I am a relatively new user of Maple. I am trying to find the partial fractions of a polynomial expression. All the values are constants determined by an outside system (that I am trying to model). The function is in terms of s. The denominator was simplified via substitution (more combinations of constants) to see if I could find the problem. There is no other code in the file, so I don't know if I have to define the constants (Cdl, RL, R1, R2, C1, C2) separately.
f:=(V[0](s^3+(2 s^2)/(C[dl] R[L])+(s^2)/(C[2] R[L])+(s^2)/(C[2] R[2])-(s^2)/(C[1] R[L])+(s)/(C[dl] C[2] R[L]^2)+(2 s)/(C[dl] C[2] R[L] R[2])+(s)/(C[dl]^2 R[L]^2)-(s)/(C[dl] C[1] R[L]^2)+1/(C[dl]^2 C[2] R[L]^2 R[2])))/(s^4+as^3+bs^2+cs+d)
convert(f, parfrac, s)
Running convert parfrac gives me an error that the argument is not a rational function. Any help is greatly appreciated!
or am I missing something?
Consider:
A:=Matrix(2, 2, [1, 4, 5, 1]);
x0:=Vector([2,1]); #initial condition
sol := DETools:-matrixDE(A, t);
M:=(Matrix(convert(sol[1], listlist)));  #convert to modern day Matrix from array that is returned by matrixDE
#the solutoion according to the documentation:
x:=M.x0;
#should match x0 at t=0, but does not:
subs(t=0, x);
#using this instead seems to work. But the docs claim this is method is meant to work for constant coeffs.
sol := DETools:-matrixDE(A, t, method=matrixexp);
Am i missing something? or is matrixDE not to be trusted (especially in cases where method is not provided)?
as a side note, the documentation is very out of date; claims matrixDE returns Matrix and vector, but these are just the old array types; means LinearAlgebra operations do not work.
 Hi guys,
I dont know much about maple, please looking for someone to help me check this maple code as to why it is not running sign.mw . The ode is copied from singh2000-thermometer.pdf.
Thank you for your help
Can someone please tell me my mistake. The plot is not responing to slider changes.
Many thanks
PolarPlotB.mw
pls help me cirrect this. i am trying to use finite element method to siolve a fluid equation. The code is give below
> pde := alpha^2*(diff(u(t, r), t))+2*(-1/2)^(1/n)*(diff(u(t, r), r))/r-(-1/2)^((1-n)/n)*(diff(u(t, r), `$`(r, 2)))*(diff(u(t, r), r))^(1/n-1)/n+2*theta/r-4*(1+e)+4*B*cos(.2) = 0; /1\ |-| \n/ /-1\ / d \ 2 |--| |--- u(t, r)| 2 / d \ \2 / \ dr / alpha |--- u(t, r)| + ----------------------- \ dt / r /1 - n\ /1 \ |-----| |- - 1| \ n / \n / /-1\ / d / d \\ / d \ |--| |--- |--- u(t, r)|| |--- u(t, r)| \2 / \ dr \ dr // \ dr / 2 theta - ---------------------------------------------------- + ------- - 4 - 4 e n r + 3.920266311 B = 0 > tmax := 0.5e-1; > rmin := 0; > rmax := 10; > N := 6; > bc1 := diff(u(t, r = rmin), r) = 1/mu; > bc2 := u(t, r = rmax) = 0; > ic1 := u(0, r) = 0; > PDE*Boundary*condition*colllection; > bcs := {u(0, r) = rhs(ic1), D[1](diff(u(t, r = rmin), r)) = rhs(bc1), (D[1](u))(t, r = rmax) = rhs(bc2)}; / / d \ 1 \ { u(0, r) = 0, D[1]|--- u(t, r = 0)| = --, D[1](u)(t, r = 10) = 0 } \ \ dr / mu / > > Collocation*method; > Typesetting[delayDotProduct](Define*a*simple*function*with*known*solution.one, can, true)*choose*either*a*trigonometric*function, othorgonal*polynomia, (Typesetting[delayDotProduct](legendre*polynomia*etc.we, want, true)*will*choose*a*simple*polynomia*which*will)*make*our*work*easier; > basis := r^i; > uhat := sum(A[i](t)*basis, i = 0 .. N-1); > Alist := indets(uhat, function(identical(t))); > Here, we*will*determine*the^2*two*unknowns*(A1, A2)*using*boundary*conditions; > duhat := diff(uhat, r); > knownAs := solve({subs(r = rmin, duhat) = rhs(bc1), subs(A[1](t) = 0, r = rmax, duhat) = rhs(bc2)}, {A[1](t), A[2](t)}); > unknownAs := `minus`(Alist, {seq(lhs(knownAs[i]), i = 1 .. nops(knownAs))}); > `and`(uhat*after*substituting*A1, A2); > uhat := subs(knownAs, uhat); > uhat := collect(uhat, Alist); > Residual*function*is*obtai*ned*after*substituting*uhat*into*the*original*pde; > residual := eval(subs(u(t, r) = uhat, pde)); > residual := collect(residual, r); > `and`(Typesetting[delayDotProduct](Now*we*choose*points*where*exact*solution*must*be*matched.since, we, true)*have*point*A[1], A[2]), we*will*only*need*N-2*points; > odes := {seq(subs(r = i*rmax/N, residual), i = 1 .. nops(unknownAs))}; > Find*ICs*of*unknown*A(t)*s; > iceqs := {seq(subs(t = 0, r = i*rmax/N, uhat) = rhs(bc2), i = 1 .. nops(unknownAs))}; > ics := solve(iceqs, subs(t = 0, unknownAs)); > > sols := dsolve(`union`(odes, ics)); Warning, computation interrupted > Approximate*solution; > uhat := subs(sols, uhat); Error, invalid input: subs received sols, which is not valid for its 1st argument > uhat := collect(uhat, r); > Plot*solution; > plot3d(uhat, r = 0 .. rmax, t = 0 .. tmax, axes = boxed, lightmodel = light4, orientation = [-120, 40], shading = zhue, transparency = .3); Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct > >
The question is all in the title really. I am struggling to make a subsection on my macbook, using 2018 Maple software. The cmd + shift + . will only make sections, regardless of where i place my cursor.
I am trying to solve a 2dof system numerically. What is the best way to find x1 and x2 by given initial conditions?
My first try to solve it is in the attached file.2DOFnumerical.mw
Baharm31
From the help pages for the Gram Schmidt command:
The number of Vectors returned is the dimension of the vector space spanned by V.  In particular, if the Vectors in V are not linearly independent, fewer Vectors than the number in V are returned.
That is not what happens when floating point numbers are involved, for example:
>restart;
>with(LinearAlgebra);
>a := Vector([1, 2, 3]); b := Vector([1, -2, 3]); c := Vector([3, 2, 1]); d := Vector([5, 1, -3]); e := Vector([0, 1.01, -3]);
>GramSchmidt([a, b, c, d, e]);
This returns 3 vectors as it should BUT
>GramSchmidt([b, c, d, e, a]) returns 5 vectors (one of which is essentially 0).  That is definitely a bug.
Hi everyone,
I just started using Maple which is part of a class I am taking.
We are asked to write a procedure which returns two random values (think two dice).
What I would like to do is:
dice := proc()
    local a,b;
    a := rand(1..6);
    b := rand(1..6);
    return a,b;
That doesn't work and I don't understand why. How does rand work? Also, how can I call rand in a loop, i.e. repeat rand n times and add the values?
I really hope you can help me here, really struggling.
I am trying to solve improper integrals using Maple. I need to choose at least one from attached and I am leaning towards number 26 but I am having trouble. I am new to Maple and have no idea where to even begin. Please provide the correct steps needed to get to the right answer.
Hi there:
i use Grid:-Map() to run some code on many cores. When I set
Grid:-Setup(numnodes=23);
everything runs fine. When I set (note I have 28 logical cores present):
Grid:-Setup(numnodes=24);
I get the "stack limit reached" message (see attached image below). I've explored setting stack limits to 'unlimited' at the OS level (ubuntu 18.04), as well as setting
kernelopts(stacklimit=infinity)
However, these do not help, and I still end up with the same message.
Any ideas what could be the problem? Also, I am assuming that kernelopts settings get passed to other, spawned kernels, but even if not, I experimented with setting this directly inside the function that gets passed to Grid:-Map()
chosen1 := [[1,2],[1,20],[3,4]]:
chosen2 := [[2,3],[20,3],[3,4]]:
chosen3 := [[3,4],[5,7]]:
chosen4 := [[4,5],[5,6]]:
chosen5 := [[5,6],[7,9]]:
hashtable can not work
for example
[1,2]'s 2 as key to find 3 in chosen2 [2,3] then use 3 to find 4 in [3,4] then use 4 to find 5 in [4,5]
a:=sin(theta3(t))*(diff(theta3(t), t))^2*cos(theta1(t))*l1*l3*m3+sin(theta3(t))*(diff(theta3(t), t))^2*cos(theta1(t))*l1*l3*mi+sin(theta3(t))*(diff(theta3(t), t))^2*cos(theta1(t))*l1*l3*m4+l1^2*m2*(diff(theta1(t), t, t))-sin(theta3(t))*(diff(theta3(t), t))^2*cos(theta1(t))*l1*lc3*m3+sin(theta4(t))*(diff(theta4(t), t))^2*cos(theta1(t))*l1*l4*mi+sin(theta4(t))*(diff(theta4(t), t))^2*cos(theta1(t))*l1*l4*m4-sin(theta4(t))*(diff(theta4(t), t))^2*cos(theta1(t))*l1*lc4*m4+sin(theta6(t))*(diff(theta6(t), t))^2*cos(theta1(t))*h2*l1*ml+sin(theta6(t))*(diff(theta6(t), t))^2*cos(theta1(t))*h2*l1*m3+l1^2*ml*(diff(theta1(t), t, t))+l1^2*mr*(diff(theta1(t), t, t))+cos(theta2(t))*cos(theta1(t))*l1*l2*ml*(diff(theta2(t), t, t))+cos(theta2(t))*cos(theta1(t))*l1*l2*mc*(diff(theta2(t), t, t))+sin(theta5(t))*sin(theta1(t))*h2*l1*mi*(diff(theta5(t), t, t))-cos(theta3(t))*cos(theta1(t))*l1*l3*m4*(diff(theta3(t), t, t))+cos(theta5(t))*cos(theta1(t))*h2*l1*mc*(diff(theta5(t), t, t))+sin(theta6(t))*(diff(theta6(t), t))^2*cos(theta1(t))*h2*l1*mi+sin(theta6(t))*(diff(theta6(t), t))^2*cos(theta1(t))*h2*l1*m4-sin(theta5(t))*(diff(theta5(t), t))^2*cos(theta1(t))*h2*l1*mi-sin(theta5(t))*(diff(theta5(t), t))^2*cos(theta1(t))*h2*l1*m4-sin(theta5(t))*(diff(theta5(t), t))^2*cos(theta1(t))*h2*l1*m3-sin(theta5(t))*(diff(theta5(t), t))^2*cos(theta1(t))*h2*l1*mr-sin(theta5(t))*(diff(theta5(t), t))^2*cos(theta1(t))*h2*l1*mc-sin(theta2(t))*(diff(theta2(t), t))^2*cos(theta1(t))*l1*l2*m3-sin(theta2(t))*(diff(theta2(t), t))^2*cos(theta1(t))*l1*lc2*m2-sin(theta2(t))*(diff(theta2(t), t))^2*cos(theta1(t))*l1*l2*mr+sin(theta2(t))*sin(theta1(t))*l1*l2*ml*(diff(theta2(t), t, t))+cos(theta5(t))*cos(theta1(t))*h2*l1*mi*(diff(theta5(t), t, t))+l1^2*m4*(diff(theta1(t), t, t))+sin(theta5(t))*sin(theta1(t))*h2*l1*m3*(diff(theta5(t), t, t))+cos(theta3(t))*cos(theta1(t))*l1*lc3*m3*(diff(theta3(t), t, t))-sin(theta3(t))*sin(theta1(t))*l1*l3*m4*(diff(theta3(t), t, t))-cos(theta6(t))*cos(theta1(t))*h2*l1*m4*(diff(theta6(t), t, t))-sin(theta4(t))*sin(theta1(t))*l1*l4*m4*(diff(theta4(t), t, t))-sin(theta2(t))*(diff(theta2(t), t))^2*cos(theta1(t))*l1*l2*mi-sin(theta2(t))*(diff(theta2(t), t))^2*cos(theta1(t))*l1*l2*mc-sin(theta2(t))*(diff(theta2(t), t))^2*cos(theta1(t))*l1*l2*ml-sin(theta2(t))*(diff(theta2(t), t))^2*cos(theta1(t))*l1*l2*m4-sin(theta7(t))*(diff(theta7(t), t))^2*cos(theta1(t))*h3*l1*mc-cos(theta4(t))*cos(theta1(t))*l1*l4*mi*(diff(theta4(t), t, t))+cos(theta2(t))*cos(theta1(t))*l1*l2*mr*(diff(theta2(t), t, t))-cos(theta6(t))*(diff(theta6(t), t))^2*sin(theta1(t))*h2*l1*mi-cos(theta6(t))*(diff(theta6(t), t))^2*sin(theta1(t))*h2*l1*m4+cos(theta5(t))*(diff(theta5(t), t))^2*sin(theta1(t))*h2*l1*m3+cos(theta5(t))*(diff(theta5(t), t))^2*sin(theta1(t))*h2*l1*mi+cos(theta5(t))*(diff(theta5(t), t))^2*sin(theta1(t))*h2*l1*mc+cos(theta5(t))*(diff(theta5(t), t))^2*sin(theta1(t))*h2*l1*mr+cos(q2(t))*sin(theta1(t))*l1*l2*mi*(diff(theta2(t), t))*(diff(theta1(t), t))+cos(q2(t))*sin(theta1(t))*l1*l2*m4*(diff(theta2(t), t))*(diff(theta1(t), t))+cos(q2(t))*sin(theta1(t))*l1*lc2*m2*(diff(theta2(t), t))*(diff(theta1(t), t))+cos(q2(t))*sin(theta1(t))*l1*l2*m3*(diff(theta2(t), t))*(diff(theta1(t), t))+cos(q2(t))*sin(theta1(t))*l1*l2*mc*(diff(theta2(t), t))*(diff(theta1(t), t))+cos(q2(t))*sin(theta1(t))*l1*l2*ml*(diff(theta2(t), t))*(diff(theta1(t), t))+cos(q2(t))*sin(theta1(t))*l1*l2*mr*(diff(theta2(t), t))*(diff(theta1(t), t))-sin(q2(t))*cos(theta1(t))*l1*l2*mc*(diff(theta2(t), t))*(diff(theta1(t), t))-sin(q2(t))*cos(theta1(t))*l1*l2*m4*(diff(theta2(t), t))*(diff(theta1(t), t))-sin(q2(t))*cos(theta1(t))*l1*l2*mr*(diff(theta2(t), t))*(diff(theta1(t), t))-sin(q2(t))*cos(theta1(t))*l1*l2*m3*(diff(theta2(t), t))*(diff(theta1(t), t))-sin(q2(t))*cos(theta1(t))*l1*l2*mi*(diff(theta2(t), t))*(diff(theta1(t), t))-sin(q2(t))*cos(theta1(t))*l1*l2*ml*(diff(theta2(t), t))*(diff(theta1(t), t))-sin(q2(t))*cos(theta1(t))*l1*lc2*m2*(diff(theta2(t), t))*(diff(theta1(t), t))-cos(theta3(t))*(diff(theta3(t), t))^2*sin(theta1(t))*l1*l3*mi+cos(theta3(t))*(diff(theta3(t), t))^2*sin(theta1(t))*l1*lc3*m3-cos(theta4(t))*(diff(theta4(t), t))^2*sin(theta1(t))*l1*l4*m4-cos(theta4(t))*(diff(theta4(t), t))^2*sin(theta1(t))*l1*l4*mi+cos(theta4(t))*(diff(theta4(t), t))^2*sin(theta1(t))*l1*lc4*m4-cos(theta6(t))*(diff(theta6(t), t))^2*sin(theta1(t))*h2*l1*ml-cos(theta6(t))*(diff(theta6(t), t))^2*sin(theta1(t))*h2*l1*m3-cos(theta3(t))*(diff(theta3(t), t))^2*sin(theta1(t))*l1*l3*m4-cos(theta3(t))*(diff(theta3(t), t))^2*sin(theta1(t))*l1*l3*m3+l1^2*mc*(diff(theta1(t), t, t))-cos(theta4(t))*cos(theta1(t))*l1*l4*m4*(diff(theta4(t), t, t))+cos(theta5(t))*cos(theta1(t))*h2*l1*mr*(diff(theta5(t), t, t))+cos(theta2(t))*cos(theta1(t))*l1*lc2*m2*(diff(theta2(t), t, t))+cos(theta1(t))*g*l1*mr+cos(theta1(t))*g*l1*m3+cos(theta1(t))*g*l1*m2+cos(theta1(t))*g*l1*m4+cos(theta1(t))*g*l1*ml+cos(theta1(t))*g*l1*mc+m1*g*lc1*cos(theta1(t))+cos(theta1(t))*g*l1*mi+cos(theta5(t))*cos(theta1(t))*h2*l1*m3*(diff(theta5(t), t, t))-cos(theta2(t))*sin(theta1(t))*(diff(theta1(t), t))*l1*l2*m4*(diff(theta2(t), t))+cos(theta2(t))*(diff(theta2(t), t))^2*sin(theta1(t))*l1*l2*mc+sin(theta2(t))*cos(theta1(t))*(diff(theta1(t), t))*l1*l2*mc*(diff(theta2(t), t))+cos(theta7(t))*(diff(theta7(t), t))^2*sin(theta1(t))*h3*l1*mc+l1^2*m3*(diff(theta1(t), t, t))+l1^2*mi*(diff(theta1(t), t, t))+cos(theta5(t))*(diff(theta5(t), t))^2*sin(theta1(t))*h2*l1*m4-cos(theta2(t))*sin(theta1(t))*(diff(theta1(t), t))*l1*l2*m3*(diff(theta2(t), t))+cos(theta2(t))*(diff(theta2(t), t))^2*sin(theta1(t))*l1*l2*ml+sin(theta2(t))*cos(theta1(t))*(diff(theta1(t), t))*l1*l2*ml*(diff(theta2(t), t))-cos(theta2(t))*sin(theta1(t))*(diff(theta1(t), t))*l1*lc2*m2*(diff(theta2(t), t))+cos(theta2(t))*(diff(theta2(t), t))^2*sin(theta1(t))*l1*l2*mr+sin(theta2(t))*cos(theta1(t))*(diff(theta1(t), t))*l1*l2*mr*(diff(theta2(t), t))+cos(theta2(t))*(diff(theta2(t), t))^2*sin(theta1(t))*l1*l2*m4+sin(theta2(t))*cos(theta1(t))*(diff(theta1(t), t))*l1*l2*m4*(diff(theta2(t), t))+cos(theta2(t))*(diff(theta2(t), t))^2*sin(theta1(t))*l1*l2*mi+sin(theta2(t))*cos(theta1(t))*(diff(theta1(t), t))*l1*l2*mi*(diff(theta2(t), t))-cos(theta2(t))*sin(theta1(t))*(diff(theta1(t), t))*l1*l2*mr*(diff(theta2(t), t))-cos(theta2(t))*sin(theta1(t))*(diff(theta1(t), t))*l1*l2*mi*(diff(theta2(t), t))+cos(theta2(t))*(diff(theta2(t), t))^2*sin(theta1(t))*l1*l2*m3+sin(theta2(t))*cos(theta1(t))*(diff(theta1(t), t))*l1*l2*m3*(diff(theta2(t), t))-cos(theta2(t))*sin(theta1(t))*(diff(theta1(t), t))*l1*l2*mc*(diff(theta2(t), t))-cos(theta2(t))*sin(theta1(t))*(diff(theta1(t), t))*l1*l2*ml*(diff(theta2(t), t))+cos(theta2(t))*(diff(theta2(t), t))^2*sin(theta1(t))*l1*lc2*m2+sin(theta2(t))*cos(theta1(t))*(diff(theta1(t), t))*l1*lc2*m2*(diff(theta2(t), t))+sin(theta2(t))*sin(theta1(t))*l1*l2*m3*(diff(theta2(t), t, t))+cos(theta2(t))*cos(theta1(t))*l1*l2*m3*(diff(theta2(t), t, t))+cos(theta2(t))*cos(theta1(t))*l1*l2*mi*(diff(theta2(t), t, t))+cos(theta5(t))*cos(theta1(t))*h2*l1*m4*(diff(theta5(t), t, t))+sin(theta2(t))*sin(theta1(t))*l1*l2*mr*(diff(theta2(t), t, t))+m1*lc1^2*(diff(theta1(t), t, t))-sin(theta6(t))*sin(theta1(t))*h2*l1*m4*(diff(theta6(t), t, t))+sin(theta5(t))*sin(theta1(t))*h2*l1*mr*(diff(theta5(t), t, t))+sin(theta5(t))*sin(theta1(t))*h2*l1*mc*(diff(theta5(t), t, t))-cos(theta6(t))*cos(theta1(t))*h2*l1*mi*(diff(theta6(t), t, t))-sin(theta6(t))*sin(theta1(t))*h2*l1*mi*(diff(theta6(t), t, t))-cos(theta6(t))*cos(theta1(t))*h2*l1*m3*(diff(theta6(t), t, t))-sin(theta6(t))*sin(theta1(t))*h2*l1*m3*(diff(theta6(t), t, t))+sin(theta2(t))*sin(theta1(t))*l1*lc2*m2*(diff(theta2(t), t, t))+cos(theta2(t))*cos(theta1(t))*l1*l2*m4*(diff(theta2(t), t, t))+sin(theta2(t))*sin(theta1(t))*l1*l2*mc*(diff(theta2(t), t, t))+sin(theta3(t))*sin(theta1(t))*l1*lc3*m3*(diff(theta3(t), t, t))-cos(theta3(t))*cos(theta1(t))*l1*l3*mi*(diff(theta3(t), t, t))-sin(theta3(t))*sin(theta1(t))*l1*l3*mi*(diff(theta3(t), t, t))-cos(theta3(t))*cos(theta1(t))*l1*l3*m3*(diff(theta3(t), t, t))-sin(theta3(t))*sin(theta1(t))*l1*l3*m3*(diff(theta3(t), t, t))+cos(theta7(t))*cos(theta1(t))*h3*l1*mc*(diff(theta7(t), t, t))-cos(theta6(t))*cos(theta1(t))*h2*l1*ml*(diff(theta6(t), t, t))+sin(theta7(t))*sin(theta1(t))*h3*l1*mc*(diff(theta7(t), t, t))-sin(theta6(t))*sin(theta1(t))*h2*l1*ml*(diff(theta6(t), t, t))+sin(theta4(t))*sin(theta1(t))*l1*lc4*m4*(diff(theta4(t), t, t))+cos(theta4(t))*cos(theta1(t))*l1*lc4*m4*(diff(theta4(t), t, t))-sin(theta4(t))*sin(theta1(t))*l1*l4*mi*(diff(theta4(t), t, t))+sin(theta2(t))*sin(theta1(t))*l1*l2*m4*(diff(theta2(t), t, t))+sin(theta2(t))*sin(theta1(t))*l1*l2*mi*(diff(theta2(t), t, t))+sin(theta5(t))*sin(theta1(t))*h2*l1*m4*(diff(theta5(t), t, t))
I want to manipulate polynomials in two non-commuting variables, over the field of rational numbers.  I read some of the help concerning Ore algebras, and also some of the help concerning the Physics package (where there are non-commuting variables), but unfortunately I could not understand much of what I read!  For someone who is not a Maple virtuoso, is there a simple way to work with non-commutative polynomials?
I also tried the “do-it-yourself” approach, i.e., defining a non-commutative multiplication via a neutral operator &*.  This time I had some success, but I ran into problems when I tried to extract the coefficient of a given monomial in a given polynomial.  In the file  NonCommutPolynomials.mw  you can see that the Maple command “coeff” gives me the correct answer only when the degree of the monomial is strictly greater than 1.  I have no idea how to extract the coefficient of x, or of y, or how to get the constant term of the polynomial — and extracting coefficients is something I need to do!
First 799 800 801 802 803 804 805 Last Page 801 of 2459
