How to find if all the rows in a matrix are unique and return true if unique and false if not
That is their are no duplicate rows
Also without another post
If given two matricies A and B how to find if they are same like what i mean is as equal here is
A and B have the same rows but they may be in rows can be jumbled imples
A:=Matrix(3, 3, [[1, 2, 3], [3, 2, 1], [4, 6, 5]])
B:=Matrix(3, 3, [[3, 2, 1], [1, 2, 3], [4, 6, 5]])
They have the same rows exactly but in jumbled order then I say they are equal then return true.
That is i have function RowEqual(A,B) gives TRUE if same by above condition and FALSE is not
Maple 2021.
I expect after exporting to pdf view of page with plot like on fig. 1.
It means with font=[TIMES, ROMAN, 12] as in maine text.
But I obtaned this view of page on pdf (fig. 2) with smaller font-size.
In previouse versions there are no the problem like this.
Dear community, how to fix this annoying inconvenience?
 fig. 1.  fig. 2.
What I want to achieve with a command is the following image, in which the elements of a matrix that are not zero are displayed in black
This can be accomplished with the Browse Matrix Dialouge, but I want to make such images part of the worksheet. (Display of the full matrix is important.)
Context: Re-execution of worksheets will allow for quick verification of changes in Jacobians.
I have a closed curve(parameterized by t) with self intersection and I'd like to locate the x-y coordinates of the intersection. fslolve only returns 1 intersection. I've tried to use a finite step method but it is way to slow even with rough stepping and becomes very inaccurate. Does maple have anything built in to handle this?
Download 111.mwFractional_محلوله.pdf
Hello my friends
How can I write the results inside the Maple code as in the picture? That is, writing the results in terms of gamma and alpha
A python program will output several  adjacency matricies which is to be given as a input to a maplesoft code by writing it to some some kind of  file or so with a sample.
The python file will generate several adjacency matrices need to send it as a input to my maple code
With a small sample codes with interface please.
The help will be surely acknowledged
Is there a way to symbolically evaluate this integral?
int(sin(sqrt(-x^2 + 1)), x);
I want to write a program for the time fractional thin film equation to be converted into an ordinary differential equation.
With respect
Any one has a trick to show in Maple that  x + sqrt(-2 + 2*sqrt(4*x^2 + 1))*sqrt(2 + 2*sqrt(4*x^2 + 1))/4; is zero for x<=0?
I'd like to get similar simplication as this below but in Maple, But everything I tried so far did not work. I am sure there is a way in Maple, but have not found it yet.
Below is the Maple worksheet
interface(version)
r := x + sqrt(-2 + 2*sqrt(4*x^2 + 1))*sqrt(2 + 2*sqrt(4*x^2 + 1))/4;
x+(1/4)*(-2+2*(4*x^2+1)^(1/2))^(1/2)*(2+2*(4*x^2+1)^(1/2))^(1/2)
simplify(r) assuming x<0
simplify(r,symbolic) assuming x<0
simplify(r,sqrt) assuming x<0
#showing it is zero for x<=0
plot(r,x=-10..1)
Download show_it_is_zero.mw
how can i plot this complex expression with polar plot and 3d complex plot? i want both 2d polar form and 3d plot of this.
thnx for the help
restart:with(plots,complexplot,implicitplot)
[complexplot, implicitplot]
f:=(r,theta)->I*sinh(theta-Pi/6)+cos(Pi/4)=r;
proc (r, theta) options operator, arrow; I*sinh(theta-(1/6)*Pi)+cos((1/4)*Pi) = r end proc
complexplot(f(r,theta), r = 0 .. 1, theta = 0 .. 2*Pi, coords=polar);
Error, (in plot) incorrect first argument [1/2*2^(1/2)-Im(sinh(theta-1/6*Pi)) = Re(r), Re(sinh(theta-1/6*Pi)) = Im(r), r = 0 .. 1]
Download complexplot.mw
I want to find the relation between w and k by putting Determinant(A) is equal to zero. Since the determinant is large (A is a matrix of size 6x6) and I am not able to find the simplified expression. How to do that?
determinant.mw
I use Maple version 2022.1 on macOS 10.14.6.
I have big problems with the parabolic groups in the "LieAlgebra" package.
First of all in the help for "Query > Parabolic", the link refers to the help page for the commands "CylinderU, CylinderV, CylinderD" which have nothing to do with it. Also, the command "Query(Alg, "Parabolic")" does not work.
Below is a list of commands that give an error for "Query".
restart:with(LinearAlgebra):with(DifferentialGeometry):with(LieAlgebras):
L:=[
Matrix(5, 5, [[0, 0, 1, 1, 1], [0, 0, 0, 0, 0], [-1, 0, 0, 0, 0], [-1, 0, 0, 0, 0], [-1, 0, 0, 0, 0]]),
Matrix(5, 5, [[0, 1, 0, 1, 1], [-1, 0, 0, 0, 0], [0, 0, 0, 0, 0], [-1, 0, 0, 0, 0], [-1, 0, 0, 0, 0]]),
Matrix(5, 5, [[0, 1, 1, 0, 1], [-1, 0, 0, 0, 0], [-1, 0, 0, 0, 0], [0, 0, 0, 0, 0], [-1, 0, 0, 0, 0]]),
Matrix(5, 5, [[0, 1, 1, 1, 0], [-1, 0, 0, 0, 0], [-1, 0, 0, 0, 0], [-1, 0, 0, 0, 0], [0, 0, 0, 0, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 0, 1, 1], [0, 0, 0, 0, 0], [0, -1, 0, 0, 0], [0, -1, 0, 0, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 1, 0, 1], [0, -1, 0, 0, 0], [0, 0, 0, 0, 0], [0, -1, 0, 0, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 1, 1, 0], [0, -1, 0, 0, 0], [0, -1, 0, 0, 0], [0, 0, 0, 0, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, -1, 0, 0], [0, 1, 0, 0, 1], [0, 0, 0, 0, 0], [0, 0, -1, 0, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, -1, 0, 0], [0, 1, 0, 1, 0], [0, 0, -1, 0, 0], [0, 0, 0, 0, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 0, -1, 0], [0, 0, 0, -1, 0], [0, 1, 1, 0, 0], [0, 0, 0, 0, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 0, 0, 0], [0, 0, 0, 1, 1], [0, 0, -1, 0, 0], [0, 0, -1, 0, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 0, 0, 0], [0, 0, 0, -1, 0], [0, 0, 1, 0, 1], [0, 0, 0, -1, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 0, 0, 0], [0, 0, 0, 0, -1], [0, 0, 0, 0, -1], [0, 0, 1, 1, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 0, -1, 0], [0, 0, 0, 0, 0], [0, 1, 0, 0, 1], [0, 0, 0, -1, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 0, 0, -1], [0, 0, 0, 0, 0], [0, 0, 0, 0, -1], [0, 1, 0, 1, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 0, 0, -1], [0, 0, 0, 0, -1], [0, 0, 0, 0, 0], [0, 1, 1, 0, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, -1/2*sqrt(2), -1/2*sqrt(2), -1/2*sqrt(2)], [0, 1/2*sqrt(2), 0, 0, 0], [0, 1/2*sqrt(2), 0, 0, 0], [0, 1/2*sqrt(2), 0, 0, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 1/2*sqrt(6), 1/6*sqrt(6), 1/6*sqrt(6)], [0, -1/2*sqrt(6), 0, -1/3*sqrt(6), -1/3*sqrt(6)], [0, -1/6*sqrt(6), 1/3*sqrt(6), 0, 0], [0, -1/6*sqrt(6), 1/3*sqrt(6), 0, 0]]),
Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 0, 2/3*sqrt(3), 1/6*sqrt(3)], [0, 0, 0, 2/3*sqrt(3), 1/6*sqrt(3)], [0, -2/3*sqrt(3), -2/3*sqrt(3), 0, -1/2*sqrt(3)], [0, -1/6*sqrt(3), -1/6*sqrt(3), 1/2*sqrt(3), 0]]), Matrix(5, 5, [[0, 0, 0, 0, 0], [0, 0, 0, 0, 1/2*sqrt(5)], [0, 0, 0, 0, 1/2*sqrt(5)], [0, 0, 0, 0, 1/2*sqrt(5)], [0, -1/2*sqrt(5), -1/2*sqrt(5), -1/2*sqrt(5), 0]])];
LieP:=LieAlgebraData(L,Alg):
DGsetup(LieP);
Query(Alg,"Parabolic");
Let G(V,E)  be a graph
 Step 1 : Choose the subsets S of the V of size k and LABEL it with the say "1"
Step 2: LABEL all the neighbours of the vertices of S with "1"
Step 3: Now LABEL "1" all the UNLABELED neighbours of the previously LABELED veritices only if its neighbours are all LABELED already
Step 4: IF atleast one vertex is LABELED in step 3 then repeat step 3   ELSE  If all vertices are already LABELED with "1" goto step 5 ELSE if some of the VERTICES are still not LABELED we reject this set GOTO step 6
Step 5: append the the the set S into the list
Step 6: Remove all the perivious labels choose a new set of size k from S label its vertices with "1" and goto step 2  if all all sets of size k have already been choosen we end and print the list.
That is we a Function F(Graph::G,k)     the function which does the above so that it can be called with parameter when required for any graph G
I am going to try too but i am not that great at coding I have desinged the algorithm need help if possible kind help
I will also be trying
I apologize to distrub all in your busy schedule.
Your work will be surely acknowledged
First_sample_1.mw
https://www.mapleprimes.com/questions/234533-How-To-Relabel-Only-A-Subset-Of-Vertex-Of-G#comment287899
Some part in above link
In code attached
I would like to
I have to on say L list.
And I have done steps at the top in that code
After the above code I have attached steps
"Find the vertices with the condition that if  all its neighbors are labeled as character (FIND(G)) then label those vertices  also as `character"`  then add those vertices also to  L1 list"  then Need to be do again and again on the same graph with new labels G
If no such vertex exits and NumberOfVertices(G) not equal to numelems(L1) then i have to break out of the loop.
or
if NumberOfVertices(G)=numelems(L1) then I print That list or store it some where
Please pardon me if my english is bad.
KInd help it will help me a lot and it will surely be acknowledged kind help.
The algorithm all told above kind help please please
I'm not quite sure, if this is the correct place but i think i found a bug in the analytic integration tool in Maple.
Since i have the student edition and i didn't find a bug report form i will post it here:
R:=1:
delta:=1:
f:=R^4*delta*cos(theta)*sin(x)*sin(-x+theta)/(8*Pi*(R^2*cos(x)+sqrt(2*R^2*cos(x)+2*R^2+4*delta^2)*delta+R^2+2*delta^2));
intfAna:=int(f,x= -Pi + theta .. Pi+ theta);
intfNum:=Int(f,x= -Pi + theta .. Pi+ theta);
intNum:=evalf(Int(eval(intfNum),theta=0..2*Pi));
intAna:=evalf(int(eval(intfAna),theta=0..2*Pi));
the last two statements yield:
                    intNum := -0.07343950362
                    intAna := -0.7853981635
Thus the numerical integrated value differes from the analytical result.
Since I also tried to integrate this with scipy in python I'm pretty sure that the numerical result is correct  and the analytical one is not.
Is my deduction here correct?
I have Maple 2018 here on my private PC. But at work i have Maple 2021 and the difference is the same.
Interestingly the analytic result seems to be -cos(theta)^2/4. If we plot the analytical and numerical integrand, we get:
plot(intfNum,theta=0..2*Pi);
plot(intfAna,theta=0..2*Pi);
Thus both integrands seem to be cosines of theta but the analytical has the wrong factor.
Thanks in advance!
Give a graph G enumerate all possible shortest paths from that vertex to all other vertices like
From vertex v1
P1={(1,2),(2,3)} shortest path from 1 to 3 is stored in P1
P2={(1,2)} shortest path from 1 to 2 of length 1
Put all possible path of length k  from a verex v in a list seperate
That is length 1 in a seperate from vertex v in a seperate list
Etc
Function with be F(Graph::G,v)
Function will return all those lists
First 292 293 294 295 296 297 298 Last Page 294 of 2426
