I have difficulties to solve a small linear system.
I attach my code. It may be due to derivate variables but i'm not sure. I remember having solve before similar systems.
Analyse_cinematique_test2.mw
May you have a look at my code and tell me why the solve function doesn't return any results ?
Thank you for your help.
I have a set of 8 kinematic constraints.
I would like to express them into the following form Jxdq with J the jacobian matrix.
I attached my code.
the 8 equations are gathered in SysEq
Thanks a lot for your help
Analyse_cinematique_test.mw
The following quiz doesn't react in the rigth way, when the respond is a fraction with nominator 1. When the fraction 4/20 is the answer, the respond 1/5 is incorrect
Grading:-Quiz("Reduce this fraction",
proc (Resp, Ans) evalb([op(InertForm:-Value(Ans))] = [op(Resp)]) end proc,
proc () local a, b, c; a := rand(1 .. 5); b := rand(1 .. 5); c := rand(2 .. 5)( ); `%/`(a( )*c, b( )*c) end proc,
'inertform' = true)
Any proposals?
For example, if we have
How can get the 0.312 part of a? I have tried evalf and op without success.
Below is my code (I hope copy paste is ok.....)
OB := add(px[i]*(px[i]-py[i])*(1-Sw[i])*fclass[i], i = 1 .. 6); # this is my objective function
px := Vector[row](6, [0.6e-2, 0.5e-2, 0.4e-3, 0.3e-2, 0.2e-3, 0.1e-3]);
py := Vector[row](6, [0.9e-2, 0.8e-2, 0.7e-2, 0.6e-2, 0.5e-3, 0.4e-3]);
fclass := Vector[row](6, [0.1e-4, 0.9e-4, 0.9e-3, 0.9e-2, 0.9e-1, .9]);  # assign some numbers for the parameters
with(Optimization);
Maximize(OB, {add(Sw[i]*fclass[i], i = 1 .. 6) = 0.001, Sw[1] <= 1, Sw[2] <= 1, Sw[3] <= 1, Sw[4] <= 1, Sw[5] <= 1, Sw[6] <= 1}, assume = nonnegative);
  [-1.08216000000000 *10^-7 , [Sw[1] = 1., Sw[2] = 0., Sw[3] = 0., ] Sw[4] = 0.110000000000000, Sw[5] = 0., Sw[6] = 0.]
The Optimization result is -1.08216*10^-7. However, this is clearly not right, since with the below solution for Sw[i], the result is bigger and the constaint still hold...(i.e. add(Sw[i]*fclass[i], i = 1 .. 6) = 0.001)
[-1.07676000000000*10^(-7), [Sw[1] = 1., Sw[2] = 1., Sw[3] = 0., Sw[4] = .1, Sw[5] = 0., Sw[6] = 0.]]
I cannot see what's wrong...Can we simply blame the floating point is not easy for Maple to handle??
Hello guys,
I have some problems with plugging in a metric ansatz to some tensorial terms.
ansatz1.mw
Best
How can reduce the number of circle in this curve
f := proc (x) options operator, arrow; sin(x) end proc;
plot(f(x), x = 0 .. 2*Pi);
When I try to simplify the expresion z+conjugate(z) I get, as expected, 2*Re(z).
The problem arises when I try to do the same with a more complicated expression as z1*conjugate(z2)+conjugate(z1)*z2. Trying to simplify this Maple only give me back the expression with nochange. The expresion is equivalent to the first example so I expected to get 2Re(z1*conjugate(z2)).
Does anybody know how to solve this problem?
Thank you in advance!
I have two functions :
x(apha1,alpha2)
y(alpha1,alpha2)
When alpha2 is fixed, i can make a parametric plot to see the evolution of the point M which have the coordinates (x,y).
Consequently,
for alpha2 = 30°, i can plot
plot([eval(X(alpha1,30*Pi/180)),eval(Y(alpha1,30*Pi/180)),alpha1=-30*Pi/180..30*Pi/180],-1..1,-1..1);
for alpha2 = 25°, i can plot
plot([eval(X(alpha1,25*Pi/180)),eval(Y(alpha1,25*Pi/180)),alpha1=-30*Pi/180..30*Pi/180],-1..1,-1..1);
for alpha2 = 20°, i can plot
plot([eval(X(alpha1,20*Pi/180)),eval(Y(alpha1,20*Pi/180)),alpha1=-30*Pi/180..30*Pi/180],-1..1,-1..1);
and so on ...
I would like to plot these different parametric plots with a increment of 5 degrees for alpha2 from 30° to -30°. But, i would like to gather all the plots on the same plot.
I attach my code. My attempt with a for loop doesn't work.
How can i do such a plot (gathering several parametric plots) ?
Analyse_cinematique_vehicule_4D_28.01_test.mw
I am having problem in plotting two function(which themselves are functions of elliptical integrals of first and third kind) together.
If I plot them separately, it has no issues but while combining it plots just one.
I am attaching the maple worksheet here, I have to plot alpha and beta together with 'z' as independent variable.
Please reply asap.
a := .5:
b__sc := -a+2*s*sqrt(3*(3-x))*cos((1/3)*arccos(-s*sqrt(3*a/(3-x)))):
d__sc := -a+2*t*sqrt(3*(3-x))*cos((1/3)*arccos(-t*sqrt(3*a/(3-x)))):
b := proc (z) options operator, arrow; s*b__sc/(1-z) end proc:
d := proc (z) options operator, arrow; t*b__sca/(1-z) end proc:
w__s := proc (z) options operator, arrow; a/b(z) end proc:
v__s := proc (z) options operator, arrow; a/d(z) end proc:
h__sc := proc (z) options operator, arrow; (b(z)+a)/(b(z)-a) end proc:
j__sc := proc (z) options operator, arrow; (d(z)+a)/(d(z)-a) end proc:
r := proc (z) options operator, arrow; (1/3)*x+2*sqrt(b(z)^2-a^2-(1/3)*x^2)*cos((1/3)*arccos(-(3/2)*sqrt(3)*(2*(b(z)-a)^2-(1/3)*x*(-a^2+b(z)^2)-(2/27)*x^3)/(b(z)^2-a^2-(1/3)*x^2)^(3/2)))/sqrt(3) end proc:
u := proc (z) options operator, arrow; (1/3)*x+2*sqrt(d(z)^2-a^2+(1/3)*x^2)*cos((1/3)*arccos(-(3/2)*sqrt(3)*(2*(d(z)-a)^2-(1/3)*x*(-a^2+d(z)^2)-(2/27)*x^3)/(d(z)^2-a^2+(1/3)*x^2)^(3/2)))/sqrt(3) end proc:
H := proc (z) options operator, arrow; 1/r(z) end proc:
J := proc (z) options operator, arrow; 1/u(z) end proc:
M := proc (z) options operator, arrow; ((h__sc(z)-2*H(z))*(6*H(z)+h__sc(z))+8*x^2/(b(z)^2*(1-w__s(z))^2))^(1/2) end proc:
P := proc (z) options operator, arrow; ((j__sc(z)-2*J(z))*(6*J(z)+j__sc(z))+8*x^2/(d(z)^2*(1-v__s(z))^2))^(1/2) end proc:
n__1 := proc (z) options operator, arrow; evalf((1-6*H(z)/h__sc(z)+M(z)/h__sc(z))/(1-2*H(z)/h__sc(z)-(4+2*x)/(h__sc(z)*(a^2+2*x))+M(z)/h__sc(z)+sqrt((2+x)^2-4*a^2-8*x)/(h__sc(z)*(a^2+2*x)))) end proc:
n__3 := proc (z) options operator, arrow; evalf((1-6*J(z)/j__sc(z)+P(z)/j__sc(z))/(1-2*J(z)/j__sc(z)-(4+2*x)/(j__sc(z)*(a^2+2*x))+P(z)/j__sc(z)+sqrt((2+x)^2-4*a^2-8*x)/(j__sc(z)*(a^2+2*x)))) end proc:
n__2 := proc (z) options operator, arrow; evalf((1-6*H(z)/h__sc(z)+M(z)/h__sc(z))/(1-2*H(z)/h__sc(z)-(4+2*x)/(h__sc(z)*(a^2+2*x))+M(z)/h__sc(z)-sqrt((2+x)^2-4*a^2-8*x)/(h__sc(z)*(a^2+2*x)))) end proc:
n__4 := proc (z) options operator, arrow; evalf((1-6*J(z)/j__sc(z)+P(z)/j__sc(z))/(1-2*J(z)/j__sc(z)-(4+2*x)/(j__sc(z)*(a^2+2*x))+P(z)/j__sc(z)-sqrt((2+x)^2-4*a^2-8*x)/(j__sc(z)*(a^2+2*x)))) end proc:
k := proc (z) options operator, arrow; evalf((1/2)*2^(1/2)*(h__sc(z)/M(z))^(1/2)*(M(z)/h__sc(z)+6*H(z)/h__sc(z)-1)^(1/2)) end proc:
l := proc (z) options operator, arrow; evalf((1/2)*2^(1/2)*(j__sc(z)/P(z))^(1/2)*(P(z)/j__sc(z)+6*J(z)/j__sc(z)-1)^(1/2)) end proc:
psi := proc (z) options operator, arrow; evalf(arcsin((1-2*H(z)/h__sc(z)-M(z)/h__sc(z))/(1-6*H(z)/h__sc(z)-M(z)/h__sc(z)))) end proc:
phi := proc (z) options operator, arrow; evalf(arcsin((1-2*J(z)/j__sc(z)-P(z)/j__sc(z))/(1-6*J(z)/j__sc(z)-P(z)/j__sc(z)))) end proc:
Omega__1 := proc (z) options operator, arrow; evalf((4*(1-w__s(z))*(2+x+sqrt((2+x)^2-4*a^2-8*x))-4*a^2-8*x)/(a*((2+x)^2-4*a^2-8*x)^(1/2)*((4+2*x)/(a^2+2*x)+2*H(z)-h__sc(z)+M(z)+sqrt((2+x)^2-4*a^2-8*x)/(a^2+2*x)))) end proc:
Omega__3 := proc (z) options operator, arrow; evalf((4*(1-v__s(z))*(2+x+sqrt((2+x)^2-4*a^2-8*x))-4*a^2-8*x)/(a*((2+x)^2-4*a^2-8*x)^(1/2)*((4+2*x)/(a^2+2*x)+2*J(z)-j__sc(z)+P(z)+sqrt((2+x)^2-4*a^2-8*x)/(a^2+2*x)))) end proc:
Omega__2 := proc (z) options operator, arrow; evalf((4*(1-w__s(z))*(2+x+sqrt((2+x)^2-4*a^2-8*x))+8*x+4*a^2)/(a*((2+x)^2-4*a^2-8*x)^(1/2)*((4+2*x)/(a^2+2*x)+2*H(z)-h__sc(z)+M(z)-sqrt((2+x)^2-4*a^2-8*x)/(a^2+2*x)))) end proc:
Omega__4 := proc (z) options operator, arrow; evalf((4*(1-v__s(z))*(2+x+sqrt((2+x)^2-4*a^2-8*x))+8*x+4*a^2)/(a*((2+x)^2-4*a^2-8*x)^(1/2)*((4+2*x)/(a^2+2*x)+2*J(z)-j__sc(z)+P(z)-sqrt((2+x)^2-4*a^2-8*x)/(a^2+2*x)))) end proc:
alpha := proc (z) options operator, arrow; evalf(-Pi+4*(Omega__1(z)*(EllipticPi(n__1(z), k(z))-EllipticPi(psi(z), n__1(z), k(z)))+Omega__2(z)*(EllipticPi(n__2(z), k(z))-EllipticPi(psi(z), n__2(z), k(z))))/((1-w__s(z))*(M(z)*h__sc(z))^(1/4))) end proc:
beta := proc (z) options operator, arrow; evalf(-Pi+4*(Omega__3(z)*(EllipticPi(n__3(z), l(z))-EllipticPi(phi(z), n__3(z), l(z)))+Omega__4(z)*(EllipticPi(n__4(z), l(z))-EllipticPi(phi(z), n__4(z), l(z))))/((1-v__s(z))*(P(z)*j__sc(z))^(1/4))) end proc:
plot([alpha, beta], 0 .. 1);
Warning, unable to evaluate 1 of the 2 functions to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct
Download deflection-angle-comd.mw
hello guys,
in the bellow, screen shot that I have sent to you.
how can I solve this three equations and obtain a1 a2 a3??? in fact non zero answers.
also is this possible to learn me how to write my codes that I have written in maple in the form that others send to you for their questions??? I dont know how to do that...and send screen shot!!
thank you
I try to reproduce in Maple this document in pdf. In it you can see the code in MathCad to find the roots of a system of equations by the method of Draghilev.
After seeing some of the codes posted in the Maple forum where the development of the method is shown and reading the document in the Application Center, some questions arise.
When the deferential ecacuion system is divided, in this case stored in variale b [i], by b [i] / (b [1] ^ 2 + b [2] ^ 2) ^ 0.5; i = 1..n + 1
Why, as I could see in some systems, the first two differential equations are taken and in others it takes three?
And in what systems does it divide at all?
https://www.mapleprimes.com/view.aspx?sf=223821_question/Draghilev
In this case in my transfer of code from Mathcad to Maple I do not get the initial values of the system fsolve calculates indefinitely
sistema9.mw
Below is a link to my worksheet that evaluates 6 expressions that are presumably equivalent.  However, there seems to be a region for 7<n<100 where the results diverge.  All other values of n yield identical results.  I am at a TOTAL loss as to what is happening.  I hope that someone here might shed some light on this quirk.
divergent_behavior.mw
CodeTools:-Usage lists information on CPU time & memory used in later versions of MAPLE.  I do not see Usage as an option for MAPLE 12.  Is there a comparable command & can you provide an example so that I have the proper syntax?
First 913 914 915 916 917 918 919 Last Page 915 of 2467
