I have this piece of command in maple which I want to get a numerical value out of it, but instead of that it shows the sines without their numerical values. What to add to these commands to get a numerical value for x? (I checked maple's help for "numerical value", but perhaps I am a bit impatient and didn't find such a thing):
with(Degrees);
solve(x^2 = (4/sind(10))^2 + ((4 + x)/sind(20))^2 - 8*(4 + x)/(sind(10)*sind(20)), x);
I get the following:
                      1                        /  /
---------------------------------------------- \8 \16
4 Degrees:-sind(10)  - 4 Degrees:-sind(10) + 1
                   2                                        2
  Degrees:-sind(10)  Degrees:-cosd(10) - 8 Degrees:-sind(10)  -
  /                     4                  2
  \256 Degrees:-sind(10)  Degrees:-cosd(10)
                          4
   - 192 Degrees:-sind(10)  Degrees:-cosd(10)
                         4
   + 32 Degrees:-sind(10)
   - 64 Degrees:-sind(10)  Degrees:-cosd(10)
   + 24 Degrees:-sind(10)
   + 16 Degrees:-sind(10)  Degrees:-cosd(10)
   - 2 Degrees:-sind(10)/^(1/2)//,
                        1                        /  /
                   2                                        2
  Degrees:-sind(10)  Degrees:-cosd(10) - 8 Degrees:-sind(10)  +
  /                     4                  2
                          4
                         4
IndependencePolynomial returns the independence polynomial for the graph G in the variable x.
For the following example, its calculation took over 20 minutes and still hasn't produced a result, and what's fatal is that it  has consumed 4G  memory.
with(GraphTheory):
G:=ConvertGraph("W|tNHEpCKoh`@@Po_WHB@CKC?WGO{G?KKCB`?OMG?_y_?Sn");
G1:=LineGraph(G);
IndependencePolynomial(G1, x) # be careful
I use  codes in  the link https://github.com/pernici/hobj.
It produced results quickly (It takes approximately 5 seconds.). So I think the built-in function " IndependencePolynomial " should be able to be improved. (Of course we are usually very concerned about their coefficients)
Their coefficients of the independent polynomial of G1 are as follows.
[340649, 12329124, 68797662, 140606548, 139481127, 77027880, 25546428, 5303544, 700911, 58580, 2982, 84, 1]
It tells me the total number of independence sets with size 12 is 340649.
Hi guys,
I'm wondering whether it's possible to reverse my "substitution" in order to gain a nicer looking form:
In this example, I'd like to get the last "subs" statement without having to define a new variable "g_new" but instead, maple shall use the old name, and do the "resubstituion" automatically.
I hope someone can help. I'm also happy to get other advice, regarding my problem. Thanks!
Have a output of similar below form
say
output := table([(3, 6) = ["C-C", 0.99414575], (3, 4) = ["C-C", 1.00000000], (6, 13) = ["C-H", 1.11484141], (2, 7) = ["O-C", 0.99996130], (3, 5) = ["C-C", 1.60953223], (4, 7) = ["C-C", 0.99414575], (3, 7) = ["C-C", 1.61174619], (10, 16) = ["C-H", 0.61996904], (3, 8) = ["C-C", 0.99997800], (6, 7) = ["C-C", 1.60940000], (5, 12) = ["C-H", 0.61992962], (5, 6) = ["C-C", 0.99404781], (8, 10) = ["C-C", 0.99997800], (5, 13) = ["C-H", 0.61992962], (11, 17) = ["C-H", 0.61996904], (4, 5) = ["C-C", 1.60953223], (9, 15) = ["C-H", 0.62000000], (9, 11) = ["C-C", 0.99997800], (4, 6) = ["C-C", 1.61174619], (4, 9) = ["C-C", 0.99997800], (5, 7) = ["C-C", 0.99404781], (10, 11) = ["C-C", 1.00000000], (1, 6) = ["O-C", 0.99996130], (7, 12) = ["C-H", 1.11484141], (8, 14) = ["C-H", 0.62000000]])
Create a function which take the above table as and ouputs an weighted undirected Graph G.
I would like to get undirected graph such that
condition
1) We need to form a square matrix say A1 of dimension n cross n where n is the larges among all the integers in the (i,j) that list the above example 17 is the highest among all of the (i,j) sets.
2) then form a weighted square matrix 17 cross 17 where second element of the inside list has to be wiegth in that position
That is the in the matrix (3,6) and (6,3) should have weight  0.99414575,  in the matrix (3,4) and (4,3) should have weight 1.00000000 etc.
3) Then we need to remove all rows and columns which matches to H
That
(10, 16) = ["C-H", 0.61996904] here H goes for 16 so we remove Row 16 and Column 16 of A1
again (5, 12) = ["C-H", 0.61992962] here H goes for 12 so we remove Row 12 and Column 12 of A1
so if we could remove all rows and coulmns where H is their in A1 in one go
as if I remove one row and columns then immedialety row and column number will changes so need to be very careful.
Then the function changes the square weighted matrix to a graph outputs the graph.
The table will of similar form but only thing is number of elements in the table can change.
Kind help
dear all
I would like to solve the following differential equation in Maple Numerically.
pde := I*10*diff(u(k, t), t) + (diff(u(k, t), t, t)) -16* u(k, t) = 0;
ics := u(k, 0) = sqrt(Pi/2)*csch(Pi/2*k), (D[2](u))(k, 0) = -(1/4)*sqrt(2)*Pi^(3/2)*csch((1/2)*Pi*k)*coth((1/2)*Pi*k)
bcs := u(0, t) = 0, u(100, t) = 0;
sol := pdsolve(pde, {ics, bcs}, numeric, range = 0 .. 1, output = listprocedure);
sol;
here the sech(x)^2 in real space and corresponding fourier transformaation is the initial condition
the Gaussian function as initial condition is also an alternative.
How can I solve it?
Hello, I am trying to evaluate this summation, but it keeps giving me a "Error, (in H) bad index into Vector", I can`t find the problem in function, would somebody helps? thanks.
My function:
with(linalg); H := proc (z, aa, AA, bb, BB, m, n, p, q) mu0 := sum('BB'[i], i = 1 .. q)-(sum('AA'[i], i = 1 .. p)); beta0 := (product('AA'[i]^(-'AA'[i]), i = 1 .. p))*(product('BB'[i]^(-'BB'[i]), i = 1 .. q)); if z <> 0 and 0 < mu0 or 0 < abs(z) and abs(z) < 1/beta0 and mu0 = 0 then do s := Vector([seq(-('bb'[i]-v)/'BB'[i], i = 1 .. m)]); Hz := sum(sum((product(('`if`')(i <> h, GAMMA('bb'[i]+'BB'[i]*'s[h]'), 1), i = 1 .. m))*(product(('`if`')(i <> h, GAMMA(1-'aa'[i]-'AA'[i]*'s[h]'), 1), i = 1 .. n))*(-1)^v*z^(('bb[h]'+v)/'BB[h]')/(('`if`')(m < q, product(('`if`')(i <> h, GAMMA(1-'bb'[i]-'BB'[i]*'s[h]'), 1), i = m+1 .. q), 1)*`if`(n < p, product(('`if`')(i <> h, GAMMA('aa'[i]+'AA'[i]*'s[h]'), i = n+1 .. p), 1), 1)*factorial(v)*'BB[h]'), h = 1 .. m), v = 0 .. 10) end do end if; return Hz end proc
>evalf(H(.547, Vector([-23-j]), Vector([.5]), Vector([0, -24-j]), Vector([1, .5]), 1, 1, 1, 2))
I am trying to solve the self similarity problem for external natural convection which is the following coupled problem
  •     3/4*F(eta)*Theta(eta)'  = Theta(eta)''
  •     1/2 (F(eta)')^2 - 3/4 F(eta)*F(eta)'' = Pr*(Theta(eta) - F(eta)''')
where Pr is a constant and  ()' denotes differentiation with respect to eta. The boundary conditions are:
  •     at eta = 0, F = 0, F'=0, Theta = 1
  •     at eta -> infinity, F' = 0, Theta = 0
I tried the following but I cannot obtain a solution
Pr:=1
etamax := infinity
infinity
eq:= 3/4*F(eta)*diff(theta(eta),eta) = diff(theta(eta),eta,eta),1/Pr*(1/2*diff(F(eta),eta)^2 - 3/4*F(eta)*diff(F(eta),eta,eta)) = -diff(F(eta),eta,eta,eta) + theta(eta)
(3/4)*F(eta)*(diff(theta(eta), eta)) = diff(diff(theta(eta), eta), eta), (1/2)*(diff(F(eta), eta))^2-(3/4)*F(eta)*(diff(diff(F(eta), eta), eta)) = -(diff(diff(diff(F(eta), eta), eta), eta))+theta(eta)
bcs := F(0) = 0, theta(0)=1, D(F)(0)=0,theta(etamax)=0,D(F)(etamax)=0
F(0) = 0, theta(0) = 1, (D(F))(0) = 0, theta(infinity) = 0, (D(F))(infinity) = 0
sol:=dsolve([eq,bcs],[F(eta),theta(eta)])
Download wip.mw
How does this happen, that is, what is the algorithm failure here?
for L in [[4, 2], [8, 5], [9, 2], [16, 14], [25, 2]] do
traperror(MinimumPermutationRepresentationDegree(SmallGroup(op(L))))
I have been unable to add a directed light source to my plot3d drawings.  Perhaps I am misreading the documentation.  In the following experiment, I attempt to shine a red light from the direction (phi,theta) but changing the values of phi and theta don't seem to change the scene's lighting.  Can you change the lighting in your Maple?
with(plottools):
Explore(display(sphere(), style=surface, color=yellow, light=[phi,theta,1,0,0]),
	phi=0..Pi, theta=0..Pi);
The documentation shows that one can set up custom latex form for different function/variables:
https://www.maplesoft.com/support/help/maple/view.aspx?path=latex/functions
This is very nice, but how do I see what's currently set?
I was hoping something like:
showstat(`latex/AntiCommutator`);
or
eval(`latex/hypergeom`);
would work, but these don't.
I would like to simply copy/paste what maple already does and only make slight adjustments - don't want to have to write these from scratch.
thanks!
How to remove the ln(e) in the fianl answer shown in the picture, ( must be Maple 15), thanks
I want to solve system of PDE equations by maple and i dont know how can i write it codes that can solve them for me. Can you create the code for the equation
with(geometry):
_EnvHorizontalName = 'x':
_EnvVerticalName = 'y':
point(A, [-2, 7]):
point(B, [-5, -2]):
point(C, [8, -2]):
triangle(ABC, [A, B, C]):
display([draw[A(color = black, symbol = solidcircle, symbolsize = 6),
               B(color = black, symbol = solidcircle, symbolsize = 6),
               C(color = black, symbol = solidcircle, symbolsize = 6),
               ABC(color = blue)],
         textplot([[coordinates(A)[], "A"],
              [coordinates(B)[], "B"],
              [coordinates(C)[], "C"]],
              align = [above, right])],
              axes = none);
Would you explain to me why this error ? Thank you.
Error, (in plots:-display) expecting plot structures but received: [geometry:-draw[A(color = black, symbol = solidcircle, symbolsize = 6), B(color = black, symbol = solidcircle, symbolsize = 6), C(color = black, symbol = solidcircle, symbolsize = 6), ABC(color = blue)]]
Edits: In fact it is a set partition problem.
I have the following subsets:
s:={"a","b","c","d","e","f"}:
I want to divide the set into 2 groups such that each group has exactly 3 elements. We want to generate all solutions. Note that we treat ({"a", "b", "c"}|{"d", "e", "f"}) and ({"d", "e", "f"}|{"a", "b", "c"}) as the same solution.
So first I used the choose function to generate all 3-subsets and then filtered for duplicate solutions.
with(combinat):
M:=[op(choose({"a","b","c","d","e","f"},3))]:
l:=[ListTools:-Categorize((x,y)-> is(x =`minus`(s, y)),M)]:
seq(l[i][1],i=1..10)
{"a", "b", "c"}, {"a", "b", "d"}, {"a", "b", "e"}, {"a", "b", "f"}, {"a", "c", "d"}, {"a", "c", "e"}, {"a", "c", "f"}, {"a", "d", "e"}, {"a", "d", "f"}, {"a", "e", "f"}
But I feel like the solution is a bit inefficient. In fact, we only need half of all 3-subsets. I wonder if we can only keep one representative member of the same  solutions when generating the 3-subsets.
gengcuts.mw
 In fact, the problem can be generalized as follows: given a list of n elements, divide it into m groups and generate all solutions. Similarly,  the same solution is generated only once.
First 273 274 275 276 277 278 279 Last Page 275 of 2467
