How do I format the display of numbers in Microsoft Excel 365 using the Maple 2023 Add-In?
The default formatting is inconsistent: displays as but displays as . At minimum, I would like all of the numbers to display using a consistent format, preferably standard scientific notation (1.27420168E7 and not or ).
I wanted to do a 3d plot such that a function is plotted over a polar plane. I am not sure what is the best way to plot this and would appreciate some guidance/tips.
I want to plot the following function 1/(r^2*sin(theta)^2) .
I tried plot3d but the base plane is not a circle but a square...
I have a i9 9th Generation processor with 32 GB ram
If I upgrade to a i9 13 Generation processor with 64 GB ram
Assume I change the main card to Z790
I wonder if I will notice a big improvement in performance when running Maple 2023?
Kjell
I have been writing a language translator. I have everything working reasonably well except that when translating abs(expr) with optimize=tryhard, the IntermediateCode converts the abs() into if...then...else statements. This would be fine except the type of the expr is generally a complex number. I need to optimize the code because there is a lot of redundant calculations otherwise.
I can't figure out how to get IntermediateCode from breaking the abs function into if...then...else statements. [My solution so far is to substitute abs with a dummy name and then use the translator to translate the dummy name into an abs statement - That's really not how things should work!]
Any suggestions?
I've included some example test cases of what is going wrong.
with(CodeGeneration)
testproc1 := proc (x) abs(x) end proc
IntermediateCode(testproc1, optimize = tryhard)
Scope( nametab,
  AssignedName(Name("testproc1"), Scope( nametab,
    Procedure(
      ParameterSequence(Declaration(Name("x"), Type(integer))),
      LocalSequence(Declaration(Name("s1"), Type(integer))),
      OptionSequence(),
      ExpressionSequence(),
      StatementSequence(
        If(
          ConditionalPair(LessEqual(Integer(0), Name("x")), StatementSequence(
            Assignment(Name("s1"), Name("x"))
          ConditionalPair(Less(Name("x"), Integer(0)), StatementSequence(
            Assignment(Name("s1"), Negation(Name("x")))
          StatementSequence(
            Assignment(Name("s1"), Integer(0))
        Return(Name("s1"))
      DescriptionSequence(),
      GlobalSequence(),
      LexicalSequence(),
      Type(integer)
testproc2 := proc (x::numeric) abs(x) end proc
IntermediateCode(testproc2, optimize = tryhard)
Scope( nametab,
  AssignedName(Name("testproc2"), Scope( nametab,
    Procedure(
      ParameterSequence(Declaration(Name("x"), Type(numeric))),
      LocalSequence(Declaration(Name("s1"), Type(numeric))),
      OptionSequence(),
      StatementSequence(
        If(
          ConditionalPair(LessEqual(Float(0, 0), Name("x")), StatementSequence(
          ConditionalPair(Less(Name("x"), Float(0, 0)), StatementSequence(
          StatementSequence(
            Assignment(Name("s1"), Float(0, 0))
        Return(Name("s1"))
      GlobalSequence(),
      LexicalSequence(),
      Type(numeric)
testproc3 := proc (x::complex) abs(x) end proc
IntermediateCode(testproc3, optimize = tryhard)
Scope( nametab,
  AssignedName(Name("testproc3"), Scope( nametab,
    Procedure(
      ParameterSequence(Declaration(Name("x"), Type(complex))),
      LocalSequence(),
      OptionSequence(),
      StatementSequence(
        Return(FunctionCall(Name("abs"), ExpressionSequence(Name("x")), unknown))
      GlobalSequence(),
      LexicalSequence(),
      Type(numeric)
Download intermediate_code_abs.mw
I'm using NLPSolve to minimize a complicated function. It works great, but the answers are not returned in numerical form which I need as they are then input for the next stage of my program.
How to I extract numbers?
S2 := NLPSolve(test, phi1 = 0 .. 2*Pi, phi2 = 1.0*Pi .. 2*Pi);
     S2 := [-1.00000000011810774,
       [phi1 = 0.773215730257661, phi2 = 5.98741001513872]]
==>The Result is a list and the solutions appear kind of string-like.
S2[2,1] returns 'phi=0.773...' not the number I need
I have a system of  second order difference equation.
How, can I update the iterate solution and solve the system
System_of_equations.mw
I would like to verify if the proposed solution u_exact of my partial differential equation defined on \mathbb{R}^2, with zero boundary condition
I write the  exact solution, how substitute this  to verify that the PDE is satisfied or not. I tried to substitute but I think someting missing.
Please check ...
solution_pde_check.mwsolution_pde_check.mw
  ra:=2: b1:=1.41: na:=0.7: we:=0.5: eta[1]:=4*0.1: d:=0.5:
  xi:=0.1: m:=na: ea:=0.5: pr:=21: gr:=0.1: R:=0.9323556933:
  PDE1:=ra*(diff(f(x,t),t))=+b1*(1+ea*cos(t))+(1/(R^2))*((diff(f(x,t),x,x))+(1/x)*diff(f(x,t),x));
  IBC:= {D[1](f)(0,t)=0,f(1,t)=0,f(x,0)=0};
2*(diff(f(x, t), t)) = 1.41+.705*cos(t)+1.150367877*(diff(diff(f(x, t), x), x))+1.150367877*(diff(f(x, t), x))/x
{f(1, t) = 0, f(x, 0) = 0, (D[1](f))(0, t) = 0}
sol := pdsolve({PDE1}, IBC, numeric); sol:-plot(f(x, t), t = 1.2, linestyle = "solid", title = "Velocity Profile", labels = ["r", "f"])
Download pde.mw
for different time plot of f(x,t) in single plot with different color
acer helped me out last week with converting strings to dates which was very helpful. However now I stumble on 2 other problems:
- I do not succeed to plot DS6 (time difference versus a numeric value) and to not understand why
- in the cvs data sheet the length of the columns is not equal. The empty cells are automatical filled with "". This prevents me to use numelems as it will also take into consideration the cells filled with "". Is there a way to prevent this
As usual I would like to thank you all, power users, for your patience and help
Test.mw
Hi all
Let us consider the set [f1=x-y, f2=-x^2+y^2, f3=x*y+x*z, f4=-x*y*z+z^3, f5=x*y^2+y*z^2-z^3] contain homogeneous polynomials in K[x,y,z]. It has the elements of degree 1,2, and 3. Now, we start from degree 1 so we have [x-y]. Now, we go to degree 2. Now, we shall multiply f1 by the variables and add to this set f2 and f3 i.e. we have now
[x-y], [x^2-x*y, x*y-y^2, x*z-y*z, -x^2+y^2, x*y+x*z]
 We have to continue to degree 3 and multiply f1 by all monomials in degree two in k[x,y,z] and multiply f2 and f3 by any variable and add them to f4 and f5 so we have finalyas a output:
[[x-y], [x^2-x*y, x*y-y^2, x*z-y*z, -x^2+y^2, x*y+x*z], [x^3-x^2*y, x^2*y-x*y^2, x^2*z-x*y*z, x*y^2-y^3, x*y*z-y^2*z, x*z^2-y*z^2, -x^3+x*y^2, -x^2*y+y^3, -x^2*z+y^2*z, x^2*y+x^2*z, x*y^2+x*y*z, x*y*z+x*z^2, -x*y*z+z^3, x*y^2+y*z^2-z^3]]. How can I do this automatically by a simple and efficient method in Maple?
Maple (2023.1) opens regularly but I cannot use "open" or "save" or "save as" and after opening Maple I no longer can close it.
That is a big problem for me.
The issue is on my new laptop Lenovo L13 Yoga with Windows 11.
Any suggestion? Thanks
hi i have a problem where maple dosent have a varible theta inside cos and sin and when i give it a size it dosent solve the equtation
The function f := x -> (x + 1)*(x^2 + (m - 5)*x - 7*m + 2) satifies
solve(discrim(f(x), x) = 0, m) has three solutions 1, -17, -1
How to find the integer numbers a, b, c, d, k, t so that the function
f := x -> x^3 + (a*m + b)*x^2 + (c*m + d)*x + k*m+t  satifies the equation
solve(discrim(f(x), x) = 0, m)  has three  integer numbers m?
Consider the function f:=x-> a*x^2 + b*m*x + x^3 + c*m.
I tried
f := x -> x^3 + a*x^2 + b*m*x + c*m;
solve(f(x) = 0, m);
g := x -> -x^2*(a + x)/(b*x + c);
solve(diff(g(x), x) = 0, x);
n := 0;
f := x -> -x^2*(a + x)/(b*x + c);
for a from -10 to 20 do
    for b to 20 do
for c from -10 to 20 do
mydelta := a^2*b^2 - 10*a*b*c + 9*c^2;
if 0 < mydelta and type(mydelta, integer) then
x1 := (-b*a - 3*c + sqrt(a^2*b^2 - 10*a*b*c + 9*c^2))/(4*b):
x2 := -(b*a + sqrt(a^2*b^2 - 10*a*b*c + 9*c^2) + 3*c)/(4*b):
x3 := 0:
if type(x1, integer) and type(x2, integer) and nops({0, x1, x2}) = 3 and type(f(x1), integer) and type(f(x2), integer) then n := n + 1; L[n] := [a, b, c]; end if; end if; end do; end do; end do;
L := convert(L, list);
I get
L := [[-10, 1, 6], [-10, 2, 12], [-9, 3, 5], [-8, 1, 10], [-5, 1, 3], [-4, 1, -6], [4, 1, 6], [5, 1, -3], [6, 3, 20], [7, 1, 15], [8, 1, -10], [8, 1, 12], [9, 3, -5], [10, 1, -6], [10, 1, 12], [12, 1, 18], [14, 1, -4], [15, 1, -9], [18, 1, 20], [18, 3, -10], [18, 3, 4], [20, 1, 2]]
With L[1], solve(discrim(x^3 - 10*x^2 + m*x + 6*m, x) = 0, m) ;
The equation has three integer solutions: 0, 12, -500
I have a PDE, with unknown u(t,x,t) ,  zero boundary condition and initial condition given
I converted the equaiton using finite difference to get a system of algebraic equation
The system is solved at each time step
I think i have a problem to update the solution inside the loop.
I hope find the problem or why the numerical solution is different to exact solution at last time
System_finite_difference.mw
Thank you for your help
Hi Everyone; I have plotted two different expressions separately and then shown them in a single graph. From the final display, we can observe that the peak of one expression, A is larger than that of another expression B. Now, the question is, how do I calculate the decrease or increase in the percentage of both curves? This means the peak of expression A is 20%, 8%, or 7% decreases or increases as of expression A.
Help_percentage_inccrease_or_decrease.mw
more explanation, each curve has its maximum point at some value of x, need to calculate that point for each curve. Then, we combined all curves we observed that the peak of each curve is smaller than others, so I am interested to observing that difference in percentage at the maximum value of x.
for reference, I uploading a file of which idea I want to implement for my problem. This is not my problem, but I want to implement it like this.
For_reference.mw
First 201 202 203 204 205 206 207 Last Page 203 of 2458
