Why does the code below work when I use a standalone "assume" statement but not "assuming"?
That is, why don't the first two attempts at calculating the limit use the assumption contained in those statements, ie why don't those statements return infinity and not a signum like the last attempt at the limit?
`ω__b` := proc (alpha) options operator, arrow; `ω__0`*sqrt(1+alpha+sqrt(alpha+alpha^2)) end proc
proc (alpha) options operator, arrow; omega__0*sqrt(1+alpha+sqrt(alpha+alpha^2)) end proc
`assuming`([limit(`ω__b`(alpha), alpha = infinity)], [`ω__0`::positive]) = signum(omega__0)*infinityNULL
`assuming`([limit(`ω__b`(alpha), alpha = infinity)], [`ω__0` > 0]) = signum(omega__0)*infinityNULL
assume(`ω__0` > 0)
limit(`ω__b`(alpha), alpha = infinity) = infinityNULL
Download assuming.mw
I'd like to simplify the simple expression below by dividing numerator and denominator by m_1 to obtain an expression only containing alpha.
Maple doesn't not generate the desired result.
Is there a way to do this?
expr := sqrt(-(-m__1-m__2+sqrt(m__2*(m__1+m__2)))*`ω__0`^2/m__1)
(-(-m__1-m__2+(m__2*(m__1+m__2))^(1/2))*omega__0^2/m__1)^(1/2)
simplify(expr, {m__2/m__1 = alpha})
(omega__0^2*(alpha*m__1+m__1-(m__1^2*alpha*(alpha+1))^(1/2))/m__1)^(1/2)
Download simplify_side.mw
In the code below, expr is a variable that is a vector times a cosine. Maple performs the multiplication of the vector times the scalar and writes it all as a single vector.
For didactical purposes, I wish for Maple to write out the vector times the cosine, without putting the cosine in the vector.
How is this accomplished?
v := `<,>`(`<|>`(a), `<|>`(b))
Matrix(%id = 36893488152047505644)
expr := v*cos(t*theta+phi)
Matrix(%id = 36893488152047493236)
expr := 'v'*cos(t*theta+phi)
v*cos(t*theta+phi)
Download expr.mw
How can I obtain the Hamiltonian of Eq. (1) in terms of dynamical variables in Maple?
with(PDEtools)
declare(phi(xi), psi(xi))
phi(xi)*`will now be displayed as`*phi
psi(xi)*`will now be displayed as`*psi
r1 := (1/2*(phi(xi)^2-2*c))*(diff(diff(phi(xi), xi), xi))+((-(1/2)*phi(xi)^2+c)*(k*phi(xi)^2-Omega)^2*(phi(xi)^2-c)^2/(phi(xi)^4*(phi(xi)^2-2*c)^2)-(-k*phi(xi)^2+c*k+Omega)*(k*phi(xi)^2-Omega)*(phi(xi)^2-c)/(phi(xi)^2*(phi(xi)^2-2*c))-(1/2)*k^2*phi(xi)^2+Omega*k+(diff(phi(xi), xi))^2+1)*phi(xi) = 0
(1/2)*(phi(xi)^2-2*c)*(diff(diff(phi(xi), xi), xi))+((-(1/2)*phi(xi)^2+c)*(k*phi(xi)^2-Omega)^2*(phi(xi)^2-c)^2/(phi(xi)^4*(phi(xi)^2-2*c)^2)-(-k*phi(xi)^2+c*k+Omega)*(k*phi(xi)^2-Omega)*(phi(xi)^2-c)/(phi(xi)^2*(phi(xi)^2-2*c))-(1/2)*k^2*phi(xi)^2+Omega*k+(diff(phi(xi), xi))^2+1)*phi(xi) = 0
r2 := simplify(%)
(-4*phi(xi)^3*(-(1/2)*phi(xi)^2+c)^2*(diff(diff(phi(xi), xi), xi))+(-2*phi(xi)^6+4*phi(xi)^4*c)*(diff(phi(xi), xi))^2-2*phi(xi)^6+(-c^2*k^2+2*Omega*c*k-Omega^2+4*c)*phi(xi)^4+Omega^2*c^2)/(-2*phi(xi)^5+4*c*phi(xi)^3) = 0
pa := {diff(diff(phi(xi), xi), xi) = diff(psi(xi), xi), diff(phi(xi), xi) = psi(xi)}
r3 := subs(pa, r2)
(-4*phi(xi)^3*(-(1/2)*phi(xi)^2+c)^2*(diff(psi(xi), xi))+(-2*phi(xi)^6+4*phi(xi)^4*c)*psi(xi)^2-2*phi(xi)^6+(-c^2*k^2+2*Omega*c*k-Omega^2+4*c)*phi(xi)^4+Omega^2*c^2)/(-2*phi(xi)^5+4*c*phi(xi)^3) = 0
psixif := isolate(r3, diff(psi(xi), xi))
diff(psi(xi), xi) = -(1/4)*(-(-2*phi(xi)^6+4*phi(xi)^4*c)*psi(xi)^2+2*phi(xi)^6-(-c^2*k^2+2*Omega*c*k-Omega^2+4*c)*phi(xi)^4-Omega^2*c^2)/(phi(xi)^3*(-(1/2)*phi(xi)^2+c)^2)
Download Hamiltonian.mw
To select all pdf files in folder the command is
L1:=FileTools:-ListDirectory(currentdir(),'all','select'="*.pdf");
And to select all dvi files the command is
 L2:=FileTools:-ListDirectory(currentdir(),'all','select'="*.dvi");
Is there a syntax to select both in one command? THis does not work as input to select must be string. It can not be list nor set.
  FileTools:-ListDirectory(currentdir(),'all','select'=["*.dvi","*.pdf"]);
So I end up doing
the_list := [ op(L1), op(L2) ];
If will be nice if Maple allows one to select based on different extensions in one command.  Imagine you have 5 different extensions to select. Now one has to issue 5 different commands, then collect all the 5 lists into one.
I'm trying to solve a system of two differential equations numerically
eq1 := diff(A(t), t) = c1*(A__T-A(t))-c2*A(t)*R(t)
eq2 := diff(R(t), t) = (c3+c1)*(R__T-R(t))-c2*Ab(t)*R(t)
sys1 := [eq1, eq2]
[diff(A(t), t) = c1*(A__T-A(t))-c2*A(t)*R(t), diff(R(t), t) = (c3+c1)*(R__T-R(t))-c2*Ab(t)*R(t)]
A__T := 100
100
R__T := 100
100
c2 := 1000
1000
c1 := 0.2e-4
0.2e-4
c3 := 2000
2000
InitCond := A(0) = A__T, R(0) = R__T
A(0) = 100, R(0) = 100
nsol := dsolve(sys1, InitCond, type = numeric)
Error, (in dsolve/numeric/type_check) insufficient initial/boundary value information for procedure defined problem
It seems to me this problem should be solvable for the initial conditions given.  Am I entering them wrong somehow?
Download dsolve_problem.mw
scmch.mw
I can't get a graph. Is this code is correct.Please help.
sps1.mw
how to plot this.i got error
How to integrate eq (4)? Since 'a', 'b', and 'c' are constant.
with(DEtools)
declare(z(x), y(x))
declare(z(x), y(x))
eq1 := (1/2)*(-z(x)^3-2*c*z(x))*(diff(diff(y(x), x), x))-((z(x)^2+2*c)*(diff(y(x), x))+b*z(x)^2+c*k+a)*(diff(z(x), x)) = 0
eq2 := simplify(z(x)*eq1)
-z(x)*(z(x)*((1/2)*z(x)^2+c)*(diff(diff(y(x), x), x))+((z(x)^2+2*c)*(diff(y(x), x))+b*z(x)^2+c*k+a)*(diff(z(x), x))) = 0
eq3 := eval(int(lhs(eq2), x))
int(-z(x)*(z(x)*((1/2)*z(x)^2+c)*(diff(diff(y(x), x), x))+((z(x)^2+2*c)*(diff(y(x), x))+b*z(x)^2+c*k+a)*(diff(z(x), x))), x)
Download integration.mw
sstf.mw
In Graph has curves that are overlapping each other and the values of  S[t] = -1, -2, 1, 2 and also the y axis to range from 0 to 1.
I am trying to separate the real and imaginary parts of a complex expression in Maple to get Eq. (1.5) as in the attached image, but the Re and Im functions do not seem to return the expected results. Instead, Maple leaves the expression unchanged. PD_OD.mw
Is it possible to set a worksheet or maple up to only express trigonometric functions as sines? This is very helpful for certain exotic coordinate systems. Meaning cos(x)=sqrt(1-sin(x)^2)  and NOT equivalently  adding Pi/2 to the argument cos(x)=sin(x+Pi/2).
It is completely useless and futile to do algsubs, as Maple will later just revert back to cosines, so you want to do it in the headers so output is always expressed as sines in the document by default.
Basically you want to set something in the header of a worksheeet to always use expsincos on output, and then in addition cos(x)=k sqrt(1-sin(x)^2)   k\e{1,-1} on the output.
The modified Liouville equation
How to solve this pde for a general solution ?
The general solution in this form exist.
with(PDEtools): declare(u(x,t)); U:=diff_table(u(x,t));
PDE1:=U[t,t]=a^2*U[x,x]+b*exp(beta*U[]);
Sol11:=u(x,t)=1/beta*ln(2*(B^2-a^2*A^2)/(b*beta*(A*x+B*t+C)^2));
Sol12:=S->u(x,t)=1/beta*ln(8*a^2*C/(b*beta))
-2/beta*ln(S*(x+A)^2-S*a^2*(t+B)^2+S*C);
Test11:=pdetest(Sol11,PDE1);
Test12:=pdetest(Sol12(1),PDE1);
Test13:=pdetest(Sol12(-1),PDE1);
table( [(  ) = u(x, t) ] )
diff(diff(u(x, t), t), t) = a^2*(diff(diff(u(x, t), x), x))+b*exp(beta*u(x, t))
u(x, t) = ln(2*(-A^2*a^2+B^2)/(b*beta*(A*x+B*t+C)^2))/beta
proc (S) options operator, arrow; u(x, t) = ln(8*a^2*C/(b*beta))/beta-2*ln(S*(x+A)^2-S*a^2*(t+B)^2+S*C)/beta end proc
The Soll11 can be plotted with a Explore plot in this form of soll11 with th eparameters , but suppose i try to get the general solution in Maple ?
infolevel[pdsolve] := 3
pdsolve(PDE1, generalsolution)
ans := pdsolve(PDE1);
What solvin gstrategy to follow ? : the pde is a non-linear wave eqation  with a exponentiel sourceterm
It seems that the pde can reduced to a ode? :
with(PDEtools):
declare(u(x,t));
# Stap 1: Definieer de PDE
PDE := diff(u(x,t), t,t) = a^2 * diff(u(x,t), x,x) + b * exp(beta * u(x,t));
# Stap 2: Definieer de transformatie naar karakteristieke variabelen
# Nieuw: x en t uitgedrukt in ξ en η
tr := {
    x = (xi + eta)/2,
    t = (eta - xi)/(2*a)
# Pas de transformatie toe op de PDE
simplified_PDE := dchange(tr, PDE, [xi, eta], params = [a, b, beta], simplify);
# Stap 3: Definieer de algemene oplossing
solution := u(x,t) = (1/beta) * ln(
    (-8*a^2/(b*beta)) *
    diff(_F1(x - a*t), x) * diff(_F2(x + a*t), x) /
    (_F1(x - a*t) + _F2(x + a*t))^2
# Stap 4: Controleer de oplossing (optioneel)
pdetest(solution, PDE);  # Moet 0 teruggeven als correct
{t = (1/2)*(eta-xi)/a, x = (1/2)*xi+(1/2)*eta}
a^2*(diff(diff(u(xi, eta), xi), xi)-2*(diff(diff(u(xi, eta), eta), xi))+diff(diff(u(xi, eta), eta), eta)) = a^2*(diff(diff(u(xi, eta), xi), xi))+2*a^2*(diff(diff(u(xi, eta), eta), xi))+a^2*(diff(diff(u(xi, eta), eta), eta))+b*exp(beta*u(xi, eta))
u(x, t) = ln(-8*a^2*(D(_F1))(-a*t+x)*(D(_F2))(a*t+x)/(b*beta*(_F1(-a*t+x)+_F2(a*t+x))^2))/beta
missing some steps here : solution u  without  the pde reduced ?
there is a ode ?
# Definieer de ODE # vorige stappen ontbreken van de reduktie
ode := (v^2 - a^2) * diff(f(xi), xi, xi) = b * exp(beta * f(xi));
# Algemene oplossing zoeken
sol := dsolve(ode, f(xi));
(-a^2+v^2)*(diff(diff(f(xi), xi), xi)) = b*exp(beta*f(xi))
f(xi) = ln((1/2)*c__1*(tan((1/2)*(-c__1*a^2*beta+c__1*beta*v^2)^(1/2)*(c__2+xi)/(a^2-v^2))^2+1)/b)/beta
Question : how do i arrive on Soll11   in Maple  ?
Download liouville_reduced_2-2-2025_mprimes_vraag.mw
I did some example to change them but i didn't get the same result as book did it and i try to figure out by hand i get another result i know all of them are true but polar is for making the simple shap for ploting so How i can get the simple shape and if possible How do step by step like using totur we have for polar or not?
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
with(plots); with(plottools)
with(VectorCalculus)
with(Student:-LinearAlgebra)
with(Student:-MultivariateCalculus)
S := x^2+y^2-1
x^2+y^2-1
convert(S, polar)
polar(abs(x^2+y^2-1), argument(x^2+y^2-1))
ChangeOfVariables(S, [cartesian[x, y], polar[r, theta]])
r^2*cos(theta)^2+r^2*sin(theta)^2-1
solve(%, r)
1, -1
T := x^4+2*x^2*y^2+y^4+2*x^3+2*x*y^2-y^2
ChangeOfVariables(T, [cartesian[x, y], polar[r, theta]])
r^4*cos(theta)^4+2*r^4*cos(theta)^2*sin(theta)^2+r^4*sin(theta)^4+2*r^3*cos(theta)^3+2*r^3*cos(theta)*sin(theta)^2-r^2*sin(theta)^2
simplify(%)
r^2*(-sin(theta)^2+r*(r+2*cos(theta)))
solve(%, r)
0, 0, -cos(theta)+(cos(theta)^2+sin(theta)^2)^(1/2), -cos(theta)-(cos(theta)^2+sin(theta)^2)^(1/2)
R := -3*x^2+y^2-4*x-1
-3*x^2+y^2-4*x-1
ChangeOfVariables(R, [cartesian[x, y], polar[r, theta]])
-3*r^2*cos(theta)^2+r^2*sin(theta)^2-4*r*cos(theta)-1
simplify(%)
-4*r^2*cos(theta)^2-4*r*cos(theta)+r^2-1
solve(%, r)
-1/(2*cos(theta)+1), -1/(2*cos(theta)-1)
Download polar.mw
Good day,
I have this system of differential equations, which I solved numerically.
Now I need to integrate the function y(t) numerically to get the corresponding expression for
Z= exp(int y(t) dt ) (integrate from a given t to 0)
then I need to plot that system of differential equation vs (Z) with (t) as the parameter.
can you please help?
 eq1 := diff(x(t), t)-(1/6)*(6*x(t)^3*y(t)+(2*y(t)^2-2)*x(t)^2+3*y(t)*(z(t)-2)*x(t)-2*y(t)^2+2)*sqrt(3) = 0;
eq2 := diff(y(t), t)-(1/6)*(y(t)-1)*sqrt(3)*(y(t)+1)*(6*x(t)^2+2*y(t)*x(t)+3*z(t)-2) = 0;
eq3 := diff(z(t), t)-(1/3)*z(t)*sqrt(3)*(6*y(t)*x(t)^2+2*x(t)*y(t)^2+3*z(t)*y(t)-2*x(t)-3*y(t)) = 0;
eq4 := diff(s(t), t)-(1/3)*(y(t)-1)*sqrt(3)*(y(t)+1)*(6*x(t)^2+2*y(t)*x(t)+3*z(t)-2)*y(t) = 0;
eq5 := diff(Q(t), t)+sqrt(3)*((4/3-z(t)-2*x(t)^2)*y(t)+(2/3*(1-y(t)^2))*x(t))*Q(t)+2*((2/3)*y(t)+x(t))*P(t)/sqrt(3)-(2/3)*R(t) = 0;
eq6 := diff(P(t), t)+(sqrt(3)*(1-z(t)-2*x(t)^2)*y(t)+2*(2-y(t)^2)*x(t)/sqrt(3))*P(t)+2*sqrt(3)*x(t)*Q(t)+(1/2)*R(t) = 0;
eq7 := diff(R(t), t)-sqrt(3)*((3*x(t)^2+(3/2)*z(t)+4)*y(t)-(1/3*(1-3*y(t)^2))*x(t))*R(t)-z(t)*P(t) = 0;
eq8 := diff(T(t), t)-sqrt(3)*((6*x(t)^2+3*z(t)+1)*y(t)-(2*(1-y(t)^2))*x(t))*T(t)-(1-y(t)^2)*(Q(t)-(2/3)*P(t)) = 0;
syst := {eq1, eq2, eq3, eq4, eq5, eq6, eq7, eq8};
ics := x(0) = .1, y(0) = .9, z(0) = .1, s(0) = .2, Q(0) = .1, P(0) = .9, R(0) = .1, T(0) = .2;
sol1 := dsolve({ics, op(syst)}, {P(t), Q(t), R(t), T(t), s(t), x(t), y(t), z(t)}, type = numeric, output = listprocedure);
First 34 35 36 37 38 39 40 Last Page 36 of 2425
