0.733333e^-1
0.733333e^-3
0.733333e^-5
0.733333e^-7
no matter what e is , expect to output the same 0.733333
I am trying to plot y:=x^2+x-12 as a curve and as a series of point. It is just not working. Suggestions, please.
Digitalize.mw
f := proc (x) options operator, arrow; x^2+x-12 end proc
n := 10
h := 5``
printf("\n    i        x       f (dec.form)    f (sci. notat.)\n"); printf("  ---------------------------------------------------\n"); for i from 0 to n do X[i] := i*h; Y[i] := f(X[i]); printf(" %5d  %9.4f  %13.9f  %17.10e\n", i, X[i], Y[i], Y[i]) end do
     0     0.0000  -12.000000000  -1.2000000000e+01
     1     5.0000   18.000000000   1.8000000000e+01
     2    10.0000   98.000000000   9.8000000000e+01
     3    15.0000  228.000000000   2.2800000000e+02
     4    20.0000  408.000000000   4.0800000000e+02
     5    25.0000  638.000000000   6.3800000000e+02
     6    30.0000  918.000000000   9.1800000000e+02
     7    35.0000  1248.000000000   1.2480000000e+03
     8    40.0000  1628.000000000   1.6280000000e+03
     9    45.0000  2058.000000000   2.0580000000e+03
    10    50.0000  2538.000000000   2.5380000000e+03
plot1 := plot([X[k], Y[k]], k = 0 .. n, style = point, symbol = soliddiamond, symbolsize = 24, color = blue)
plot2 := plot(f(x), x = 0 .. 50)
with(plots)
display([plot1, plot2])
Download Digitalize.mw
with(IntegrationTools):
# A very simple double integral
J:=Int(Int(x^2, x = 0 .. y), y = 0 .. 1);
value(J);
1/12
# Try a simple change of variables
Change(J, x=t*y, [t]);   # Why this form?
Intat(Intat(_a^2, _a = _b)-Intat(_a^2, _a = 0), _b = 1)-Intat(Intat(_a^2, _a = _b)-Intat(_a^2, _a = 0), _b = 0)
value(%);
1/12
# Now the same for 2*J
Change(2*J, x=t*y, [t]);  # OK, but why?
2*(Int(y^3*(Int(t^2, t = 0 .. 1)), y = 0 .. 1))
value(%);
1/6
Download IntegrationTools-Change.mw
Am trying to analyse a set of strings.   Can anyone help?
We have 10 x10 matrix into which we need to add connection score.
ExY := [WPKCPYWFYWCXHY, WPKCTEYFHCFEEE, HYCYTFHYYWWKCE, HYHHTFHKFEYHEH, HKXWYHFECTFFTF, HKWEHPPECWWHTC, HKXWYTPXHFHWYP, HKFEXCTFECXFKP, HKFEYPPEEEPHYW, HYTHCCFEWPPEXX, HKXKXCKFCHTEWK, HYEKPPCKFTWXXW];
Here is the code to create the connection matrix
A__c = A__a+A__d;
Blist:=[W,P,K,C,Y,F,X,H,T,E]:# basis letters
nWords:=numelems(ExY):Wletters:=length(ExY[1]):Bletters:=numelems(Blist):A:=Matrix(Bletters,Bletters):# set up dimensions
for iW from 1 to nWords do  # loop through words
  for iL from 1 to Wletters-1 do # loop through letters of each word
     fromLett:=C(iW,iL); # see char extraction from ExY list above
     toLett:=C(iW,iL+1); # ditto
     BfromLett:=Search(fromLett,Blist);# column id   <<<<<< the search is returning 0, it works if one uses "A" rather than say fromLett=A
     BtoLett:=Search(toLett,Blist);# row id   <<<<<  ditto here
     A(BfromLett,BtoLett):=A(BfromLett,BtoLett)+ 1; # add statistic to the A-matrix
  end do; # end letter loop
end do; # end word loop
Error, index out of bounds
The search function is failing:
Blist; Wletters; Bletters; nWords; fromLett; toLett; BfromLett; BtoLett; A; iW; iL;
                 [W, P, K, C, Y, F, X, H, T, E]
                               14
                               10
                               12
                              "W"
                              "P"
                 [0  0  0  0  0  0  0  0  0  0]
I found this paper.
http://benson-labs.com/uploads/stuff/POW15.pdf
I'm not sure if the population after 1 year is correct.
I wanted to get the formula from rsolve. But i have incorrorectly formulated the sum by day and the total.
Rattus_recursion.mw
Whilst trying to debug another problem on this site, this one
https://www.mapleprimes.com/questions/225688-How-To-Compute-Inverse-Of-A-Matrix-For
I came across a Maple bug(?) which was so serious, I thought either
  1. I'm being more than usually dim
  2. it needs it's own entry here, so that others can check
Problem can be summarized as:
When using 2D input, can the '.' character be used for simple matrix multiplication???? Because it isn't working for me!
Entering the '.' character places a bold, midline dot between the two arguments, but executing the result gives "Error unable to parse". Converting to 1-D input, no issues - everything works as expected.I should also point out that
  1. I never normally use 2D-input for my own work
  2. the attached worksheet executes correctly in Maple 2017.3, X86 64 WINDOWS, Sep 13 2017, Build ID 1262472.
If this is reproducible then wtf!
restart; with(LinearAlgebra); kernelopts(version)
`Maple 2018.1, X86 64 WINDOWS, Jun 8 2018, Build ID 1321769`
A := RandomMatrix(2, 2); B := RandomMatrix(2, 2)
Matrix(2, 2, {(1, 1) = 44, (1, 2) = -31, (2, 1) = 92, (2, 2) = 67})
Matrix(%id = 18446744074378134462)
A.B
Error, unable to parse
"A*B;"
LinearAlgebra:-Multiply(A, B)
Matrix(%id = 18446744074378136502)
A:= RandomMatrix(2, 2);
B:= RandomMatrix(2, 2);
A.B
Matrix(2, 2, {(1, 1) = -32, (1, 2) = -4, (2, 1) = -74, (2, 2) = 27})
Matrix(2, 2, {(1, 1) = -93, (1, 2) = -72, (2, 1) = -76, (2, 2) = -2})
Matrix(%id = 18446744074378132406)
Download matMulProb.mw
I'm start making an homepage about mathematic and wondt to link a workpage writen in Maple 16 into WP, thanks to whose ho have any idea :)
I have a set of nonlinear equations (transcendental) containing variables and one free parameter. I want to solve this system for variables while varying parameter's value. I have tried with fsolve and solve commands keeping fixed the parameter value, but they are not solving yet. Is there any way to solve this system for a range of parameter's value.
The systmem is like this, x,y,z are the variables and 'a' is the parameter:
f1(x,y,z,a)=0,
f2(x,y,z,a)=0,
f3(x,y,z,a)=0.
Many thanks in advance.
I submit you this strange result:
for somenumerical  values of a, b, c  (a, b, c real and b > a), Maple 2018 is not able to compute the mean of
c*U where U is a Uniform random variable with support [a, b].
with(Statistics):
`Standard Worksheet Interface, Maple 2018.0, Windows 7, March 10 2018 Build ID 1298750`
z := .4070716688*RandomVariable(Uniform(0.12-0.02*0.12, 0.12+0.02*0.12));
Mean(z);
.4070716688*_R
Error, (in Statistics:-Mean) the expression does not have a taylor expansion at t = 0
z := .4070716688*RandomVariable(Uniform(a, b));
Mean(z);
subs({a=0.12-0.02*0.12, b=0.12+0.02*0.12}, %);
.4070716688*_R0
.2035358344*a+.2035358344*b
0.4884860026e-1
Download Mean.mw
PLEASE: Maple still fails if I replace  a = 0.12 -0.02*0.12 by its value 0.1174
        and b = 0.12+0.02*0.12 by its value 0.1224
This is incomprehensible and could hide a more profound problem.
Good day everyone,
I am trying to write HAM code for coupled ODE but getting errors like "table(...)" or
"Error, (in dsolve) found the independent variables {eta} also present in the names of the functions of the system {(diff(diff(diff((table( [( 0 ) = proc (eta) options operator, arrow, function_assign; eta*exp(-eta)-F[w] end proc ] ))(eta), eta), eta), eta))(f[1](eta)), (diff(diff((table( [( 0 ) = proc (eta) options operator, arrow, function_assign; exp(-eta) end proc ] ))(eta), eta), eta))(theta[1](eta)), (diff((table( [( 0 ) = proc (eta) options operator, arrow, function_assign; eta*exp(-eta)-F[w] end proc ] ))(eta), eta))(f[1](eta)), ((table( [( 0 ) = proc (eta) options operator, arrow, function_assign; exp(-eta) end proc ] ))(eta))(theta[1](eta))}"
Anyone with useful informations should please help.
Below is the attached of the file
untitled22222.m
Does Maple have a way to upload a screenshot of a worksheet or a savefile of a worksheet to MaplePrimes?
Hi.
How I can Plot voltage (v) versus time (t) in nonlinear differential equation.
if possible please provide a simple example for me. for instance the command that I must use!!
plot.pdf
Hello everyone, i've a problem working with Maple because i have a really big system of equations and for everything that i have to do with them, for example, collect terms, coefficients, take a lot of time from me. The problem it is when, for example, i wait 30 minutes to take the coefficients from a equation and in the next command Maple might stop, then i have to close and start all over again... My question it is if have anyway to save my file in a way that if i close and re open i dont have to compile all again. Maybe this is pretty obvious but i really dont know how to do it, because if i close my work and open again, i have to compile everything again.
Following creates a list of 10 numbers 1..10:
  L := []; for i from 1 to 10 do L := [op(L), i] end do;
Now suppose I have equations labelled (1) ... (10). Can I place these equations into a list by some analogy of the above code using the label references?
Y = (-2*k^3+6*k^2+sqrt(k^8-12*k^7+64*k^6-198*k^5+448*k^4-636*k^3+369*k^2)-7*k-15)/((k^3-3*k^2+5*k-15)*(1+k))
First 796 797 798 799 800 801 802 Last Page 798 of 2459
