Good morning, I've tried to solve this pd-eqn with pdsolve, but there is no output (not solution nor error) and the promp goes on the next row
I have installed Maple 11.02 on Vista.   I opened up a .MW file the print quality is awful.   I zoomed into to higher magnification and even at 400% the text is very grainy (but very large).
I imagine there is some setting to control the rendering of fonts.
How do I make it render on screen nicely?
As it is right now I very quickly get eye-strain looking at it.  It's awful and unusable as is.
Here is my worksheet code:
> f := theta -> (a*b)/sqrt(a^2*(sin(theta-Pi/4))^2+b^2*(cos(theta-Pi/4))^2)+c*cos(4*theta);
(1) ...
> simplify(f(theta));
(2) ...
 > subs(sqrt(a^2*(cos(theta+Pi/4))^2+b^2-b^2*(cos(theta+Pi/4))^2)=tmp,simplify(f(theta)));
(3) ...
I recently asked about HTTP Requests and found out it could be done with either a Socket or with the HTTP package. The reason I asked is that I would like to connect to Blackboard (Course Management System). I would like Bb to launch a Maple worksheet or maplet and then Maple to be able to insert grades into the Bb gradebook. Does anyone know how to do that?
Dear colleagues, please help me to animate a pendulum motion, L i s the length of the pendulum,  the differential equation is:
de := diff(theta(t), `$`(t, 2))+c*(diff(theta(t), t))+9.8*sin(theta(t))/L = 0; c := 2; L := 2;
init := theta(0) = 0, (D(theta))(0) = 0;
sol := dsolve({de, init}, theta(t), numeric);
_EnvAllSolutions := true; solve([((1/24)*sqrt(1/11*(819+210*sqrt(5)-126*sqrt(11)-90*sqrt(55)))*cos(sqrt(2/5*(7-2*sqrt(11)))*t*tau/h)+(1/8)*sqrt(1/33*(273+70*sqrt(5)+42*sqrt(11)+30*sqrt(55)))*cos(sqrt(2/5*(7+2*sqrt(11)))*t*tau/h))^2+(-(1/8)*sqrt(1/11*(91+39*sqrt(5)-2*sqrt(22*(47+21*sqrt(5)))))*sin(sqrt(2/5*(7-2*sqrt(11)))*t*tau/h)+(1/8)*sqrt(1/11*(91+39*sqrt(5)+2*sqrt(22*(47+21*sqrt(5)))))*sin(sqrt(2/5*(7+2*sqrt(11)))*t*tau/h))^2 = 1, t > 0, h > 0, tau > 0], t)
Hello fellow digitheads, I'm running the spanking new Maple 12 and I would like to graph the rather harmless expression for wave motion a sin(x - v*t) When I type it in and bring up the Plot Builder assistant it gives me the option (among many) of making one variable the animation variable and the other two "slidable". When I hit "Plot" an "Interactive Parameter Maplet" pops up where I can slide the value of those parameters while it cycles through the animation.
Is there a way for Maple to make GET or POST HTTP requests?
If there are no direct Maple commands, has anyone written a package to do this possibly on top of the Sockets package?
Phil Yasskin
Just wanted to look at a worksheet in the Maple Application Center and had to jump through a lot of hoops to do that.
Is it really necessary - to sign in with my email and password, and with title "I am a Maplesoft Member" over, so it looked as if I signed that I am a Maplesoft member. In what sense?
If I use Windows and Adobe Reader, does that make me a Microsoft and Adobe member, too?
Alec
(could I add a "Maplesoft member" in my signature?)
Hi all, im just starting with maple, mostly teaching myself how to code, but as you can see, i require some assistance.
ok, so, the basis of this program is to recreate the chaos game, check-out wikipedia if you want to know more, the chaos game is a basic and easy way to make the sierpinski triangle.
my problem is getting multiple plots on the same graph (see my code below)
the plots are in a loop, so each time the loop executes, a new point will be plotted on the original graph (the one right at the beginning that makes a triangle.
hi
i've 40 samples which i should split up in 5 classes with a width of 0.5
i used TallyInto for doing this:
with(Statistics):with(ArrayTools):with(plots): with(plottools):
A:= <10.1, 10.6, 10.9, 10.0, 10.4, 10.5, 9.7, 10.5, 10.4, 10.1, 10.8, 9.2, 10.2, 10.3, 10.5, 9.2, 10.2, 10.5, 9.4, 10.2, 9.6, 10.2, 9.7, 10.2, 10.8, 9.9, 10.5, 10.6, 9.8, 10.7, 11.2, 10.8, 9.0, 10.0, 10.5, 10.4, 11.4,10.4, 10.1, 10.4>;
TallyInto(A, [9.0..9.5,9.6..10.0, 10.1..10.5, 10.6..11.0, 11.1..11.5], bins=5);
I´ve got problems with solving this task! Please help me with the solutions. Maybe someone knows how it works. I solved it from 1-4 and don´t know 5-8
Tim
The Crank - rocker consists of rocker 1, coupler 2 and rocker 4. It´s connected with swivel joints. The rack is fixed.
We look at the  point mass m in A and the torsion spring (with damper) in B0. The weight and the inert force because of the motion affect in A (vx,vy ax,ay). All other components are without mass, rotary inertia could also been disregarded.
I have the following equation: -(1/12)*x+1 = sqrt(x-6)+0.5
Right click -> Solve -> Obtain solutions for -> x, only returns 1 of the solutions (6.), but I know there's another solution as well (+/- root) from the quadric formula. I already set the _EnvAllSolutions=true variable, which did not help.
Why doesn't Maple return both solutions and how to get it to do that?
When I run the attached code (basically just a big loop that doesnt do anything) it terminates early (when i is about 4600).
On my computer I get the error message "kernel connection lost".
On other computers it just stops.
It seems to be quite memory intensive but I don't understand why it terminates. normally if i run a large loop it may take a long time but it will get there eventually. I dont understand why this terminates in the middle.
any ideas would be great!
I was running the BirthdayPi procedure that was somewhere here in mapleprimes.
I replaced the string evalf(.. _BigPi   with evalf(Pi, 1000000) and ran the procdure.  I hit the stop hand because it was taking too long then I ran it again with a different number.  shortly after it said kernel connection lost.
I just upgraded my memory from 1Gb to 2.5 Gb (ie I removed 2 of the 4  512 Mb chips and replaced those with 1 Gb chips).  Could that have something to do with it?
First 2255 2256 2257 2258 2259 2260 2261 Last Page 2257 of 2459
