I have a list L:=[[0,0,0], [1,0,0], [1,1,0], [0,1,0], [0,0,1], [1,0,1], [1,1,1], [0,1,1]] (8 vertices of a cube). How can I select four vertices of the list to make a regular tetrahedron?
I am experiencing some trouble with the function Minimize of the Optimization package. I have some trouble understanding what Maple is doing with nice functions already.
f := (x-2)^2+1;
                          (x - 2)  + 1
Minimize(f, {x >= -2, x <= 2});
             [1., [x = HFloat(1.9999999999999998)]]
Minimize(f(x), {x >= -2, x <= 2});
                    [1., [x = HFloat(2.0)]]
g := proc (x) options operator, arrow; (x-2)^2+1 end proc;
x -> (x - 2)  + 1
Minimize(g, {x >= -2, x <= 2});
Error, (in Optimization:-NLPSolve) constraints must be specified as a set or list of  procedures
Minimize(g(x), {x >= -2, x <= 2});
Hello there!
I have just an elemental question. Given an equation as input, how could I write a procedure to know the variables involved in that equation?
For example, my input is 2x+3y=0, and I would like to have the output  {x,y}.
Thanks in avance for the help!
I have the equations of a trajectory:
I am trying to study a solution so I can learn how to do this. I know the graph should look like this:
But I don't know how to plot x(t) and y(t) as a graph of y vs x.
This seems like it should be easy but I've never done this before. Please help!
I am attempting to have the piecewise function
Render using either mathML or Letex in maple, using the syntax:
f := piecewise(-Pi <= x and x < 0, 1, 0 <= x and x < Pi, 0);
la := latex(f);
mml := MathML[ExportPresentation](f);
Unfortunately, as you will notice the latex produces some really annoying "and" words amongst the code.  While the MathML produces some equally annoying "&wedge;", and symbols, amongst the code.
Any help would be appreciated.
Mark
I have a question about the Import of .txt file:
I can import the following .txt, but everytime I want to convert in a matrix or something else, maple chrashes.
I need some parts (smaller matrices) of this data (for example: all values from coloumn 200-400 and row 100-600)
I hope somebody can help me
Martin
-Validierung-Stahl-AI-.txt
Hey
i want to solve these 3 eqations
21000 = ((10/1000)/60)*4181*983*(x-y)
H = -((10/1000)/60)*4181*ln(1-((x-y)/(x-40)))
H = 124+102'ln(x-40)+(7+2*ln(x-40))
with the result of:
H,x,y
how do i do that?
Hi everyone, I am trying to plot field lines but I face problem in plotting field plot. kindly help me if anyone can do it. Find the code in the attached file. Thank you.
Field_lines.mw
tomleslie 2300Mohsen 20 @Carl Love @Markiyan Hirnyk @maple fan 175 @asa12 405  @Adri van der Meer 1253
f:=5*x^3-5*x+1;
5*x^3-5*x+1
s:=[solve(f)]; evalf(%);  # All the roots are real
[(1/30)*(-2700+(300*I)*219^(1/2))^(1/3)+10/(-2700+(300*I)*219^(1/2))^(1/3), -(1/60)*(-2700+(300*I)*219^(1/2))^(1/3)-5/(-2700+(300*I)*219^(1/2))^(1/3)+((1/2)*I)*3^(1/2)*((1/30)*(-2700+(300*I)*219^(1/2))^(1/3)-10/(-2700+(300*I)*219^(1/2))^(1/3)), -(1/60)*(-2700+(300*I)*219^(1/2))^(1/3)-5/(-2700+(300*I)*219^(1/2))^(1/3)-((1/2)*I)*3^(1/2)*((1/30)*(-2700+(300*I)*219^(1/2))^(1/3)-10/(-2700+(300*I)*219^(1/2))^(1/3))]
[.8788850663-0.2e-9*I, -1.088033915-0.2598076212e-9*I, .2091488484+0.2598076212e-9*I]
max(s);  # ?
Error, (in simpl/max) complex argument to max/min: (1/30)*(-2700+(300*I)*219^(1/2))^(1/3)+10/(-2700+(300*I)*219^(1/2))^(1/3)
type(s,list(realcons)); # Wrong, the type realcons should not be purely syntactic; or is it?
R:=convert(s,RootOf):
max(R);  #  For nested RootOfs fails
Error, (in simpl/max) complex argument to max/min: (1/30)*RootOf(_Z^3+2700-300*RootOf(_Z^2+1, index = 1)*RootOf(_Z^2-73, index = 1)*RootOf(_Z^2-3, index = 1), index = 1)+10/RootOf(_Z^3+2700-300*RootOf(_Z^2+1, index = 1)*RootOf(_Z^2-73, index = 1)*RootOf(_Z^2-3, index = 1), index = 1)
sort(s): evalf(%);  # Wrong
[.8788850663-0.2e-9*I, .2091488484+0.2598076212e-9*I, -1.088033915-0.2598076212e-9*I]
Workaround
S:=[seq(RootOf(f,x,index=i),i=1..3)];
[RootOf(5*_Z^3-5*_Z+1, index = 1), RootOf(5*_Z^3-5*_Z+1, index = 2), RootOf(5*_Z^3-5*_Z+1, index = 3)]
evalf(S);
[.2091488484, .8788850662, -1.088033915]
min(S);max(S);  # OK
sort(S);   # Wrong!
r:=(sqrt(2)+I)^3 + (sqrt(2)-I)^3;
(2^(1/2)+I)^3+(2^(1/2)-I)^3
type(r,realcons);  # Purely syntactic?
type(expand(r),realcons);
max(r,13);  # Even for such a simple expression?
Error, (in simpl/max) complex argument to max/min: (2^(1/2)+I)^3+(2^(1/2)-I)^3
Download TryHarder.mw
So I've got a function and try to find an extrema (and there is one on the plot), but Maple gives me empty brackets.
First, earlier it gave me 2 x-coordinates with extrema (both empty), but now (after reloading) it gives one and empty.
Second, how do I set an interval, if I want to look for extrema from x=0 to x=1, for example? I tried extrema (V, {0,1}, x) and (V, {x=0, x=1}, x), but nothing seems to work.
2.mw
Hi everybody,
I use the Grid package to do intensive computations.
For some reason I'm ignorant about, the test case described in the Grid[Server][StartServer]
 help page doesn't work with Maple 2015 (neither on Mac OS X, neither on Windows 7 ; here is the mw file run on MAC Os X)
Could someone explain me why (probably something I did not read with enough attention ... some license maybe) ?
GridServer.mw
I need to calculate sum w2(x,y),
v2 := proc (x, y) options operator, arrow; sin(x)*cos(y) end proc;
u2 := proc (x, y) options operator, arrow; 3*sin(x)-cos(y) end proc;
w2 := proc (x, y) options operator, arrow; diff(v2(x, y), x)-(diff(u2(x, y), y)) end proc;
L1 := proc (x, y) option inline; abs(w2(x, y)) end proc; CodeTools:-Usage(evalhf(add(add(abs(w2(x, y)), x = 0 .. 10), y = 0 .. 10)));
Error, (in CodeTools:-Usage) unable to evaluate built-in function `diff` in evalhf
 but it is error , how  can be rewritten properly?
I created the following plot
plot([BesselJ(0, x), BesselJ(1, x)], x = 0 .. 10, color = [red, blue]);
What I want to do mext is calculate all x values on this interval wherethe two paths intersect
 Calculate all x values on this interval where
I have a question as this:
Examples as following:(come from MAPLE‘s help )
with(LinearAlgebra);
Ax := <1.00004, 1.99987, -0.12e-3>;
b := <1., 2., 0.>;
Add(Ax, b, 1, -1);
result is this:[0.400000000000400e-4, -0.129999999999963e-3, -0.120000000000000e-3]'
I think result is :[0.400000000000400e-4, -0.13e-3, -0.120000000000000e-3]'
Is this a bug of MAPLE?
I am trying to solve the function
f :=  sqrt(1-x2)
L := int(sqrt(1+(diff(f(x), x))2), x = 0 .. 5)
Maple is returning an answer with Pi:  (1/2)*Pi+I*ln(5+2*sqrt(6))
How do I convert this into a numerical format?
First 868 869 870 871 872 873 874 Last Page 870 of 2427
