I would like to display a complete trigonometric circle.like the attached photo. How to do it? Thanks
TrigonometricCircle.mw
It is necessary that the expressions are combined in a new function. So as I'm trying not is obtained.
restart; x := 5; y := 10; f := proc (x, y) options operator, arrow; x+y end proc; f2 := proc (x, y) options operator, arrow; x^2+y^3 end proc; f3 := proc (x, y) options operator, arrow; f+f2 end proc; f3(x, y)
5
10
f+f2
Download testmaple.mw
Dear Users!
Hope you would be fine. I want to export dat file for 3D plot in maple and want to replot it any perfessional software like tecplot, origin.
u:=sin(x+y):
plot3d(sin(x+y), x = 0 .. 2*Pi, y = 0 .. 2*Pi);
How can I export the data in 3D. Thanks in advance for you help.
Apostrophe '  is always interpreted as a "differentiate command", i.e., A' is always translated  to diff(A(x),x).
Is it possible to override this behaviour, it is to say, is there a way for using A' as a variable name?
In euclidean geometry of triangles, A' is a common name given to some points built from vertex A of a triangle ABC.
Thanks in advance,
César Lozada
Please check this code and fix the error. And help me with the below two questions.
1- In the above image, I'm getting the error when I'm to plot my solutions.
2- How to get information from this system?
      The values of x_1 and corresponding y_1 and so on and errors etc
This is a downloadable link to my worksheet [Practice.mw]
How do I get Maple to factorize this simple expression without too much effort?
f:=3/2 + sqrt(8*k + 2) + 2*k
I want to create a distribution table and then find expected value,variance and standard deviation.
For example : X=-1,P(X)=0.2
                       X=0,P(X)=0.25
                       X=1,P(X)=0.35
                       X=2,P(X)=0.2
E(X) would then equal -1*0.2+0*0.25+1*0.35+2*0.2.
How can I do all of this with Maple ?
How should linearization a nonlinear equation with maple?
I'm trying to use the ExpectedValue function to get the next close value of a stock.
restart; with(Finance)
W := WienerProcess()
T := 1.0
S := SamplePath(W(t), t = 0 .. T, timesteps = 100, replications = 10^4)
A := S[1 .. 10^4, 50]
TI := 1
AN := 100 (Start Value)
sigma := 3.5 (volatility)
r := 0.5e-1    (interest)
ANF := AN*exp((r-(1/2)*sigma^2)*TI+sigma*W(TI))       (ANF: is the forecasting Value)
ExpectedValue(ANF, timesteps = 100, replications = 10^3)
Is this approach right?
Why it be like that and how to solve it ?
>restart;
> ODEtools[declare]((S, L, B)(t), prime = t);
         ODEtools[declare](S(t), L(t), B(t), prime = t)
> DE1 := diff(S(t), t) = -L*S*beta-`μS`+mu;
                    d
            DE1 := --- S(t) = -L S beta - μS + mu
                    dt
> DE2 := diff(L(t), t) = L*S*beta-(gamma+mu)*S;
                  d
          DE2 := --- L(t) = beta S L - (gamma + mu) S
                  dt
> DE3 := diff(B(t), t) = L*gamma-gamma*mu;
                      d
              DE3 := --- B(t) = L gamma - gamma mu
                      dt
> init_conds := S(0) >= 0, L(0) >= 0, B(0) >= 0;
         init_conds := 0 <= S(0), 0 <= L(0), 0 <= B(0)
> sys := {init_conds, diff(B(t), t) = L*gamma-gamma*mu, diff(L(t), t) = L*S*beta-(gamma+mu)*S, diff(S(t), t) = -L*S*beta-`&mu;S`+mu};
> sol := dsolve(sys, numeric, parameters = [mu, beta, gamma, S(t), L(t), B(t)], method = rkf45);
> sol(parameters = [mu = .234, beta = 2.345, gamma = 5.678, S(t) = 6.678, L(t) = 6.789, B(t) = 7.123]);
           sol(parameters = [mu = 0.234, beta = 2.345, gamma = 5.678, S(t) = 6.678, L(t) = 6.789, B(t) = 7.123])
Is the following a bug? I am using Maple 2019  64 bit with latest Physics package 357 on windows 10.
pde :=  diff(w(x,y,z),x)+(y^2- a*exp(alpha*x)*(x*y-1))*diff(w(x,y,z),y)+(c*exp(beta*x)*z^2+b*exp(-beta*x))*diff(w(x,y,z),z)= 0;
sol:=pdsolve(pde,w(x,y,z));
diff(w(x, y, z), x)+(y^2-a*exp(alpha*x)*(x*y-1))*(diff(w(x, y, z), y))+(c*exp(beta*x)*z^2+b*exp(-beta*x))*(diff(w(x, y, z), z)) = 0
Error, (in depends) too many levels of recursion
pde :=  diff(w(x,y,z),x)+ (b*exp(alpha*x)*y^2 + a*exp(beta*x)*(beta- a*b*exp((alpha+beta)*x)))*diff(w(x,y,z),y)+(c*z^2*exp(gamma*x)+ d*z + k*exp(-gamma*x))*diff(w(x,y,z),z)= 0;
diff(w(x, y, z), x)+(b*exp(alpha*x)*y^2+a*exp(beta*x)*(beta-a*b*exp((alpha+beta)*x)))*(diff(w(x, y, z), y))+(c*z^2*exp(gamma*x)+d*z+k*exp(-gamma*x))*(diff(w(x, y, z), z)) = 0
pde :=  x*diff(w(x,y,z),x)+ ( a1*exp(alpha*x)*y^2 + beta*y+ a1*b2^2*x^(2*beta)*exp(alpha*x))*diff(w(x,y,z),y)+(a2*x^(2*n)*z^2*exp(lamba*x)+(b2*x^n*exp(lambda*x) - n)*z + c*exp(lambda*x))*diff(w(x,y,z),z)= 0;
x*(diff(w(x, y, z), x))+(a1*exp(alpha*x)*y^2+beta*y+a1*b2^2*x^(2*beta)*exp(alpha*x))*(diff(w(x, y, z), y))+(a2*x^(2*n)*z^2*exp(lamba*x)+(b2*x^n*exp(lambda*x)-n)*z+c*exp(lambda*x))*(diff(w(x, y, z), z)) = 0
Download bug2.mw
I want to find following NxN matrix P                                           (N=2^k.M where k and M are a positive integers)
My Code Try: question.mw
interface(rtablesize=20):
k:=2:
M:=4:
N:=2^k*M:
for i from 1 to M do
S:= (sqrt(2)/2^k)*Matrix(M,M, (i,j)-> `if`(`and`(i::odd,j=1) ,-1/(i*(i-2)),0)):
C:= (1/2^k)*BandMatrix( [ [ seq(-1/(2*sqrt(2)*(i-1)*(i-3)), i=4..M)], [ 1, seq(0*i,i=1..M-1) ],[ seq(4/2*(i-3),i=2..M)]
              ); #I think the matrix C is not same in the question
Gen:=proc(K::posint,A,B)
  Matrix(scan=triangular[upper],[seq([A,seq(B,i=j..2^(K)-1)],j=1..2^(K))]);
P:=Gen(k,C,S);
question.mw
Is there any way to make this kind of problem in Maple?
I have to find the intersection of subsets, and if there is no intersection then to multiply elements of the subsets. For example,
A={x6,x4,x2,x7,x8,x9,x10},  B={x2,x3,x5,x8} and C={x4,x9,x11,x12,x13}.
Now, the intersection of A and B is {x2}, after that, I don't have the intersection with C, so the solution is x2x4, x2x9, x2x11, x2x11 and x2x13.
Another solution is to make the intersection of A and C and it will be {x4,x9} and after that, I don't have the intersection with B so I have to multiply x4 and x9 with elements in B (obviously, the first solution is better because it has fewer terms)
Is something like this is possible to do in Maple and how?
Thanks in advance!
I am using Maple to solve a couple of differential equations.  Here is what I did so far
k := 141/10000;
yB0 := 296/1000;
e := -148/1000;
Ff0 := 67844/1000;
Far0 := 323066/1000;
FB0 := 135688/1000;
P0 := 10;
x0 := 0;
a := 38/1000;
dsys:={diff(x(w),w)=(k*((yB0*p(w)*(1 - x(w)))/(1 + e*x(w)))^(1/3)*(Ff0/(Far0 + FB0)*p(w)*((Ff0/FB0 - 1/2*x(w))/(1 + e*x(w))))^(2/3))/FB0,
diff(p(w),w)=P0*(-a)/(2*p(w)/P0)*(1 + e*x(w)),x(0)=x0,p(0)=P0}:
dsn1:≔dsolve(dsys,numeric,[x(w),p(w)],stiff=true);
Maple returns neither an error message or a solution.   I am sure I have mistyped something or did not understand how dsolve works at all.
Can you help me out?
Many thanks
Ed
PS. How to plot the solution?
First 727 728 729 730 731 732 733 Last Page 729 of 2467
