Hi every body:
I want to solve these equations with maple, can everyone help me how to solve them?
eq1 := diff(u1(x), x, x)+diff(u2(x), x)+int(2*x*s*(u1(s)-3*u2(s)), s = 0 .. 1) = 6*x^2+3*x*(1/10)+8
eq2 := diff(u1(x), x)+diff(u2(x), x, x)+int((3*(s^2+2*x))*(u1(s)-2*u2(s)), s = 0 .. 1) = 21*x+4/5
bcs := u1(0)+(D(u1))(0) = 1, u2(0)+(D(u2))(0) = 1, u1(1)+(D(u1))(1) = 10, u2(1)+(D(u2))(1) = 7
with regards...
I want to plot these in one frame:
between [0, 0.2]
between [0.2, 0.4]
betwen [0.4,0.6]
between [0.6, 0.8]
I want to plot all these functions y[0], y[1], y[2], y[3] in one plot between the mentioned interval.
I am trying to find numerically eigevalues and eigenvectors of a 70x70 matrix. When I type
Eigenvalues(M70, output = 'list');
Maple returns the matrix M70 without processing it. I have also tried Determinant, Gaussian elimination and other - the same story. However, Maple has no problem inverting this matrix numerically. Everything also works well for 20x20 matrix but not for 70x70 one.  70x70 is not such a big matrix. It should be doable.
What is the solution? Do I do something wrong?
I've tried every which way to get the Bezier Curves task to work.  I have embedded it in an existing document and in a new one using Tools / Tasks / Bezier Curves, and it doesn't work at all for me.  Sometimes I get errors when I click Initialize (not always), and I never get any reaction from clicking or dragging in the plot.  Is this me or the task?
I also can't see any of the inner workings of the task.  I don't see how the slider connects to the n variable, or how the plot is generated, or where the plot points come from.  Therefore I can't see how to customize the task for my use.
I've seen other Maple documents like this in Help, too.  How do I see and modify the inner workings of these documents?
Below is an attempt to evaluate an integral from t to ZERO.  I believe the issue is that sin(x) in the denominator is causing a problem.  However, in actuality sin(nx) is in the numerator so at the lower integral bound approaching ZERO the factor of n remains.  So how can I get MAPLE to evaluate this correctly?
int((2*cos(Pi*x*n/T)^2-1)*sin(Pi*x*n/T)*cos(Pi*x*n/T)/(sin(Pi*x/T)*cos(Pi*x/T)), x = 0 .. t)"(=)"int((2*cos(Pi*x*n/T)^2-1)*sin(Pi*x*n/T)*cos(Pi*x*n/T)/(sin(Pi*x/T)*cos(Pi*x/T)), x = 0 .. t)"="int((2*cos(Pi*x*n/T)^2-1)*sin(Pi*x*n/T)*cos(Pi*x*n/T)/(sin(Pi*x/T)*cos(Pi*x/T)), x = 0 .. t)
Download evaluating_integral.mw
I'm trying to evaluate an integral (code snippet and screen-shot included below) assuming that certain parameters and integers. Using assume statements the integral evaluates to 0. However, if I evaluate the integral for a specific set of integers, the integral evaluates as non-zero.
Can anyone clarify why the two int statements return different values?
assume(K::integer);
assume(L::integer);
assume(M::integer);
int(sin(K*x)*sin(L*x)*cos(M*x), x = 0 .. Pi);
     returns: 0
int(sin(14*x)*sin(2*x)*cos(12*x), x = 0 .. Pi);
     returns: Pi/4
I have the following maple code.
R11 := x -> (x+2*a_1)*(product(x+b[j], j = 1 .. k-n))/(x+a_1);
T_4 :=  (z_1, z_2, z_3, z_4) -> R11(z_1)*z_2*z_3*z_4;
%*(z_1+a_1);
I would like maple to simplify (z_1+a_1) in the denominator of R11(z_1) with the (z_1+a_1) from the last line, but it does not do that. Simplify command also does not help.
I am trying to learn how to use the Physics tensor routines by using a simple 2D example.  In the following, I set up the Cartesian Euclidean metric tensor and then tried to transform to cylindrical coordinates.  The metric tensor is correctly transformed in line (5), but then when it is called in line (7), it still has Cartesian values.  What am I doing wrong?
with(LinearAlgebra);
DotProduct([a, b], [c, d]);
gives
Does it think that I want my variables complex conjugated? (And why?) How do i turn it off?
Hello.
I can not find a tool for calculating the number of permutations with fixed points. I looked at the package combinat. Help me please.
I have a question: Hw can I add a straight line in the following plot?
2018-01-20_Biegeversuch_Ablauf.mw
Thank you very much!
Martin
Dear sir,
 i want to plot a graph with  tick marks on all sides , i am attaching codes and  a sample graph, see the attachmnent,
The graph range should be displace only on x and y axis and the vaues should not be on opposite to x and y axis
please see the sample graph
h:=z->1-(delta2/2)*(1 + cos(2*(Pi/L1)*(z - d1 - L1))):
K1:=((4/h(z)^4)-(sin(alpha)/F)-h(z)^2+Nb*h(z)^4):
lambda:=Int(K1,z=0..1):
F:=0.3:
L1:=0.2:
d1:=0.2:
alpha:=Pi/6:
plot( [seq(eval(lambda, Nb=j), j in [0.1,0.2,0.3])], delta2=0.02..0.1);
hi everyone
I am trying to call the maple function fsolve in the matlab. I have used maple('fsolve(x^2-4)'). It worked.Now in the matlab code I have defined another variable. let us say a = 10.  Now I am trying to call the fsolve as follows.
a=10;
maple('fsolve(a*x^2-1)')
I ended up with the following error :
Error, (in fsolve) number of equations, 1, does not match number of variables,
could any body help? tnx
How do you way text below
Maple 2015
if i use function cat() is not
Hi, i want to plot stream tubes for the following problem, can anybody help me? Thanks
with(linalg);
Digits := 15;
velocity=[u(r,z),v(r,z),w(r,z)]
u(r,z)=cr, v(r,z)=r*omega, w(r,z)=0 at z=0
eq1:= 2*f(eta)+diff(h(eta),eta)
eq2 := (1/4)*(diff(h(eta),eta))^2-g(eta)*g(eta)-(1/2)*h(eta)*diff(h(eta),eta,eta)+(1/2)*diff(h(eta),eta,eta,eta);
eq3 := -g(eta)*diff(h(eta),eta)+h(eta)*diff(g(eta),eta)-diff(g(eta),eta,eta);
where f(eta), g(eta) and h(eta) are the solution of above system
bc:=f(0)=1,f (N)=0,h(0)=0,D(h)(N)=0,D(h)(0)=-2,g(0)=R,g(N)=0; where R is constant
First 915 916 917 918 919 920 921 Last Page 917 of 2467
