Hello.
I would like to know if Maple can or cannot evaluate the integral below. It can be done analytically and also in Mathematica. It is not an uncommon type of integral being related to a Fourier transform of a Hankel function.
assume(alpha>0);assume(beta>0);assume(s>0);
gr:=(beta,r)->(1/8*I)*(-HankelH1(1, beta*r)-(2*I)*BesselK(1, beta*r)/Pi)/beta^2;
int(cos(alpha*s)*gr(beta,s),s=0..infinity);
Many thanks
"(a)(b"
"(a)(b"
Copy the string, paste into a new cell, delete and retype the opening quote.
""(a)(`b"`"
Error, unable to delimit strings/identifiers
""(a)(`b"`"
Copy the string from the first cell, add f() around it.
"f("(a)(`b"`)"
"f("(a)(`b"`)"
Download 2dstring.mw
Hope everything is fine with everything. I want to draw the graph of the u(x,0.5) and T(x,0.5) for different values of alpha like alpha =0.4,0.6,0.8 while keeping Gr, R and Pr are fixed. Please solve the following problem I shall be vary thankful to you. Thanks in advance
with the following BCs
Is there a way to determine the coordinates of all the vertices of a cuboid using geom3d?
See WC06_Vertices_of_a_Cuboid.mwWC06_Vertices_of_a_Cuboid.mw attached.
The graphic of the cuboid is created with
A:=(cuboid([1,1,2],[3,4,5]), orientation [27,78],lightmodel = light4, shading = none, transparency =.85,scaling = constrained, axesfont = [bold, roman, 18], axes = normal):
And the vertices are self-evident, for example
B:= pointplot3d({[3,1,5]}, symbol = solidsphere, symbolsize = 18, color = red):
One geom3d ....
geom3d[point](P,1,1,2): geom3d[point(Q,3,4,5): geom3d[distance](P,Q);
gives the lengths of the diagonal of the box.  Is there a way to get geom3d to list the coordinates of the 8 vertices of a cubeoid?
Can someone show how this can be done in Maple?  I've added the zipped original noisy image .Fig0240(a)(apollo_17_boulder_noisy).zip
Stupid question maybe, but when will the newest version be released or what will the newest version be label wise? When are the newest versions generally released???
I am having a difficulty is running a loop with solve command. I am using a command solve(f(x,alpha)=0, x) in a loop for alpha = 1 by 1 to 10. For some reasons, for some values of alpha, the solve command does not give any solution and hence the program keeps running on. When I interrupt the program at such instance, the remainder of the program is not complete.
I tried using the try-catch command. I face the same issue.
Is there a way for me to bypass the solve command when it does not find any solution for a particular alpha and continue with the remainder of the program? I can come back and manually obtain the solution for such alpha values where solve command does not provide an answer.
I would appreciate your help.
Omkar
Does anyone know if there exist a script in JAWS for MapleSoft?
How do I access and assign values given by the solve command
for example
f := unapply(x*(8*x^2+5*x+cos(y)), x, y);
p := solve({diff(f(x, y), x) = 0, diff(f(x, y), y) = 0}, {x, y})
This gives the following
{x = 0, y = (1/2)*Pi}, {x = -1/6, y = 0}, {x = -1/4, y = 0}, {x = -1/2, y = Pi}, {x = 1/12, y = Pi}
now if I type: p[1] I get the following
Now this isn't very useful. I want to access the "0" and the "(1/2)*Pi". How do I do that?
I have been using random numbers in Maple and want to generate a sum of that random number. I have consider the following
with(stats):
x = random[uniform](10);
and now want
sum(x_i)^a
where (x_i) is the ith values in x (random array) and "a" is any real number.
in maple 2017 I have enconterd a problem in showing of matrix elements. this error did not exist in maple 2016.
after some mathematical operations with(Linearalgebra)
I have obtained a matrix but maple shows it as below
`Vector(3, {(1) = \`+\`(\`*\`(0.19498673e10, \`*\`(\`^\`(x[1], 3))), \`-\`(\`*\`(0.36539123e10, \`*\`(\`^\`(x[1], 2), \`*\`(x[2])))), \`*\`(0.12514628e10, \`*\`(\`^\`(x[1], 2), \`*\`(x[3]))), \`-\`(\`*\`(7987.1506, \`*\`(\`^\`(x[1], 2)))), \`*\`(0.35170874e10, \`*\`(x[1], \`*\`(\`^\`(x[2], 2)))), \`-\`(\`*\`(0.41418339e10, \`*\`(x[1], \`*\`(x[2], \`*\`(x[3]))))), \`-\`(\`*\`(9187.8615, \`*\`(x[1], \`*\`(x[2])))), \`*\`(0.28788960e10, \`*\`(x[1], \`*\`(\`^\`(x[3], 2)))), \`*\`(2871.4325, \`*\`(x[1], \`*\`(x[3]))), \`-\`(\`*\`(0.95594712e9, \`*\`(\`^\`(x[2], 3)))), \`*\`(0.21616680e10, \`*\`(\`^\`(x[2], 2), \`*\`(x[3]))), \`-\`(\`*\`(16552.293, \`*\`(\`^\`(x[2], 2)))), \`-\`(\`*\`(0.20009067e10, \`*\`(x[2], \`*\`(\`^\`(x[3], 2))))), \`-\`(\`*\`(30447.582, \`*\`(x[2], \`*\`(x[3])))), \`*\`(0.42009564e9, \`*\`(\`^\`(x[3], 3))), \`-\`(\`*\`(42372.407, \`*\`(\`^\`(x[3], 2))))), (2) = \`+\`(\`-\`(\`*\`(0.14713991e11, \`*\`(\`^\`(x[1], 3)))), \`*\`(0.42489026e11, \`*\`(\`^\`(x[1], 2), \`*\`(x[2]))), \`-\`(\`*\`(0.25018214e11, \`*\`(\`^\`(x[1], 2), \`*\`(x[3])))), \`-\`(\`*\`(55498.093, \`*\`(\`^\`(x[1], 2)))), \`-\`(\`*\`(0.34645652e11, \`*\`(x[1], \`*\`(\`^\`(x[2], 2))))), \`*\`(0.52229109e11, \`*\`(x[1], \`*\`(x[2], \`*\`(x[3])))), \`-\`(\`*\`(399927.96, \`*\`(x[1], \`*\`(x[2])))), \`-\`(\`*\`(0.24172439e11, \`*\`(x[1], \`*\`(\`^\`(x[3], 2))))), \`-\`(\`*\`(367829.40, \`*\`(x[1], \`*\`(x[3])))), \`*\`(0.11603445e11, \`*\`(\`^\`(x[2], 3))), \`-\`(\`*\`(0.24618238e11, \`*\`(\`^\`(x[2], 2), \`*\`(x[3])))), \`*\`(163169.71, \`*\`(\`^\`(x[2], 2))), \`*\`(0.24814370e11, \`*\`(x[2], \`*\`(\`^\`(x[3], 2)))), \`-\`(\`*\`(711030.81, \`*\`(x[2], \`*\`(x[3])))), \`-\`(\`*\`(0.64758011e10, \`*\`(\`^\`(x[3], 3)))), \`*\`(427083.52, \`*\`(\`^\`(x[3], 2)))), (3) = \`+\`(\`*\`(0.13627334e11, \`*\`(\`^\`(x[1], 3))), \`-\`(\`*\`(0.67651416e11, \`*\`(\`^\`(x[1], 2), \`*\`(x[2])))), \`*\`(0.94045968e11, \`*\`(\`^\`(x[1], 2), \`*\`(x[3]))), \`*\`(46901.078, \`*\`(\`^\`(x[1], 2))), \`*\`(0.70616015e11, \`*\`(x[1], \`*\`(\`^\`(x[2], 2)))), \`-\`(\`*\`(0.13072873e12, \`*\`(x[1], \`*\`(x[2], \`*\`(x[3]))))), \`-\`(\`*\`(994642.52, \`*\`(x[1], \`*\`(x[2])))), \`*\`(0.41170263e11, \`*\`(x[1], \`*\`(\`^\`(x[3], 2)))), \`-\`(\`*\`(2768390.4, \`*\`(x[1], \`*\`(x[3])))), \`-\`(\`*\`(0.22189949e11, \`*\`(\`^\`(x[2], 3)))), \`*\`(0.67100205e11, \`*\`(\`^\`(x[2], 2), \`*\`(x[3]))), \`-\`(\`*\`(961344.42, \`*\`(\`^\`(x[2], 2)))), \`-\`(\`*\`(0.52533380e11, \`*\`(x[2], \`*\`(\`^\`(x[3], 2))))), \`*\`(2309741.6, \`*\`(x[2], \`*\`(x[3]))), \`*\`(0.23373385e11, \`*\`(\`^\`(x[3], 3))), \`-\`(\`*\`(2708629.4, \`*\`(\`^\`(x[3], 2)))))})`
however its elemets is shown correctly
for example the first element is shown as:
x(1) ^ 3 * 0.194986727121702600e10 + x(1) ^ 2 * x(2) * (-0.365391227687975264e10) + x(1) ^ 2 * x(3) * 0.125146284187383199e10 + x(1) ^ 2 * (-0.798715058230362229e4) + x(1) * x(2) ^ 2 * 0.351708738191481209e10 + x(1) * x(2) * x(3) * (-0.414183393126536083e10) + x(1) * x(2) * (-0.918786154503699254e4) + x(1) * x(3) ^ 2 * 0.287889598946906424e10 + x(1) * x(3) * 0.287143252997207219e4 + x(2) ^ 3 * (-0.955947121705965400e9) + x(2) ^ 2 * x(3) * 0.216166802966718006e10 + x(2) ^ 2 * (-0.165522927641286878e5) + x(2) * x(3) ^ 2 *
Spawned from here. The code itself is perfectly fine, but if the definition of TD is in the same cell with the rest of the code, TD gives an error. The same definition in a separate cell works.
ans := dsolve({diff(y(t), `$`(t, 2)) = y(t), y(0) = a, (D(y))(0) = 0}, numeric, parameters = [a]); td := proc (x, tt) option remember; ans(parameters = [a = x]); eval([t, y(t), diff(y(t), t)], ans(tt)) end proc; TD := proc (k::{1, 2, 3}) options operator, arrow; proc (x, tt) options operator, arrow; td(x, tt)[k] end proc end proc
(TD(1))(.2, .2)
Error, (in unknown) invalid keyword expression
(TD(1))(.2, .2)
.2
Download td.mw
Any any good programming language or design program the format and style of a document is important for sharing with others.  But for the life of me, I don't know if I'm just missing the painfully obvious, but seriously is there not a blogpost or document about the best writing practices for using maple?
It would be a great help to understand general practices for formatting with the document blocks and execution groups.
How do we print the determinant as a matrix with vertical bars instead of brackets?
mapleatha
Hello people in mapleprimes,
I have a problem about map.
map(`*`,op([1/x,y,z]));
The output of this code is not y*z/x, but  (x*y*z)^(-y*z).
I can't understand why this occurs.
Can't you teach me about this?
Nov_3_2017_mapleprimes.mw
First 911 912 913 914 915 916 917 Last Page 913 of 2428
