C_t := -A(t)*omega[0]*(sigma-(diff(C(t), t)))-(1/4)*A(t)^5*beta[2]*omega[0]^2-(1/4)*A(t)^3*beta[1]*omega[0]^2-(1/2)*F[0]*cos(C(t))+5*alpha[2]*A(t)^5*(1/16)+3*alpha[1]*A(t)^3*(1/8) = 0;
-A(t)*omega[0]*(sigma-(diff(C(t), t)))-0.3297500000e-1*A(t)^5*omega[0]^2-0.8345000000e-1*A(t)^3*omega[0]^2-cos(C(t))+0.4059375000e-1*A(t)^5+.1249125000*A(t)^3 = 0
A_t := (1/2)*mu*A(t)*omega[0]+(diff(A(t), t))*omega[0]-(1/2)*F[0]*sin(C(t)) = 0;
0.5000000000e-2*A(t)*omega[0]+(diff(A(t), t))*omega[0]-sin(C(t)) = 0
F[0] :=2: w0 := 1: alpha[1]:=0.3331:alpha[2]:=0.1299:beta[1]:=0.3338:beta[2]:=0.1319:mu:=0.01:sigma=0:
sigma = `0:`
C_t;A_t;
ICS:=[C(0)=0,D(C)=0,A(0)=1,D(A)=0]:
sol:=dsolve({C_t,A_t,ICS},[C(t2),D(C),A(t2),D(A)],type=numeric):
pRange:=0..20:
 Atime:=odeplot( sol, [t, A],t=pRange, numpoints=10000 ):
Atime;
odeplot(sol, [t, A], t = 0 .. 20, numpoints = 10000)
Download phase_plot.mw
rho := -2*K*(s+K)^2*k[e]*sinh((s+K)*x/d)/(s*d^2*(4*(s+K)^3*cosh((s+K)*h/d)*h/d^2-4*K*(s+K)*cosh((s+K)*h/d)*h/d+4*sinh((s+K)*h/d)*K))
l.mw
All variables are constant except s and x
I would like to ask, how can I translate a Maple worksheet to a Mathematica notebook.
I'm working on coding questions and I want to realize a particular addition (sometimes called "Nim addition")
Here is an example in base 3
Let A=11 and B=21 two numbers written inbase 10.
I want to realize the operation "A plus B" defined this way
  1. write A and B in base 3 : A -> a=102  and B -> b=210
  2. do c=a+b just as if a and b were numbers in base 10 : c=312
  3. compute all digits modulo 3 : 312 -> 012 = 12
  4. write this number in base 10 : 12 -> 5
Then 11 plus 21 = 5
In Maple"s syntax :
A := 11:
B := 21:
a := convert(A, base, 3):   # returns [1, 0, 2]
b := convert(B, base, 3):   # returns [0, 1, 2]
# the simplest thing I found to implement operation 2 and 3 above is :
# 1/ convert each list into polynomials (let's say pa and pb)
# 2/ set pc = pa+pb mod 3
# 3/ convert pc into a list
# Instead of coding something like pa := add(a[k]*x^(k-1), k=1..numelems(a)),
# I found more astute to use the gfun package
sa := gfun[listtoseries](a, x, 'ogf'):  # returns x^2+2+O(x^3)
sb := gfun[listtoseries](b, x, 'ogf'):  # returns 2*x^2+x+O(x^3)
pc := convert(sa, polynom)+convert(sb, polynom) mod 3; # returns x+2
Unfortunately I can't use now gfun[seriestolist](pc, 'revogf') for pc is obviously not a serie !
Reciprocally sc := sa+sb mod 3 doesn't return x+2+O(x^3)
Then I'm trapped here and I don't know how to go further
(of course I know how to proceed if I build directly the polynoms associated to a and b ... but it is far less elegant)
Does anyone have some idea ?
This problems raise the following question: how can we add tho series ?
For instance sa+sb returns (x^2+2+O(x^3))+(2*x^2+x+O(x^3)) without, apparently, no way to simplify this into  x+2+O(x^3)
Currently, I have some definitions of modules and or functions in one worksheet, say A.
To reduce clutter in A, I'd like to open second worksheet, say B, and invoke the functions defined in A in the B worksheet. This way I keep the definitions in one worksheet, and the tests/trying them, in another worksheet.  I do this all the time in Mathematica. It useful, as I like to keep one notebook for just definitions, and second one for testing and calling the functions.
I just found out, that a function defined in worksheet is not "seen" in worksheet B.  I looked at options and settings, googled a little, but not able to find an option to allow me to do this. I tried Tools->General->Share one engine among all documents. Clicked Apply. But that still did not do it.  From worksheet B, it tells me it does know the function I am trying to call. Only in worksheet A it can see the function.
Is there an option to allow one to have the function definition be seen on all open worksheets?
I know I could save the functions as mpl files, and then load them in the second worksheet. But during development, the first method is easier.
Dear sir / madam
I'm a student of mechanical engineering and looking for some HPM ( homotopy perturbation method) maple codes with the related article to practice more in this field.
can I ask you for help?
unfortunately, I couldn't find any articles with maple solution about HPM.
sincerely
Aidin
Hi everybody,
I'm working with orthogonal or Bernstein polynomials and I would like to keep my results expressed in terms of such polynomials.
Here is a notional example.
with(orthopoly):
#  first example : the result of diff is of the desired form  (p*q)' =  p' * q + p * q'
p := H(2, x):
q := H(3,x):
pq;
    (4*x^2-2)*(8*x^3-12*x)
dpq := diff(pq, x);
    8*x*(8*x^3-12*x)+ (4*x^2-2)*(24*x^2-12)
#  second example : the result of diff is not exactly of the desired form (p*q)' =  p' * q + p * q'
# for  p' * q has been expanded
p := H(1,x)
q := H(3,x):
pq := p*q;
    2*x*(8*x^3-12*x)
diff(pq, x);
    16*x^3-24*x+ 2*x*(24*x^2-12)
#  third example : here the result has been fully expanded
p := H(1,x)
q := H(2,x):
pq := p*q;
    2*x*(4*x^2-2)
diff(pq, x);
    24*x^2-4
First question : How could Iforce Maple to  preserve the form  p' * q + p * q' in all the situations ?
______________________________________________________________________
In the first test case the value of dpq (   8*x*(8*x^3-12*x)+ (4*x^2-2)*(24*x^2-12)    ) is not expressed in terms of Hermite polynomials.
I would like it to be, so I tried this ...
r := degree(dpq, x):
A := add(a__||k*H(k,x), k=0..r):
C := coeffs(expand(dpq-A), x)
S := solve(C, {seq(a__|-k, k=0..r)});
      {a0=48, a1=0, a2=72, a3=0, a4=10}
Hdpq := subs(S, A)
    160*x^4-192*z^2+24
...but  I had hope to obtain   Hdpq := 48*H(0,z)+72*H(2,z)+10*H(4,z), so here
   48 + 72 * (4*z^2 - 2) + 10 * (16*z^4 - 48*z^2 + 12)
Second question : How could I prevent Maple to simplify the result os subs(S, A) ?
sys_ode := diff(I1(x), x) = -10*I1(x)+10*I2(x)+30, diff(I2(x), x) = -4*I1(x)+3*I2(x)+12;
             d
            --- I1(x) = -10 I1(x) + 10 I2(x) + 30,        >>> there are no sys_ode := before d\dx but when my friend do the same
             dx        at another laptop it show.. and also i cant plot the graph.
               d
              --- I2(x) = -4 I1(x) + 3 I2(x) + 12
               dx
dsolve([sys_ode]);
         { I1(x) = exp(-5 x) _C2 + exp(-2 x) _C1 + 3,
                   1                 4              \
           I2(x) = - exp(-5 x) _C2 + - exp(-2 x) _C1 }
                   2                 5              /
ics := I1(0) = 0, I2(0) = 0;
dsolve([sys_ode, ics]);
           {I1(x) = -8 exp(-5 x) + 5 exp(-2 x) + 3,
             I2(x) = -4 exp(-5 x) + 4 exp(-2 x)}
I can't get my answer when type Dx := Ky(0) , what to do?What the problem?
Worksheet:
As an exercise to gain familiarity with the maple programming platform, I am attempting to repackage a geometric algebra program written for Maple V as a module. I have attached file NewGlyph.mpl containing the initialization code for a module to support the GA routines in the package. The text file was created in the Maple code editor (Maple 2018) and loaded by reading it into a worksheet (configured for maple input instead of 2D math). I have two questions: one: how to get the GAinit procedure to execute completely, and two: to understand the puzzling warnings produced by the code editor.  The behaviour I observe when the module is loaded into a worksheet is: NewGlyph:= a maple id.  At this point the load=setup procedure has registered type blade, but not executed the remaining procedures in the setup routine. When I execute with(NewGlyph) the exported procedures are displayed properly.  However, I still have to execute the GAversion procedure and
the GA_addmetric procedure manually to properly initialize the metric table in the module. It would appear that the module load process permits the execution of the addtype procedure but not the output of the version procedure or the metric table constructor. Is there a way to autoexecute these procedures when the NewGlyph module is invoked by the with(NewGlyph) command? Are there any criteria for the kinds of processes that can be included using option load=setup? My second question concerns the compiler warning raised by the code editor.  It warns that "These names were used as global names but were not declared: blade, sig. Also "These local variable were assigned a value but not otherwise used: cleanup.
NewGlyph := module ()
description "Basic Geometric Algebra Functions";
local setup, cleanup;
global e;
export GAversion,GAinit, GAadd_metric,GAmetric,GAmv;
option package, load = setup, unload = cleanup;
setup := proc ()
TypeTools:-AddType(`blade`, proc (a) type(a, indexed) and op(0, a) = 'e' end proc);
GAversion();
GAinit();
setup();
cleanup:=proc()
TypeTools:-RemoveType(`blade`);
GAinit := proc()
global `&@`, `&.`, `&^`, `&x`, `&s` , `&/`, `&l`, `&v`;
protect('`&@`','`&.`', '`&^`', '`&x`', '`&s`', '`&/`', '`&l`', '`&v`');
GAadd_metric('default', signum, -infinity, infinity);
GAadd_metric('SA', proc () 1 end proc, 1, 3);
GAadd_metric('STA', proc (i) `if`(i = 0, 1, -1) end proc, 0, 3);
GAadd_metric('MSTA', proc (i) `if`(modp(i, 4) = 0, 1, -1) end proc, 0, infinity);
GAadd_metric('Homogeneous', proc () 1 end proc, 0, infinity);
GAadd_metric('Conformal', proc (i) `if`(i = -1, -1, 1) end proc, -1, infinity);
GAmetric('default');
GAversion := proc ()
print(`GA Package`);
print(`Version 2.0`);
print(`Written by: Mark Ashdown, maja1@mrao.cam.ac.uk`);
print(`Extended by: Alan Macdonald, macdonal@luther.edu`);
print(`Re-Packaged for Maple 2018 by: Ian McCreath`);
GAadd_metric := proc (fred::name, signature::procedure, minind::{integer, infinity}, maxind::{integer, infinity})
global MetricTable;
unprotect('MetricTable');
MetricTable['fred'][sig] := eval(signature);
if maxind < minind then
ERROR(`The minimum index is greater than the maximum index`)
MetricTable['fred'][min] := minind;
MetricTable['fred'][max] := maxind;
print(`The GA package knows about metric ` . fred . `.`)
GAmetric := proc (a::name)
global Metric, Sig, MetricTable, MinIndex, MaxIndex;
if member([a], [indices(MetricTable)]) then
unprotect('Metric', 'Sig', 'MinIndex', 'MaxIndex');
Metric := a;
Sig := MetricTable[Metric][sig];
MinIndex := MetricTable[Metric][min];
MaxIndex := MetricTable[Metric][max];
print(`Metric is now set to: ` . Metric)
ERROR(`The metric ` . a . ` is unknown to the GA package`)
end if
# Creates multivector with name x of with grade or set of grades g with
# indices ind
GAmv := proc(x::name,g::{nonnegint,set(nonnegint)},ind::set(integer))
local i;
if g::set then
add(procname(x,i,ind), i=g)
elif g > nops(ind) then
ERROR(`grade too large for number of indices.`)
elif g=0 then
x[NULL]
add(x[op(i)]*e[op(i)], i=combinat:-choose(sort([op(ind)]),g))
end if
end:
end module;
Download NewGlyph.txt
ode:=-diff(y(x),x,x)+(1/4)*y(x)-4*exp(-x)=0:
init:=y(0)=0,y(1)=0:
exact:=dsolve({ode,init},y(x)):
N:=8:
trial:=sum(c[i]*x^i,i=1..N):
residual:=lhs(subs(y(x)=trial,ode)):
R:=simplify(residual):
sys:=[]:
for i from 1 to N  do sys:=[op(sys),int(R*x^i,x=0..1)=0];
sys:
vars:=seq(c[i],i=1..N):
A,b:=LinearAlgebra[GenerateMatrix](sys,[vars]):
sol:=solve({op(sys)},{vars}):
assign(sol):
trial:
# if i am plotting the graph exact and trial i am getting the error, separately if i am plotting the graph of exact i am getting the plot, similarly exact - trial error
trial_fun:=unapply(trial,x):
exact_fun:=unapply(rhs(exact),x):
evalf(trial_fun(1)-exact_fun(1)):
plot(exact,trial,x=0..1):
plot(trial,x=0..1,legend['trial']):
#error calculation
plot(exact-trial,x=0..1):
Eqn:=-diff(y(x),x,x)+(1/4)*y(x)-4*exp(-x)=0:
BCs:=y(0)=0,y(1)=0:
dsolve({Eqn,BCs},y(x)):
assign(%):y:=unapply(y(x),x):
plot(y(x),x=0..1);
When running this code in Maple 13 and 16 this works just fine,
GenMs:= (k::posint)-> assign(m||(1..2*k) =~ seq([dx||i, dy||i][], i= 1..k)):
GenMs(k), m || (1 .. 2*k);
gln := evalDG(l1 &s n1+`&s`(l2, n2)+sum('epsilon || i'*(cat(m, 2*i-1) &s cat(m, 2*i-1)+cat(m, 2*i) &s cat(m, 2*i)), i = 1 .. k));
But running the same code in Maple 2018 I get the following error:
Error, (in DifferentialGeometry:-Tensor:-SymmetrizeIndices) expected 1st argument to be a tensor. Received: `m2*i-1`^2
I don't know if it's related to Maple 2018 screwing with my tensor formatting:
https://gyazo.com/88eaeceda2e36cf411df44dbc4aa3ab6
(compare https://gyazo.com/b33396131165d66bbcf16e45d20cc579)
For whatever reason I just noticed that my inline &t's have been turned into `&t` but that's a separate issue.
I am learning how to do parsing in Maple.
I want to check that a user supplied an expression with correct argument to y(*) from some complicated expression. So I need to find all instanced of y() to check that its agument is only y(x) and nothing else.  For example, given this
expr:=y(x)^2+x+y(x)+2*1/y(z)+sin(x)+sin(y(x))+y+f(z)/Int(sin(y(x)),x)+y(x,y,z);
I need to obtain all these y(anything), like this
No matter where they show up in the expression. The above is just some made up example. The actual input will be a differential equation, and I want to check that the dependent variable y(x) has only x as its argument.
So I did the following
candidates:=convert(select(has,expr,y),list);
The problem now, is how to scan this list and check that each entry in it, the "y" in there has form y(x) and nothing else, so I can reject or accept the input. For example, the first one above is Ok, so the second one, but the third is not, since it function of z and not x. #4 is OK, #5 is not OK, since it has y without (x), and the last one is no OK, since it has 3 arguments, and so on.
I am not good in pattern matching in Maple. do I need to check match() for this? or patmatch()? If given single expresion like y(x), then I can handle it. I do something like
expr:=y(x);
if type(expr,'function') and nops(expr)=1 and op(0,expr)=y and op(1,expr)=x then
   print("OK");
   print("not ok");
fi;
But when the expression gets more complicated, like 1/y(z), then I need to check other things, and things gets complicated quickly. I think pattern matching is needed? or is there a better approach to do this that works in general?
How does Maple do it internally? When I type
   dsolve(diff(y(x),x)+x+y(z)=0,y(x));
Error, (in dsolve) found the indeterminate function y with different arguments {y(x), y(z)}
dsolve(diff(y(x),x)+x+sin(y(z))=0,y(x));
dsolve(diff(y(x),x)+x+y()=0,y(x));
So I need to do the same thing as Maple does. I looked at dsolve() code, but did not understand it how or where it does the parsing.
I am asking the students to write down the integral  (1/3)*int(10*cos(2*Pi*t/3),t=-1..1) without calculating it.  Both Maple TA in student answer, and Maple in my algorithm evaluate the integral. I just want the formula to be displayed not evaluated. How can I do that.  Thanks in advance.
I am using this proc by Carl Love posted here
https://www.mapleprimes.com/questions/211401-How-Do-I-Print-Text-Followed-By-Math
TSprintf:= proc()
   local e;
   uses T= Typesetting;
   T:-mrow(seq(`if`(e::string, T:-mn(e), T:-Typeset(T:-EV(e))), e= [args]))
when I do
         TSprintf("Solving ", diff(y(x),x)=x);
it works fine and it prints on the screen as expected.
The problem is that inside a proc, if I use an error() later on, the message do not show up
foo:=proc()
   TSprintf("Solving ", _passed);
   error "opps"
And now when I call it like this
  foo(diff(y(x),x)=x);
      Error, (in foo) opps   # Where the message "solving...." gone?? it does not show on the screen
I only see the "opps" and never see the message.  If I remove error(), then it shows up. But with standard printf, both show up
foo:=proc()
   printf("Solving %a", _passed);
   error "opps";
    Solving diff(y(x),x) = x  # printf message shows OK
    Error, (in foo) opps      # from error
Why TSprintf message do not show up if there is an error() after it?
First 817 818 819 820 821 822 823 Last Page 819 of 2427
