As soon as my matrices are larger then 10 by 10, Maple doesn't show them. Instead I get
Vector(4, {(1) = ` 14 x 14 `*Matrix, (2) = `Data Type: `*anything, (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
How can I change this?
I'm a newbie with Maple12 (MacOS) and unfortunately not able to solve my problem on my own, that's why I'm asking you for help:
After importing an 8x8 matrix from Excel into Maple I cannot get the eigenvalue of my matrix. Error message:
Error, (in LinearAlgebra:-Eigenvalues) invalid input: LinearAlgebra:-Eigenvalues expects its 1st argument, A, to be of type Matrix(square) but received C
Why is the function Eigenvalues expecting an square Matrix???
here are my files:
Hallo,
I´m trying to create a 3D-plot of the following data
0.25Y               0.5Y               1Y               2Y               5Y               10Y
 I m new with maple and  i want to calculate a limit of function like this one, what must i do to have the true value because i can't do this with   limit(f,x=-1),   my function is f:=(-e-xe)/xe(x+1)  at x =-1
How can I combine two plots so that one is above the other and they have the same x-axis.
Here's an example of what I want.
I tried array of plots, but in this case each plot has its own axes and they are side by side horizontally.
Any other suggestions?
I am dealing with the following problem, which has extensive symbolic computations. It was taking extremely long in MATLAB so I thought of Maple. It turns out that Maple is also taking pretty long time. Is there any way to accelerate this in Maple (or in MATLAB).
I am attaching a two-line Maple code (Thanks Alec for the previous help)
u := (1-cos(x)):
for i to 10 do u := u+int(subs(x = t, diff(u, [`$`(x, 2)])+u-A*(1+2*u+3*u^2+4*u^3))*(t-x), t = 0 .. x) end do:
where A is a constant.
I am new to Maple and wish to convert the following simple code written in Matlab to its equivalent Maple.
syms x
F=x^2;
for i=1:5
    G=F+int(F);
    F=G;
end
Does anybody know how to solve the attached quation analytically for rho? The solve command fails.
(Solving numerically and plotting with implicitplot3d works well.)
View 6629_maple1.mw on MapleNet or Download 6629_maple1.mw
View file details
How would I find the number of vertices, the number of edges and the degree of each vertex in the given undirected graph.
Please see the attached Maple file.  It has my work.
I would really appreciate any reply back.
Take care
Say I have an expression like this:
E = 1/(x^2 + y^2) + (x^2+y^2)
And let's say I want to make a substitution for t = (x^2 + y^2);
E = 1/t + t
Now I want to be able to differentiate this.  eg,
diff(E, x)
I should get:
- dt/dx / t^2 + dt/dx
How can I make Maple provide output in this form?  ie, I do not want to see an output of - 2*x/(x^2+y^2)^2 + 2*x
Hey, does anyone here know how to program the product Nystrom method for solving integral equations of the second kind? Thanks
Hi i am having difficulty converting a text file consisting of words into ascii code. using maple and vice versa.
I dont know how to.
My notepad text is  "(testing)" and i wanted maple to show me "testing"  in ascii code but i just dnt knw how to get it to do it.
Can someone please help me i would be very gratefull
Thank u
Hello.  I'm quite new to Maple and I've run into a problem.
My assignment is to create a program that takes input as plaintext, converts it into a matrix X using an alphabet, then encrypts it by multiplying the matrix X by a key matrix M.  Only problem is, I can't even get Maple to recognize a proper if statement.  The if statement is never triggered.
with(Maplets[Elements]):
with(StringTools):
block := 3;
maplet := Maplet(
I have a Bivariate Distribution that has a PDF equal to
(1/2)*exp(-RootOf(erf(_Z)*b*exp(exp((-x+a)/b))+b*exp(exp((-x+a)/b))-2*exp((-x+a)/b))^2-RootOf(erf(_Z)*sqrt(Pi)*d+sqrt(Pi)*d-sqrt(2)*exp(-(1/2)*(-y+c)^2/d^2))^2)/Pi
First 2167 2168 2169 2170 2171 2172 2173 Last Page 2169 of 2459
