    This is not an answer. I can't ask question, since I can't add any 'tags'! This problem appeared long time ago, but I hadn't solved it until now. So I ask here.
    I have a question about the function coeffs(). I don't know why it cann't get coefficients for me.
question.mw
Variable disappear after read file and then pass parameter to create thread
I have a question about animating 3d space curves (vector-valued functions). I have a curve that has a component x(t), component y(t), component z(t), and a time, t. The problem says to create an animation of a point moving around the curve. How do I do this?
first I define some constants (note I may change the constants later based on the context of the application)
p_l := 10^(-15);
epsilon := 1.09*10^(-10);
p_B := 1.09*10^(-8);
n_A := 10^7;
k_A := 0;
n_B := 10^8;
k_B := 0;
then I define a function l(x,y):
l := (x, y) -> x^k_A*(1 - x)^(n_A - k_A)*y^k_B*(1 - y)^(n_B - k_B)
Now I use both with(GlobalOptimization) and with(Optimization) to maximize l(x,y) give some constraints and I get:
GlobalSolve(l(x_1, y_1), x_1 = p_l .. epsilon, y_1 = p_B .. 1, maximize, initialpoint = [x_1 = 0, y_1 = 0]);
  [-0., [x_1 = 1.09000000000000 10^(-10)   , y_1 = 0.633548870211381]]
Maximize(l(x_1, y_1), x_1 = p_l .. epsilon, y_1 = p_B .. 1, initialpoint = [x_1 = 0, y_1 = 0]);
 [0.33621648834727435318,  [x_1 = 1.00000000000000 10^(-15)   , y_1 = 1.0900000000000000000 10^(-8)  ] ]
Clearly the second answer is right and the first is wrong... I am not sure why the ``global optimazation'' is doing worse than the normal and free ``optimazation''.. Am I using the GlobalSolve in a wrong way??
A warm greeting for everyone
I have a function in one variable r defined in spherical coordinates f(r)=r^2+1.
I want to getting field plot or gradient plot for this function in spherical coordinates: 0<r<1,  0<theta<Pi/2 and 0<phi<2Pi.
is there any suggestion
Amr
Hi, for each region shown in the figure, there is a single point. I want to define the location constraints of the point in each region
e.g. for region 1 and 5, it is easy to define:
R1 := {p_B <= y_1 <= 1, p_l <= x_1 <= epsilon}
R5:={y_5 <= x_5, p_l <= x_5<= epsilon, p_l <= y_5 <= epsilon}
but what about region 2? it seems wrong if I define like this in maple:
R2 := {epsilon <= x_2 <= p_B, p_B <= y_2 <= 1} union {x_2 <= y_2, p_B <= x_2  <= 1, p_B <= y_2 <= 1}
Or it is actually right....
Hello people in mapleprimes,
I have a question.
I use maple2019 with mac os 10.14.6.
$ sw_vers
ProductName:	Mac OS X
ProductVersion:	10.14.6
BuildVersion:	18G95
With maple2019, errors appears.
> kernelopts(version);
        Maple 2019.1, APPLE UNIVERSAL OSX, Jun 6 2019, Build ID 1403154
> assume(a>-1,b>0);
> additionally(a<=1);
> about(a);
Originally a, renamed a~:
  is assumed to be: FAIL
> assume(tau<1,tau>0,s<1,s>0):
> a_e1:=tau*s*(1+tau)<tau*s+tau+s-1:
> b_e2:=expand(lhs(a_e1)-rhs(a_e1))<0:
>  b_e3:=collect(b_e2,s,factor):
> solve(b_e2,s) assuming tau<1;
Error, (in assuming) when calling 'property/ConvertProperty'. Received: 'FAIL
is an invalid property'
On the other hand, with maple2018, they do not.
       Maple 2018.2, APPLE UNIVERSAL OSX, Nov 16 2018, Build ID 1362973
> assume(a>-1,b>0);
> additionally(a<=1);
> about(a);
  is assumed to be: RealRange(Open(-1),1)
                               [{-------- < s~}]
                                 1 + tau~
Are errors due to some bugs in maple2019 when being used with mac os 10.14.6?
Take care.
taro
Can anyone know how to speed up Directsearch package 2 optimization command
model1.mw
When I run the program it shows an error about one of the dependant variables.
I want to find abs(psi)^2 for below psi
psi=int(int(exp(-a*(mu-b)^2)*exp(-c*(V-d)^2)*exp(I*(Q*u-(5/3*Q)*v^(mu/V)-3/16*(v^(4/V)/Q)))*v^((1/2)*(1-V)/V), mu = 0 .. 2), V = -15 .. 15) when mu=0..2 and V=-15..15 for Q:=3, a=10, c=5, b=3 and d=0.
unfortunatelly, I write above psi in maple 18 but it does not work, please tell me how to calculate (abs(psi))^2 for above wave equation (psi).
with the best regard.
I'm working in MapleSim to model a mechanism called Schatz which has a six-Revolut, known whit TURBULA name.
I modeled the mechanism in CREO to have a CAD part to use in maplesim.
everything is okay when I run the simulation without a speed constant. as shown in the picture above.
when I add a speed source, MapleSim finds an error (Internal error occurred during the simulation).
Can someone help me please?
Is there or will there be a german version or is there a language pack available somewhere?
I was wondering if you can index arrays in maple with a loop. In MATLAB, you can index all rows and columns in the Matrix, A, with A(:,:), or a portion of the elements such as A(2:10,5:20) to index, or "loop" through these specific elements. In Maple, I am trying to index the following elements, as done in MATLAB with the command
dIdQ(nmid-(imax-1)/2:nmid+(imax-1)/2,1) = -(omega_t(1:imax,1) - omega_1(nmid-imax*jmax-(imax-1)/2:nmid-imax*jmax+(imax-1)/2,1));
Is there a way to convert this matlab code to maple code?
Any help is very appreciated. Thank you!
r=a+b sin(x), this is the function I want to plot the graph in polar co-ordinates but how to manage those arbitrary constants "a and b" ?
Hi everyone, I need someone’s expertise with the Maple Soft Application, I am currently into my 4th day of my Maple Soft experience and also returning to School after many years. Can someone help me with the following codes to solve step by step Differential Equation 1 below;
Please help me with following codes below
  1. Boundary Condition 1
  2. Boundary Condition 2
  3. General Solution
  4. The integration Part of the Equation
  5. Solving the Differential Equation
Equation 1.
Determine the equilibrium temperature for a one dimensional rod with a constant thermal properties with the following source and boundary conditions.
  1. Q = 0, U(0) = 10, u(L) = 20
  2. Q/K0 = x, u(0) = 0, u(L) = 10
I understand how to obtain the solution to the equation above,
(a) Equilibrium satisfies
                                                U’’(x) = 0,
Whose general solution is u = c1 + c2x.
The boundary condition u(0) = 0 implies c1 = 0 and u(L) = T implies c2 = T/L so that u = T x/L.
(f) In equilibrium, u satisfies
U’’(x) = −Q/K0 = −x^2,
Whose general solution (by integrating twice) is
u = −x ^4 /12 + c1 + c2x.
The boundary condition u(0) = T yields c1 = T, while u’(L) = 0 yields c2 = L^3/3.
Thus u = −x ^4 /12 + L^3x/3 + T.
First 669 670 671 672 673 674 675 Last Page 671 of 2458
