I was wondering if Maple could be setup in a way that no parallel processing is performed (as on a single core)?
I know, it's a poor way to test an algorithim/method for thread safety (i.e. deterministic behaviour). But it is better than nothing.
Are there other ways to test for thread safety?
I am getting Maple server crash each time running this solve command.
Could others reproduce it? I am using windows 10. Maple 2024.  Why does it happen?
Will report it to Maplesoft in case it is not known. Worksheet below.
22396
`The "Physics Updates" version in the MapleCloud is 1762 and is the same as the version installed in this computer, created 2024, June 13, 11:3 hours Pacific Time.`
sol:=(3^(1/2)*u(x)-1/3*3^(1/2)+(3*u(x)^2-2*u(x)-1)^(1/2))^(1/3*3^(1/2)) = x^(1/3*3^(1/2))*c__1;
(3^(1/2)*u(x)-(1/3)*3^(1/2)+(3*u(x)^2-2*u(x)-1)^(1/2))^((1/3)*3^(1/2)) = x^((1/3)*3^(1/2))*c__1
eval(sol,u(x) = u);
(3^(1/2)*u-(1/3)*3^(1/2)+(3*u^2-2*u-1)^(1/2))^((1/3)*3^(1/2)) = x^((1/3)*3^(1/2))*c__1
timelimit(30,[solve(%,u)]);
Download maple_crash_calling_solve_june_18_2024.mw
This bug seems to have been introduced in Maple 2023 since it crashes there also.
But not in Maple 2022. No crash there. Same PC.
22396
`The "Physics Updates" version in the MapleCloud is 1762. The version installed in this computer is 1401 created 2023, March 2, 10:49 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2022\Physics Updates\lib\`
eval(sol,u(x) = u);
solve(%,u);
(1/18)*3^(1/2)*(3*(x^((1/3)*3^(1/2))*c__1)^(3^(1/2))+2*3^(1/2)+4*(x^((1/3)*3^(1/2))*c__1)^(-3^(1/2)))
Download maple_NO_crash_calling_solve_june_18_maple_2022.mw
I want to solve for the intrinsic frequency of a structure by using the equation of the determinant of a matrix equal to 0. I don't know if this is the correct procedure. Also the result is too complicated, what does z mean? Is it possible to simplify the result?
odeadvisor says that this ode is _homogeneous, `class A`, but I am not able to verify this. Also when asking dsolve to solve it as 'homogeneous' it returns no solution.
This type is described in https://www.maplesoft.com/support/help/maple/view.aspx?path=odeadvisor%2fhomogeneous
Here is worksheet with my tries.
Would someone be able to confirm if this is really an _homogeneous, `class A` ?
my own code checking says no.  But if it is, then why dsolve do not solve it when asking it to use homogeneous method? Is the method I asked it to use it do not apply to class A?
30348
ode:=x + diff(y(x), x)*y(x)*(2*diff(y(x), x)^2 + 3) = 0;
DEtools:-odeadvisor(ode);
x+(diff(y(x), x))*y(x)*(2*(diff(y(x), x))^2+3) = 0
[[_homogeneous, `class A`], _dAlembert]
infolevel[dsolve]:=5;
dsolve(ode,y(x))
5
Methods for first order ODEs:
   *** Sublevel 2 ***
   -> Solving 1st order ODE of high degree, 1st attempt
   trying 1st order WeierstrassP solution for high degree ODE
   trying 1st order WeierstrassPPrime solution for high degree ODE
   trying 1st order JacobiSN solution for high degree ODE
   trying 1st order ODE linearizable_by_differentiation
   trying differential order: 1; missing variables
   trying simple symmetries for implicit equations
   <- symmetries for implicit equations successful
y(x) = -((1/2)*I)*2^(1/2)*x, y(x) = ((1/2)*I)*2^(1/2)*x, y(x) = RootOf(-ln(x)+Intat(-(-2*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*_a^2+2*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)*_a^3-((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)+_a*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)+_a^2)/(((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)*(2*_a^4+3*_a^2+1)), _a = _Z)+c__1)*x, y(x) = RootOf(-2*ln(x)+Intat(((2*I)*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*3^(1/2)*_a^2+I*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*3^(1/2)-2*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*_a^2-4*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)*_a^3+I*3^(1/2)*_a^2-((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)-2*_a*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)+_a^2)/(((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)*(2*_a^4+3*_a^2+1)), _a = _Z)+2*c__1)*x, y(x) = RootOf(-2*ln(x)-Intat(((2*I)*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*3^(1/2)*_a^2+I*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*3^(1/2)+I*3^(1/2)*_a^2+2*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)*_a^2+4*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)*_a^3+((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(2/3)+2*_a*((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)-_a^2)/(((_a^2-(2*_a^2+1)^(1/2)+1)*_a/(2*_a^2+1)^(3/2))^(1/3)*(2*_a^4+3*_a^2+1)), _a = _Z)+2*c__1)*x
dsolve(ode,y(x),[homogeneous])
Classification methods on request
Methods to be used are: [homogeneous]
Successful isolation of dy/dx: 3 solutions were found. Trying to solve each resulting ODE.
* Tackling ODE using method: homogeneous
trying homogeneous types:
sol:=PDEtools:-Solve(ode,diff(y(x),x));
diff(y(x), x) = (1/2)*2^(1/3)*(-y(x)^2*2^(1/3)+((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(2/3))/(y(x)*((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(1/3)), diff(y(x), x) = -(1/4)*2^(1/3)*(I*3^(1/2)*y(x)^2*2^(1/3)+I*3^(1/2)*((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(2/3)-y(x)^2*2^(1/3)+((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(2/3))/(y(x)*((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(1/3)), diff(y(x), x) = (1/4)*2^(1/3)*(I*3^(1/2)*y(x)^2*2^(1/3)+I*3^(1/2)*((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(2/3)+y(x)^2*2^(1/3)-((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(2/3))/(y(x)*((-x+(2*y(x)^2+x^2)^(1/2))*y(x)^2)^(1/3))
map(X->DEtools:-odeadvisor(X),[sol])
[[[_homogeneous, `class A`], _dAlembert], [[_homogeneous, `class A`]], [[_homogeneous, `class A`]]]
map(X->dsolve(X,y(x),[homogeneous]),[sol])
Download checking_homogo_ode_type_june_18_2024.mw
Hi everyone...
if f(x,y)=x+y
How can I calculate the following expressions for derivative of y(i) where i=1...n?
Hello guys, I am doing the numercial error analysis study, but now I meet such problem:
how to change the 2d dot plot to the 3d plot? I mean extending like the generatrix of a cylinder.
It can be understood as the inverse operation of projecting a three-dimensional xyz surface onto the xy plane. the code is attached. Welcome all you discuss.
Dear all, how can I plot the edge coordinates of a 2d plane?
using diff command to find  partial dervative of function g give zero in maple...it shouldn't be zero...how to fix itpartial_dervative.mw
sigma_t:= map(epsilon-> E_0[90]*epsilon_dot*((epsilon/epsilon_dot)-(sum(p[i], i = 1 .. 3)*(epsilon/epsilon_dot))+(sum(p[i]*tau[i],i=1..3))-(sum(p[i]*tau[i]*exp(-(epsilon/(epsilon_dot*tau[i]))),i=1..3))),true_strain):
 g:= sum(( sigma[j]-sigma_t[j])^2,j=1..10):
diff(g,p[1]);
Download partial_dervative.mw
if i want to solve non linear least square problem ..maple optimazation Interactive box show ..many option...but when it comes to least square default....what kind of algothrim does it used....and in maple ..NonLinear fit commad use what kind of algothrim?..Levenberg-Marquardt algorithm?
I use one engine per one worksheet. So one would expect that doing restart; command; to always behave the same way. Right?
Because each time, new or refreshed mserver.exe is used.  But here is a worksheet, where I run it few times (all with restart each time), where sometime the command timelimit hangs, and sometime does not. I do not mean it takes little longer sometime. I mean completely hang.
I've waited 10-20 minutes and nothing happens. And sometime I saw it return back in 2 or 3 minutes. But most of the time it hangs.
I wish someone could explain this to me. If it hangs each time, or not hang each time, I can understand. (ofcourse timelimit should never hang, as it was supposed to have been fixed in 2021, but this is separate issue).
But why it hangs sometimes and not other times? Does Maple use some sort of random number generator inside it to decide on things? For me, software should behave the same each time when run from same initial state.
It also depends on the amount of timeout given if it hangs or not.
What can cause this different behavior and most important, what can one do to make it behave same way each time? I thought that what restart supposed to do.
Any insight what can cause this is welcome.
I also found that closing the worksheet completely and opening it again, results in different behavior in the timing. It looks like restart does not clear everything, as what happens when closing the worksheet and reopeing it again.
i.e. Sometimes when it completes and not hang, then issuing restart again and running the int() command, it will also not hang most likely.
It seems Maple have remembered something. But closing the worksheet and opening it again, it will hang again most of the times.
The point of all this, is that Maple behaves differently each time. But why??
9704
`The "Physics Updates" version in the MapleCloud is 1762. The version installed in this computer is 1757 created 2024, June 6, 14:53 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib\`
expr:=-4*(1-exp(I*x))^(-4*x)*(exp(I*x)+1)^(4*x)*exp(4*I*(polylog(2,exp(I*x)))-polylog(2,-exp(I*x) ))*csc(x)*x*(tan(x)^2-1)
-4*(1-exp(I*x))^(-4*x)*(exp(I*x)+1)^(4*x)*exp((4*I)*polylog(2, exp(I*x))-polylog(2, -exp(I*x)))*csc(x)*x*(tan(x)^2-1)
time();
#hangs sometimes and not other times. Most of the time it hangs. increasing time
#will improve the chance it will hang
timelimit(60,int(expr,x,method=_RETURNVERBOSE));
time();
.375
Download hangs_int_june_16_2024.mw
Here is one screen shot of one of those times where it returned back. Took little over one minute. Good.
Here is second screen shot where it took about1,800 real time seconds to return. (30 minutes, even though timelimit was one minute). Same exact code.
update
I tried the suggestion given below to use _EnvProbabilistic:=0 but it had no effect on making Maple behavior consistent each time.
Below worksheet shows this. I tried 6 trials, each with restart.
First trial it timeout at 74 second. good. Second trial took 1403 seconds !  Third trial went back to 74 seconds again (good).  Trial 4 took also took about 74 seconds (good). trial 5 went back to being slow and took about 1400 seconds again. Trial 6 went back to being fast and took about 74 seconds.
So the pattern seems to be
                     fast SLOW fast fast SLOW fast.....
But I also tried this whole test again, by closing the worksheet and opening. Now the pattern changed to
                     SLOW fast fast fast SLOW SLOW ....
I also attached the worksheet for the above below.
So Maple still behaves in random fashion in doing the integration above. sometimes it is slow, sometimes fast. All using same exact code and same integral. Extra points to anyone who could find out why and how to fix this.
This worksheet have pattern    fast SLOW fast fast SLOW fast....
1036
Trial #1
_EnvProbabilistic:=0;
expr:=-4*(1-exp(I*x))^(-4*x)*(exp(I*x)+1)^(4*x)*exp(4*I*(polylog(2,exp(I*x)))-polylog(2,-exp(I*x) ))*csc(x)*x*(tan(x)^2-1);
st:=time[real]();
print("time taken ",time[real]()-st);
4019.660
Error, (in PDEtools/NumerDenom) time expired
"time taken ", 74.618
Trial #2
st:=time[real]():
Error, (in sdmp:-mul) time expired
"time taken ", 1403.978
Trial #3
st:=time[real]():
"time taken ", 73.979
Trial #4
st:=time[real]():
"time taken ", 73.732
Trial #5
st:=time[real]():
"time taken ", 1396.089
Trila #6
st:=time[real]():
Error, (in anonymous procedure called from PDEtools/NumerDenom) time expired
"time taken ", 73.383
Download hangs_int_V2_june_16_2024.mw
This worksheet below have pattern      SLOW fast fast fast SLOW SLOW ....
Trial #1
st:=time[real]();
28.483
"time taken ", 1400.316
Trial #2
st:=time[real]():
"time taken ", 74.404
Trial #3
st:=time[real]():
"time taken ", 73.993
Trial #4
st:=time[real]():
"time taken ", 73.550
Trial #5
st:=time[real]():
"time taken ", 1373.684
Trila #6
st:=time[real]():
"time taken ", 1383.174
Download hangs_int_V3_june_16_2024.mw
Observation: When it finishes fast, timeout is always in  PDEtools/NumerDenom.
When it takes long time, timeout is always in sdmp:-mull
Any other suggestions what to try are welcome.
expr:=cos(x)^2;
expr=combine[trig](expr);
(x->x=combine[trig])(expr);
Update:
Same outcome with
expr=`combine/trig`(expr);
(x->x=`combine/trig`)(expr);
                          2   1            1
                    cos(x)  = - cos(2 x) + -
                              2            2
                     cos(x)  = combine/trig
Hi everyone ...
How can I define the below Matrix with for command: (A[n] is n*n and n=1...i)
Tnx...
It seems like there exists a bug when taking the following limit in Maple (I tried Maple 2021):
If I run this command:
> evalf(limit(CylinderU(0,CylinderU(0,x)),x=0));
1.2722774800
the result is 1.2722774800, which seems to be incorrect.
However, when I run this command:
> evalf(CylinderU(0,limit(CylinderU(0,x),x=0)));
0.5456799403
the result is 0.5456799403, which seems to be correct.
Finally, when I run this command:
> evalf(CylinderU(0,CylinderU(0,0)));
0.5456799403
the result is 0.5456799403 which is also correct.
My expectation is that all three commands must return the same result, thus I consider this a bug.
I also run the following command in WolframAlpha
> limit ParabolicCylinderU(0,ParabolicCylinderU(0,x)) as x->0.0
and obtained the correct result 0.54568, confirming that in Maple this is evaluated incorrectly.
Would appreciate if anybody can confirm that this is a bug.
How such Maple bug should be reported?
Is this a valid behvior by int?
int(A,x,method=_RETURNVERBOSE) hangs.
But  int(simplify(A),x,method=_RETURNVERBOSE) returns in few seconds with "default" result same as int(A,x)
Should this have happen? I try to avoid calling simplify unless neccessary because it can add csgn's and signums and so on to the result.
But the question is: Should one really need to simplify the integrand to get the result in this example? Does this mean one should call simplify on the integrand to avoid the hang that can show up?
This only happens when using method=_RETURNVERBOSE
Just trying to find out if this is normal behavior and can be expected sometimes.
25844
A:=exp(-1/2*cos(2*x))*exp(-sin(x)^2);
int(A,x);
exp(-(1/2)*cos(2*x))*exp(-sin(x)^2)
exp(1/2)*exp(-1)*x
int(A,x,method=_RETURNVERBOSE);  #hangs
["default" = x*exp(-1/2), "risch" = x*exp(-1/2), "orering" = x*exp(-sin(x)^2-(1/2)*cos(2*x)), FAILS = ("gosper", "lookup", "derivativedivides", "norman", "trager", "meijerg", "elliptic", "pseudoelliptic", "parallelrisch", "parts")]
Download why_int_hang_unless_simplify_june_15_2024.mw
First 128 129 130 131 132 133 134 Last Page 130 of 2458
