi) = 1/(B[1]*(RootOf(3*_Z^2-3*_Z-1)+coth(xi)))
pde3 := eval(ode, case1)
I*(-2*(diff(U(xi), xi))*k*exp(I*(k*x-t*w))-I*U(xi)*w*exp(I*(k*x-t*w)))+(diff(diff(U(xi), xi), xi))*exp(I*(k*x-t*w))+(2*I)*(diff(U(xi), xi))*k*exp(I*(k*x-t*w))-U(xi)*k^2*exp(I*(k*x-t*w))+(k^2*B[1]^2-w*B[1]^2-1)*U(xi)*exp(I*(k*x-t*w))/B[1]^2+6*RootOf(3*_Z^2-3*_Z-1)*U(xi)^2*exp(I*(k*x-t*w))/B[1]-12*RootOf(3*_Z^2-3*_Z-1)*U(xi)^3*exp(I*(k*x-t*w))+(10/3)*B[1]*(RootOf(3*_Z^2-3*_Z-1)+1)*U(xi)^4*exp(I*(k*x-t*w))+(1/3)*B[1]^2*(3*RootOf(3*_Z^2-3*_Z-1)-7)*U(xi)^5*exp(I*(k*x-t*w)) = 0
odetest(eval(G, case1), pde3)
79584*exp(I*k*x-I*t*w+12*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-127440*exp(I*k*x-I*t*w+10*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+8352*exp(I*k*x-I*t*w+6*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-27792*exp(I*k*x-I*t*w+8*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-24*exp(2*xi-I*t*w+I*k*x)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+4752*exp(I*k*x-I*t*w+4*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+288*exp(2*xi-I*t*w+I*k*x)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-479376*exp(I*k*x-I*t*w+12*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+138240*exp(I*k*x-I*t*w+10*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+70560*exp(18*xi+I*k*x-I*t*w)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-492912*exp(I*k*x-I*t*w+16*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+777888*exp(I*k*x-I*t*w+14*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+16608*exp(I*k*x-I*t*w+8*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-1056*exp(I*k*x-I*t*w+6*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+288*exp(I*k*x-I*t*w+4*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-39000*exp(18*xi+I*k*x-I*t*w)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-50400*exp(I*k*x-I*t*w+16*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+121440*exp(I*k*x-I*t*w+14*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+27000*RootOf(3*_Z^2-3*_Z-1)*exp(18*xi+I*k*x-I*t*w)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-55080*RootOf(3*_Z^2-3*_Z-1)*exp(18*xi+I*k*x-I*t*w)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+7200*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+16*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+394416*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+16*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-205920*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+14*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-609984*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+14*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-244512*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+12*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+366768*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+12*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-42480*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+10*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-144720*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+10*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-48672*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+8*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+8208*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+8*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+9504*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+6*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+20736*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+6*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+288*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+4*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+18576*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+4*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-72*RootOf(3*_Z^2-3*_Z-1)*exp(2*xi-I*t*w+I*k*x)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+1080*RootOf(3*_Z^2-3*_Z-1)*exp(2*xi-I*t*w+I*k*x)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))
simplify(-492912*exp(I*k*x-I*t*w+16*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+777888*exp(I*k*x-I*t*w+14*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+16608*exp(I*k*x-I*t*w+8*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-1056*exp(I*k*x-I*t*w+6*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+288*exp(I*k*x-I*t*w+4*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-39000*exp(18*xi+I*k*x-I*t*w)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-50400*exp(I*k*x-I*t*w+16*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+121440*exp(I*k*x-I*t*w+14*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+79584*exp(I*k*x-I*t*w+12*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-127440*exp(I*k*x-I*t*w+10*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+8352*exp(I*k*x-I*t*w+6*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-27792*exp(I*k*x-I*t*w+8*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-24*exp(2*xi-I*t*w+I*k*x)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+4752*exp(I*k*x-I*t*w+4*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+288*exp(2*xi-I*t*w+I*k*x)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-479376*exp(I*k*x-I*t*w+12*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+138240*exp(I*k*x-I*t*w+10*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+70560*exp(18*xi+I*k*x-I*t*w)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-55080*RootOf(3*_Z^2-3*_Z-1)*exp(18*xi+I*k*x-I*t*w)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+7200*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+16*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+394416*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+16*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-205920*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+14*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-609984*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+14*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-244512*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+12*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+366768*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+12*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-42480*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+10*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-144720*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+10*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-48672*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+8*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+8208*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+8*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+9504*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+6*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+20736*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+6*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+288*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+4*xi)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+18576*RootOf(3*_Z^2-3*_Z-1)*exp(I*k*x-I*t*w+4*xi)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))-72*RootOf(3*_Z^2-3*_Z-1)*exp(2*xi-I*t*w+I*k*x)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+1080*RootOf(3*_Z^2-3*_Z-1)*exp(2*xi-I*t*w+I*k*x)/(B[1]^3*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1))+27000*RootOf(3*_Z^2-3*_Z-1)*exp(18*xi+I*k*x-I*t*w)/(B[1]*(3125*exp(20*xi)+25000*exp(18*xi)+76875*exp(16*xi)+108000*exp(14*xi)+55650*exp(12*xi)-12432*exp(10*xi)-11130*exp(8*xi)+4320*exp(6*xi)-615*exp(4*xi)+40*exp(2*xi)-1)))
(((244512*B[1]^2-366768)*exp(10*xi)+(205920*B[1]^2+609984)*exp(12*xi)+(-7200*B[1]^2-394416)*exp(14*xi)+42480*exp(8*xi)*B[1]^2-27000*exp(16*xi)*B[1]^2-288*exp(2*xi)*B[1]^2-9504*exp(4*xi)*B[1]^2+48672*exp(6*xi)*B[1]^2+72*B[1]^2+144720*exp(8*xi)+55080*exp(16*xi)-18576*exp(2*xi)-20736*exp(4*xi)-8208*exp(6*xi)-1080)*RootOf(3*_Z^2-3*_Z-1)+(-79584*B[1]^2+479376)*exp(10*xi)+(-121440*B[1]^2-777888)*exp(12*xi)+(50400*B[1]^2+492912)*exp(14*xi)+127440*exp(8*xi)*B[1]^2+39000*exp(16*xi)*B[1]^2-288*exp(2*xi)*B[1]^2+1056*exp(4*xi)*B[1]^2-16608*exp(6*xi)*B[1]^2+24*B[1]^2-138240*exp(8*xi)-70560*exp(16*xi)-4752*exp(2*xi)-8352*exp(4*xi)+27792*exp(6*xi)-288)*exp(2*xi-I*t*w+I*k*x)/(B[1]^3*(-3125*exp(20*xi)-25000*exp(18*xi)-76875*exp(16*xi)-108000*exp(14*xi)-55650*exp(12*xi)+12432*exp(10*xi)+11130*exp(8*xi)-4320*exp(6*xi)+615*exp(4*xi)-40*exp(2*xi)+1))
Download ode.mw
this is my first time something like that   coming up my equation after taking integral exponential coming up why?
g1.mw
the series is so complicated but have a strange pattern if you watch the index of parameter  they are not repeated
I am looking for a simpler way to find the equation of a parabola passing through 3 points. I see that using the Geometry package requires defining the parabola with 5 distinct points. Thank you for your guidance.QuestionParabole.mw
Do you think the result of String(0.016)  should be "0.016"  instead of ".16e-1" ?
Any reason why it gives the second form and not the first?  Now have to keep using sprintf to force formating as decimal point. Is this documented somewhere? quick search did not find anything do far.
Maple 2024.2 on windows.
s:="0.016";
"0.016"
z:= :-parse(s);
0.16e-1
String(z);
".16e-1"
sprintf("%0.3f",z);
"0.016"
Download string_of_decimal_number.mw
I'd like to know the details of the method Statistics:-Mean uses to numerically estimate the expectation of a random variable.
showstat seems of no use and neither seems to be LibraryTools[Browse]();
Here are two examples: the first one (1D) suggests  Statistics:-Mean could use some evalf/Int method, but the conclusion to draw from the second example (R2 --> R) is less clear.
How_does_Mean_proceed.mw
PS: I already asked a similar question months ago but didn't get any reply.
       Even answers such as “We don't know” or “We don't care” would suit me better than their absence.
with(geometry);
_EnvHorizontalName := 'x';
_EnvVerticalName := 'y';
HC := HorizontalCoord;
VC := VerticalCoord;
a := 11;
b := 7;
t := (3*Pi)/8;
c := sqrt(a^2 - b^2);
ellipse(e1, x^2/a^2 + y^2/b^2 = 1);
point(Oo, 0, 0);
point(A, a*cos(t), b*sin(t));
point(B, a*cos(t + 2/3*Pi), b*sin(t + 2/3*Pi));
point(C, a*cos(t + 4/3*Pi), b*sin(t + 4/3*Pi));
point(G, (A[1] + B[1] + C[1])/3, (A[2] + B[2] + C[2])/3);
eval(coordinates(G));
line(NorA, y - A[2] = a^2*A[2]*(x - A[1])/b^2, [x, y]);
line(NorB, y - B[2] = a^2*B[2]*(x - B[1])/b^2, [x, y]);
line(NorC, y - C[2] = a^2*C[2]*(x - C[1])/b^2, [x, y]);
lieu := a^2*x^2 + b^2*y^2 - c^4/4 = 0;
Lieu := implicitplot(lieu, x = -a .. a, y = -b .. b, color = green);
tx := textplot([[coordinates(A)[], "A"], [coordinates(B)[], "B"], [coordinates(C)[], "C"], [coordinates(Oo)[], "O"]], font = [times, bold, 16], align = [above, left]);
dr := draw([e1(color = blue), NorA(color = red), NorB(color = red), NorC(color = red), A(color = red, symbol = solidcircle, symbolsize = 12), B(color = red, symbol = solidcircle, symbolsize = 12), C(color = red, symbol = solidcircle, symbolsize = 12), Oo(color = red, symbol = solidcircle, symbolsize = 12)]);
display([dr, tx, Lieu], scaling = constrained, axes = normal, title = "Ellipse et normales ", titlefont = [HELVETICA, 14]);
      [1        1        1       1        1        1     ]
      [- A[1] + - B[1] + - C[1], - A[2] + - B[2] + - C[2]]
      [3        3        3       3        3        3     ]
                              NorA
                              NorB
                              NorC
First 65 66 67 68 69 70 71 Last Page 67 of 2457
