How can I change the color of a graphic tittle?
Hello guys, i would like to do parallel computation in my code written in the Maple18. The question that can help me is:
Given a procedure that compute an function g, where g = f1+f2+f3+f4+f5+f6+f7+f8, i would like to compute all fi at same time.
Now, i´m using " grid:-seq('f[i]',[i=1,2,3,4,5,6,7,8])" and it works very well. However, i think that for my case an better solution should be;
Calculate the f1 in core 1, f2 in core 2, f3 in core 3 ... f8 in core 8 at same time, and after this, to sum all results(f1+f2+f3+..+f8). How i can do this?
Att,
Griffith.
import com.maplesoft.openmaple.*;
import com.maplesoft.externalcall.MapleException;
class test
    public static void main( String args[] )
        String a[];
        Engine t;
        int i;
        a = new String[1];
        a[0] = "java";
        try
            t = new Engine( a, new EngineCallBacksDefault(), null, null );
            t.evaluate( "int( x,x );" );
        catch ( MapleException e )
            System.out.println( "An exception occurred\n" );
            return;
        System.out.println( "Done\n" );
This code error import com.maplesoft.externalcall.MapleException in java?
Please help me.
http://www.maplesoft.com/support/help/Maple/view.aspx?path=OpenMaple/Java/Examples
I have the following multi-variable polynomial:
F:=(d^4-2)*C+(7*d^3-3*d)*C^2-(10*d^4-4*d)*L^2+(d-d^2)*L^3+(R+z^2)*x1+(10*d^3-4*d)*L;
Here my question is how to (i) generate "F" in the following form-> F:=k1*C+k2*L+k3*x1; (ii) How to find the coeficient terms of  "C", "L", "x1".
Thanking you in advance.
MVC
I am using mathematical simplification. In between the simplifcations I have the function after unsing "factor(f)"
f:=X^2*R*(1-y^3)(5+4*x-10*p+34*x^2)*y*x^2*(R+d^3+4*R-10*a*b^2)
Here my question is "How can separate or take out the term(s) within the brackets()" from the multivariate polynomial.
Thanking you in advance for your help.
MVC
I am trying to solve an optimization problem with several constraints and it is not working. The decision variables are the matrix entries.
Below is the code:
interface(displayprecision = 4): with( plots ):
with(linalg):with( Optimization );
[ImportMPS, Interactive, LPSolve, LSSolve, Maximize, Minimize,
NLPSolve, QPSolve]
f:=proc(x1,x2,x3,x4,x5,x6)
global lambda,mu,rho,Ls;
local eq,Lsq,g,P,n,IM,ImP,ImPi,c0,cb,Sol,i,j,t1,t2,fact,t3,t4,t5,Wq,W,Lq,L,Ws;
n:=7;
g:=array(1..n,[5,0,0,0,0,0,0]);
mu:=array(1..n,[10,5,5,5,5,5,5]);
P:=matrix([[0,x1,x2,0,0,0,0],[0,0,0,x3,x4,0,0],[0,0,0,0,0,x5,x6],
[0,0,0,0,0,0,0],[0,0,0,0,0,0,0],[0,0,0,0,0,0,0],[0,0,0,0,0,0,0]]);
IM := array(identity, 1..n,1..n):
ImP:=evalm(IM-P):
ImPi:=inverse(ImP):
lambda:=evalm(g&*ImPi):
for i from 1 to n do
rho[i] := lambda[i]/mu[i]
c0:=array(1..n,[1/2,0,0,0,0,0,0]);
cb:=array(1..n,[1/5,1/5,1/5,1/5,1/5,1/5,1/5]);
eq[i]:=(g[i]/lambda[i])*c0[i] + sum((lambda[j]/lambda[i])*P[j,i]*((P[j,i]*(rho[j]^2*cb[j] +(1-rho[j]^2)*cx[j] ))+ (1 -P[j,i])),j=1..n)
Sol:=fsolve({eq[1]-cx[1]=0,eq[2]-cx[2]=0,eq[3]-cx[3]=0,eq[4]-cx[4]=0,eq[5]-cx[5]=0,eq[6]-cx[6]=0,eq[7]-cx[7]=0},{cx[1],cx[2],cx[3],cx[4],cx[5],cx[6],cx[7]}):
assign(Sol):cx:
t1:= -2*(1-rho[i])/(3*rho[i]):
t2:= ((1-cx[i])^2)/(cx[i]+cb[i]):
fact := exp(t1*t2):
if cx[i] >= 1 then
fact:=1:
fact:
fi:
t3:=rho[i]/(1-rho[i]):
t4:= (cx[i]+ cb[i])/2:
t5:=1/mu[i]:
Wq[i] := (t3*t4*t5*fact):
W[i] := Wq[i] + t5:
Lq[i] := lambda[i]*Wq[i]:
L[i] := lambda[i]*W[i]:
Ls:=add(L[i],i=1..n);Lsq:=add(Lq[i],i=1..n):Ws:=Ls/add(g[i],i=1..n):
RETURN(Ls):
# here are the constraint procedures to ensure the probability pairs sum to one
p1 := proc (x1, x2) x1+x2-1 end proc;
proc(x1, x2) ... end;
p2 := proc (x3, x4) x3+x4-1 end proc;
proc(x3, x4) ... end;
p3 := proc (x5, x6) x5+x6-1 end proc;
proc(x5, x6) ... end;
sol := Optimization:-NLPSolve(f, {p1}, {p2}, {p3}, 0 .. 1, 0 .. 1, 0 .. 1, 0 .. 1, 0 .. 1, 0 .. 1, initialpoint = [.5, .5, .5, .5, .5, .5]);
Error, (in Optimization:-NLPSolve) unexpected parameters: {p3}
It seems to say that the problem are the constraints but this seems odd.
My PhD involves generating equations that are very long, in some cases, more than 10 pages long.
For the reader its much more useful to have some of these equations described than presented. One of the descriptions I'd like to use is number of characters and intuitively the command Length feels like it should tell you the number of characters in an expr
However what is written on the help page for this function I don't understand:
https://www.maplesoft.com/support/help/maple/view.aspx?path=length
For other objects, the length of each operand of expr is computed recursively and added to the number of words used to represent expr. In this way, the measure of the size of expr is returned.
then the example that is given is
>length(x+2y)
length(x+2y)
99
See Also
numelems
S
Could anyone explain to me what is meant when it is said length(x+2y)=9? if I try an apply things recursively the expression with the most chatracters i can generate is "x+y+y"which is only 5 characters.
Is there another command that would be better suited to my purposes?
i would like to plot a graph in R^3 of a function f(n,t), where n is integer and t is real. For every t i would like to have a sequence of points. Is it possible?
thanks, anna rita
hello everyone,
To illustrate my question I will get Bob and Alice
Suppose Bob and Alice work separately on the same subject and must share some information.
They decide to exchange information among themselves by using .m files (Maple internal format files).
1) Bob performs the first serie of calculus which ends by some "result".
This result is the information Bob must send to Alice for her doing her part of the job.
Bob assigns this result to a variable named MyVar and saves it in a .m file :
MyVar := ... :
save  MyVar   "/.../MyFile.m"
Then Bob indicates to Alice the complete path to MyFile.m ... but forgets to say her the name of the variable he has saved.
2) Alice reads the file MyFile.m (read "/.../MyFile.m") ....
Of course, if Alice knew the name of the variable Bob used in his "save" command, it would be the simplest thing in the World for her to browse the content of the .m file (eval(MyVar) generally works well).
But I assumed it is not the case, so my question :
Can Alice recover the name of the variable and visualize it ?
Any answer will be greatly appreciated
postscript : it is not the first time I find myself in the situation Alice faces here. Often I have to recover the content of .m files written years ago by people who have changed their core business without having properly documented (like Bob) what these files contain
How do we specify the length of the string in external calling if we don't know the length beforehand?
In a local directory I have a number of worksheets that uses the same procedures, so I want to collect these procedures in a package, where the file with the package should be stored locally, since it is only relevant locally.
Is that possible, and how can it be done ?
I have to find the root of an equation corresponding to the maximum absolute value. I am using root finding package to get all the roots. But after getting all the roots i am not able to apply abs function. Maple sheet is attached.
with(DEtools):
with(ColorTools):
Digits := 30
30
x := proc (t) options operator, arrow; x0*exp(lambda*t) end proc:
phi := proc (t) options operator, arrow; phi0*exp(lambda*t) end proc:
eqm1 := collect(simplify(coeff(expand(diff(x(t), `$`(t, 2))+(2*0)*beta*(diff(x(t), t))+0*x(t)+n*psi*(-v*(phi(t)-phi(t-2*Pi/(n*omega0)))+x(t)-x(t-2*Pi/(n*omega0)))), exp(lambda*t))), {phi0, x0})
(-n*psi*v+n*psi*v*exp(-2*lambda*Pi/(n*omega0)))*phi0+(lambda^2+n*psi-n*psi*exp(-2*lambda*Pi/(n*omega0)))*x0
eqm2 := collect(simplify(coeff(expand(diff(phi(t), `$`(t, 2))+(2*0)*(diff(phi(t), t))+phi(t)+n*(-v*(phi(t)-phi(t-2*Pi/(n*omega0)))+x(t)-x(t-2*Pi/(n*omega0)))), exp(lambda*t))), {phi0, x0})
(-n*v+n*v*exp(-2*lambda*Pi/(n*omega0))+lambda^2+1)*phi0+(n-n*exp(-2*lambda*Pi/(n*omega0)))*x0
mode := simplify(evalc(Re(evalc(subs(lambda = I*Omega, solve(subs(x0 = m*phi0, eqm1), m)))))^2+evalc(Im(evalc(subs(lambda = I*Omega, solve(subs(x0 = m*phi0, eqm1), m)))))^2)
-2*n^2*psi^2*v^2*(-1+cos(2*Omega*Pi/(n*omega0)))/(Omega^4-2*Omega^2*n*psi+2*Omega^2*n*psi*cos(2*Omega*Pi/(n*omega0))+2*n^2*psi^2-2*n^2*psi^2*cos(2*Omega*Pi/(n*omega0)))
A, b := GenerateMatrix([eqm1, eqm2], [x0, phi0])
A, b := Matrix(2, 2, {(1, 1) = lambda^2+n*psi-n*psi*exp(-2*lambda*Pi/(n*omega0)), (1, 2) = -n*psi*v+n*psi*v*exp(-2*lambda*Pi/(n*omega0)), (2, 1) = n-n*exp(-2*lambda*Pi/(n*omega0)), (2, 2) = -n*v+n*v*exp(-2*lambda*Pi/(n*omega0))+lambda^2+1}), Vector(2, {(1) = 0, (2) = 0})
with(RootFinding):
eq := subs(n = 6, psi = 1000, omega0 = 1.15, v = 0.1e-1, Determinant(A))
6000.94*lambda^2-5999.94*exp(-.289855072463768115942028985507*lambda*Pi)*lambda^2+lambda^4+6000-6000*exp(-.289855072463768115942028985507*lambda*Pi)
zeros := RootFinding:-Analytic(eq, lambda, re = 0 .. 400, im = -200 .. 200)
0.899769545162895563524511282265e-56, 0.813609592584011756247655681635e-1-20.6993361029378520006643410260*I, .242743338419727199544214811606-34.4961764258358768825593120288*I, .440964962950043888796944083291-100.074138054178692973033664525*I, .107710271188082726666762251538-106.954651646879437684160623413*I, 1.12290283496379505456476079030-62.0290638297730162295171014475*I, .879463466045683309032252293625-93.2168861049771086211729407830*I, 2.54860869821265794971735119535-80.1919866273564551209847942490*I, 1.52678990439144770439544731898-86.4450560720567958301493690195*I, 2.62945288424037545703549470125-75.0161229879790946191171617450*I, 1.68779005203728587549371003511-68.8012471850312399391042105550*I, .776570081405504740452992339900-55.1681878011205261920670466495*I, 0.851171007270465178285429398270e-9+1.00000500045406723708450960132*I, 0.851171007270465178285445699470e-9-1.00000500045406723708450960133*I, 0.874874719902730972066854301075e-2-6.89997772561385443312823760560*I, 0.354201863215292148351069041542e-1-13.7998152076043523748759861636*I, .369195444156713173497807954493-41.3921704506707022569621870947*I, .540047057129385026999638567235-48.2843908783769449582520027744*I, .149078330738225743331408017894-27.5982749361891156626731068484*I, .369195444156713173497807954500+41.3921704506707022569621870948*I, .440964962950043888796944083291+100.074138054178692973033664525*I, .107710271188082726666762251538+106.954651646879437684160623413*I, 1.12290283496379505456476079030+62.0290638297730162295171014475*I, .879463466045683309032252293625+93.2168861049771086211729407830*I, 2.54860869821265794971735119535+80.1919866273564551209847942490*I, 1.52678990439144770439544731898+86.4450560720567958301493690195*I, 2.62945288424037545703549470125+75.0161229879790946191171617450*I, 1.68779005203728587549371003511+68.8012471850312399391042105550*I, .776570081405504740452992339900+55.1681878011205261920670466495*I, 0.813609592584011756247655681660e-1+20.6993361029378520006643410260*I, 0.354201863215292148351069041261e-1+13.7998152076043523748759861634*I, 0.874874719902730972066854301075e-2+6.89997772561385443312823760560*I, .540047057129385026999638567235+48.2843908783769449582520027744*I, .242743338419727199544214811602+34.4961764258358768825593120288*I, .149078330738225743331408017894+27.5982749361891156626731068484*I
"zeros.select(int 1)"
Error, missing operation
Download question.mw
I will be really thankful for the help.
Sunit
I'm running into a very simple problem with the way that Maple integrates Heaviside functions. Naively, it should act like a step function, but it is not integrating properly. See the attached document.
int(int(Heaviside(-x^2-y^2+1), x = -1 .. 1), y = -1 .. 1)
evalf(Int(Heaviside(-x^2-y^2+1), [x = -1 .. 1, y = -1 .. 1]))
3.141592654
int(piecewise(-x^2-y^2+1 > 0, 1, 0), [x = -1 .. 1, y = -1 .. 1])
Pi
Note that the symbolic integration of the Heaviside function (defined to be 1 inside the unit circle and 0 outside) gives zero, whereas it should clearly give the area of the unit circle, which the numerical integration does. I even checked that the (suposedly equivalent) piecewise definition symbolically evaluates to the area, and it, too, gets the right answer.
Anyone have any clue as to why the symbolic integration of this Heaviside function is so wrong? My understanding is that if we do the integral as two nested 1D integrals, the returned function (as a function of y) is zero everywhere except at y=0, but that result cannot be right either.
Thoughts?
Download Heaviside-error.mw
I am trying to find the optimal routing probabilities in a Maple procedure where the Mean Value Analysis is used to compute the queueing values. The Maple code is below. It first tries to compute the visit ratios where the probability routing values are the decision variables. There is one specified constraint on the sum of the probability decision variables.
interface(warnlevel=0): interface(displayprecision = 4): with( plots ):
with(linalg):with( Optimization ); with(Student[NumericalAnalysis]):
NLPSolve, QPSolve]
f:=proc(x1,x2,x3)
global T,lambda,nq,u;
local i,j,pop,Sum;
n:=3;N:=2;M:=3;
# Gauss-Seidel iterations
A:=Matrix([[1,-x1,-x2],[0,1,-x3],[0,0,1]]);
b:= Vector([1,0,0]);
v := IterativeApproximate(LinearAlgebra:-Transpose(A), b, initialapprox = Vector([1, 3/4, 3/4]), tolerance = 10^(-3), maxiterations = 20, stoppingcriterion = relative(infinity), method = gaussseidel);
mu:=array(1..n,[2.0,1.0,1.0]);
nq:=array(1..M,[0,0,0]);# must initialize queue lengths
for i from 1 to N do
pop:=i;
for j from 1 to M do # mean waiting times
T[j]:=t[j]*(1 + nq[j]) od;
Sum := 0.0;
for j from 1 to M do # mean cycle time
Sum := Sum + v[j]*T[j] od;
for j from 1 to M do #compute the throughputs
lambda[j] := (v[j]*pop)/Sum od;
for j from 1 to M do #compute the queue lengths
nq[j]:= lambda[j]*T[j] od;
for j from 1 to M do #compute the utilizations
u[j]:= lambda[j]*t[j] od;
od;
RETURN(lambda[1]);
proc(x1, x2, x3) ... end;
sol := Optimization:-NLPSolve(f, {}, {proc (x1, x2, x3) options operator, arrow; x1+x2+x3-5/3 end proc}, 0 .. 1, 0 .. 1, 0 .. 1, initialpoint = [.75, .25, .6667], assume = nonnegative); 1;
Error, (in Optimization:-NLPSolve) non-numeric result encountered
I am not sure why I get the error message
I was trying to call a C shared library which calls a Python function. I got the following error:
Error, external linking: error loading external library
/directory/of/my/library/libbe.so: libpython2.7.so.1.0: cannot open shared object
file: No such file or directory
Since I was running this using a pbs file, I made sure that I exported LD_LIBRARY_PATH (to libpython.so) inside the specific node. Does anyone have ideas on why this happens? Thank you!
First 1102 1103 1104 1105 1106 1107 1108 Last Page 1104 of 2434
