<p>I have the following code:</p>
<p> </p>
<p> for D5d_counter from 1 to 1000 do<br />
increment := 0.1:<br />
D5d_incr := initial_D5d + increment:<br />
D5d_decr := initial_D5d - increment:<br />
energy_D5d_init := energy1d(initial_D5d);<br />
energy_D5d_incr:= energy1d(D5d_incr);<br />
energy_D5d_decr := energy1d(D5d_decr);<br />
#evalM(cat("plot(",convert(P[1],string), ",",convert(P[2],string), ", '+')"))</p>
I have always wanted to know why the lognormal distribution in the Black & Scholes (BS) option pricing model
is assumed to have a mean of  T*(r-0.5*sigma^2 ) . I have seen various explanation but non that make any sense.
I know that the mean in a lognormal distribution is exp(u+0.5*sigma^2) but why does it suddenly become
T*(r-0.5*sigma^2 ) in the BS model ?   I can understand the T = mean proportional to the time increament but why does
How can I extract the order of a number in a list?
e.g.
L:=[1,3,5,8,9];
Order(3)=2
Order(9)=5
Reading about the "Table of Chords" of Ptolemy, I stumbled on something I thought should be easy in Maple.
For example, in the table, I have that the chord length  for 1/2 degrees (with radius 60 of course) = 0;31,25 wiich mean 0+31/60+25/(60)^2=377/720=0.52361.
What I would like to do in Maple is evalf[6](sin(1/2 degree))=0.008728 and then convert the decimal part of the answer into a list so I can do
How do I define a large multivariate polynomial
For all i, j, k, l, m, n from 1 to 2
         sum t = 0 to 7: x_{i,j, t} * y_{k,l, t} * z_{m,n, t}
in maple?
I'm new to maple's datastructures. Is it possible to store some rather complicated data in the nodes (or leafs) of a n-nary Tree? Are there also B-Trees?
How do I complete the following by using row reduction rules.
3x            -z=-1
4x     -y    -2z =-5
2x +  7y  + 9z = 0
Hi everybody?
I have a small bug when create a maplet for a simple logical example.
> myMaplet := Maplet(Window(title="Logic Test",
["A : ", TextField['A'](5),
 "B : ", TextField['B'](5)],
["A = B?", TextField['TF'](10)],
[Button['EX']("Do", onclick=ACT),
 Button['QT']("Quit", enabled=true, Shutdown())]
Action[ACT](Evaluate('TF'=evalb(eval(A=B))))
>Maplets[Display](myMaplet);
Hey,
I am uing cmaple.ext to generate batch of images.
However, i found some of the functions are not the same as i execute from the worksheet from standard maple interface.
There are lot of white space around the image...
Is there any way to reduce them?
This is a problem about which I have previously posted here on several occasions, please stop reading now if you are fed up with it, I do apologize.
Let me go straight to the somewhat-reduced-form problem. I have two (non-autonomous) ODEs in C(x) and Q(x)
ODE1 := diff(C(x),x) = s*(fx(x)-Q(x))*C(x) / (f(x)-C(x));
ODE2 := diff(Q(x),x) = (Q(x)-b1)*(b2-Q(x)) / (f(x)-C(x)) + (Q(x)-b)*s*(fx(x)-Q(x))*C(x) / (f(x)-C(x))^2;
In the above, f(x) is a known function and s, b1, b2, b are known real parameters. A particular parameterization is the following:
Hi everybody:
I have an application that requires the following:
a) perform integration of a 2D function over a triangle;
b) perform integration of a 2D or 3D function using different orders in each direction.
Other than writing your own procedures is there a way to do that with Maple? And if you have to go down that path, could you somehow utilize the weights and stations of integration which are hardwired (I assume) in Maple? And in so doing save your self the effort of typing long streams of numbers.
thanks a lot
Maple People,
I've been trying to work out a procedure for a friend for a couple days right now and I'm totally stumped. It's just a maple syntax thing.
Given a set like:
S:={X(t)^2+Y(t)^2=1,2*X(t)*diff(X(t),t)+2*Y(t)*diff(Y(t),t$2)=0}
how can I determine the ''highest t-derivative'' of X(t) (or any other of the functions).
That is, the highest t-derivative of X(t) in S is diff(X(t),t)
... of Y(t) in S is diff(Y(t),t$2)
I can't seem to get any relevant information by doing:
> f:=diff(X(t),t);
d
I need to delete certain components of a vector, I know if it was a matrix I could use DeleteRow and DeleteColumn but it does not work for a vector, how can I do that?
e.g.
A:=<2,10,5,7>;
n:=2 (delete second component) ??
A:=<2,5,7>
Hi, I am working on a complicated expression. For the matter of simplicity, I want to define some new variables in order to express it in a more concise form. For example, where ever I have p^2/q^2, I want in to be replaced by a new defined variable like s, which is defined the same, i.e. p^2/q^2. So an expression like p^2/q^2 + 3 will turn to s+2. Please let me know if maple can do it, and if yes, how? Thanks, Hamidreza
Hi everybody:
I have a bilinear form, that is an expression that may be written down in the form
Rowvector(1,n)*Matrix (n,m)*Columnvector(m,1)
and what I like to do is extract the Matrix(n,m) from it.
One way of doing that is take the derivatives of the expression in terms of the components of the two vectors. However, in my view coeffs should work as well. The problem is I don't see how the returned results are sorted out based on my supplied list, e.g.
First 2128 2129 2130 2131 2132 2133 2134 Last Page 2130 of 2459
