I  can't solve this series,please could you help me ,the maple code for this.
U[0](x):=(e)^(x);
                             exp(x)
n:=7:  for k from 0 to n do  U[k+1](x):=solve((k+1)U[k+1](x)-((∂)^2)/((∂)^( )x^2) U[k](x)-2 U[k](x));  end do;
Error, (in solve) cannot solve expressions with diff(diff(U[0](x), x), x) for x
Let the curves y=2x^3-x^2-5x   and 𝑦=−𝑥^2+3𝑥be given.
a) Plot both curves on the same 𝑥y −axis.
b) Shade the region (between the curves).
c) Calculate the area of the region enclosed by the curves given.
What values of a and b make f(x)=x³+ax²+bx have
a. A local maximum at x=−1 and a local minimum at x=3?
b. A local minimum at x=4 and a point of inflection at x=1?
eq1 := diff(x(t), t) = x(K[1]-x(t))-p*x(t-tau[1])*y(t); eq2 := diff(y(t), t) = y(K[2]-x(t))-q*y(t-tau[2])*x(t);
(x*, y*):= (p*K[2]-k[1])/(p*q-1), (q*K[1]-k[2])/(p*q-1);
where, k_1, k_2, p, q, tau_1, tau_2 are positive constants
I get this error when typing a sigma symbol with some subscripts.
Is there anyway to get rid of it?
If mapleflow doesn't allow typing in this way, how can I type it in an unexcutable Math format like document mode in Maple?
Hi everyone! I'd really appreciate if I could get pointed in the right direction as I am a brand new maple user.
So im trying to solve this constrainted optimization problem (See picture) using Maple symbollically. I believe I should have a closed form solution given I can substitute the one constraint into the objective function. Specifically closed form solutions for the three phi variables.
Can someone point me in the right direction as to how I should go about this? I've already taken first order conditions and tried to using the solve() function to no avail, realizing my sytem of equations weren't linear );.
I have problems with tasks.
If you have some usefull commands, you select them all, right-click and select 'create task'. You now get a button in the 'task'-pane in Maple you can use whenever you need to insert these commands- - - brilliant!!
But now I want to modify these tasks and delete the ones I don't use anymore or the ones I made by mistake.
Right-click on the task does nothing.
Selecting 'tools' from the menu and then 'tasks' allows me to see the tasks I have made, but not to modify them or delete them
How do I modify or delete a task??
/Rasmus Post
how we can merge multiple plots in single graph in maple ???
Hi! do you know any effective method to count area under this function given by dataset points? (I counted this by approximation by trapezes)
Edit: PolyFit is ok the best what I have done
Edit2: triangulation is the best (just add all triangles)
How to rectify this error
k := 0;
for k[1] from 0 to k do Y[k[1]+3] := solve(sum(sum(factorial(k[1]+3)*(-1)^((k-k[1]-1)*(1/2))*Y(k[1]+3)/(factorial(k[1])*factorial(k-k[1])), k[1] = 0 .. k), k = 0 .. infinity)-(sum(1/4*((-1)^((1/2)*k)/factorial(k)-(3^k)(-1)^((1/2)*k)/factorial(k)), k = 0 .. infinity))-(sum(factorial(k[1]+2)*(-1)^((k-k[1])*(1/2))*Y(k[1]+2)/(factorial(k[1])*factorial(k-k[factorial(1)])), k[1] = 0 .. k)), Y[k[1]+3]) end do;
Error, (in sum) summation variable previously assigned, second argument evaluates to 0 = 0 .. k
Hi! Do you know how to divide this array from .txt data to take separately these numbers? (I have over one thousands of these so I don't want to rewrite)
PS this is 1x1 I want to make 1x8
["0,00244140625;8,07751097960625;-3,555908203125E-05;0,002166748046875;1;1;0,0056941700604248;-0,0101856454842773;100 µA"]
Maple apparently has managed to destroy the last working piece of code in the Units package in the 2022 release.
This code is working in Maple 2021, but not in 2022 anymore.
with(Units[Simple])
[`*`, `+`, `-`, `/`, `<`, `<=`, `<>`, `=`, Im, Re, `^`, abs, add, arccos, arccosh, arccot, arccoth, arccsc, arccsch, arcsec, arcsech, arcsin, arcsinh, arctan, arctanh, argument, ceil, collect, combine, conjugate, cos, cosh, cot, coth, csc, csch, csgn, diff, eval, evalc, evalr, exp, expand, factor, floor, frac, frem, ln, log, log10, log2, max, min, mul, normal, piecewise, polar, root, round, sec, sech, seq, shake, signum, simplify, sin, sinh, sqrt, surd, tan, tanh, trunc, type, verify]
alpha := 45*Unit('degree')
45*Units:-Unit(arcdeg)
if alpha = 0 then
Error, cannot determine if this expression is true or false: 0 < 1/4*Pi
evalf(sin(alpha))
.7071067810
Download UnitsSimple_alpha.mw
I tried to use the command Secant to solve a nonlinear system of equations, In the following, example of two simple equations, how can I use Secant to solve the problem
secant_for_system.mw
Hy
How I solved it accurately,and remove "'rootoff
eq1 := alpha + beta*r[c] - d*n[c] - Upsilon*n[c]*(n[r] + r[c]) - n[r]*(alpha - d*n[c] - b*(n[r] + r[c]));
q2 := `e&Upsi;`*n[c]*(n[r] + r[c]) - mu*n[r] + d*n[c]*n[r] + b*n[c]*n[r] - alpha*n[r];
eq3 := b*n[c]*n[r] + d*n[c]*n[r] - alpha*n[r] - beta*r[c] + mu*n[r];
 eq1 := alpha + beta r[c] - d n[c] - Upsilon n[c] (n[r] + r[c])
    - n[r] (alpha - d n[c] - b (n[r] + r[c]))
   eq2 := Upsilon n[c] (n[r] + r[c]) - mu n[r] + d n[c] n[r]
      + b n[c] n[r] - alpha n[r]
   eq3 := b n[c] n[r] + d n[c] n[r] - alpha n[r] - beta r[c]
      + mu n[r]
solve({eq1, eq2, eq3}, {n[c], n[r], r[c]});
 /       alpha                    \    /             /
{ n[c] = -----, n[r] = 0, r[c] = 0 }, { n[c] = RootOf\(Upsilon b
 \         d                      /    \
   + Upsilon d) _Z  + (-Upsilon alpha + Upsilon beta + Upsilon mu
   + b beta + beta d) _Z - alpha beta - mu beta/, n[r] = RootOf\\
   2           2                         \   2   /
  b  beta + 2 b  mu + b beta d + 2 b d mu/ _Z  + \
       /                          2
-RootOf\(Upsilon b + Upsilon d) _Z  + (-Upsilon alpha
   + Upsilon beta + Upsilon mu + b beta + beta d) _Z - alpha beta
   - mu beta/ Upsilon alpha b - 2 RootOf\(Upsilon b + Upsilon d)
  _Z  + (-Upsilon alpha + Upsilon beta + Upsilon mu + b beta
   + beta d) _Z - alpha beta - mu beta/ Upsilon b beta - 2 RootOf\
  (Upsilon b + Upsilon d) _Z  + (-Upsilon alpha + Upsilon beta
   + Upsilon mu + b beta + beta d) _Z - alpha beta - mu beta/
                         /                          2
  Upsilon b mu - 3 RootOf\(Upsilon b + Upsilon d) _Z  + (
-Upsilon alpha + Upsilon beta + Upsilon mu + b beta + beta d) _Z
   - alpha beta - mu beta/ Upsilon beta d - 3 RootOf\(Upsilon b
   + b beta + beta d) _Z - alpha beta - mu beta/ Upsilon d mu
   - alpha b beta + 2 b beta mu + 3 beta d mu/ _Z + RootOf\
                          /                          2
  Upsilon alpha b + RootOf\(Upsilon b + Upsilon d) _Z  + (
   - alpha beta - mu beta/ Upsilon beta d + RootOf\(Upsilon b
                             \          1   /      // 2
   + alpha b beta - beta d mu/, r[c] = ---- \RootOf\\b  beta
                                       beta
        2                         \   2   /
       /                          2
                         /                          2
                          /                          2
   + alpha b beta - beta d mu/ \RootOf\(Upsilon b + Upsilon d)
   + beta d) _Z - alpha beta - mu beta/ b + RootOf\(Upsilon b
   + b beta + beta d) _Z - alpha beta - mu beta/ d - alpha + mu//
I have  a funciton f(x,y)
I compute the critical point, maple gives me three different points, denoted in the code tmin
from these points how can I fix one  one of them that  give me the min( f(x))
code.mw
thank you for any help
First 318 319 320 321 322 323 324 Last Page 320 of 2426
