if V=(u(x,y,t),v(x,y,t),0) is vector field ( x,y space, t is time), how can find gradient of V in maple ?
iqt + aqxy + ibq (qq*x − q*qx) = 0. write this equation in maple
ABB_IRB_120_Model_IK_OK_6_RealParamsLinearization.msim
I did the model of the ABB IRB 120 in MapleSim, but I would like to lock several links but I do not know how to do it.
Also I need the differential equations of the robot, which must be six differential equations but in MapleSim equation extraction page there are lots of equations.
Please can you help me ?
In the worksheet below I produce a sequence of frames for an animation by distributing the task into several threads.  The result has strange artifacts as we see in the sample.  The artifacts vary randomly from run to run.  Am I doing something wrong?
kernelopts(version);
`Maple 2018.2, X86 64 LINUX, Oct 23 2018, Build ID 1356656`
kernelopts(numcpus);
4
Draw a simple picture:
frame := proc(t)
  plot(x^2 + t, x=-1..1, title=typeset("t = %1", t));
Generate a sequence of pictures:
frames := Threads:-Seq(frame(t), t=0..1, 0.05):
Animate the sequence:
plots:-display([frames], insequence);
Download theads.mw
I have a data set (see .txt file attached) to be fit to the model function A*sin(B*x+C)+D. Calculating the parameters A, B, C, and D is easy enough, but is there a way to have Maple return their standard errors?
Data.txt
I can’t perform the last command (GridPlot) on my worksheet
IRISdata.mw
I am new to Maple and have some problems with fonts in Maple's forms. How can I increase the size of the monospaced font? (see the screenshot).
How would I go about getting true or false returned on these propositions?
I have tried just about every eval and various syntax methods, but nothing has worked so far.
I know most can easilly be done by hand/thinking, but I'm sure Maple should have a way to do this as well.
∀n∈Z:2n>n+2   ,   ∃n∈Z:2|(3n+1)    ,   ∃k∈Z:∀n∈Z:n=kn   ,   ∃k∈Z:∀n∈Z:2|(n+k)   ,   ∀n∈Z:∀k∈Z:(n>k∨k≥n)
How to view all  statistical bank of data in Maple ? ( for example , Iris data)
I am trying to find coodinates projection H(x,y, z)  of the point P :=<x3, y3, z3> on the line AB, where A:= <x1,y1,z1>, B:= <x2,y2,z2>. I tried
with(LinearAlgebra);
A:= <x1,y1,z1>:
B:= <x2,y2,z2>:
P :=<x3, y3, z3>:
H:=<x,y,z>;
solve([DotProduct(B-A, H-P, conjugate = false) = 0, B-A = k*(H-A)], [x, y, z, k]);
I can not get the result. How can I get the coordinates of the point H?
I have a hard to understand quotient of multivariate polynomials- my intuition is that the denominator nearly divides the numerator - and it could be rewritten as:
remainder+(much simpler numerator)/denominator
as far as I can see the functions quo and rem aren't designed for this - but I'm certain that people in the maple community must have overcome this kind of problem before
MVP_quotient.mw
I am trying to run maple program in a workstation using 20-40 processor for a job. I have no idea how to do this. Thank you.
how i can solve the eqution by ritz methode codes?
For example...
Using a $2 calculator I get that rad(2470) it is approximately 49.699094.
I haven't used Maple in several months and was surprised to see that I couldn't easily search the answer to this question. Something like eval() does not work on this.
There is a time difference variation between two clocks (0.124, 0.120) and between the same clocks for the same calculations at different times(0.07, 0.124 and 0.120, 68. What is the reason?
Thanks for answering.
Ramakrishnan V
restart; t1 := time[real]()
2344.956
t1PC := Now(ProcessClock)
_m1718422690432
"for i = 1 to 1000  i:=i+1  end;"
t2 := time[real]()
2345.080
t2PC := Now(ProcessClock)
_m1718421822656
tdiff := t2-t1
.124
tdiffPC := t2PC-t1PC
120*Units:-Unit(ns)
I redo the same programm again to see the time of performance
t1 := time[real]()
2345.253
_m1718419758016
t2 := time[real]()
2345.323
_m1718418631616
tdiff := t2-t1
0.70e-1
68*Units:-Unit(ns)
Now I again recall the stored time values. (unit: milliseconds). t1 and t2 are retained for ever until unassigned.
t1
2345.253
t2
2345.323
(14)
t2-t1
0.70e-1
(15)
t2PC-t1PC
68*Units:-Unit(ns)
(16)
Download timeToRunDifference.mw
First 769 770 771 772 773 774 775 Last Page 771 of 2467
