I am trying to understand under which conditions submenus disappear.
Now I have seen that the context panel is empty when submenues disappear.
Has anybody noticed the same and are there other instances when the context panel is emtpy?
Both effects could have the same rootcause.
Here is an example:
A -> no submenu
B -> Empty context panel
C -> Menu appears inside workspace (first time I see that)
Update
C seems to happen when the Maple window is not maximized to the full screen. -> then the context pannel becomes empty (for some reason) -> then if the Maple window is maximized to full screen we see C. Opeing new documents do not show this when toggling between and
On donne un cercle fixe de diamètre AB, un point M variable sur ce cercle et on construit un carré de sens direct AMNP; Trouver les lieux des points N et P.
r := 1;
A := [-r, 0];
B := [r, 0];
M := [r*cos(theta), r*sin(theta)];
N := [r*cos(theta) - r*sin(theta), r*sin(theta) + r*cos(theta)];
P := [-r*cos(theta) - r*sin(theta), r*cos(theta) - r*sin(theta)];
c1 := `~`[plottools]*circle([0, 0], r, color = blue);
plot1 := plot(c1, color = blue);
plot2 := animate([N[1], N[2], theta = 0 .. 2*Pi], color = red, thickness = 2);
plot3 := animate([P[1], P[2], theta = 0 .. 2*Pi], color = green, thickness = 2);
display(plot1, plot2, plot3);
Would you like to improve this code so it works. Thank you.
Hi everyone,
I’m encountering an issue with Maple 2024 on my MacBook Air M1 (2020) running macOS Sonoma 14.6.1. Every time I try to log in to Maple Cloud from within the application, the entire program freezes and becomes unresponsive. I’ve tried restarting the application and my MacBook, but the problem persists.
Is anyone else experiencing similar issues with Maple 2024 on an M1 Mac running macOS Sonoma? If so, have you found any solutions or workarounds? I’ve checked for updates and even reinstalled the software, but the problem still exists.
Any help or advice would be greatly appreciated!
Thanks in advance!
This problem began about 3 nights ago.
When I load the subpackage UHG to RationalTrigonometry no warning.
When I rerun the worksheet warnings appear. If I put in arestart and reload the packages no warning. The problem only occurs with the sub packageUHG. The RationalTrigonometry package also has a few aliases.
Screen shot of one rerun  then added restart.
Chrome autofills my "Search Questions:" field on https://www.mapleprimes.com/questions/. Does anyone know a prompt way to correct this?
I've modified my call to coulditbe() to always use assuming real to prevent false positives.
Now I find it gives internal error Error, (in type/complex) too many levels of recursion which can not even be trapped when the thing I am checking happened to have complex I in it. (This is done in code).
So I modied the code to only do this check if there is no complex in the expression being checked.
But I think Maple should not generate such error in first place. This indicates some internal problem in Maple, correct?
Here is worksheet. (ps. updated, wrong worksheet for somereason was uploaded).
`The "Physics Updates" version in the MapleCloud is 1792 and is the same as the version installed in this computer, created 2024, August 22, 12:6 hours Pacific Time.`
libname;
the_residual:=-1/4*I*x^(1/2)/(8*x^(3/2)+12*c__1)^(1/3)*(-(8*x^(3/2)+12*c__1)^(2/3)-I*(8*x^(3/2)+12*c__1)^(2/3)*3^(1/2))^(1/2)*6^(1/2)-1/4*x^(1/2)/(8*x^(3/2)+12*c__1)^(1/3)*2^(1/2)*(-(8*x^(3/2)+12*c__1)^(2/3)-I*(8*x^(3/2)+12*c__1)^(2/3)*3^(1/2))^(1/2)-x^(1/2);
try
    coulditbe(the_residual=0) assuming real;
catch:
   print("error");
end try;
-((1/4)*I)*x^(1/2)*(-(8*x^(3/2)+12*c__1)^(2/3)-I*(8*x^(3/2)+12*c__1)^(2/3)*3^(1/2))^(1/2)*6^(1/2)/(8*x^(3/2)+12*c__1)^(1/3)-(1/4)*x^(1/2)*2^(1/2)*(-(8*x^(3/2)+12*c__1)^(2/3)-I*(8*x^(3/2)+12*c__1)^(2/3)*3^(1/2))^(1/2)/(8*x^(3/2)+12*c__1)^(1/3)-x^(1/2)
try
    if not has(the_residual,I) then
       print("by passing, since residual is complex");
    fi;
catch:
   print("error");
end try;
Download internal_error_too_many_Levels_from_coulditbe_august_23_2024.mw
while i am writing code for loop with if condition i am having problem kindly help me out i am sharing fileburgers_type_method.mw
Are there any tools in Maple that allow you to find real roots of complex integral equations?
I have attached examples of such equations.
Unfortunately, I can't solve them.
Best regards.
Test.mw
Hello community,
I recently became a Maple Ambassador and  I would like to ask about some portals that were mentioned to me. Are these portals on mapleprimes and how can I access them?
I was thinking that I could also create a LinkedIn group, so that I could present there the activities I will do at the university, the online workshops I will do in the future or upload material from student projects.
Best Regards,
Athanasios Paraskevopoulos
HI, I saw an example in Maplesim where the speed of the Unwinder roller is modeled as a feedback control from the dancer's position, the radius of the Unwinder roller, to maintain a constant speed of the web.
I was wondering how the Unwinder roller radius (m) was divided by the target constant web speed (Lamp signal (m/s)) and added from the dancer's angle to achieve feedback control of the Unwinder roller.
Studying the attached documentDuffing Equation from the University of Colorado, I tried to plot the Duffing equation in three different ways. My worksheet is attached.
But I didn't get the desired result as you can see below. Any suggestion on how to fix my problem?
Download Example.mw
This ode has solution when solving for the IC by hand. But Maple gives new error I did not see before when asking it to solve the ode with IC.
No error if asked to solve the ODE without the IC.
Is this new error in dsolve? I have no earlier Maple versions to check. Below is worksheet. Solving for the IC by hand gives the solution which odetest verified.
`The "Physics Updates" version in the MapleCloud is 1789 and is the same as the version installed in this computer, created 2024, August 10, 8:50 hours Pacific Time.`
ode := diff(y(x), x) = sqrt(2)*sqrt(-(y(x) - 6)*(2*y(x) - 3))/(-y(x) + 6);
IC:=y(0)=3;
diff(y(x), x) = 2^(1/2)*(-(y(x)-6)*(2*y(x)-3))^(1/2)/(-y(x)+6)
y(0) = 3
sol:=dsolve(ode);
x-(1/4)*(-4*y(x)^2+30*y(x)-36)^(1/2)-(9/8)*arcsin((4/9)*y(x)-5/3)+c__1 = 0
sol_with_IC:=dsolve([ode,IC]); #why this error??
Error, (in dsolve) when calling 'series/RootOf'. Received: 'unable to compute series'
#lets solve for the IC by hand:
eq:=eval(sol,[y(x)=3,x=0])
-(1/4)*18^(1/2)+(9/8)*arcsin(1/3)+c__1 = 0
C_sol:=PDEtools:-Solve(eq,_C1);
c__1 = (3/4)*2^(1/2)-(9/8)*arcsin(1/3)
my_new_sol:=eval(sol,C_sol)
x-(1/4)*(-4*y(x)^2+30*y(x)-36)^(1/2)-(9/8)*arcsin((4/9)*y(x)-5/3)+(3/4)*2^(1/2)-(9/8)*arcsin(1/3) = 0
odetest(my_new_sol,[ode,IC])
[0, 0]
Download internal_error_when_unable_to_find_solution_august_22_2024.mw
i have solution of ODE but again i want take derivative from solution function F then i want take reciprocal of derivative
if F'=G then i want 1/F'=1/G like that i want all solution by list and if possible don't give the parameter a sequence  it will be better
thanks for any help
K := diff(G(xi), xi $ 2) = -lambda*diff(G(xi), xi) - mu;
                d                    / d        \
          K := ----- G(xi) = -lambda |---- G(xi)| - mu
                   2                 \ dxi      /
                dxi
V:= [seq](-1..1, 1/2);
                          [    -1     1   ]
                     V := [-1, --, 0, -, 1]
                          [    2      2   ]
interface(rtablesize= nops(V)^3):
DataFrame(
    <seq(seq(<a | b | rhs(dsolve(eval(K, [lambda,mu]=~ [a,b])))>, a= V), b= V)>,
    columns= [lambda, mu, F]
loading
Dear Expert Users,
I am still struggling with my transition from Mathcad 15 to Maple. Would someone be so kind to look at the attached worksheet and how I can obtain the desired result? Thanks in advance. The data used in the example come from TestFleck.xlsx
QuestionPrimes.mw TestFleck.xlsx
my odetest must give me zero everything is true but still not simplify the function with power include 1/n  not do cancelation even
test_sol_for_PDE.mw
First 78 79 80 81 82 83 84 Last Page 80 of 2426
