I'm experimenting with some plot functions in Maple and cannot make the animate function to work, even for the help example (attached). It works fine when I insert it here but not in my worksheet.
with(plots)
plots[animate](plot, [A*sin(x), x = 0 .. 10], A = 0 .. 2)
Download animate_prob.mw
Any ideas?
I like to know if it is possible to use a for loops in MapleFlow. I've tried a couple of times but it didn't work. For example,
n:=6
a:=Matrix(n,n)
for l from 1 to n do
   for c from 1 to n do
     a[l,c]:=2^(l+c)
   end do
end do
a=
doesn't produce any result for a
Best regards,
Hello;
Hope you are fine. Can i apply numerical scheme on maple for the following problem. This in integro-differential equation i think. Waiting for kind response.
could you please help me ,the maple code for this given series.
U[0](x) := x;
x
"U[k+1](x):=solve((k+1)*U[k+1](x)+(x*(-1)^((k-1)/(2)))/(k!)-x^(2)*((e)^(x))/(10){6/(k!)-sum((2^(k[1]))/(k[1!])(5*delta[k[]-k[1]](x)+(2^(k-k[1])*(-1)^((k-k[1])/(2)))/((k-k[1])!)+(2^(k-k[1]+1)*(-1)^((k-k[1]-1)/(2)))/((k-k[1])!)),k[1]=0..k)}-(cos^(2)(x)+sin^()(x))*((∂)^2)/((∂)^( )x^2) [U[k](x)]-(e)^(x)[sum(1/(k[1]!){1/(k-k[1])(sum(sum(1/(k[3]!)*U[k[2]-k[3]](x)*U[k-k[1]-k[2]-1](x)},k[1]=0..k),k[2]=0..k-k[1]-1),k[3]=0..k[2])),U[k+1](x)];  od;"
Error, unable to match delimiters
"U[k+1](x):=solve((k+1)*U[k+1](x)+(x*(-1)^((k-1)/2))/(k!)-x^2*((e)^x)/10{6/(k!)-sum((2^(k[1]))/(k[1!])(5*delta[k-k[1]](x)+(2^(k-k[1])*(-1)^((k-k[1])/2))/((k-k[1])!)+(2^(k-k[1]+1)*(-1)^((k-k[1]-1)/2))/((k-k[1])!)),k[1]=0..k)}-(cos^2(x)+sin(x))*((∂)^2)/(∂x^2) [U[k](x)]-(e)^x[sum(1/(k[1]!){1/(k-k[1])(sum(sum(1/(k[3]!)*U[k[2]-k[3]](x)*U[k-k[1]-k[2]-1](x)},k[1]=0..k),k[2]=0..k-k[1]-1),k[3]=0..k[2])),U[k+1](x)];  od;"
Download Chapter_6-Example-6.5.4.mw
How to make the matrix construction by points animated?
I sketched this code - it doesn't work(((
a := Matrix([stoimostyM, izmeniya]);
plots[animate](plot, [a[n, m]], n = 1 .. 2970, m = 1 .. 2, numpoints = 50, frames = 100);
Error, bad index into Matrix
Hi! Do you know maybe how to solve equation with Laplace operator in Maple like BZ equation?
a := 0.75;
rho := u(t) + v(t) + w(t);
ode := diff(u(t), t) = 10*Delta(u(t)) + u*(-a*v - rho + 1);
ode1 := diff(v(t), t) = 10*Delta(v(t)) + v*(-a*w - rho + 1);
ode2 := diff(w(t), t) = 10*Delta(w(t)) + w*(-a*u - rho + 1);
Edit: Sorry I guess it should be function of three variables so u,v,w depends on (x,y,z) not strictle from time
I am wondering how to animate something like this from BZ equation:
Given a list L=[x,y,z], what is the best way to generate the following sequential expression?
L1=[[x],[y],[z],[x,x],[x,y],[[x,z],[y,y],[y,z],[z,z],[x,x,x],[x,x,y],[x,x,z],[x,y,y],[x,y,z],[y,y,y],[y,y,z],[y,z,z],[z,z,z]].
With Lin mind (a list of list of at most three variables), how can one generate a list of lists of any number of variable from L.
I am currently out of options, a response will be highly appreciated.
I have Maple 2021 and Mapleflow 2021 installed. The Maple 2021 is working fine. However, MapleFlow gives the error as follows. ERROR: Flow does not evaluate to a module. My system OS is Windows 10 updates till April 2022
Details about our approach for phase-field models are provided in a paper just submitted.
https://ecsarxiv.org/k2vu6/
Maple code (based on UMFPACK linearsolver and different compiled procedures for marching in time) is given here. Run the code for small values of NN and MM and keep increasing them. The goal is to do 100, 200, 400, etc and still get the code to run very fast.
t11:=time():
t12:=time[real]():
Digits:=15;
15
NN is the number of node points (elements) in the X and MM is the number of elements in the Y direction. delta is the applied current density at the top (Y =1). tf is the final time for simulation. vel is the velocity constant v in the paper. ki0 is the scaled exchange current density k in the paper. This code can be run for positive values of delta. This simulates plating. At the end of simulation, changing delta to negative values and rerunning the code will automatically used the geometry at the end of plating.
Ydatstore stores the geometry at every point in time. Phiaveadd stores the total liquid phase in the domain at any point in time.
Users can change NN, delta, tf, vel, ki0, MM just in this line and choose Edit execute worksheet to run for different design parameters.
Users can modify the call for y0proc for choosing different models.
Users can modify the call for HF to run first-order upwind, ENO2 or WENO3 methods. NN and MM should be even numbers.
NN:=100;delta:=0.1;tf:=2.0;vel:=1.0;ki0:=1.0;MM:=NN;
100
.1
2.0
1.0
1.0
100
N:=NN+2:h:=1.0/NN:M:=MM+2;Ny:=MM;
102
100
Initial geometry, Model 1, semicircle in a square
y0proc1:=proc(NN,MM,Y00)
local i,j,xx,yy,N,h,w,M,Ny,rf,f,ff,rr;
N:=NN+2:h:=1.0/NN:w:=h/2:
M:=MM+2;Ny:=MM;
for i from 2 to N-1 do for j from 2 to M-1 do
xx:=-0+(i-1/2-1)*h:yy:=-0+(j-1/2-1)*h:
rr:=xx^2+yy^2;
Y00[i,j]:=max(1e-9,0.5+0.5*tanh((sqrt(rr)-0.3)/w/sqrt(2.0))):
od:od:
for i from 1 to N do
Y00[i,1]:=Y00[i,2]:
Y00[i,M]:=Y00[i,M-1]:
for j from 1 to M do
Y00[1,j]:=Y00[2,j]:
Y00[N,j]:=Y00[N-1,j]:
Model 2, square in a square
y0proc2:=proc(NN,MM,Y00)# square inside a circle, Model 2
M:=MM+2;Ny:=MM;
if xx <=0.3 and yy<=0.3 then Y00[i,j]:=1e-9; else Y00[i,j]:=1.0:end:
od:od:
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
Initial geometry, Model 3, electrodeposition problem trenches and via
y0proc3:=proc(NN,MM,Y00)
M:=MM+2;Ny:=MM;
if abs(xx-0.5) >0.2 and yy<=0.5 then Y00[i,j]:=1e-9; else Y00[i,j]:=1.0:end:
od:od:
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
Initial geometry, Model 4, Gaussian Seed at the bottom
y0proc4:=proc(NN,MM,Y00)
M:=MM+2;Ny:=MM;
rr:=0.1+0.1*exp(-500.*(xx-0.5)^2);
Y00[i,j]:=max(1e-9,0.5+0.5*tanh((yy-rr)/w/sqrt(2.0))):
od:od:
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
y0proc:=eval(y0proc1):#choose different models using y0proc2, etc.
Y00:=Matrix(1..N,1..M,datatype=float[8]):
evalhf(y0proc(NN,MM,Y00)):
if delta<0 then read("Y0data.m"):end:
if delta<0 then read("tdata.m"):end:
tf;
2.0
p0:=plots:-surfdata(Y00,-h/2..NN*h+h/2,-h/2..MM*h+h/2,dimension=2,style=surface,colorscheme = ["Red", "Green", "Blue"]):
printlevel:=2;
eq:=Array(1..N,1..M):
Nx:=NN:
Next, boundary conditiosn at X  = 0, X =1, Y = 0, Y = 1 are specified below, but these equations are not used and optimally coded inside the procedure Eqs11.
for i from 1 to 1 do for j from 1 to M do eq[i,j]:=-Phi[i,j]+Phi[i+1,j]:od:od:
for i from N to N do for j from 1 to M do eq[i,j]:=Phi[i-1,j]-Phi[i,j]:od:od:
for i from 1 to N do for j from 1 to 1 do eq[i,j]:=Phi[i,j+1]-Phi[i,j]:od:od:
for i from 1 to N do for j from M to M do eq[i,j]:=Phi[i,j-1]-Phi[i,j]+delta*h:od:od:
Eqs:=Vector(N*(M)):
N,M;
102, 102
Residues at different points in X and Y are coded in the Eqs11 procedure. Y0 is the input phase-field parameter (2D Matrix). The potential y is a vector to expedite the calculation of residue.
Eqs11:=proc(Y0::Matrix(datatype=float[8]),y::Vector(datatype=float[8]),delta::float,ki0::float,ff::Vector(datatype=float[8]))
local i::integer,j::integer,i1::integer,h::float[8];
global N,M;
h:=1.0/(N-2):
i1:=i+(j-1)*N:
ff[i1]:=
(Y0[i,j]+Y0[i,j+1])*(y[i1+N]-y[i1])
-(Y0[i,j]+Y0[i,j-1])*(y[i1]-y[i1-N])
+(Y0[i+1,j]+Y0[i,j])*(y[i1+1]-y[i1])
-(Y0[i,j]+Y0[i-1,j])*(y[i1]-y[i1-1])
-ki0*y[i1]*h*(1e-24+(Y0[i+1,j]-Y0[i-1,j])^2+(Y0[i,j+1]-Y0[i,j-1])^2)^(1/2):
od:od:
i1:=i+(j-1)*N:
ff[i1]:=-y[i1]+y[i1+1]:
od:od:
i1:=i+(j-1)*N:
ff[i1]:=-y[i1]+y[i1-1]:
od:od:
i1:=i+(j-1)*N:
ff[i1]:=-y[i1]+y[i1+N]:
od:od:
i1:=i+(j-1)*N:
ff[i1]:=-y[i1]+y[i1-N]+delta*h:
od:od:
#print(1);
#ff;
The Jacobian for the residues is coded int he procedure Jac1.
Jac1:=proc(Y0::Matrix(datatype=float[8]),y::Vector(datatype=float[8]),delta::float,ki0::float,j00::Matrix(datatype=float[8]))
global N,M;
h:=1.0/(N-2):
i1:=i+(j-1)*N:
j00[i1,i1]:=-4*Y0[i,j]-Y0[i,j+1]-Y0[i,j-1]-Y0[i+1,j]-Y0[i-1,j]-ki0*h*(1e-24+(Y0[i+1,j]-Y0[i-1,j])^2+(Y0[i,j+1]-Y0[i,j-1])^2)^(1/2):
j00[i1,i1+1]:=Y0[i+1,j]+Y0[i,j]:j00[i1,i1-1]:=Y0[i-1,j]+Y0[i,j]:
j00[i1,i1+N]:=Y0[i,j+1]+Y0[i,j]:j00[i1,i1-N]:=Y0[i,j-1]+Y0[i,j]:
od:od:
i1:=i+(j-1)*N:
j00[i1,i1]:=-1.0:j00[i1,i1+1]:=1.00:
#ff[i1]:=-y[i1]+y[i1+1]:
od:od:
i1:=i+(j-1)*N:
j00[i1,i1]:=-1.0:j00[i1,i1-1]:=1.00:
#ff[i1]:=-y[i1]+y[i1-1]:
od:od:
i1:=i+(j-1)*N:
#ff[i1]:=-y[i1]+y[i1+N]:
j00[i1,i1]:=-1.0:j00[i1,i1+N]:=1.00:
od:od:
i1:=i+(j-1)*N:
j00[i1,i1]:=-1.0:j00[i1,i1-N]:=1.00:
#ff[i1]:=-y[i1]+y[i1-N]+delta*h:
od:od:
#print(1);
#ff;
Eqs11:=Compiler:-Compile(Eqs11):
ntot:=N*(M);
10404
Ntot:=ntot;
10404
First-order Upwind method is coded in the procedure UpW.
UpW:=proc(Y00::Matrix(datatype=float[8]),Phi0::Vector(datatype=float[8]),F0::Matrix(datatype=float[8]),dt::float,N::integer,M::integer,v0::float)
local i::integer,j::integer,h::float[8],nx::float[8],vel::float[8],vx::float[8],vy::float[8],phix::float[8],phiy::float[8],phiave::float[8],jj::integer,phixb::float[8],phixf::float[8],phixb2::float[8],phixf2::float[8],vxb::float[8],phiyb::float[8],phiyf::float[8],vxf::float[8],phiyb2::float[8],phiyf2::float[8],vyb::float[8],vyf::float[8],uf::float[8],ub::float[8],vf::float[8],vb::float[8],tt::float[8],vv0::float[8],sd::float[8],sdf::float[8],sdb::float[8],sdx::float[8],sdy::float[8],sdxb::float[8],s1x::float[8],sdxf::float[8],sdyb::float[8],sdyf::float[8],s1y::float[8],vx1::float[8],vx2::float[8],vy1::float[8],vy2::float[8],w1::float[8],w2::float[8],r1::float[8],r2::float[8],alpha::float[8],beta::float[8];
#e1:=1e-15:
h:=1.0/(N-2):
vv0:=v0:
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
vx:=0.0:vy:=0.0:phix:=0.0:phiy:=0.0:
vx1:=(Y00[i,j]-Y00[i-1,j])/h:
vx2:=(Y00[i+1,j]-Y00[i,j])/h:
vy1:=(Y00[i,j]-Y00[i,j-1])/h:
vy2:=(Y00[i,j+1]-Y00[i,j])/h:
if v0>=0 then
vx1:=max(vx1,0):vx2:=-min(vx2,0): else
vx1:=-min(vx1,0):vx2:=max(vx2,0): end:
if v0>=0 then
vy1:=max(vy1,0):vy2:=-min(vy2,0): else
vy1:=-min(vy1,0):vy2:=max(vy2,0): end:
nx:=sqrt(max(vx1,vx2)^2+max(vy1,vy2)^2):
F0[i,j]:=nx:
od:od:
Second-order ENO2 method is coded in the procedure ENO2.
ENO2:=proc(Y00::Matrix(datatype=float[8]),Phi0::Vector(datatype=float[8]),F0::Matrix(datatype=float[8]),dt::float,N::integer,M::integer,v0::float)
local i::integer,j::integer,h::float[8],nx::float[8],vel::float[8],vx::float[8],vy::float[8],phix::float[8],phiy::float[8],phiave::float[8],jj::integer,phixb::float[8],phixf::float[8],phixb2::float[8],phixf2::float[8],vxb::float[8],phiyb::float[8],phiyf::float[8],vxf::float[8],phiyb2::float[8],phiyf2::float[8],vyb::float[8],vyf::float[8],uf::float[8],ub::float[8],vf::float[8],vb::float[8],tt::float[8],vv0::float[8],sd::float[8],sdf::float[8],sdb::float[8],sdx::float[8],sdy::float[8],sdxb::float[8],s1x::float[8],sdxf::float[8],sdyb::float[8],sdyf::float[8],s1y::float[8],vx1::float[8],vx2::float[8],vy1::float[8],vy2::float[8],alpha::float[8],beta::float[8];
h:=1.0/(N-2):
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
sdx:=(Y00[i+1,j]-2*Y00[i,j]+Y00[i-1,j])/h:sdy:=(Y00[i,j+1]-2*Y00[i,j]+Y00[i,j-1])/h:
vxb:=0:vxf:=0:vyb:=0:vyf:=0:
if i = 2 then sdxb:=(Y00[i,j]-2*Y00[i-1,j]+Y00[i-1,j])/h:else sdxb:=(Y00[i,j]-2*Y00[i-1,j]+Y00[i-2,j])/h:end:
if sdx*sdxb>=0 then s1x:=1.0 else s1x:=0.0:end:
vx1:=(Y00[i,j]-Y00[i-1,j])/h+0.5*signum(sdx)*s1x*min(abs(sdx),abs(sdxb)):
if i = N-1 then sdxf:=(Y00[i+1,j]-2*Y00[i+1,j]+Y00[i,j])/h:else sdxf:=(Y00[i+2,j]-2*Y00[i+1,j]+Y00[i,j])/h:end:
if sdx*sdxf>=0 then s1x:=1.0 else s1x:=0.0:end:
vx2:=(Y00[i+1,j]-Y00[i,j])/h-0.5*signum(sdx)*s1x*min(abs(sdx),abs(sdxf)):
if j = 2 then sdyb:=(Y00[i,j]-2*Y00[i,j-1]+Y00[i,j-1])/h:else sdyb:=(Y00[i,j]-2*Y00[i,j-1]+Y00[i,j-2])/h:end:
if sdy*sdyb>=0 then s1y:=1.0 else s1y:=0.0:end:
vy1:=(Y00[i,j]-Y00[i,j-1])/h+0.5*signum(sdy)*s1y*min(abs(sdy),abs(sdyb)):
if j = M-1 then sdyf:=(Y00[i,j+1]-2*Y00[i,j+1]+Y00[i,j])/h:else sdyf:=(Y00[i,j+2]-2*Y00[i,j+1]+Y00[i,j])/h:end:
if sdy*sdyf>=0 then s1y:=1.0 else s1y:=0.0:end:
vy2:=(Y00[i,j+1]-Y00[i,j])/h+0.5*signum(sdy)*s1y*min(abs(sdy),abs(sdyf)):
if v0>=0 then
if v0>=0 then
F0[i,j]:=nx:
od:od:
Third-order WENO3 method is coded in the procedure WENO3.
WENO3:=proc(Y00::Matrix(datatype=float[8]),Phi0::Vector(datatype=float[8]),F0::Matrix(datatype=float[8]),dt::float,N::integer,M::integer,v0::float)
local i::integer,j::integer,h::float[8],nx::float[8],vel::float[8],vx::float[8],vy::float[8],phix::float[8],phiy::float[8],phiave::float[8],jj::integer,phixb::float[8],phixf::float[8],phixb2::float[8],phixf2::float[8],vxb::float[8],phiyb::float[8],phiyf::float[8],vxf::float[8],phiyb2::float[8],phiyf2::float[8],vyb::float[8],vyf::float[8],uf::float[8],ub::float[8],vf::float[8],vb::float[8],tt::float[8],vv0::float[8],sd::float[8],sdf::float[8],sdb::float[8],sdx::float[8],sdy::float[8],sdxb::float[8],s1x::float[8],sdxf::float[8],sdyb::float[8],sdyf::float[8],s1y::float[8],vx1::float[8],vx2::float[8],vy1::float[8],vy2::float[8],w1::float[8],w2::float[8],r1::float[8],r2::float[8],alpha::float[8],beta::float[8],e1::float[8];
e1:=1e-6:
h:=1.0/(N-2):
vv0:=v0:
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
phix:=(Y00[i+1,j]-Y00[i-1,j])/2/h:
phiy:=(Y00[i,j+1]-Y00[i,j-1])/2/h:
if i = 2 then sdb:=Y00[i,j]-2*Y00[i-1,j]+Y00[i-1,j]: else sdb:=Y00[i,j]-2*Y00[i-1,j]+Y00[i-2,j]:end:
sd:=Y00[i+1,j]-2*Y00[i,j]+Y00[i-1,j]:
if i = N-1 then sdf:=Y00[i,j]-2*Y00[i+1,j]+Y00[i+1,j]: else sdf:=Y00[i+2,j]-2*Y00[i+1,j]+Y00[i,j]:end:
r1:=(e1+sdb^2)/(e1+sd^2):w1:=1/(1+2*r1^2):r2:=(e1+sdf^2)/(e1+sd^2):w2:=1/(1+2*r2^2):
vx1:=phix-0.5*w1/h*(sd-sdb):
vx2:=phix-0.5*w2/h*(sdf-sd):
if j = 2 then sdb:=Y00[i,j]-2*Y00[i,j-1]+Y00[i,j-1]:else sdb:=Y00[i,j]-2*Y00[i,j-1]+Y00[i,j-2]:end:
sd:=Y00[i,j+1]-2*Y00[i,j]+Y00[i,j-1]:
if j = M-1 then sdf:=Y00[i,j]-2*Y00[i,j+1]+Y00[i,j+1]: else sdf:=Y00[i,j+2]-2*Y00[i,j+1]+Y00[i,j]:end:
vy1:=phiy-0.5*w1/h*(sd-sdb):
vy2:=phiy-0.5*w2/h*(sdf-sd):
if v0>=0 then
if v0>=0 then
#nx:=sqrt(vx1^2+vx2^2+vy1^2+vy^2):
F0[i,j]:=nx:
od:od:
UpW:=Compiler:-Compile(UpW):
ENO2:=Compiler:-Compile(ENO2):
WENO3:=Compiler:-Compile(WENO3):
F0:=Matrix(1..N,1..M,datatype=float[8]):
h/0.1/2;
0.500000000000000e-1
Nx;
100
PhiAdd:=proc(N::integer,Phi0::Vector(datatype=float[8]),db::Vector(datatype=float[8]))
local i::integer;
for i from 1 to N do Phi0[i]:=Phi0[i]+db[i]:od:
PhiAdd:=Compiler:-Compile(PhiAdd):
Ntot:=ntot:
Phi0:=Vector(1..Ntot,datatype=float[8]):
printlevel:=1:
ff:=copy(Phi0):
j00:=Matrix(1..Ntot,1..Ntot,datatype=float[8],storage=sparse):
evalf(Eqs11(Y00,Phi0,delta,ki0,ff));
0.100000000000000e-2
Jac1(Y00,Phi0,delta,ki0,j00):
db:=LinearAlgebra:-LinearSolve(j00,-ff,method=SparseDirect):
Phi0:=Phi0+db:
V[0]:=(Phi0[ntot-2*N+N/2]/2+Phi0[ntot-2*N+N/2+1]/2)+h/2*delta;
HFloat(0.31581237885872887)
TT[0]:=0;tt:=0:
vv0:=max(abs(Phi0[ntot-2*N+1]),abs(Phi0[ntot-2*N+N/2]),abs(Phi0[ntot-2*N+N/2+1]),abs(Phi0[ntot-N])):
dt:=min(h/vv0/vel/ki0,tf-tt);
HFloat(0.031202770994846224)
(14)
Ymid:=Matrix(1..N,1..M,datatype=float[8]):
phiaveAdd:=proc(Y00::Matrix(datatype=float[8]),N::integer,M::integer,Ny::integer)
local i::integer,j::integer,phiave::float;
phiave:=0.0:
for i from 2 to N-1 do for j from 2 to M-1 do phiave:=phiave+Y00[i,j]:od:od:
phiave/(N-2)/(M-2);
phiaveAdd:=Compiler:-Compile(phiaveAdd):
Ny;M;
100
102
(15)
phiaveAdd(Y00,N,M,Ny);
.929280193991299241
(16)
The three stages of  SSR-RK3 are stored in EFAdd, EFAdd2 and EFAdd3
EFAdd:=proc(Y00::Matrix(datatype=float[8]),Ymid::Matrix(datatype=float[8]),Phi0::Vector(datatype=float[8]),F0::Matrix(datatype=float[8]),dt::float[8],vel::float[8],ki0::float[8],N::integer,M::integer)
local i::integer,j::integer;
#for i from 2 to N-1 do for j from 2 to M-1 do Ymid[i,j]:=Y00[i,j]-dt*F0[i,j]*Phi0[i+(j-1)*N]:od:od:
for i from 2 to N-1 do for j from 2 to M-1 do Ymid[i,j]:=max(1e-9,Y00[i,j]-dt*vel*ki0*F0[i,j]*Phi0[i+(j-1)*N]):od:od:
Ymid[i,1]:=Ymid[i,2]:
Ymid[i,M]:=Ymid[i,M-1]:
Ymid[1,j]:=Ymid[2,j]:
Ymid[N,j]:=Ymid[N-1,j]:
EFAdd:=Compiler:-Compile(EFAdd):
EFAdd2:=proc(Y00::Matrix(datatype=float[8]),Ymid::Matrix(datatype=float[8]),Phi0::Vector(datatype=float[8]),F0::Matrix(datatype=float[8]),dt::float[8],vel::float[8],ki0::float[8],N::integer,M::integer)
Ymid[i,j]:=max(1e-9,Y00[i,j]*3/4.+Ymid[i,j]/4.-dt/4.*vel*ki0*F0[i,j]*Phi0[i+(j-1)*N]):od:od:
EFAdd2:=Compiler:-Compile(EFAdd2):
EFAdd3:=proc(Y00::Matrix(datatype=float[8]),Ymid::Matrix(datatype=float[8]),Phi0::Vector(datatype=float[8]),F0::Matrix(datatype=float[8]),dt::float[8],vel::float[8],ki0::float[8],N::integer,M::integer)
Y00[i,j]:=max(1e-9,Y00[i,j]*1/3.+Ymid[i,j]*2/3.-dt*2/3.*vel*ki0*F0[i,j]*Phi0[i+(j-1)*N]):od:od:
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
EFAdd3:=Compiler:-Compile(EFAdd3):
YdatStore:=proc(Y00::Matrix(datatype=float[8]),Ydat::Array(datatype=float[8]),N::integer,M::integer,jj::integer)
Ydat[jj,i,j]:=Y00[i,j]:od:od:
YdatStore:=Compiler:-Compile(YdatStore):
Phiave[0]:=phiaveAdd(Y00,N,M,Ny);
.929280193991299241
(17)
Nt:=round(tf/dt)+50;
114
(18)
printlevel:=1:
Ymid:=copy(Y00):
Ydat:=Array(1..Nt+1,1..N,1..M,datatype=float[8]):
YdatStore(Y00,Ydat,N,M,1);
1.
(19)
ii:=0:TT[0];tt;
Different upwind schemes can be called by assign WENO3, UpW or ENO3 scheme.
HF:=eval(WENO3):
#HF:=eval(UpW):
#HF:=eval(ENO2):
A while loop is written from t=0 to t= tf.
while tt<tf do
HF(Y00,Phi0,F0,evalf(dt),N,M,delta):
EFAdd(Y00,Ymid,Phi0,F0,dt,vel,ki0,N,M);
evalf(Eqs11(Ymid,Phi0,delta,ki0,ff));
Jac1(Ymid,Phi0,delta,ki0,j00):
PhiAdd(Ntot,Phi0,db):
HF(Ymid,Phi0,F0,evalf(dt),N,M,delta):
EFAdd2(Y00,Ymid,Phi0,F0,dt,vel,ki0,N,M);
EFAdd3(Y00,Ymid,Phi0,F0,dt,vel,ki0,N,M);
ii:=ii+1:#print(i);
V[ii]:=(Phi0[ntot-2*N+N/2]/2+Phi0[ntot-2*N+N/2+1]/2)+h/2*delta;#print(ii,V[ii]);
TT[ii]:=TT[ii-1]+dt:tt:=tt+dt:
YdatStore(Y00,Ydat,N,M,ii+1);
Phiave[ii]:=phiaveAdd(Y00,N,M,Ny);
dt:=min(h/vv0/vel/ki0,tf-tt);#print(tt,ii,dt);
#YdatStore(Y00,Ydat,N,M,i+1);
#Phiave[i]:=phiaveAdd(Y00,N,M,Ny);
end:
nt:=ii;
46
(21)
V[nt];
HFloat(0.17021428328406052)
(22)
Voltage time curves are plotted below. Voltage is measured at X = 0.5, Y = 1.
plot([[seq([TT[ii],V[ii]],ii=0..nt)]],style=point);
Voltage at the end of plating, cpu time can be documented as
V[nt];time[real]()-t12;time()-t11;NN;
19.042
14.719
100
(23)
p1:=plots:-surfdata(Y00,-h/2..NN*h+h/2,-h/2..MM*h+h/2,dimension=2,style=surface,colorscheme = ["Red", "Green", "Blue"]):
tf:=TT[nt];
HFloat(2.0)
(24)
Contour plots at t= 0 and t = 2.0 (at the of plating are given below)
plots:-display({p0});plots:-display({p1});
The liquid phase content as a funciton of time is plotted below
plot([[seq([TT[ii],Phiave[ii]],ii=0..nt)]],style=point);
save Y00,"Y0data.m";
save tf,"tdata.m";
read("Y0data.m"):
plots:-surfdata(Y00,-h/2..NN*h+h/2,-h/2..MM*h+h/2,dimension=2,style=surface,colorscheme = ["Red", "Green", "Blue"]);
Download Phasefield2DBaseCodeParametric.mw
t11:=time():
t12:=time[real]():
Digits:=15;
15
100
.1
2.0
1.0
1.0
100
102
100
M:=MM+2;Ny:=MM;
rr:=xx^2+yy^2;
od:od:
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
M:=MM+2;Ny:=MM;
od:od:
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
M:=MM+2;Ny:=MM;
od:od:
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
M:=MM+2;Ny:=MM;
od:od:
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
tf;
2.0
printlevel:=2;
Nx:=NN:
Eqs:=Vector(N*(M)):
N,M;
102, 102
global N,M;
h:=1.0/(N-2):
i1:=i+(j-1)*N:
ff[i1]:=
od:od:
i1:=i+(j-1)*N:
od:od:
i1:=i+(j-1)*N:
od:od:
i1:=i+(j-1)*N:
od:od:
i1:=i+(j-1)*N:
od:od:
#print(1);
#ff;
global N,M;
h:=1.0/(N-2):
i1:=i+(j-1)*N:
od:od:
i1:=i+(j-1)*N:
od:od:
i1:=i+(j-1)*N:
od:od:
i1:=i+(j-1)*N:
od:od:
i1:=i+(j-1)*N:
od:od:
#print(1);
#ff;
ntot:=N*(M);
10404
Ntot:=ntot;
10404
#e1:=1e-15:
h:=1.0/(N-2):
vv0:=v0:
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
if v0>=0 then
if v0>=0 then
F0[i,j]:=nx:
od:od:
h:=1.0/(N-2):
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
if v0>=0 then
if v0>=0 then
F0[i,j]:=nx:
od:od:
e1:=1e-6:
h:=1.0/(N-2):
vv0:=v0:
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
if v0>=0 then
if v0>=0 then
F0[i,j]:=nx:
od:od:
h/0.1/2;
Nx;
100
local i::integer;
Ntot:=ntot:
printlevel:=1:
ff:=copy(Phi0):
Phi0:=Phi0+db:
TT[0]:=0;tt:=0:
(14)
phiave:=0.0:
phiave/(N-2)/(M-2);
Ny;M;
100
102
(15)
.929280193991299241
(16)
Y00[i,1]:=Y00[i,2]:
Y00[1,j]:=Y00[2,j]:
.929280193991299241
(17)
114
(18)
printlevel:=1:
Ymid:=copy(Y00):
1.
(19)
ii:=0:TT[0];tt;
HF:=eval(WENO3):
#HF:=eval(UpW):
#HF:=eval(ENO2):
while tt<tf do
ii:=ii+1:#print(i);
end:
nt:=ii;
46
(21)
V[nt];
(22)
19.042
14.719
100
(23)
tf:=TT[nt];
HFloat(2.0)
(24)
save tf,"tdata.m";
read("Y0data.m"):
Hello;
Hope you are fine. I am devolping code for rk-2 at N=8 and further comparing my results with bultin comands on rk-2 on maple. My results is not matching with maple buliton commands. I am confused and tried a lot but not able to find the mistake. I have attached code. May be i have mistake in the calculation of K_1 and K_2. Kindly guide me please. Thanks a lot in advance.
Question_(1)_Posted.mw
I  can't solve this series,please could you help me ,the maple code for this.
U[0](x):=(e)^(x);
                             exp(x)
n:=7:  for k from 0 to n do  U[k+1](x):=solve((k+1)U[k+1](x)-((&PartialD;)^2)/((&PartialD;)^( )x^2) U[k](x)-2 U[k](x));  end do;
Error, (in solve) cannot solve expressions with diff(diff(U[0](x), x), x) for x
Let the curves y=2x^3-x^2-5x   and 𝑦=−𝑥^2+3𝑥be given.
a) Plot both curves on the same 𝑥y −axis.
b) Shade the region (between the curves).
c) Calculate the area of the region enclosed by the curves given.
What values of a and b make f(x)=x³+ax²+bx have
a. A local maximum at x=−1 and a local minimum at x=3?
b. A local minimum at x=4 and a point of inflection at x=1?
eq1 := diff(x(t), t) = x(K[1]-x(t))-p*x(t-tau[1])*y(t); eq2 := diff(y(t), t) = y(K[2]-x(t))-q*y(t-tau[2])*x(t);
(x*, y*):= (p*K[2]-k[1])/(p*q-1), (q*K[1]-k[2])/(p*q-1);
where, k_1, k_2, p, q, tau_1, tau_2 are positive constants
I get this error when typing a sigma symbol with some subscripts.
Is there anyway to get rid of it?
If mapleflow doesn't allow typing in this way, how can I type it in an unexcutable Math format like document mode in Maple?
First 325 326 327 328 329 330 331 Last Page 327 of 2434
