Hi everyone,
I am trying to write a proc for the binomial method for option prices.  I have the following code:
treeStockPrices := proc (s0, X, r, sigma, T, N)
local dt, u, d, a, b, p, L, i, j, k, m;
<p>How do I force values to be shown in scientific notation in a spreadsheet? The Format:Numeric Formatting ... menu selection seems to have no effect in this case. I also can find no option (ie hfloat) or interface parameter (ie Digits) that can be run within a function that will "massage" numbers to be scientific notation.</p>
<p>My application is ... I have a table of values and am doing a calculation ...</p>
<p><maple></p>
<p>DT := table():</p>
Hello, How can I combine a 2d contour plot with a 3d plot? i.e. the contour plot would appear at some z-level in the same box containing the 3d plot. Thank you
Dear all:
   suppossed i have a function as following :
f(x):=2*sin(x)*(sin(x)+I3*sin(3*x)+I5*sin(5*x))
where  x is belong to (0,Pi/2), I3,I5 is defined to I3^2+I5^2 < .232.
i have ploted some curves of f(x) . As to different I3 and I5, the curve of f(x) have different point of intersection with y=1 function, may one point or two  point or three where 0<x<Pi/2.
How come this doesn't work:
> A := {Matrix(2, 2, {(1, 1) = 1, (1, 2) = 1, (2, 1) = 1, (2, 2) = 1}), Matrix(2, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0})};
> evalb(`in`(Matrix(2, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0}), A));
Maple answers here false. Is the in-command only for numbers and not for matrices? How can I solve this problem?
Thanks!!
I'm working on a project in my Linear Algebra class dealing with Encrypting and Decrypting text. I have been trying for hours to find the right commands to do this the way my professor wants. Here's the question:
(a) Encrypt the following (choosing your own 3x3 key matrix):
"This class is starting to get boring" (Not including the quotation marks. There are 36 characters in this phrase.)
Use blocks of size 3 (ie a 3x12 matrix with all the characters) and the alphabet:
The LinearAlgebra`MatrixManipulation` package is now obsolete with the new version of Mathematica.
Say you had an existing script with commands:
TakeRows, TakeColumns, AppendColumns, ZeroMatrix, AppendRows (which are also obsolete)
What do you change these commands to?
if anyone could please help me out with this code i would really appreciate it
> cuberootkj := proc (m, n)
local e, tol, x0, x1, x2, maxsteps, counter;
tol := 1/200000;
e := 1;  x1 := m;  x0 := n;
while tol < e do
x2 := (2/3)*x1+(1/3)*x0/x1^2;
e := x2-surd(x0, 3)
print("root"); x1
i get this error message: Error, (in cuberootkj) cannot determine if this expression is true or false: 0 < 9399973/5400000-5^(1/3)
I want to try to find the Laurent series centered about z=1 for the function f(z)=1/[(z+1)(z+2)] in the annular region |z|>3.  When I use the laurent() function, Maple returns the laurent series that is valid for 0<|z|<2.  Is there some way to restrict the domain of the function to make Maple return a Laurent series for a different domain?
I need to solve equation: log[2*sqrt(2+sqrt(3))](y)=log[2+sqrt(3)](y-1) I know (i did it with my hands) that y=8+4*sqrt(3) is a solution of this eqution. But i can not find this solution using Maple. How i can obtain it? P/s/ I solved with maple numerically. It is not enough for me. I need solution namely in form 8+4*sqrt(3). Because it is explicit solution. I am looking forward for answer. Thanks.
hi
I'm looking at Fourier coefficients:
Dn:= (2/L)* int(f*sin(n*Pi*x/L), x=0..L); where L = Pi
and the series
u:= Sum (Dn * sin(n*Pi*x/L)*cos(n*Pi*t/L), n=1..infinity);
When I try to sum the series:
u:= sum (Dn * sin(n*Pi*x/L)*cos(n*Pi*t/L), n=1..10);
I get the error
Error, (in NumericRange) summand is singular in the interval of summation
Now I can see the 0 / 0 thing, but the first term should be 1 and the other terms zero. The first term is 1 if you take limit as n->1
So I have to explicitly state that:
D1:= (2/L)* int(f*sin(Pi*x/L), x=0..L);
hye, how to plot the pde using pdsolve if the error that we get is unable to handle elliptic PDEs. please look at the attachment. thanks for your help. regards, zarith
we want to find the sum:
sum((6*n+5)*(6*n+3)/((12*n*n+12*n+1)*(6*n*n+6*n+1)), n = 1 .. infinity)
is is equal to:
-15-(1/2)*sqrt(3)*Pi*tan((1/6)*Pi*sqrt(3))+(1/2)*sqrt(6)*Pi*tan((1/6)*Pi*sqrt(6))-2*Psi(1/2+(1/6)*sqrt(6))+Pi*tan((1/6)*Pi*sqrt(6))+2*Psi(1/2+(1/6)*sqrt(3))-Pi*tan((1/6)*Pi*sqrt(3))
can we get rid of  the function "\Psi"?  Can we bound this function \Psi with other known constant such as zeta function?
For certain points I have determined values: z depending on x and y. I look for a method to get extrapolated values for any x-y combination in this area.
To fit a 3D curve is not feasible because the fitted curve would not deliver the exact z values for a given data set (=essential condition). For a 2D data set I would do something like a linear regression between two data points but I have no approach to do something similar with data points depending on two variables. I hope somebody can help me to solve this problem. Thanks!
First 2168 2169 2170 2171 2172 2173 2174 Last Page 2170 of 2459
