I want to create a matrix of variables, and another matrix of variables that are different from the first matrix.
The idea is to generate a matrix of equations, then reshape the matrix into an array of functions, and then enter the array into "solve" to solve the system of equations.
I was able to do this in a different software package, and I was able to do it.
Basically, (matrix a - matrix b - identity matrix).  Then, "equate" this matrix to a matrix of zeros to generate the right hand side.
Can this be done in maple? How would one do this?
Given a conventionally labeled triangle ABC with the two sides a=3 and b=4, c is not given. What is the side length of the largest inscribed square whose "base" lies on the triangle side c?
How merge or combine two or more 3D plot together ? and How many 3D plot exist for describe graph ? and how we can transfer this combine plot to another program like matlab?
Maple is  good for decribe plot  and very faster from other program but for visualization and some other stuff we need other language program, so how we can combine the plot and how we transfer this plot another program like matlab i know the matlab have special template for this kind plot but i didn't have the template if any one have it it will be  awesome?
Download combine_graph.mw
If we have the system of difference equations
xn=yn-1xn-1+2,             yn=0.5 xn-1+yn-1+1,      n=1,2,...,
 where x0 and y0 are positive initial valyes.
How can I plot the solution {xn,yn} ??
The usual ODE must be solved:
y´´*(y^3-y)+y´^2 *(y^2+1)=0
"Dangerous places" of the definition domain must be described: Where are the general solution y(x) and its derivatives continuous?
This is probably asked before but can't find it.
After making a plot, then RIGHT-CLICKing on it, option menu comes up that allows one to modify the plot (like adding gridlines, or change the line style).
How does one find the Maple command after doing such changes, so one can use the command in the code?
Here is an example. I modified a little acers plot in this answer and added the points to the plot
eq:=-0.0004*x^2 - 2.7680*10^(-28)*x^12 - 2.1685*10^(-43)*x^18 - 1.3245*10^(-37)*x^16 - 1.6917*10^(-32)*x^14 + 0.7650 + 6.6773*10^(-18)*x^8 - 2.5543*10^(-23)*x^10 - 8.0002*10^(-13)*x^6 + 3.6079*10^(-8)*x^4 = 0:
the_roots:=fsolve(eq):
the_roots:=map(X->[X,0],[the_roots]):
p1:=plot(lhs(eq),x=-210..210,size=[500,200]):
p2:=plot(the_roots,style=point, color=red, symbol=solidcircle, symbolsize=20):
plots:-display(p1,p2)
I was lazy to look up the grid option syntax. So right clicked on the plot and found option to add gridline. So said, great. And the above is the result.
But now I'd like to see the command used so I know where the grid option goes and how its syntax is. There does not seem to be option in the interface to display the Maple command used.
How would one find it?
Maple 2024.1 on windows 10
hi...
how can I just find the real roots of this equation in Maple:
I want to solve it first with fsolve (with options) command and second other command than fsolve.
tnx...
I am trying to plot the shearforce of a hollow section circular beam along the hight of the cross section.
I don't seem to be able to solve the equation. I get the message:"Warning, solutions may have been lost"
Can anyone help?
The tricky part is the distance of the "point of grafity of the area above y' to the 'point of grafity of the cross section (y=0)'. This distance is a function of y and is called y_
this is de code: M_V_as_function_of_hight_cc__temporary.mw
restart: with(LinearAlgebra): with(plots, textplot, display): #Digits :=5: evalf(%): with(RealDomain):
Rout:=168.3/2:
Rin :=Rout-12.5:
T:=V*Q/(II*b):
Q:=A_*y_:
bout:=2*sqrt(Rout**2 - y**2):
bin:=piecewise( y<Rin,2*sqrt(Rin**2 - y**2)  ,  y>=Rin,0):
#bin:=Re(2*sqrt(Rin**2 - y**2)):
b:=bout-bin;
A_ :=piecewise(  y<=0,0   ,    y<Rin,evalf( int(b ,  y=y..Rout ) ) ,    y>=Rin,int(bout , y=y..Rout)    ,    y>=Rout,0);
y:=y_: AA_:=A_;
y:='y':
eq1:=2*AA_ = A_:
sol1:=solve(eq1, y_ );
y_ := sol1:
y_;
#plot(y_,y=0..Rout);
Let us say f(x) is a procedure that can take two possible values for x.
How do I store the stats of CodeTools:-Usage(f(1))  and CodeTools:-Usage(f(2)) for ease of comparison?  Hopefully, I am not missing any help statements/examples.
Hi all
I have a simple problem with the following matrix entries. I probably have a problem with the indices. Because the matrix is ​​not calculated correctly. Anyone have suggestion?
Drear freinds,
I want to simplify f (a long experssion) in the form of f2. How to determine M1^2 and M0^2?
f1.mw
I try to run the test.java example but still fails with the error:
Error loading libraries: java.lang.UnsatisfiedLinkError: no jopenmaple in java.library.path: /Library/Frameworks/Maple.framework/Versions/2024/java:/Library/Frameworks/Maple.framework/Versions/2024/java:/Library/Frameworks/Maple.framework/Versions/2024/java
the file jopenmaple.jar is located in
the maple part of my .bash_profile :
# set Maple Home
export MAPLEDIR="/Library/Frameworks/Maple.framework/Versions/2024"
export DYLD_LIBRARY_PATH="$DYLD_LIBRARY_PATH:<BINDIR>"
export MAPLE="<MAPLEDIR>"
export DYLD_LIBRARY_PATH="/Library/Frameworks/Maple.framework/Versions/2024/bin.APPLE_ARM64_MACOS"
export CLASSPATH="/Library/Frameworks/Maple.framework/Versions/2024/JAVA"
The eclipse part:
JDK 22 and Compiler 22
Classpath Variables in Eclipse Java Build Path Settings:
DYLD_LIBRARY_PATH /Library/Frameworks/Maple.framework/Versions/2024/bin.APPLE_ARM64_MACOS
JAVAC /Library/Frameworks/Maple.framework/Versions/2024/java/Maple.jar
MAPLEDIR /Library/Frameworks/Maple.framework/Versions/2024
So I don't know what to do.
I want a plot of the function & the approx. calculus of integral:
E0 := evalf(int(T2, x = x0 .. x0 + 1.542976947*10^(-13))); it doesn't compute in in normal time...Audion.mw
in the program:
a := -1.44670357887361*10^(-7);
b := -1.049267156*10^(-9);
c := 1.890440485*10^(-12);
d := -6.233924848*10^(-16);
Ea := 0.00762014687*t + a*t^2 + b*t^3 + c*t^4 + d*t^5;
E1 := diff(Ea, t);
E2 := subs(t = 435, Ea);
E3 := subs(t = 528, Ea);
E4 := subs(t = 2860, Ea);
It seems that Maple needs more help than necessary:
kernelopts(version)
expr:= A+B*limit(f(x), x=+infinity);
eval(expr, limit(f(x), x=+infinity)=1)
A+B*(limit(f(x), x = infinity))
A+B
expr:= A+B*limit(2*f(x), x=+infinity);
eval(expr, limit(f(x), x=+infinity)=1);     # Shouldn't this return A+2*B
eval(expr, limit(2*f(x), x=+infinity)=2);   # Can I avoid doing this?
A+B*(limit(2*f(x), x = infinity))
A+2*B
expr:= A+B*limit(f(x)^2, x=+infinity);
eval(expr, limit(f(x), x=+infinity)=1);     # Shouldn't this return A+B
eval(expr, limit(f(x)^2, x=+infinity)=1);   # Can I avoid doing this?
A+B*(limit(f(x)^2, x = infinity))
A+B
expr:= A+B*limit(2*f(x)^2, x=+infinity);
eval(expr, limit(f(x)^2, x=+infinity)=1);    # Shouldn't this return A+2*B
eval(expr, limit(2*f(x)^2, x=+infinity)=2);  # Can I avoid doing this?
A+B*(limit(2*f(x)^2, x = infinity))
A+2*B
Download limits.mw
Why don't the commands labelled "Shouldn't this return.." do the job?
TIA
Hi everyone...
How can the coefficients of below nonlinear equation be obtained?
c1*diff(f(x), x$4) + c2*diff(f(x), x$3)/x +c3*diff(f(x), x$2)/x^2 + c4*diff(f(x), x)/x^3 +c5 *f(x)=0
I want to calculate separately, c1,c2,c3,c4,c5
tnx...
First 64 65 66 67 68 69 70 Last Page 66 of 2426
