I have an ODE for which I want to show that any initial condition leads to a convergence towards a point. So far I made a sequence of dsolve procedure, each with a distinct random initial condition, and I can plot everything on the same plot without a problem with display.
The parameter of the ode is the time t, so that the system of ode is some d/dt x(t) = f(x(t),y(t),z(t)), etc. To show time passing, I have two solutions in a sense, either by color, or by an animation. But the latter is not very convenient as I am already planning of to animate the rotation of the camera since the plot is 3D. What I would like, is the color of the curve to be say blue at time 0 then go to green as t goes to 5, for example.
I know something should be possible as there is somehow an example given in plot3d documentation,
plot3d(x*exp(−x^2−y^2),x=−2..2,y=−2..2,color=x)
but I can't seem to make it work, no matter where I put my "color = t" option. Would one have an idea on how to achieve that?
Thank you for your time,
Cryme
I am attempting to have maple recognize the difference in singularities between:
f(x)=x+1  and
g(x)=(x+1)*(x-2)/(x-2)
In other words how can I stop maple from simplifying g(x) and observe the singularity.
Mark
I'm trying to solve an ODE system from an IVP problem, but the error occurs: "Error, (in ...) cannot evaluate the solution further left of ..., maxfun limit exceeded (see ?dsolve,maxfun for details)"
I've already tried modifying the maxfun value but this did not work. I would like some suggestion.
ODE_System.mw
If any one can tell me how to solve the nonlinear system sys:={x^2+y^2+z^2=4,x^2+y^2-z^2=4,x+y+z=0} by using fsolve command? I tried fsolve(sys,{x,y,z});, but there is no value returned. May I give fsolve an initial approxiamtaion of the solution ? If that is the case, what should I do?
Thanks in advance!
can anyone  indicate me how display  1O^-5 and not 1/100000 on the vertical axis?
 I created my own costum package and I want to edit this package: insert procedures or modules. Is there a way?
with(VectorCalculus);
with(LinearAlgebra);
r1 := Vector([0, 0, 1]);
r2 := Vector([sin(theta1), 0, cos(theta1)]);
r3 := Vector([VectorCalculus:-`*`(sin(theta2), cos(phi2)), VectorCalculus:-`*`(sin(theta2), sin(phi2)), cos(theta2)]);
M := Matrix([r1, r2, r3]); ex := `assuming`([simplify(VectorCalculus:-`*`(Determinant(M), 1/VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(1, DotProduct(r1, r2)), DotProduct(r1, r3)), DotProduct(r2, r3))))], [theta1 > 0, theta2 > 0, phi2 > 0]);
dex := eval(simplify(diff(arctan(ex), phi2)), phi2 = t);
VectorCalculus:-`*`(2, Int(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(2, Int(dex, t = 0 .. phi2)), 1/VectorCalculus:-`*`(4, Pi)), VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(2, Pi), sin(theta1)), sin(theta2)), 1/VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(4, Pi), 4), Pi))), [phi2 = 0 .. Pi, theta2 = 0 .. Pi, theta1 = 0 .. Pi], method = _CubaCuhre, epsilon = 0.5e-2));
evalf(%)
Ok I deleted my other question, since there was a mistake. I actually want to integrate the following expression. The arctan is not every positive in my integral there, so I needed to go this way to make it continuous. The problem here is the nested integral inside Int(...,t=0..phi2) which leads to maple not being able to evaluate.
ψ =-0.09,-0.07,-0.04,-0.01,0,0.01,0.04,0.07,0.09
these are the ψ values.
then X=
here we can take eta =0..2 and X=-15..15
using this relation how to plot streamlines for eta against X.
Code:
restart; with(plots); fcns := {T(eta), f(eta)}; ep := .1; M := 1; kp := .5; n := 1; ec := .1; pr := 1; s := .1; N := 5; sys := diff(f(eta), eta, eta, eta)+f(eta)*(diff(f(eta), eta, eta))-(diff(f(eta), eta))*(diff(f(eta), eta))+ep*ep+(M+1/kp)*(ep-(diff(f(eta), eta))) = 0, diff(T(eta), eta, eta)+pr*(f(eta)*(diff(T(eta), eta))-n*(diff(f(eta), eta))*T(eta))+pr*(ec*(diff(f(eta), eta, eta))*(diff(f(eta), eta, eta))+ec*(M+1/kp)*(diff(f(eta), eta))^2+s*T(eta)) = 0; bc := f(0) = 0, (D(f))(0) = 1, (D(f))(N) = ep, T(0) = 1, T(N) = 0; R := dsolve(eval({bc, sys}), numeric, method = bvp[midrich], abserr = 0.1e-9, output = operator); psi = [-0.9e-1, -0.7e-1, -0.4e-1, -0.1e-1, 0, 0.1e-1, 0.4e-1, 0.7e-1, 0.9e-1]; for i to 9 do X[i] = psi[i]/f(eta); print(plots:-contourplot(X[i](X, eta), eta = 0 .. N, X = 0 .. 6)) end do
I am interested to find the primes in in field Zp which Have prime inverses.  In particular, for any prime p up to an arbitrary number N, the number of pairs (a,b) where a and b are mutually inverse primes <p in Zp. Obviously in this context (a,b) is the same as (b,a) so no need for double counting. What I have so far is the following simple code for finding the inverse of prime q<p, given a chosen value of p. I can then see which results are prime and which are composite.
N:=p:
for n from 1 to N do
X:=q*n-1;
if mod(X,p)=0 then print(n);
end if:
This “hand cranking” method works but is of course boring but I don’t know how to scale it up to a more efficient code as described above. I would be grateful to anyone  able to assist me with this.
David
I am currently implementing the math behind the McEliece Cryptosystem in Maple, and as such I need to do work in the Galois Field GF(2^m). In my working example I am working with p=2, k=4, and a=1+x (i.e. the rank of my polynomial is 1). Parameters are per documentation found at https://www.maplesoft.com/support/help/maple/view.aspx?path=GF.
When attempting to initialize this field, however, I am receiving an error that the rank is not 4=k as expected. It is, however, not a requirement for a field that the polynomial has to be of rank k. How do I go about this?
G16 := GF(2, 4, 1+x);
Error, (in GF) polynomial 1+x does not determine an extension of degree 4
I tried to find Killing vectors of a certain metric, but Maple gives an error, which is reproduced with the following piece of code (the metric which I need is more difficult, so I would like to refrain from using "Physics" package). Could anybody tell me what the problem is and how I should solve it, please?
exampleError.mw
with(DifferentialGeometry); with(Tensor); with(LieAlgebras)
DGsetup([xi, chi, u1, u2, v1, v2], P)
`frame name: P`
P >
g := evalDG(1/2*(`&t`(dxi, dxi)+`&tensor`(du1*v1+du2*v2+dchi, du1*v1+du2*v2+dchi)*exp(-2*xi)+`&t`(dv1, dv1)+`&t`(dv2, dv2)))
_DG([["tensor", P, [["cov_bas", "cov_bas"], []]], [[[1, 1], 1/2], [[2, 2], (1/2)*exp(-2*xi)], [[2, 3], (1/2)*exp(-2*xi)*v1], [[2, 4], (1/2)*exp(-2*xi)*v2], [[3, 2], (1/2)*exp(-2*xi)*v1], [[3, 3], (1/2)*exp(-2*xi)*v1^2], [[3, 4], (1/2)*exp(-2*xi)*v1*v2], [[4, 2], (1/2)*exp(-2*xi)*v2], [[4, 3], (1/2)*exp(-2*xi)*v1*v2], [[4, 4], (1/2)*exp(-2*xi)*v2^2], [[5, 5], 1/2], [[6, 6], 1/2]]])
P >
KV := KillingVectors(g)
Error, (in DifferentialGeometry:-Tensor:-Christoffel) expected 1st argument to be a metric tensor. Received: _DG([["tensor", P, [["cov_bas", "cov_bas"], []]], [`...`]])
P >
Download exampleError.mw
What's going on here? Am I missing something, or is it a bug? If it's a bug, then it's by far the deepest and most profound bug that I've ever found or seen in Maple (and I've seen thousands over the decades). And since that surprises me, my guess is that I'm missing something obvious.
Op:= (R,F)-> F(['R()'$2]):
Op(rand(1..9), [f,f]);
                     [f([7, 6]), f([2, 4])]
The expected output is [f([7,6]), f([7,6])]. The same thing happens if I replace with seq, or if I replace -> with proc.
make a program that generates 20 numbers between 1 and 100, calculate the sum and the average of even numbers
please help, I do not know how to do it and the teacher wants this with "for, do and an external accountant
Limit((2x-3)/(x-2),x=2)->
How type this expression?
Can anyone advise me on the difference between the Internally and Externally Standardized Residuals from the LinearFit procedure?
Sincerely
Jo
First 798 799 800 801 802 803 804 Last Page 800 of 2459
