I am looking for the table containing the value m,vv and mm. and these values I can easily copy and paste in excel sheet.
Plz suggest commands
Thanks Dummy_5.mw
Given the following functions, graph them and identify relative and absolute extrema (if any).
f(x)=3x^3-2x^2+5x-7     [-3,6]
for Example
A is vector A[r[= x+y , this is the equation generating multiple values. some are real and some are imaginery like,20,133, 2+3i,3+3i. I am interested the value which ilies within certain limits like 10-30. Here in this example 20 fits. So A[r] vector should store 20 only. How to do it.
Please help me on that.
I'm doing a statistic analysis on a lot of data which i have imported from Excel into a matrix. I've got about 2880 data points and i'm trying to use regression and its giving me an error which i do not know how to deal with.
How would i execute the following calculate? I know i could use the statistics package but i want to do with with the formula. I'm trying to find the standard deviation. Look at the attached picture so see. I've also attached a copy of the calculations in maple format.
Download Test.mw
Also another little side thing, but not necessary. Is it possible to have a matrix with empty spaces in it and return it?
Is there any Maple code that allows to view a complex function using the "domain coloring" technique?
This technique is described for example in Wikypedia: https://en.wikipedia.org/wiki/Domain_coloring
How I can determine a function that satisfy these boundary and initial conditions.
S2
Maple Worksheet - Error
Failed to load the worksheet //convert/S2
Download S2
How I can do ?
Substitution of . 5,6,7) into Eqs. 1–(4), gives the new equation as functions of the generalized coordinates,
u_m,n(t);  v_m,n ( t), and w_m,n ( t). These expressions are then inserted in the Lagrange equations (see Eq. 8)) a set of N second-order coupled ordinary differential equations with both quadratic   and cubic nonlinearities.
In Eq (8) q are generalized coordinate such as uvw  and q = {`u__m,n`(t), `v__m,n`(t), `w__m,n`(t)}^T.
\where the elements of the vector,q_i are the time-dependent generalized coordinates.
L_Maple
U = (1/2)*(int(int(int(E*(`∂`(u(x, y, t))/`∂`(x)+(1/2)*(`∂`(w(x, y, t))/`∂`(x))^2+`∂`(w(x, y, t))/`∂`(x)*(`∂`(w__0(x, y, t))/`∂`(x))-z*(diff(w(x, y, t), x, x))+v(x, y, t)*(`∂`(v(x, y, t))/`∂`(y)+(1/2)*(`∂`(w(x, y, t))/`∂`(y))^2+`∂`(w(x, y, t))/`∂`(y)*(`∂`(w__0(x, y, t))/`∂`(y))-z*(diff(w(x, y, t), y, y))))*(`∂`(u(x, y, t))/`∂`(x)+(1/2)*(`∂`(w(x, y, t))/`∂`(x))^2+`∂`(w(x, y, t))/`∂`(x)*(`∂`(w__0(x, y, t))/`∂`(x))-z*(diff(w(x, y, t), x, x)))/(-nu^2+1)+E*(`∂`(nu(x, y, t))/`∂`(y)+(1/2)*(`∂`(w(x, y, t))/`∂`(y))^2+`∂`(w(x, y, t))/`∂`(y)*(`∂`(w__0(x, y, t))/`∂`(y))-z*(diff(w(x, y, t), y, y))+v(x, y, t)*(`∂`(u(x, y, t))/`∂`(x)+(1/2)*(`∂`(w(x, y, t))/`∂`(x))^2+`∂`(w(x, y, t))/`∂`(x)*(`∂`(w__0(x, y, t))/`∂`(x))-z*(diff(w(x, y, t), x, x))))*(`∂`(v(x, y, t))/`∂`(y)+(1/2)*(`∂`(w(x, y, t))/`∂`(y))^2+`∂`(w(x, y, t))/`∂`(y)*(`∂`(w__0(x, y, t))/`∂`(y))-z*(diff(w(x, y, t), y, y)))/(-nu^2+1)+E*(`∂`(u(x, y, t))/`∂`(y)+`∂`(v(x, y, t))/`∂`(x)+`∂`(w(x, y, t))/`∂`(x)*(`∂`(w(x, y, t))/`∂`(y))+`∂`(w__0(x, y, t))*`∂`(w(x, y, t))/(`∂`(x)*`∂`(y))+`∂`(w__0(x, y, t))*`∂`(w(x, y, t))/(`∂`(x)*`∂`(y))-2*z*(diff(w(x, y, t), x, y)))^2/(2*(1+nu))+E*l^2*(diff(w(x, y, t), x, y))^2/(1+nu)+E*l^2*(diff(w(x, y, t), x, y))^2/(1+nu)+E*l^2*(diff(w(x, y, t), y, y)-(diff(w(x, y, t), x, x)))^2/(2*(1+nu))+E*l^2*(diff(v(x, y, t), y, y)-(diff(u(x, y, t), x, x)))^2/(8*(1+nu))+E*l^2*(diff(v(x, y, t), x, y)-(diff(u(x, y, t), y, y)))^2/(8*(1+nu)), z = -(1/2)*h .. (1/2)*h), y = 0 .. b), x = 0 .. a))
U = (1/2)*(int(int((1/12)*(-E*(-v(x, y, t)*(diff(diff(w(x, y, t), y), y))-(diff(diff(w(x, y, t), x), x)))*(diff(diff(w(x, y, t), x), x))/(-nu^2+1)-E*(-v(x, y, t)*(diff(diff(w(x, y, t), x), x))-(diff(diff(w(x, y, t), y), y)))*(diff(diff(w(x, y, t), y), y))/(-nu^2+1)+4*E*(diff(diff(w(x, y, t), x), y))^2/(2+2*nu))*h^3+E*(`∂`(u(x, y, t))/`∂`(x)+(1/2)*`∂`(w(x, y, t))^2/`∂`(x)^2+`∂`(w(x, y, t))*`∂`(w__0(x, y, t))/`∂`(x)^2+v(x, y, t)*(`∂`(v(x, y, t))/`∂`(y)+(1/2)*`∂`(w(x, y, t))^2/`∂`(y)^2+`∂`(w(x, y, t))*`∂`(w__0(x, y, t))/`∂`(y)^2))*(`∂`(u(x, y, t))/`∂`(x)+(1/2)*`∂`(w(x, y, t))^2/`∂`(x)^2+`∂`(w(x, y, t))*`∂`(w__0(x, y, t))/`∂`(x)^2)*h/(-nu^2+1)+E*(`∂`(nu(x, y, t))/`∂`(y)+(1/2)*`∂`(w(x, y, t))^2/`∂`(y)^2+`∂`(w(x, y, t))*`∂`(w__0(x, y, t))/`∂`(y)^2+v(x, y, t)*(`∂`(u(x, y, t))/`∂`(x)+(1/2)*`∂`(w(x, y, t))^2/`∂`(x)^2+`∂`(w(x, y, t))*`∂`(w__0(x, y, t))/`∂`(x)^2))*(`∂`(v(x, y, t))/`∂`(y)+(1/2)*`∂`(w(x, y, t))^2/`∂`(y)^2+`∂`(w(x, y, t))*`∂`(w__0(x, y, t))/`∂`(y)^2)*h/(-nu^2+1)+E*(`∂`(u(x, y, t))/`∂`(y)+`∂`(v(x, y, t))/`∂`(x)+`∂`(w(x, y, t))^2/(`∂`(x)*`∂`(y))+2*`∂`(w__0(x, y, t))*`∂`(w(x, y, t))/(`∂`(x)*`∂`(y)))^2*h/(2+2*nu)+2*E*l^2*(diff(diff(w(x, y, t), x), y))^2*h/(1+nu)+E*l^2*(diff(diff(w(x, y, t), y), y)-(diff(diff(w(x, y, t), x), x)))^2*h/(2+2*nu)+E*l^2*(diff(diff(v(x, y, t), y), y)-(diff(diff(u(x, y, t), x), x)))^2*h/(8+8*nu)+E*l^2*(diff(diff(v(x, y, t), x), y)-(diff(diff(u(x, y, t), y), y)))^2*h/(8+8*nu), y = 0 .. b), x = 0 .. a))
T = rho*h*(int(int((`∂`(u(x, y, t))/`∂`(t))^2+(`∂`(v(x, y, t))/`∂`(t))^2+(`∂`(w(x, y, t))/`∂`(t))^2, y = 0 .. b), x = 0 .. a))
T = rho*h*(int(int(`∂`(u(x, y, t))^2/`∂`(t)^2+`∂`(v(x, y, t))^2/`∂`(t)^2+`∂`(w(x, y, t))^2/`∂`(t)^2, y = 0 .. b), x = 0 .. a))
F = (1/2)*c*(int(int((`∂`(u(x, y, t))/`∂`(t))^2+(`∂`(v(x, y, t))/`∂`(t))^2+(`∂`(w(x, y, t))/`∂`(t))^2, y = 0 .. b), x = 0 .. a))
F = (1/2)*c*(int(int(`∂`(u(x, y, t))^2/`∂`(t)^2+`∂`(v(x, y, t))^2/`∂`(t)^2+`∂`(w(x, y, t))^2/`∂`(t)^2, y = 0 .. b), x = 0 .. a))
W = int(int(w(x, y, t)*f__1(x, y, t)*cos(omega*t), y = 0 .. b), x = 0 .. a)
W = int(int(w(x, y, z)*f__1(x, y, z)*cos(omega*t), y = 0 .. b), x = 0 .. a)
u(x, y, t) = sum(sum(`u__m,n`(t)*sin(m*Pi*x/a)*sin(n*Pi*y/b), n = 1 .. N), m = 1 .. M)
u(x, y, t) = -(1/4)*(cos(Pi*y*N/b)*cos(Pi*x/a)*sin(Pi*y/b)*sin((M+1)*Pi*x/a)-cos(Pi*y*N/b)*cos((M+1)*Pi*x/a)*sin(Pi*x/a)*sin(Pi*y/b)+cos(Pi*x/a)*sin(Pi*y*N/b)*cos(Pi*y/b)*sin((M+1)*Pi*x/a)-cos((M+1)*Pi*x/a)*sin(Pi*x/a)*sin(Pi*y*N/b)*cos(Pi*y/b)-cos(Pi*y*N/b)*sin(Pi*y/b)*sin((M+1)*Pi*x/a)-cos(Pi*x/a)*sin(Pi*y*N/b)*sin((M+1)*Pi*x/a)-cos(Pi*x/a)*sin(Pi*y/b)*sin((M+1)*Pi*x/a)+cos((M+1)*Pi*x/a)*sin(Pi*x/a)*sin(Pi*y*N/b)+sin(Pi*x/a)*sin(Pi*y/b)*cos((M+1)*Pi*x/a)-sin(Pi*y*N/b)*cos(Pi*y/b)*sin((M+1)*Pi*x/a)+sin(Pi*y*N/b)*sin((M+1)*Pi*x/a)+sin(Pi*y/b)*sin((M+1)*Pi*x/a))*`u__m,n`(t)/((cos(Pi*x/a)-1)*(cos(Pi*y/b)-1))+(1/4)*(-cos(Pi*y*N/b)*sin(Pi*y/b)*sin(Pi*x/a)-sin(Pi*y*N/b)*cos(Pi*y/b)*sin(Pi*x/a)+sin(Pi*y*N/b)*sin(Pi*x/a)+sin(Pi*y/b)*sin(Pi*x/a))*`u__m,n`(t)/((cos(Pi*x/a)-1)*(cos(Pi*y/b)-1))
v(x, y, t) = sum(sum(`v__m,n`(t)*sin(m*Pi*x/a)*sin(n*Pi*y/b), n = 1 .. N), m = 1 .. M)
v(x, y, t) = -(1/4)*(cos(Pi*y*N/b)*cos(Pi*x/a)*sin(Pi*y/b)*sin((M+1)*Pi*x/a)-cos(Pi*y*N/b)*cos((M+1)*Pi*x/a)*sin(Pi*x/a)*sin(Pi*y/b)+cos(Pi*x/a)*sin(Pi*y*N/b)*cos(Pi*y/b)*sin((M+1)*Pi*x/a)-cos((M+1)*Pi*x/a)*sin(Pi*x/a)*sin(Pi*y*N/b)*cos(Pi*y/b)-cos(Pi*y*N/b)*sin(Pi*y/b)*sin((M+1)*Pi*x/a)-cos(Pi*x/a)*sin(Pi*y*N/b)*sin((M+1)*Pi*x/a)-cos(Pi*x/a)*sin(Pi*y/b)*sin((M+1)*Pi*x/a)+cos((M+1)*Pi*x/a)*sin(Pi*x/a)*sin(Pi*y*N/b)+sin(Pi*x/a)*sin(Pi*y/b)*cos((M+1)*Pi*x/a)-sin(Pi*y*N/b)*cos(Pi*y/b)*sin((M+1)*Pi*x/a)+sin(Pi*y*N/b)*sin((M+1)*Pi*x/a)+sin(Pi*y/b)*sin((M+1)*Pi*x/a))*`v__m,n`(t)/((cos(Pi*x/a)-1)*(cos(Pi*y/b)-1))+(1/4)*(-cos(Pi*y*N/b)*sin(Pi*y/b)*sin(Pi*x/a)-sin(Pi*y*N/b)*cos(Pi*y/b)*sin(Pi*x/a)+sin(Pi*y*N/b)*sin(Pi*x/a)+sin(Pi*y/b)*sin(Pi*x/a))*`v__m,n`(t)/((cos(Pi*x/a)-1)*(cos(Pi*y/b)-1))
w(x, y, t) = sum(sum(`w__m,n`(t)*sin(m*Pi*x/a)*sin(n*Pi*y/b), n = 1 .. N), m = 1 .. M)
w(x, y, t) = -(1/4)*(cos(Pi*y*N/b)*cos(Pi*x/a)*sin(Pi*y/b)*sin((M+1)*Pi*x/a)-cos(Pi*y*N/b)*cos((M+1)*Pi*x/a)*sin(Pi*x/a)*sin(Pi*y/b)+cos(Pi*x/a)*sin(Pi*y*N/b)*cos(Pi*y/b)*sin((M+1)*Pi*x/a)-cos((M+1)*Pi*x/a)*sin(Pi*x/a)*sin(Pi*y*N/b)*cos(Pi*y/b)-cos(Pi*y*N/b)*sin(Pi*y/b)*sin((M+1)*Pi*x/a)-cos(Pi*x/a)*sin(Pi*y*N/b)*sin((M+1)*Pi*x/a)-cos(Pi*x/a)*sin(Pi*y/b)*sin((M+1)*Pi*x/a)+cos((M+1)*Pi*x/a)*sin(Pi*x/a)*sin(Pi*y*N/b)+sin(Pi*x/a)*sin(Pi*y/b)*cos((M+1)*Pi*x/a)-sin(Pi*y*N/b)*cos(Pi*y/b)*sin((M+1)*Pi*x/a)+sin(Pi*y*N/b)*sin((M+1)*Pi*x/a)+sin(Pi*y/b)*sin((M+1)*Pi*x/a))*`w__m,n`(t)/((cos(Pi*x/a)-1)*(cos(Pi*y/b)-1))+(1/4)*(-cos(Pi*y*N/b)*sin(Pi*y/b)*sin(Pi*x/a)-sin(Pi*y*N/b)*cos(Pi*y/b)*sin(Pi*x/a)+sin(Pi*y*N/b)*sin(Pi*x/a)+sin(Pi*y/b)*sin(Pi*x/a))*`w__m,n`(t)/((cos(Pi*x/a)-1)*(cos(Pi*y/b)-1))
diff(`∂`(T(x, y, t))/`∂`(`#mscripts(mi("q"),mi("j"),none(),none(),mo("."),none(),none())`), t)-`∂`(T(x, y, t))/`∂`(`#mscripts(mi("q"),mi("j"),none(),none(),mo("."),none(),none())`)+`∂`(U(x, y, t))/`∂`(`#mscripts(mi("q"),mi("j"),none(),none(),mo("."),none(),none())`)+`∂`(U(x, y, t))/`∂`(`#mscripts(mi("q"),mi("j"),none(),none(),mo("."),none(),none())`)+`∂`(F(x, y, t))/`∂`(`#mscripts(mi("q"),mi("j"),none(),none(),mo("."),none(),none())`) = `∂`(W(x, y, t))/`∂`(`#mscripts(mi("q"),mi("j"),none(),none(),mo("."),none(),none())`), j = 1, () .. (), N
(D(`∂`))(T(x, y, t))*(diff(T(x, y, t), t))/`∂`(`#mscripts(mi("q"),mi("j"),none(),none(),mo("."),none(),none())`)-`∂`(T(x, y, t))/`∂`(`#mscripts(mi("q"),mi("j"),none(),none(),mo("."),none(),none())`)+2*`∂`(U(x, y, t))/`∂`(`#mscripts(mi("q"),mi("j"),none(),none(),mo("."),none(),none())`)+`∂`(F(x, y, t))/`∂`(`#mscripts(mi("q"),mi("j"),none(),none(),mo("."),none(),none())`) = `∂`(W(x, y, t))/`∂`(`#mscripts(mi("q"),mi("j"),none(),none(),mo("."),none(),none())`), j = 1, () .. (), N
Download L_Maple
How come maple doesn't support symbolic matrix calculus?
For example, I'd like to differentiate or simplify expressions with relation to general vectors and matrices. Besides simpifying the expressions, in runtime (e.g. optimizing a function in matlab) my vector and matrix size change according to the data, so deriving specific expressions element-wise would only be valid for a specific case.
A simple example (A is a matrix, x is a vector):
f(x) = ||Ax||^2
df/dx = 2A'Ax
Recently, I stumbled into this
http://www.matrixcalculus.org/
where you can try my example above: norm2(A*x)^2
I was wondering how come that mature symbolic softwares on the market (maple and mathematica) can't do it?
An hour or two ago, I answered a question in which it was a question of plotting a complex-valued function of 2 real variables. But the question itself and also my answer to it disappeared somewhere. Therefore, I send my answer here below.
There are two options for plotting:
1. Graphs of real and imaginary parts (as 2 surfaces in 3D).
2. Graph of the absolute value of this function (one surface in 3d) .
f:=(1+cosh(2*x))*exp(-4*I*t):
plot3d([Re,Im](f), x=0..1, t=0..1, color=[red,blue]);
plot3d(sqrt(add([Re,Im](f)^~2)), x=0..1, t=0..1, color=green);
I define the spherical Bessel function with j([n, z]) := sqrt(2)*sqrt(Pi/z)*BesselJ(n + 1/2, z)/2.  Then I attempt to plot with
Digits := 20;
plot(j([1, z]), z = 0 .. 25);
I get an empty plot and an error message:
Warning, expecting only range variable z in expression j([1, z]) to be plotted but found name j
which makes no sense to me.
(I am using Maple 2019.)
I would like to solve the non-linear system to obtain rho1 and rho2 .
But when i use solve i get the following error
Error, (in solve) cannot solve for an unknown function with other operations in its arguments
system.mw
many thanks
>SIRvector := [op(SIRvector), op(evalf(solve(eval({Yeqnx(1), Yeqny(1), Yeqnz(1)}, SIRvector), {JJ(1), RR(1), SS(1)})))];
I have a picture. I tried to find the formula of the curve
My code
t := proc (x) options operator, arrow; b*x^10+c*x^9+d*x^8+e*x^7+f*x^6+g*x^5+h*x^4+i*x^3+j*x^2+k*x+l end proc
And solve
solve([t(-2) = 2, t(0) = -2, t(1) = 0, t(2.5) = -3, t(3.5) = 0, t(-1) = 0, eval(diff(t(x), x), x = -2) = 0, eval(diff(t(x), x), x = 0) = 0, eval(diff(t(x), x), x = 2.5) = 0, eval(diff(t(x), x), x = 1) = 0, t(2.8) = 0], [b, c, d, e, f, g, h, i, j, k, l])
[[b = -0.2688965311e-1, c = .1687428810, d = -0.3166922031e-1, e = -1.490599337, f = 1.885667707, g = 3.845330330, h = -6.939129440, i = -2.523473874, j = 7.112020606, k = 0., l = -2.]]
I ploted
plot(-.2688965311*x^10+.1687428810*x^9-.3166922031*x^8-1.490599337*x^7+1.885667707*x^6+3.845330330*x^5-6.939129440*x^4-2.523473874*x^3+7.112020606*x^2-2, x = -3.5 .. 4.5)
The result too far with picture. How can I repair?
I want to made a comparison via plots of RK-4, NSFD and LWM.
Restart
eqn1 := diff(x(t), t) = x(t)*(2-(1/20)*x(t))-x(t-tau)*y(t)/(x(t)+10)-10;
eqn2 := diff(y(t), t) = y(t)*(x(t)/(x(t)+10)-2/3);
bc := x(0) = 40, y(0) = 16,tau=0;
sol := dsolve({bc, eqn1, eqn2}, numeric);
plots[odeplot](sol, 0 .. 10);
I got the plot Vertically x and horizontally t but i need vertically y and horizontally x, Please help me, how can i write the code for ploting, thanks in advance.
First 735 736 737 738 739 740 741 Last Page 737 of 2459
